Using the Connect SDK client functions to access the buttonless dfu service.
Cant get the target into DfuTarg mode.  I’ve written a manual DFU client app using Bluez.  We are changing our client app to run on a 52840.  Peripheral is also a 52840.
I’m able to discover the single buttonless dfu service.  Using NULL instead of DFU_SERVICE discovers only handles 0x0000 to 0x0009.
#define UUID_DFU_SERVICE        BT_UUID_DECLARE_16(0xfe59)
err = bt_gatt_dm_start(conn, UUID_DFU_SERVICE, &dfu_discovery_cb, NULL);
I enable indications in a discovery_complete_cb:
struct bt_gatt_subscribe_params indication_params =
    .notify = indicate_callback,
    .value = BT_GATT_CCC_INDICATE,
    .value_handle = 0x0010,
    .ccc_handle = 0x0011,
    .subscribe = subscribe_callback,
    .write = NULL,
    .node = NULL,
    .flags = BT_GATT_SUBSCRIBE_FLAG_VOLATILE,
int err = bt_gatt_subscribe(conn, &indication_params);
I then write 0x01 to 0x0010 but get the invalid op code response.
00:00:10.316,070] <dbg> command_c: gatt_discover: Command DFU
[00:00:10.316,131] <dbg> command_c: connected: >>>>>>>> Connected waiting for services
[00:00:10.417,480] <inf> command_c: MTU exchange done
[00:00:11.467,346] <dbg> dfu_c: discovery_dfu_complete: UUID:<2800>    Handle: 0x000E    permissions: 0x0000
[00:00:11.467,407] <dbg> dfu_c: discovery_dfu_complete: UUID:<2803>     Handle: 0x000F
[00:00:11.467,620] <dbg> dfu_c: discovery_dfu_complete: UUID:<8ec90003-f315-4f60-9fb8-838830daea50>     Handle: 0x0010
[00:00:11.467,681] <dbg> dfu_c: discovery_dfu_complete: UUID:<2902>     Handle: 0x0011
[00:00:11.493,164] <dbg> dfu_c: dfu_connect_buttonless: Services Resolved, Connection complete in 1220 msec
[00:00:11.567,291] <dbg> dfu_c: subscribe_callback: value_handle:0x0010    CCC_Handle:0x0011    Value: 0x0002
[00:00:11.667,236] <dbg> dfu_c: write_response_callback: write_response_callback()   data: 0x01   len: 1   handle: 0x10   offset: 0
[00:00:11.667,724] <dbg> dfu_c: indicate_callback: <0x20>
[00:00:11.667,724] <dbg> dfu_c: indicate_callback: <0x46>
[00:00:11.667,755] <dbg> dfu_c: indicate_callback: <0x02>
[00:00:11.674,499] <dbg> dfu_c: dfu_connect_buttonless: >>>> Buttonless UUID written in 180 msec
A Wireshark capture shows that indications are not getting set:
Frame 245: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM7-4.2, id 0
nRF Sniffer for Bluetooth LE
Bluetooth Low Energy Link Layer
Bluetooth L2CAP Protocol
Bluetooth Attribute Protocol
    Opcode: Write Request (0x12)
    Handle: 0x0011 (Unknown: Client Characteristic Configuration)
        [Characteristic UUID: 8ec90003f3154f609fb8838830daea50]
        [UUID: Client Characteristic Configuration (0x2902)]
    Characteristic Configuration Client: 0x0000
        0000 0000 0000 00.. = Reserved: 0x0000
        .... .... .... ..0. = Indication: False
        .... .... .... ...0 = Notification: False
  • Hi!
    Thanks for the project, I will test it and see why it fails to put the device in DFU mode.
    I tried building the project using NCS(nRF Connect SDK) v2.5.0, but I got some build errors. I'm guessing this project was originally written for another version. What version of NCS did you use?
  • V2.3.0   Sorry, I should have mentioned that.  I don't object to updating.  I'm developing on a nRF52840 dev kit and will be using the Fanstel BT840F module.  Our system will use a Debian board to interface with it, thus the overlay.  Not needed in the test project.  Thanks again.
  • Hey Sigurd, I found it.  And updated to v2.5.0.  Thanks.
                uint8_t send_data[3] = {0};
                send_data[0]= 0x01;
                struct bt_gatt_write_params write_params =
                    //.data = 0x01,
                    .data = send_data,
                    .length = 1,
                    .func = write_callback,
                    .handle = 0x0010,
                    .offset = 0,
                err = bt_gatt_write(conn, &write_params);
