Running OpenThread Border Router in Docker?
What are the limitations for running OpenThread Border Router in Docker?
I have not been able to successfully use it to build a Thread network and join Matter devices to it. I would like to be able to setup and run it in a Docker container and use it as if I installed the OTBR software on bare metal.
If I run on bare metal, I can use this command running on another computer to see the service:
avahi-browse -r -t _meshcop._udp
If I run OTBR in Docker and run the above command, I cannot see any services.
It looks like to network traffic from the Docker container isn't properly integrated with the LAN network.
Have anyone successfully done this?
  • 1) Running OTBR on bare metal
    Checking from another computer:
    ubuntu@ubuntu:~$ avahi-browse -r -t _meshcop._udp
    + eth0 IPv6 OpenThread BorderRouter #EDEC _meshcop._udp local
    + eth0 IPv4 OpenThread BorderRouter #EDEC _meshcop._udp local
    = eth0 IPv6 OpenThread BorderRouter #EDEC _meshcop._udp local
    hostname = [otbr.local]
    address = [192.168.1.232]
    port = [49152]
    txt = ["dn=DefaultDomain" "sb=\000\000\000!" "xa=\"��.\019���" "tv=1.3.0" "xp=ޭ\000��\000��" "nn=OpenThread" "mn=BorderRouter" "vn=OpenThread" "id=� U�{H\012��\025�\"��&�" "rv=1"]
    = eth0 IPv4 OpenThread BorderRouter #EDEC _meshcop._udp local
    port = [49152]
    ubuntu@ubuntu:~$
    2) Running OTBR in Docker container.
    ubuntu@ubuntu:~$
    If avahi-browse doesn't see the Thread mDNS broadcasts it's even not needed to try the chip-tool pairing.
    Please try following all the steps in the guide and test with chip-tool. If you get errors when commissioning with chip-tool, please upload the logs from chip-tool and the device here.
    Marte
  • Log from chip-tool:
    ubuntu@ubuntu:~/connectedhomeip/out/standalone$ ./chip-tool pairing ble-thread 10 hex:0e08000000000001000035060004001fffe00708fd47c866a2d5bb8d0c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
    [1706281514.265136][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_tool_kvs
    [1706281514.266086][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1706281514.266119][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs
    [1706281514.271500][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1706281514.271771][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1706281514.271884][689286:689286] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1706281514.272208][689286:689286] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-FmULtx)
    [1706281514.272738][689286:689286] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1706281514.272793][689286:689286] CHIP:DL: NVS set: chip-counters/reboot-count = 55 (0x37)
    [1706281514.273360][689286:689286] CHIP:DL: Got Ethernet interface: eth0
    [1706281514.273688][689286:689286] CHIP:DL: Found the primary Ethernet interface:eth0
    [1706281514.274052][689286:689286] CHIP:DL: Got WiFi interface: wlan0
    [1706281514.274118][689286:689286] CHIP:DL: Failed to reset WiFi statistic counts
    [1706281514.274169][689286:689286] CHIP:IN: UDP::Init bind&listen port=0
    [1706281514.274273][689286:689286] CHIP:IN: UDP::Init bound to port=34300
    [1706281514.274294][689286:689286] CHIP:IN: UDP::Init bind&listen port=0
    [1706281514.274377][689286:689286] CHIP:IN: UDP::Init bound to port=45241
    [1706281514.274395][689286:689286] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1706281514.274412][689286:689286] CHIP:IN: TransportMgr initialized
    [1706281514.274441][689286:689286] CHIP:FP: Initializing FabricTable from persistent storage
    [1706281514.274601][689286:689286] CHIP:TS: Last Known Good Time: 2023-10-23T16:58:40
    [1706281514.276013][689286:689286] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xBA8284A0AC0FAA35, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1706281514.277826][689286:689286] CHIP:ZCL: Using ZAP configuration...
    [1706281514.279414][689286:689286] CHIP:CTL: System State Initialized...
    [1706281514.279543][689286:689286] CHIP:CTL: Setting attestation nonce to random value
    [1706281514.279589][689286:689286] CHIP:CTL: Setting CSR nonce to random value
    [1706281514.279647][689286:689286] CHIP:IN: UDP::Init bind&listen port=5550
    [1706281514.279727][689286:689286] CHIP:IN: UDP::Init bound to port=5550
    [1706281514.279747][689286:689286] CHIP:IN: UDP::Init bind&listen port=5550
    [1706281514.279814][689286:689286] CHIP:IN: UDP::Init bound to port=5550
    [1706281514.279832][689286:689286] CHIP:IN: TransportMgr initialized
    [1706281514.280106][689286:689288] CHIP:DL: CHIP task running
    [1706281514.280197][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1706281514.280521][689286:689288] CHIP:CTL: Setting attestation nonce to random value
    [1706281514.280680][689286:689288] CHIP:CTL: Setting CSR nonce to random value
    [1706281514.281481][689286:689288] CHIP:CTL: Generating NOC
    [1706281514.282315][689286:689288] CHIP:FP: Validating NOC chain
    [1706281514.283889][689286:689288] CHIP:FP: NOC chain validation successful
    [1706281514.284039][689286:689288] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1706281514.284068][689286:689288] CHIP:TS: Last Known Good Time: 2023-10-23T16:58:40
    [1706281514.284086][689286:689288] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1706281514.284103][689286:689288] CHIP:TS: Retaining current Last Known Good Time
    [1706281514.288067][689286:689288] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1706281514.289681][689286:689288] CHIP:TS: Committing Last Known Good Time to storage: 2023-10-23T16:58:40
    [1706281514.291099][689286:689288] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: BA8284A0AC0FAA35)
    [1706281514.291187][689286:689288] CHIP:IN: UDP::Init bind&listen port=5550
    [1706281514.291291][689286:689288] CHIP:IN: UDP::Init bound to port=5550
    [1706281514.291312][689286:689288] CHIP:IN: UDP::Init bind&listen port=5550
    [1706281514.291383][689286:689288] CHIP:IN: UDP::Init bound to port=5550
    [1706281514.291401][689286:689288] CHIP:IN: TransportMgr initialized
    [1706281514.304872][689286:689288] CHIP:CTL: Setting thread operational dataset from parameters
    [1706281514.304916][689286:689288] CHIP:CTL: Setting attestation nonce to random value
    [1706281514.304965][689286:689288] CHIP:CTL: Setting CSR nonce to random value
    [1706281514.304998][689286:689288] CHIP:CTL: Commission called for node ID 0x000000000000000A
    [1706281514.309376][689286:689287] CHIP:DL: TRACE: Bus acquired for name C-8486
    [1706281514.315933][689286:689288] CHIP:DL: PlatformBlueZInit init success
    [1706281514.321378][689286:689287] CHIP:BLE: BLE removing known devices.
    [1706281514.322793][689286:689287] CHIP:BLE: BLE initiating scan.
    [1706281514.362469][689286:689287] CHIP:BLE: New device scanned: 34:25:B4:A0:B9:82
    [1706281514.362516][689286:689287] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1706281514.883002][689286:689287] CHIP:DL: ConnectDevice complete
    [1706281516.013240][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013288][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013311][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013328][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013348][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013364][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013387][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013403][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013425][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013442][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013461][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013476][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013494][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013510][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013531][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013548][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013566][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013581][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013600][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0001
    [1706281516.013616][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013636][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service000e
    [1706281516.013652][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013670][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service000e
    [1706281516.013686][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013704][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service000e
    [1706281516.013720][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013741][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013758][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013778][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013794][689286:689287] CHIP:DL: Char1 /org/bluez/hci0/dev_34_25_B4_A0_B9_82/service0015
    [1706281516.013817][689286:689287] CHIP:DL: New BLE connection: conn 0xffffa8053ff0, device 34:25:B4:A0:B9:82, path /org/bluez/hci0/dev_34_25_B4_A0_B9_82
    [1706281516.013942][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1706281516.013976][689286:689288] CHIP:DIS: Closing all BLE connections
    [1706281516.014053][689286:689288] CHIP:IN: BleConnectionComplete: endPoint 0xaaaab1f9fc88
    [1706281516.014434][689286:689288] CHIP:IN: SecureSession[0xffffa0010d00]: Allocated Type:1 LSID:29128
    [1706281516.014476][689286:689288] CHIP:SC: Assigned local session key ID 29128
    [1706281516.014592][689286:689288] CHIP:EM: <<< [E:23564i S:0 M:65966330] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1706281516.014648][689286:689288] CHIP:IN: Message appended to BLE send queue
    [1706281516.014674][689286:689288] CHIP:SC: Sent PBKDF param request
    [1706281516.441530][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281516.539434][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1706281516.539481][689286:689288] CHIP:BLE: subscribe complete, ep = 0xaaaab1f9fc88
    [1706281516.539834][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281516.539928][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281516.539954][689286:689288] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1706281516.539972][689286:689288] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1706281516.539988][689286:689288] CHIP:BLE: local and remote recv window size = 5
    [1706281516.540276][689286:689288] CHIP:IN: BLE EndPoint 0xaaaab1f9fc88 Connection Complete
    [1706281516.636535][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281516.638938][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281516.639064][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281516.639203][689286:689288] CHIP:EM: >>> [E:23564i S:0 M:266217851] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1706281516.639233][689286:689288] CHIP:EM: Found matching exchange: 23564i, Delegate: 0xffffa000df50
    [1706281516.639270][689286:689288] CHIP:SC: Received PBKDF param response
    [1706281516.639314][689286:689288] CHIP:SC: Peer assigned session ID 62583
    [1706281516.639342][689286:689288] CHIP:SC: Found MRP parameters in the message
    [1706281516.644836][689286:689288] CHIP:EM: <<< [E:23564i S:0 M:65966331] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1706281516.645513][689286:689288] CHIP:SC: Sent spake2p msg1
    [1706281516.734048][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281516.784552][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281516.784695][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281516.784865][689286:689288] CHIP:EM: >>> [E:23564i S:0 M:266217852] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1706281516.784898][689286:689288] CHIP:EM: Found matching exchange: 23564i, Delegate: 0xffffa000df50
    [1706281516.784935][689286:689288] CHIP:SC: Received spake2p msg2
    [1706281516.786180][689286:689288] CHIP:EM: <<< [E:23564i S:0 M:65966332] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1706281516.786555][689286:689288] CHIP:SC: Sent spake2p msg3
    [1706281516.880251][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281516.881604][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281516.881927][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281516.882044][689286:689288] CHIP:EM: >>> [E:23564i S:0 M:266217853] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1706281516.882075][689286:689288] CHIP:EM: Found matching exchange: 23564i, Delegate: 0xffffa000df50
    [1706281516.882277][689286:689288] CHIP:SC: SecureSession[0xffffa0010d00, LSID:29128]: State change 'kEstablishing' --> 'kActive'
    [1706281516.882306][689286:689288] CHIP:IN: SecureSession[0xffffa0010d00]: Activated - Type:1 LSID:29128
    [1706281516.882323][689286:689288] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:29128 PSID:62583!
    [1706281516.882348][689286:689288] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1706281516.882366][689286:689288] CHIP:TOO: Pairing Success
    [1706281516.882382][689286:689288] CHIP:TOO: PASE establishment successful
    [1706281516.882401][689286:689288] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1706281516.882422][689286:689288] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1706281516.882439][689286:689288] CHIP:CTL: Sending request for commissioning information
    [1706281516.882475][689286:689288] CHIP:DMG: SendReadRequest ReadClient[0xffffa000a2e0]: Sending Read Request
    [1706281516.882645][689286:689288] CHIP:EM: <<< [E:23565i S:29128 M:61819004] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest)
    [1706281516.883009][689286:689288] CHIP:DMG: MoveToState ReadClient[0xffffa000a2e0]: Moving to [AwaitingIn]
    [1706281516.977773][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281516.981236][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281516.981367][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.076040][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.076175][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.076353][689286:689288] CHIP:EM: >>> [E:23565i S:29128 M:263416815] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1706281517.076388][689286:689288] CHIP:EM: Found matching exchange: 23565i, Delegate: 0xffffa000a2f0
    [1706281517.076476][689286:689288] CHIP:DMG: ReportDataMessage =
    [1706281517.076498][689286:689288] CHIP:DMG: {
    [1706281517.076515][689286:689288] CHIP:DMG: AttributeReportIBs =
    [1706281517.076564][689286:689288] CHIP:DMG: [
    [1706281517.076585][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.076611][689286:689288] CHIP:DMG: {
    [1706281517.076631][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.076672][689286:689288] CHIP:DMG: {
    [1706281517.076698][689286:689288] CHIP:DMG: DataVersion = 0x5a62c680,
    [1706281517.076740][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.076782][689286:689288] CHIP:DMG: {
    [1706281517.076824][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.076867][689286:689288] CHIP:DMG: Cluster = 0x31,
    [1706281517.076911][689286:689288] CHIP:DMG: Attribute = 0x0000_0003,
    [1706281517.076951][689286:689288] CHIP:DMG: }
    [1706281517.076978][689286:689288] CHIP:DMG:
    [1706281517.077020][689286:689288] CHIP:DMG: Data = 20,
    [1706281517.077059][689286:689288] CHIP:DMG: },
    [1706281517.077114][689286:689288] CHIP:DMG:
    [1706281517.077137][689286:689288] CHIP:DMG: },
    [1706281517.077166][689286:689288] CHIP:DMG:
    [1706281517.077185][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.077210][689286:689288] CHIP:DMG: {
    [1706281517.077230][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.077258][689286:689288] CHIP:DMG: {
    [1706281517.077285][689286:689288] CHIP:DMG: DataVersion = 0x90880e04,
    [1706281517.077314][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.077344][689286:689288] CHIP:DMG: {
    [1706281517.077371][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.077402][689286:689288] CHIP:DMG: Cluster = 0x28,
    [1706281517.077434][689286:689288] CHIP:DMG: Attribute = 0x0000_0004,
    [1706281517.077461][689286:689288] CHIP:DMG: }
    [1706281517.077488][689286:689288] CHIP:DMG:
    [1706281517.077516][689286:689288] CHIP:DMG: Data = 32769,
    [1706281517.077542][689286:689288] CHIP:DMG: },
    [1706281517.077567][689286:689288] CHIP:DMG:
    [1706281517.077587][689286:689288] CHIP:DMG: },
    [1706281517.077616][689286:689288] CHIP:DMG:
    [1706281517.077635][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.077659][689286:689288] CHIP:DMG: {
    [1706281517.077680][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.077705][689286:689288] CHIP:DMG: {
    [1706281517.077728][689286:689288] CHIP:DMG: DataVersion = 0x90880e04,
    [1706281517.077757][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.077783][689286:689288] CHIP:DMG: {
    [1706281517.077813][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.077845][689286:689288] CHIP:DMG: Cluster = 0x28,
    [1706281517.077877][689286:689288] CHIP:DMG: Attribute = 0x0000_0002,
    [1706281517.077906][689286:689288] CHIP:DMG: }
    [1706281517.077937][689286:689288] CHIP:DMG:
    [1706281517.077968][689286:689288] CHIP:DMG: Data = 65521,
    [1706281517.077994][689286:689288] CHIP:DMG: },
    [1706281517.078021][689286:689288] CHIP:DMG:
    [1706281517.078041][689286:689288] CHIP:DMG: },
    [1706281517.078070][689286:689288] CHIP:DMG:
    [1706281517.078088][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.078113][689286:689288] CHIP:DMG: {
    [1706281517.078133][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.078157][689286:689288] CHIP:DMG: {
    [1706281517.078183][689286:689288] CHIP:DMG: DataVersion = 0x95f7e87a,
    [1706281517.078209][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.078238][689286:689288] CHIP:DMG: {
    [1706281517.078268][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.078300][689286:689288] CHIP:DMG: Cluster = 0x30,
    [1706281517.078331][689286:689288] CHIP:DMG: Attribute = 0x0000_0003,
    [1706281517.078360][689286:689288] CHIP:DMG: }
    [1706281517.078391][689286:689288] CHIP:DMG:
    [1706281517.078421][689286:689288] CHIP:DMG: Data = 0,
    [1706281517.078450][689286:689288] CHIP:DMG: },
    [1706281517.078477][689286:689288] CHIP:DMG:
    [1706281517.078497][689286:689288] CHIP:DMG: },
    [1706281517.078524][689286:689288] CHIP:DMG:
    [1706281517.078543][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.078567][689286:689288] CHIP:DMG: {
    [1706281517.078587][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.078612][689286:689288] CHIP:DMG: {
    [1706281517.078638][689286:689288] CHIP:DMG: DataVersion = 0x95f7e87a,
    [1706281517.078683][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.078711][689286:689288] CHIP:DMG: {
    [1706281517.078739][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.078770][689286:689288] CHIP:DMG: Cluster = 0x30,
    [1706281517.078801][689286:689288] CHIP:DMG: Attribute = 0x0000_0002,
    [1706281517.078831][689286:689288] CHIP:DMG: }
    [1706281517.078861][689286:689288] CHIP:DMG:
    [1706281517.078892][689286:689288] CHIP:DMG: Data = 0,
    [1706281517.078917][689286:689288] CHIP:DMG: },
    [1706281517.078944][689286:689288] CHIP:DMG:
    [1706281517.078964][689286:689288] CHIP:DMG: },
    [1706281517.078993][689286:689288] CHIP:DMG:
    [1706281517.079011][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.079037][689286:689288] CHIP:DMG: {
    [1706281517.079057][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.079082][689286:689288] CHIP:DMG: {
    [1706281517.079107][689286:689288] CHIP:DMG: DataVersion = 0x95f7e87a,
    [1706281517.079136][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.079163][689286:689288] CHIP:DMG: {
    [1706281517.079192][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.079224][689286:689288] CHIP:DMG: Cluster = 0x30,
    [1706281517.079256][689286:689288] CHIP:DMG: Attribute = 0x0000_0001,
    [1706281517.079285][689286:689288] CHIP:DMG: }
    [1706281517.079313][689286:689288] CHIP:DMG:
    [1706281517.079342][689286:689288] CHIP:DMG: Data =
    [1706281517.079369][689286:689288] CHIP:DMG: {
    [1706281517.079427][689286:689288] CHIP:DMG: 0x0 = 60,
    [1706281517.079459][689286:689288] CHIP:DMG: 0x1 = 900,
    [1706281517.079490][689286:689288] CHIP:DMG: },
    [1706281517.079519][689286:689288] CHIP:DMG: },
    [1706281517.079547][689286:689288] CHIP:DMG:
    [1706281517.079567][689286:689288] CHIP:DMG: },
    [1706281517.079596][689286:689288] CHIP:DMG:
    [1706281517.079615][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.079639][689286:689288] CHIP:DMG: {
    [1706281517.079659][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.079684][689286:689288] CHIP:DMG: {
    [1706281517.079709][689286:689288] CHIP:DMG: DataVersion = 0x95f7e87a,
    [1706281517.079738][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.079765][689286:689288] CHIP:DMG: {
    [1706281517.079792][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.079823][689286:689288] CHIP:DMG: Cluster = 0x30,
    [1706281517.079854][689286:689288] CHIP:DMG: Attribute = 0x0000_0000,
    [1706281517.079884][689286:689288] CHIP:DMG: }
    [1706281517.079912][689286:689288] CHIP:DMG:
    [1706281517.079942][689286:689288] CHIP:DMG: Data = 0,
    [1706281517.079970][689286:689288] CHIP:DMG: },
    [1706281517.079997][689286:689288] CHIP:DMG:
    [1706281517.080017][689286:689288] CHIP:DMG: },
    [1706281517.080045][689286:689288] CHIP:DMG:
    [1706281517.080064][689286:689288] CHIP:DMG: AttributeReportIB =
    [1706281517.080088][689286:689288] CHIP:DMG: {
    [1706281517.080108][689286:689288] CHIP:DMG: AttributeDataIB =
    [1706281517.080132][689286:689288] CHIP:DMG: {
    [1706281517.080158][689286:689288] CHIP:DMG: DataVersion = 0x5a62c680,
    [1706281517.080183][689286:689288] CHIP:DMG: AttributePathIB =
    [1706281517.080209][689286:689288] CHIP:DMG: {
    [1706281517.080239][689286:689288] CHIP:DMG: Endpoint = 0x0,
    [1706281517.080270][689286:689288] CHIP:DMG: Cluster = 0x31,
    [1706281517.080301][689286:689288] CHIP:DMG: Attribute = 0x0000_FFFC,
    [1706281517.080330][689286:689288] CHIP:DMG: }
    [1706281517.080360][689286:689288] CHIP:DMG:
    [1706281517.080391][689286:689288] CHIP:DMG: Data = 2,
    [1706281517.080419][689286:689288] CHIP:DMG: },
    [1706281517.080445][689286:689288] CHIP:DMG:
    [1706281517.080465][689286:689288] CHIP:DMG: },
    [1706281517.080488][689286:689288] CHIP:DMG:
    [1706281517.080506][689286:689288] CHIP:DMG: ],
    [1706281517.080553][689286:689288] CHIP:DMG:
    [1706281517.080573][689286:689288] CHIP:DMG: SuppressResponse = true,
    [1706281517.080592][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281517.080610][689286:689288] CHIP:DMG: }
    [1706281517.081345][689286:689288] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
    [1706281517.081415][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1706281517.081443][689286:689288] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1706281517.081468][689286:689288] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1706281517.081489][689286:689288] CHIP:CTL: Arming failsafe (60 seconds)
    [1706281517.081546][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281517.081572][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281517.081690][689286:689288] CHIP:EM: <<< [E:23566i S:29128 M:61819005] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281517.082047][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281517.221555][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281517.222973][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.223267][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.223433][689286:689288] CHIP:EM: >>> [E:23566i S:29128 M:263416816] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281517.223463][689286:689288] CHIP:EM: Found matching exchange: 23566i, Delegate: 0xffffa000a2e8
    [1706281517.223495][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281517.223541][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281517.223560][689286:689288] CHIP:DMG: {
    [1706281517.223579][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281517.223597][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281517.223623][689286:689288] CHIP:DMG: [
    [1706281517.223642][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281517.223668][689286:689288] CHIP:DMG: {
    [1706281517.223688][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281517.223718][689286:689288] CHIP:DMG: {
    [1706281517.223741][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281517.223772][689286:689288] CHIP:DMG: {
    [1706281517.223803][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281517.223835][689286:689288] CHIP:DMG: ClusterId = 0x30,
    [1706281517.223865][689286:689288] CHIP:DMG: CommandId = 0x1,
    [1706281517.223895][689286:689288] CHIP:DMG: },
    [1706281517.223926][689286:689288] CHIP:DMG:
    [1706281517.223951][689286:689288] CHIP:DMG: CommandFields =
    [1706281517.223981][689286:689288] CHIP:DMG: {
    [1706281517.224013][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281517.224047][689286:689288] CHIP:DMG: 0x1 = "" (0 chars),
    [1706281517.224078][689286:689288] CHIP:DMG: },
    [1706281517.224106][689286:689288] CHIP:DMG: },
    [1706281517.224133][689286:689288] CHIP:DMG:
    [1706281517.224153][689286:689288] CHIP:DMG: },
    [1706281517.224177][689286:689288] CHIP:DMG:
    [1706281517.224195][689286:689288] CHIP:DMG: ],
    [1706281517.224219][689286:689288] CHIP:DMG:
    [1706281517.224238][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281517.224256][689286:689288] CHIP:DMG: },
    [1706281517.224307][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1706281517.224367][689286:689288] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1706281517.224397][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1706281517.224415][689286:689288] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1706281517.224439][689286:689288] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1706281517.224455][689286:689288] CHIP:CTL: Setting Regulatory Config
    [1706281517.224471][689286:689288] CHIP:CTL: Device does not support configurable regulatory location
    [1706281517.224530][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281517.224570][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281517.224668][689286:689288] CHIP:EM: <<< [E:23567i S:29128 M:61819006] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281517.225009][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281517.225073][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281517.319011][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281517.320485][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.320808][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.320991][689286:689288] CHIP:EM: >>> [E:23567i S:29128 M:263416817] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281517.321024][689286:689288] CHIP:EM: Found matching exchange: 23567i, Delegate: 0xffffa0009158
    [1706281517.321058][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281517.321126][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281517.321148][689286:689288] CHIP:DMG: {
    [1706281517.321167][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281517.321196][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281517.321222][689286:689288] CHIP:DMG: [
    [1706281517.321241][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281517.321282][689286:689288] CHIP:DMG: {
    [1706281517.321304][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281517.321343][689286:689288] CHIP:DMG: {
    [1706281517.321372][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281517.321406][689286:689288] CHIP:DMG: {
    [1706281517.321438][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281517.321478][689286:689288] CHIP:DMG: ClusterId = 0x30,
    [1706281517.321518][689286:689288] CHIP:DMG: CommandId = 0x3,
    [1706281517.321550][689286:689288] CHIP:DMG: },
    [1706281517.321591][689286:689288] CHIP:DMG:
    [1706281517.321620][689286:689288] CHIP:DMG: CommandFields =
    [1706281517.321658][689286:689288] CHIP:DMG: {
    [1706281517.321699][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281517.321734][689286:689288] CHIP:DMG: 0x1 = "" (0 chars),
    [1706281517.321775][689286:689288] CHIP:DMG: },
    [1706281517.321805][689286:689288] CHIP:DMG: },
    [1706281517.321844][689286:689288] CHIP:DMG:
    [1706281517.321875][689286:689288] CHIP:DMG: },
    [1706281517.321901][689286:689288] CHIP:DMG:
    [1706281517.321919][689286:689288] CHIP:DMG: ],
    [1706281517.321953][689286:689288] CHIP:DMG:
    [1706281517.321972][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281517.321998][689286:689288] CHIP:DMG: },
    [1706281517.322060][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1706281517.322097][689286:689288] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1706281517.322136][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1706281517.322155][689286:689288] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1706281517.322180][689286:689288] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1706281517.322197][689286:689288] CHIP:CTL: Sending request for PAI certificate
    [1706281517.322222][689286:689288] CHIP:CTL: Sending Certificate Chain request to 0xffffa000df00 device
    [1706281517.322289][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281517.322314][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281517.322433][689286:689288] CHIP:EM: <<< [E:23568i S:29128 M:61819007] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281517.322772][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281517.322840][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281517.416539][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281517.419902][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.420245][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.517115][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.517262][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.612397][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.612761][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.612932][689286:689288] CHIP:EM: >>> [E:23568i S:29128 M:263416818] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281517.612963][689286:689288] CHIP:EM: Found matching exchange: 23568i, Delegate: 0xffffa000a2e8
    [1706281517.612999][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281517.613045][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281517.613064][689286:689288] CHIP:DMG: {
    [1706281517.613140][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281517.613163][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281517.613198][689286:689288] CHIP:DMG: [
    [1706281517.613218][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281517.613253][689286:689288] CHIP:DMG: {
    [1706281517.613274][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281517.613330][689286:689288] CHIP:DMG: {
    [1706281517.613363][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281517.613395][689286:689288] CHIP:DMG: {
    [1706281517.613429][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281517.613462][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281517.613496][689286:689288] CHIP:DMG: CommandId = 0x3,
    [1706281517.613526][689286:689288] CHIP:DMG: },
    [1706281517.613566][689286:689288] CHIP:DMG:
    [1706281517.613592][689286:689288] CHIP:DMG: CommandFields =
    [1706281517.613631][689286:689288] CHIP:DMG: {
    [1706281517.613671][689286:689288] CHIP:DMG: 0x0 = [
    [1706281517.613804][689286:689288] CHIP:DMG: 0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
    [1706281517.613868][689286:689288] CHIP:DMG: ] (463 bytes)
    [1706281517.613900][689286:689288] CHIP:DMG: },
    [1706281517.613929][689286:689288] CHIP:DMG: },
    [1706281517.613957][689286:689288] CHIP:DMG:
    [1706281517.613978][689286:689288] CHIP:DMG: },
    [1706281517.614002][689286:689288] CHIP:DMG:
    [1706281517.614032][689286:689288] CHIP:DMG: ],
    [1706281517.614059][689286:689288] CHIP:DMG:
    [1706281517.614078][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281517.614105][689286:689288] CHIP:DMG: },
    [1706281517.614166][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1706281517.614202][689286:689288] CHIP:CTL: Received certificate chain from the device
    [1706281517.614240][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1706281517.614264][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1706281517.614297][689286:689288] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1706281517.614315][689286:689288] CHIP:CTL: Sending request for DAC certificate
    [1706281517.614332][689286:689288] CHIP:CTL: Sending Certificate Chain request to 0xffffa000df00 device
    [1706281517.614410][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281517.614436][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281517.614564][689286:689288] CHIP:EM: <<< [E:23569i S:29128 M:61819008] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281517.614917][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281517.614987][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281517.709020][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281517.712421][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.712733][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.810291][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.810610][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.905496][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281517.905847][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281517.906060][689286:689288] CHIP:EM: >>> [E:23569i S:29128 M:263416819] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281517.906104][689286:689288] CHIP:EM: Found matching exchange: 23569i, Delegate: 0xffffa0009158
    [1706281517.906154][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281517.906217][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281517.906247][689286:689288] CHIP:DMG: {
    [1706281517.906274][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281517.906303][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281517.906340][689286:689288] CHIP:DMG: [
    [1706281517.906369][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281517.906414][689286:689288] CHIP:DMG: {
    [1706281517.906445][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281517.906490][689286:689288] CHIP:DMG: {
    [1706281517.906531][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281517.906578][689286:689288] CHIP:DMG: {
    [1706281517.906624][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281517.906672][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281517.906719][689286:689288] CHIP:DMG: CommandId = 0x3,
    [1706281517.906764][689286:689288] CHIP:DMG: },
    [1706281517.906811][689286:689288] CHIP:DMG:
    [1706281517.906853][689286:689288] CHIP:DMG: CommandFields =
    [1706281517.906899][689286:689288] CHIP:DMG: {
    [1706281517.906946][689286:689288] CHIP:DMG: 0x0 = [
    [1706281517.907121][689286:689288] CHIP:DMG: 0x30, 0x82, 0x01, 0xe7, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x69, 0xcd, 0xf1, 0x0d, 0xe9, 0xe5, 0x4e, 0xd1, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x46, 0x3a, 0xc6, 0x93, 0x42, 0x91, 0x0a, 0x0e, 0x55, 0x88, 0xfc, 0x6f, 0xf5, 0x6b, 0xb6, 0x3e, 0x62, 0xec, 0xce, 0xcb, 0x14, 0x8f, 0x7d, 0x4e, 0xb0, 0x3e, 0xe5, 0x52, 0x60, 0x14, 0x15, 0x76, 0x7d, 0x16, 0xa5, 0xc6, 0x63, 0xf7, 0x93, 0x
    [1706281517.907213][689286:689288] CHIP:DMG: ] (491 bytes)
    [1706281517.907261][689286:689288] CHIP:DMG: },
    [1706281517.907305][689286:689288] CHIP:DMG: },
    [1706281517.907351][689286:689288] CHIP:DMG:
    [1706281517.907385][689286:689288] CHIP:DMG: },
    [1706281517.907426][689286:689288] CHIP:DMG:
    [1706281517.907454][689286:689288] CHIP:DMG: ],
    [1706281517.907491][689286:689288] CHIP:DMG:
    [1706281517.907518][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281517.907546][689286:689288] CHIP:DMG: },
    [1706281517.907621][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1706281517.907669][689286:689288] CHIP:CTL: Received certificate chain from the device
    [1706281517.907708][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1706281517.907741][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1706281517.907775][689286:689288] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1706281517.907799][689286:689288] CHIP:CTL: Sending Attestation Request to the device.
    [1706281517.907825][689286:689288] CHIP:CTL: Sending Attestation request to 0xffffa000df00 device
    [1706281517.907902][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281517.907939][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281517.908068][689286:689288] CHIP:EM: <<< [E:23570i S:29128 M:61819009] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281517.908549][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281517.908597][689286:689288] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1706281517.908665][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281518.001966][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.005219][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.005383][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.102253][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.102533][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.199497][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.199652][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.199839][689286:689288] CHIP:EM: >>> [E:23570i S:29128 M:263416820] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281518.199871][689286:689288] CHIP:EM: Found matching exchange: 23570i, Delegate: 0xffffa000a2e8
    [1706281518.199909][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281518.199959][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281518.199979][689286:689288] CHIP:DMG: {
    [1706281518.199999][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281518.200020][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281518.200048][689286:689288] CHIP:DMG: [
    [1706281518.200069][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281518.200101][689286:689288] CHIP:DMG: {
    [1706281518.200124][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281518.200149][689286:689288] CHIP:DMG: {
    [1706281518.200172][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281518.200199][689286:689288] CHIP:DMG: {
    [1706281518.200226][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281518.200254][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281518.200281][689286:689288] CHIP:DMG: CommandId = 0x1,
    [1706281518.200308][689286:689288] CHIP:DMG: },
    [1706281518.200336][689286:689288] CHIP:DMG:
    [1706281518.200360][689286:689288] CHIP:DMG: CommandFields =
    [1706281518.200387][689286:689288] CHIP:DMG: {
    [1706281518.200415][689286:689288] CHIP:DMG: 0x0 = [
    [1706281518.200549][689286:689288] CHIP:DMG: 0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
    [1706281518.200612][689286:689288] CHIP:DMG: ] (583 bytes)
    [1706281518.200640][689286:689288] CHIP:DMG: 0x1 = [
    [1706281518.200688][689286:689288] CHIP:DMG: 0xb8, 0x75, 0x3e, 0x68, 0x2f, 0x0c, 0xdc, 0xed, 0x9b, 0x56, 0xb2, 0xc2, 0x70, 0x11, 0x38, 0x73, 0x0d, 0xda, 0xad, 0x45, 0x73, 0xab, 0xb0, 0x7c, 0x10, 0x32, 0xce, 0x9e, 0x4e, 0x1a, 0x6e, 0xe4, 0xf5, 0x3a, 0x4f, 0x8e, 0x53, 0x89, 0x2c, 0x7b, 0x79, 0x5a, 0xdc, 0x50, 0xeb, 0xb6, 0x85, 0x02, 0x35, 0x1a, 0xdb, 0x53, 0x1c, 0x8c, 0x38, 0x9a, 0xc1, 0x84, 0xc8, 0x7a, 0x47, 0xfe, 0x9c, 0x3e,
    [1706281518.200723][689286:689288] CHIP:DMG: ] (64 bytes)
    [1706281518.200751][689286:689288] CHIP:DMG: },
    [1706281518.200781][689286:689288] CHIP:DMG: },
    [1706281518.200812][689286:689288] CHIP:DMG:
    [1706281518.200836][689286:689288] CHIP:DMG: },
    [1706281518.200866][689286:689288] CHIP:DMG:
    [1706281518.200888][689286:689288] CHIP:DMG: ],
    [1706281518.200918][689286:689288] CHIP:DMG:
    [1706281518.200940][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281518.200962][689286:689288] CHIP:DMG: },
    [1706281518.201026][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1706281518.201068][689286:689288] CHIP:CTL: Received Attestation Information from the device
    [1706281518.201136][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1706281518.201162][689286:689288] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
    [1706281518.201218][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1706281518.201249][689286:689288] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1706281518.201266][689286:689288] CHIP:CTL: Verifying attestation
    [1706281518.236663][689286:689288] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
    [1706281518.236735][689286:689288] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
    [1706281518.236758][689286:689288] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
    [1706281518.236785][689286:689288] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
    [1706281518.236804][689286:689288] CHIP:CTL: Sending CSR request to 0xffffa000df00 device
    [1706281518.236883][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281518.236920][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281518.237109][689286:689288] CHIP:EM: <<< [E:23571i S:29128 M:61819010] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281518.237679][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281518.237748][689286:689288] CHIP:CTL: Sent CSR request, waiting for the CSR
    [1706281518.237817][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281518.294345][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.297858][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.298257][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.393923][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.394123][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.394343][689286:689288] CHIP:EM: >>> [E:23571i S:29128 M:263416821] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281518.394381][689286:689288] CHIP:EM: Found matching exchange: 23571i, Delegate: 0xffffa003e138
    [1706281518.394425][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281518.394480][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281518.394502][689286:689288] CHIP:DMG: {
    [1706281518.394523][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281518.394546][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281518.394577][689286:689288] CHIP:DMG: [
    [1706281518.394600][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281518.394632][689286:689288] CHIP:DMG: {
    [1706281518.394656][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281518.394684][689286:689288] CHIP:DMG: {
    [1706281518.394709][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281518.394738][689286:689288] CHIP:DMG: {
    [1706281518.394767][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281518.394798][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281518.394828][689286:689288] CHIP:DMG: CommandId = 0x5,
    [1706281518.394856][689286:689288] CHIP:DMG: },
    [1706281518.394886][689286:689288] CHIP:DMG:
    [1706281518.394912][689286:689288] CHIP:DMG: CommandFields =
    [1706281518.394940][689286:689288] CHIP:DMG: {
    [1706281518.394970][689286:689288] CHIP:DMG: 0x0 = [
    [1706281518.395094][689286:689288] CHIP:DMG: 0x15, 0x30, 0x01, 0xdd, 0x30, 0x81, 0xda, 0x30, 0x81, 0x81, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0b, 0x0c, 0x03, 0x43, 0x53, 0x41, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0xaa, 0xff, 0x13, 0x6e, 0x51, 0xb6, 0x82, 0x38, 0x16, 0xfa, 0x87, 0xed, 0xf4, 0x01, 0x03, 0x8c, 0x3a, 0xf8, 0xfb, 0x0f, 0xf7, 0xe8, 0xaf, 0xc8, 0x6b, 0x76, 0x73, 0x36, 0x27, 0x30, 0x00, 0x9a, 0xae, 0xcd, 0xee, 0x45, 0xdb, 0x58, 0x4a, 0x0e, 0xeb, 0x13, 0x95, 0x28, 0x4e, 0x0c, 0xd9, 0xd7, 0x56, 0x96, 0xd3, 0x23, 0x2e, 0xb6, 0x2f, 0xee, 0x86, 0xb2, 0x38, 0xea, 0x61, 0xb3, 0xd6, 0x6e, 0xa0, 0x11, 0x30, 0x0f, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x09, 0x0e, 0x31, 0x02, 0x30, 0x00, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x03, 0x48, 0x00, 0x30, 0x45, 0x02, 0x21, 0x00, 0xf7, 0xdb, 0x62, 0xd6, 0xdd, 0x6d, 0x96, 0x3b, 0x4f, 0x45, 0x89, 0x0c, 0xc9, 0xa5, 0xc2, 0x16, 0x1e, 0xea, 0x08, 0x56, 0x51, 0xcd, 0xc1, 0xa6, 0x50, 0xe7, 0xe0, 0x6b, 0x0e, 0x91, 0xf1, 0x05, 0x02, 0x20, 0x3a, 0x9c, 0xf9, 0x8d, 0x3c, 0x8c, 0x68, 0x18, 0xcb, 0xa9, 0x56, 0x08, 0x0c, 0xfe, 0x5d, 0xf0, 0xdb, 0x60, 0x47, 0x79, 0xd5, 0xd3, 0x3c, 0xe4, 0x0e, 0x61, 0x8d, 0xa3, 0x8c, 0x6f, 0xa5, 0xc6, 0x30, 0x02, 0x20, 0xe6, 0x9f, 0x21, 0x29, 0xef, 0x2d, 0xe1, 0xaf, 0xf3, 0x93, 0xc5, 0xeb, 0x72, 0x62, 0x62, 0xba, 0x9f, 0x30, 0xed, 0x91, 0x86, 0xe9, 0x22, 0x59, 0x1c, 0x90, 0xff, 0x0e, 0xdd, 0x27, 0x06, 0x90, 0x18,
    [1706281518.395161][689286:689288] CHIP:DMG: ] (261 bytes)
    [1706281518.395198][689286:689288] CHIP:DMG: 0x1 = [
    [1706281518.395266][689286:689288] CHIP:DMG: 0x4b, 0xdc, 0x05, 0xf0, 0xaf, 0x01, 0x14, 0x0d, 0xa8, 0xfa, 0xfb, 0x36, 0x5f, 0xba, 0x11, 0xee, 0xc2, 0x4c, 0x7d, 0x02, 0x72, 0x39, 0xa9, 0xee, 0x84, 0xde, 0xab, 0xfe, 0xad, 0x5a, 0x12, 0x5d, 0x13, 0xca, 0x93, 0xc9, 0xca, 0x02, 0x4a, 0x24, 0x72, 0xed, 0x8a, 0x26, 0x8a, 0x3d, 0xb7, 0xcd, 0x44, 0x95, 0x1b, 0x15, 0x6a, 0x56, 0x89, 0x5c, 0x77, 0x13, 0x29, 0x7e, 0x97, 0x84, 0xb7, 0xf6,
    [1706281518.395317][689286:689288] CHIP:DMG: ] (64 bytes)
    [1706281518.395361][689286:689288] CHIP:DMG: },
    [1706281518.395394][689286:689288] CHIP:DMG: },
    [1706281518.395429][689286:689288] CHIP:DMG:
    [1706281518.395455][689286:689288] CHIP:DMG: },
    [1706281518.395487][689286:689288] CHIP:DMG:
    [1706281518.395511][689286:689288] CHIP:DMG: ],
    [1706281518.395544][689286:689288] CHIP:DMG:
    [1706281518.395568][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281518.395617][689286:689288] CHIP:DMG: },
    [1706281518.395701][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
    [1706281518.395760][689286:689288] CHIP:CTL: Received certificate signing request from the device
    [1706281518.395800][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
    [1706281518.395835][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
    [1706281518.395870][689286:689288] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
    [1706281518.401706][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
    [1706281518.401776][689286:689288] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
    [1706281518.401809][689286:689288] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
    [1706281518.401836][689286:689288] CHIP:CTL: Getting certificate chain for the device from the issuer
    [1706281518.406245][689286:689288] CHIP:CTL: Verifying Certificate Signing Request
    [1706281518.408641][689286:689288] CHIP:CTL: Generating NOC
    [1706281518.409005][689286:689288] CHIP:CTL: Providing certificate chain to the commissioner
    [1706281518.409041][689286:689288] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
    [1706281518.409075][689286:689288] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
    [1706281518.409308][689286:689288] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
    [1706281518.409335][689286:689288] CHIP:CTL: Sending root certificate to the device
    [1706281518.409412][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281518.409452][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281518.409607][689286:689288] CHIP:EM: <<< [E:23572i S:29128 M:61819011] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281518.410350][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281518.410447][689286:689288] CHIP:CTL: Sent root certificate to the device
    [1706281518.410982][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281518.489576][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.635466][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.636990][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.637190][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.637452][689286:689288] CHIP:EM: >>> [E:23572i S:29128 M:263416822] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281518.637492][689286:689288] CHIP:EM: Found matching exchange: 23572i, Delegate: 0xffffa000a2e8
    [1706281518.637531][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281518.637583][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281518.637604][689286:689288] CHIP:DMG: {
    [1706281518.637625][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281518.637646][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281518.637674][689286:689288] CHIP:DMG: [
    [1706281518.637696][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281518.637726][689286:689288] CHIP:DMG: {
    [1706281518.637750][689286:689288] CHIP:DMG: CommandStatusIB =
    [1706281518.637776][689286:689288] CHIP:DMG: {
    [1706281518.637801][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281518.637829][689286:689288] CHIP:DMG: {
    [1706281518.637857][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281518.637886][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281518.637914][689286:689288] CHIP:DMG: CommandId = 0xb,
    [1706281518.637941][689286:689288] CHIP:DMG: },
    [1706281518.637972][689286:689288] CHIP:DMG:
    [1706281518.637997][689286:689288] CHIP:DMG: StatusIB =
    [1706281518.638025][689286:689288] CHIP:DMG: {
    [1706281518.638052][689286:689288] CHIP:DMG: status = 0x00 (SUCCESS),
    [1706281518.638079][689286:689288] CHIP:DMG: },
    [1706281518.638107][689286:689288] CHIP:DMG:
    [1706281518.638130][689286:689288] CHIP:DMG: },
    [1706281518.638159][689286:689288] CHIP:DMG:
    [1706281518.638181][689286:689288] CHIP:DMG: },
    [1706281518.638208][689286:689288] CHIP:DMG:
    [1706281518.638228][689286:689288] CHIP:DMG: ],
    [1706281518.638255][689286:689288] CHIP:DMG:
    [1706281518.638276][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281518.638296][689286:689288] CHIP:DMG: },
    [1706281518.638352][689286:689288] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
    [1706281518.638384][689286:689288] CHIP:CTL: Device confirmed that it has received the root certificate
    [1706281518.638418][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
    [1706281518.638446][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
    [1706281518.638476][689286:689288] CHIP:CTL: Performing next commissioning step 'SendNOC'
    [1706281518.638557][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281518.638625][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281518.638784][689286:689288] CHIP:EM: <<< [E:23573i S:29128 M:61819012] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281518.639406][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281518.639478][689286:689288] CHIP:CTL: Sent operational certificate to the device
    [1706281518.639548][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281518.733052][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.879288][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.976756][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281518.978518][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281518.979026][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281518.979261][689286:689288] CHIP:EM: >>> [E:23573i S:29128 M:263416823] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281518.979334][689286:689288] CHIP:EM: Found matching exchange: 23573i, Delegate: 0xffffa003e138
    [1706281518.979385][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281518.979451][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281518.979483][689286:689288] CHIP:DMG: {
    [1706281518.979527][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281518.979560][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281518.979601][689286:689288] CHIP:DMG: [
    [1706281518.979645][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281518.979698][689286:689288] CHIP:DMG: {
    [1706281518.979745][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281518.979784][689286:689288] CHIP:DMG: {
    [1706281518.979832][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281518.979874][689286:689288] CHIP:DMG: {
    [1706281518.979926][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281518.979971][689286:689288] CHIP:DMG: ClusterId = 0x3e,
    [1706281518.980027][689286:689288] CHIP:DMG: CommandId = 0x8,
    [1706281518.980068][689286:689288] CHIP:DMG: },
    [1706281518.980122][689286:689288] CHIP:DMG:
    [1706281518.980160][689286:689288] CHIP:DMG: CommandFields =
    [1706281518.980213][689286:689288] CHIP:DMG: {
    [1706281518.980256][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281518.980311][689286:689288] CHIP:DMG: 0x1 = 1,
    [1706281518.980356][689286:689288] CHIP:DMG: },
    [1706281518.980393][689286:689288] CHIP:DMG: },
    [1706281518.980448][689286:689288] CHIP:DMG:
    [1706281518.980481][689286:689288] CHIP:DMG: },
    [1706281518.980535][689286:689288] CHIP:DMG:
    [1706281518.980664][689286:689288] CHIP:DMG: ],
    [1706281518.980730][689286:689288] CHIP:DMG:
    [1706281518.980763][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281518.980793][689286:689288] CHIP:DMG: },
    [1706281518.980933][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
    [1706281518.981045][689286:689288] CHIP:CTL: Device returned status 0 on receiving the NOC
    [1706281518.981237][689286:689288] CHIP:CTL: Operational credentials provisioned on device 0xffffa000df00
    [1706281518.981290][689286:689288] CHIP:TOO: Secure Pairing Success
    [1706281518.981317][689286:689288] CHIP:TOO: CASE establishment successful
    [1706281518.981353][689286:689288] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
    [1706281518.981398][689286:689288] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
    [1706281518.981427][689286:689288] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
    [1706281518.981478][689286:689288] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
    [1706281518.981587][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281518.981649][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281518.981859][689286:689288] CHIP:EM: <<< [E:23574i S:29128 M:61819013] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281518.982511][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281518.982632][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281519.074414][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281519.075936][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281519.076423][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281519.076690][689286:689288] CHIP:EM: >>> [E:23574i S:29128 M:263416824] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281519.076743][689286:689288] CHIP:EM: Found matching exchange: 23574i, Delegate: 0xffffa000a2e8
    [1706281519.076795][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281519.076857][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281519.076886][689286:689288] CHIP:DMG: {
    [1706281519.076914][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281519.076955][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281519.076994][689286:689288] CHIP:DMG: [
    [1706281519.077023][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281519.077064][689286:689288] CHIP:DMG: {
    [1706281519.077125][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281519.077161][689286:689288] CHIP:DMG: {
    [1706281519.077191][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281519.077226][689286:689288] CHIP:DMG: {
    [1706281519.077266][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281519.077303][689286:689288] CHIP:DMG: ClusterId = 0x31,
    [1706281519.077338][689286:689288] CHIP:DMG: CommandId = 0x5,
    [1706281519.077373][689286:689288] CHIP:DMG: },
    [1706281519.077413][689286:689288] CHIP:DMG:
    [1706281519.077448][689286:689288] CHIP:DMG: CommandFields =
    [1706281519.077485][689286:689288] CHIP:DMG: {
    [1706281519.077524][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281519.077563][689286:689288] CHIP:DMG: 0x2 = 0,
    [1706281519.077602][689286:689288] CHIP:DMG: },
    [1706281519.077636][689286:689288] CHIP:DMG: },
    [1706281519.077675][689286:689288] CHIP:DMG:
    [1706281519.077705][689286:689288] CHIP:DMG: },
    [1706281519.077742][689286:689288] CHIP:DMG:
    [1706281519.077770][689286:689288] CHIP:DMG: ],
    [1706281519.077807][689286:689288] CHIP:DMG:
    [1706281519.077835][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281519.077862][689286:689288] CHIP:DMG: },
    [1706281519.077938][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1706281519.077990][689286:689288] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
    [1706281519.078031][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
    [1706281519.078060][689286:689288] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'FailsafeBeforeThreadEnable'
    [1706281519.078096][689286:689288] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeThreadEnable'
    [1706281519.078141][689286:689288] CHIP:CTL: Arming failsafe (73 seconds)
    [1706281519.078222][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281519.078261][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281519.078410][689286:689288] CHIP:EM: <<< [E:23575i S:29128 M:61819014] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281519.078956][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281519.079061][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281519.171754][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281519.173327][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281519.173516][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281519.173757][689286:689288] CHIP:EM: >>> [E:23575i S:29128 M:263416825] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281519.173803][689286:689288] CHIP:EM: Found matching exchange: 23575i, Delegate: 0xffffa003e138
    [1706281519.173845][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281519.173903][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281519.173929][689286:689288] CHIP:DMG: {
    [1706281519.173953][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281519.173977][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281519.174011][689286:689288] CHIP:DMG: [
    [1706281519.174035][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281519.174069][689286:689288] CHIP:DMG: {
    [1706281519.174095][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281519.174126][689286:689288] CHIP:DMG: {
    [1706281519.174153][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281519.174184][689286:689288] CHIP:DMG: {
    [1706281519.174216][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281519.174249][689286:689288] CHIP:DMG: ClusterId = 0x30,
    [1706281519.174281][689286:689288] CHIP:DMG: CommandId = 0x1,
    [1706281519.174312][689286:689288] CHIP:DMG: },
    [1706281519.174344][689286:689288] CHIP:DMG:
    [1706281519.174372][689286:689288] CHIP:DMG: CommandFields =
    [1706281519.174403][689286:689288] CHIP:DMG: {
    [1706281519.174435][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281519.174471][689286:689288] CHIP:DMG: 0x1 = "" (0 chars),
    [1706281519.174504][689286:689288] CHIP:DMG: },
    [1706281519.174533][689286:689288] CHIP:DMG: },
    [1706281519.174566][689286:689288] CHIP:DMG:
    [1706281519.174592][689286:689288] CHIP:DMG: },
    [1706281519.174623][689286:689288] CHIP:DMG:
    [1706281519.174647][689286:689288] CHIP:DMG: ],
    [1706281519.174678][689286:689288] CHIP:DMG:
    [1706281519.174702][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281519.174725][689286:689288] CHIP:DMG: },
    [1706281519.174793][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1706281519.174842][689286:689288] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1706281519.174880][689286:689288] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
    [1706281519.174904][689286:689288] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
    [1706281519.174936][689286:689288] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
    [1706281519.175019][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281519.175059][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281519.175202][689286:689288] CHIP:EM: <<< [E:23576i S:29128 M:61819015] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281519.175868][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281519.175982][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281519.269286][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281520.733761][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281520.734066][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281520.734385][689286:689288] CHIP:EM: >>> [E:23576i S:29128 M:263416826] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281520.734468][689286:689288] CHIP:EM: Found matching exchange: 23576i, Delegate: 0xffffa000a2e8
    [1706281520.734555][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281520.734659][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281520.734714][689286:689288] CHIP:DMG: {
    [1706281520.734768][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281520.734825][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281520.734899][689286:689288] CHIP:DMG: [
    [1706281520.734955][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281520.735033][689286:689288] CHIP:DMG: {
    [1706281520.735093][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281520.735164][689286:689288] CHIP:DMG: {
    [1706281520.735228][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281520.735303][689286:689288] CHIP:DMG: {
    [1706281520.735376][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281520.735455][689286:689288] CHIP:DMG: ClusterId = 0x31,
    [1706281520.735534][689286:689288] CHIP:DMG: CommandId = 0x7,
    [1706281520.735607][689286:689288] CHIP:DMG: },
    [1706281520.735684][689286:689288] CHIP:DMG:
    [1706281520.735750][689286:689288] CHIP:DMG: CommandFields =
    [1706281520.735824][689286:689288] CHIP:DMG: {
    [1706281520.735902][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281520.735982][689286:689288] CHIP:DMG: 0x2 = NULL
    [1706281520.736060][689286:689288] CHIP:DMG: },
    [1706281520.736129][689286:689288] CHIP:DMG: },
    [1706281520.736206][689286:689288] CHIP:DMG:
    [1706281520.736264][689286:689288] CHIP:DMG: },
    [1706281520.736331][689286:689288] CHIP:DMG:
    [1706281520.736386][689286:689288] CHIP:DMG: ],
    [1706281520.736458][689286:689288] CHIP:DMG:
    [1706281520.736513][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281520.736569][689286:689288] CHIP:DMG: },
    [1706281520.736705][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1706281520.736794][689286:689288] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
    [1706281520.736866][689286:689288] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
    [1706281520.736923][689286:689288] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
    [1706281520.736984][689286:689288] CHIP:CTL: Performing next commissioning step 'FindOperational'
    [1706281520.737034][689286:689288] CHIP:IN: Expiring all sessions for node <000000000000000A, 1>!!
    [1706281520.737145][689286:689288] CHIP:CSM: FindOrEstablishSession: PeerId = [1:000000000000000A]
    [1706281520.737204][689286:689288] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1706281520.737272][689286:689288] CHIP:DIS: OperationalSessionSetup[1:000000000000000A]: State change 1 --> 2
    [1706281520.738022][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281520.937830][689286:689288] CHIP:DIS: Checking node lookup status after 200 ms
    [1706281523.315359][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281524.326036][689286:689288] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:173: CHIP Error 0x00000032: Timeout
    [1706281525.801835][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281525.801975][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281528.434133][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281530.920590][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281530.920951][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281533.504170][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281535.991734][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281535.992272][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281538.574554][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281541.060680][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281541.061041][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281543.644177][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281546.130707][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281546.131069][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281548.714229][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281551.200835][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281551.201001][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281551.743143][689286:689288] CHIP:DIS: Timeout waiting for mDNS resolution.
    [1706281553.784982][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281556.270777][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281556.270917][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281558.854276][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281561.340802][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281561.340943][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281563.924331][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281565.739399][689286:689288] CHIP:DIS: Checking node lookup status after 45002 ms
    [1706281565.739529][689286:689288] CHIP:DIS: OperationalSessionSetup[1:000000000000000A]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout
    [1706281565.739587][689286:689288] CHIP:DIS: Retrying operational DNS-SD discovery. Attempts remaining: 2
    [1706281565.740264][689286:689288] CHIP:CTL: Session establishment failed for <000000000000000A, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout. Next retry expected to get a response to Sigma1 or fail within 60 seconds
    [1706281565.740356][689286:689288] CHIP:CTL: Arming failsafe (120 seconds)
    [1706281565.740497][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281565.740571][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281565.740839][689286:689288] CHIP:EM: <<< [E:23577i S:29128 M:61819016] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281565.741687][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281565.826066][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281565.828244][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281565.828521][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281565.828822][689286:689288] CHIP:EM: >>> [E:23577i S:29128 M:263416827] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281565.828904][689286:689288] CHIP:EM: Found matching exchange: 23577i, Delegate: 0xffffa003e138
    [1706281565.828989][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281565.829151][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281565.829211][689286:689288] CHIP:DMG: {
    [1706281565.829265][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281565.829323][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281565.829398][689286:689288] CHIP:DMG: [
    [1706281565.829456][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281565.829533][689286:689288] CHIP:DMG: {
    [1706281565.829593][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281565.829668][689286:689288] CHIP:DMG: {
    [1706281565.829733][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281565.829817][689286:689288] CHIP:DMG: {
    [1706281565.829893][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281565.829974][689286:689288] CHIP:DMG: ClusterId = 0x30,
    [1706281565.830054][689286:689288] CHIP:DMG: CommandId = 0x1,
    [1706281565.830129][689286:689288] CHIP:DMG: },
    [1706281565.830207][689286:689288] CHIP:DMG:
    [1706281565.830276][689286:689288] CHIP:DMG: CommandFields =
    [1706281565.830355][689286:689288] CHIP:DMG: {
    [1706281565.830434][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281565.830519][689286:689288] CHIP:DMG: 0x1 = "" (0 chars),
    [1706281565.830598][689286:689288] CHIP:DMG: },
    [1706281565.830668][689286:689288] CHIP:DMG: },
    [1706281565.830746][689286:689288] CHIP:DMG:
    [1706281565.830805][689286:689288] CHIP:DMG: },
    [1706281565.830876][689286:689288] CHIP:DMG:
    [1706281565.830931][689286:689288] CHIP:DMG: ],
    [1706281565.831002][689286:689288] CHIP:DMG:
    [1706281565.831057][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281565.831112][689286:689288] CHIP:DMG: },
    [1706281565.831252][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1706281565.831339][689286:689288] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
    [1706281565.831428][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281565.939873][689286:689288] CHIP:DIS: Checking node lookup status after 200 ms
    [1706281568.410150][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281570.895907][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281570.896054][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281573.479378][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281575.965929][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281575.966082][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281578.549428][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281581.035923][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281581.036212][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281583.619659][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281586.107107][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281586.107418][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281588.689509][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281591.175986][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281591.176351][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281593.759525][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281596.246031][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281596.246393][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281596.744072][689286:689288] CHIP:DIS: Timeout waiting for mDNS resolution.
    [1706281598.830061][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281601.317203][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281601.317512][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281603.899586][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281606.386101][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281606.386263][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281608.969655][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281610.741564][689286:689288] CHIP:DIS: Checking node lookup status after 45002 ms
    [1706281610.741631][689286:689288] CHIP:DIS: OperationalSessionSetup[1:000000000000000A]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout
    [1706281610.741651][689286:689288] CHIP:DIS: Retrying operational DNS-SD discovery. Attempts remaining: 1
    [1706281610.741987][689286:689288] CHIP:CTL: Session establishment failed for <000000000000000A, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout. Next retry expected to get a response to Sigma1 or fail within 60 seconds
    [1706281610.742027][689286:689288] CHIP:CTL: Arming failsafe (120 seconds)
    [1706281610.742099][689286:689288] CHIP:DMG: ICR moving to [AddingComm]
    [1706281610.742126][689286:689288] CHIP:DMG: ICR moving to [AddedComma]
    [1706281610.742256][689286:689288] CHIP:EM: <<< [E:23578i S:29128 M:61819017] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1706281610.742745][689286:689288] CHIP:DMG: ICR moving to [CommandSen]
    [1706281610.870906][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281610.872354][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281610.872670][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281610.872835][689286:689288] CHIP:EM: >>> [E:23578i S:29128 M:263416828] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1706281610.872868][689286:689288] CHIP:EM: Found matching exchange: 23578i, Delegate: 0xffffa003e138
    [1706281610.872902][689286:689288] CHIP:DMG: ICR moving to [ResponseRe]
    [1706281610.872948][689286:689288] CHIP:DMG: InvokeResponseMessage =
    [1706281610.872966][689286:689288] CHIP:DMG: {
    [1706281610.872985][689286:689288] CHIP:DMG: suppressResponse = false,
    [1706281610.873003][689286:689288] CHIP:DMG: InvokeResponseIBs =
    [1706281610.873028][689286:689288] CHIP:DMG: [
    [1706281610.873047][689286:689288] CHIP:DMG: InvokeResponseIB =
    [1706281610.873074][689286:689288] CHIP:DMG: {
    [1706281610.873124][689286:689288] CHIP:DMG: CommandDataIB =
    [1706281610.873148][689286:689288] CHIP:DMG: {
    [1706281610.873176][689286:689288] CHIP:DMG: CommandPathIB =
    [1706281610.873203][689286:689288] CHIP:DMG: {
    [1706281610.873227][689286:689288] CHIP:DMG: EndpointId = 0x0,
    [1706281610.873254][689286:689288] CHIP:DMG: ClusterId = 0x30,
    [1706281610.873278][689286:689288] CHIP:DMG: CommandId = 0x1,
    [1706281610.873303][689286:689288] CHIP:DMG: },
    [1706281610.873328][689286:689288] CHIP:DMG:
    [1706281610.873350][689286:689288] CHIP:DMG: CommandFields =
    [1706281610.873374][689286:689288] CHIP:DMG: {
    [1706281610.873400][689286:689288] CHIP:DMG: 0x0 = 0,
    [1706281610.873428][689286:689288] CHIP:DMG: 0x1 = "" (0 chars),
    [1706281610.873454][689286:689288] CHIP:DMG: },
    [1706281610.873476][689286:689288] CHIP:DMG: },
    [1706281610.873501][689286:689288] CHIP:DMG:
    [1706281610.873521][689286:689288] CHIP:DMG: },
    [1706281610.873545][689286:689288] CHIP:DMG:
    [1706281610.873563][689286:689288] CHIP:DMG: ],
    [1706281610.873588][689286:689288] CHIP:DMG:
    [1706281610.873606][689286:689288] CHIP:DMG: InteractionModelRevision = 11
    [1706281610.873624][689286:689288] CHIP:DMG: },
    [1706281610.873676][689286:689288] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1706281610.873711][689286:689288] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
    [1706281610.873742][689286:689288] CHIP:DMG: ICR moving to [AwaitingDe]
    [1706281610.941974][689286:689288] CHIP:DIS: Checking node lookup status after 200 ms
    [1706281613.454839][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281615.942358][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281615.942664][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281618.524764][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281621.011204][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281621.011346][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281623.594754][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281626.081243][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281626.081388][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281628.664723][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281631.152300][689286:689287] CHIP:DL: Indication received, conn = 0xffffa8053ff0
    [1706281631.152609][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1706281633.735153][689286:689288] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1706281634.280560][689286:689286] CHIP:CTL: Shutting down the commissioner
    [1706281634.280742][689286:689286] CHIP:DIS: Closing all BLE connections
    [1706281634.280777][689286:689286] CHIP:IN: Clearing BLE pending packets.
    [1706281634.281291][689286:689286] CHIP:BLE: Auto-closing end point's BLE connection.
    [1706281634.281335][689286:689286] CHIP:DL: Closing BLE GATT connection (con 0xffffa8053ff0)
    [1706281634.281427][689286:689287] CHIP:DL: BluezDisconnect peer=34:25:B4:A0:B9:82
    [1706281636.124572][689286:689286] CHIP:IN: SecureSession[0xffffa0010d00]: MarkForEviction Type:1 LSID:29128
    [1706281636.124621][689286:689286] CHIP:SC: SecureSession[0xffffa0010d00, LSID:29128]: State change 'kActive' --> 'kPendingEviction'
    [1706281636.124672][689286:689286] CHIP:IN: SecureSession[0xffffa0010d00]: Released - Type:1 LSID:29128
    [1706281636.124700][689286:689286] CHIP:CTL: Shutting down the controller
    [1706281636.124723][689286:689286] CHIP:DIS: OperationalSessionSetup[1:000000000000000A]: Cancelling incomplete address resolution as device is being deleted.
    [1706281636.124775][689286:689286] CHIP:CTL: Device connection failed. Error src/app/OperationalSessionSetup.cpp:464: CHIP Error 0x00000074: The operation has been cancelled
    [1706281636.124797][689286:689286] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1706281636.124813][689286:689286] CHIP:FP: Forgetting fabric 0x1
    [1706281636.124837][689286:689286] CHIP:TS: Pending Last Known Good Time: 2023-10-23T16:58:40
    [1706281636.124893][689286:689287] CHIP:DL: Bluez disconnected
    [1706281636.124915][689286:689287] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    [1706281636.124986][689286:689286] CHIP:TS: Previous Last Known Good Time: 2023-10-23T16:58:40
    [1706281636.125004][689286:689286] CHIP:TS: Reverted Last Known Good Time to previous value
    [1706281636.125043][689286:689286] CHIP:CTL: Shutting down the commissioner
    [1706281636.125183][689286:689286] CHIP:CTL: Shutting down the controller
    [1706281636.125202][689286:689286] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1706281636.125350][689286:689286] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1706281636.125446][689286:689286] CHIP:FP: Shutting down FabricTable
    [1706281636.125468][689286:689286] CHIP:TS: Pending Last Known Good Time: 2023-10-23T16:58:40
    [1706281636.125546][689286:689286] CHIP:TS: Previous Last Known Good Time: 2023-10-23T16:58:40
    [1706281636.125563][689286:689286] CHIP:TS: Reverted Last Known Good Time to previous value
    [1706281636.125780][689286:689286] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-elk1pw)
    [1706281636.126281][689286:689286] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1706281636.126329][689286:689286] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1706281636.126349][689286:689286] CHIP:DL: Inet Layer shutdown
    [1706281636.126364][689286:689286] CHIP:DL: BLE shutdown
    [1706281636.127818][689286:689286] CHIP:DL: System Layer shutdown
    [1706281636.128209][689286:689286] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/common/CHIPCommand.cpp:588: CHIP Error 0x00000032: Timeout
    ubuntu@ubuntu:~/connectedhomeip/out/standalone$
    Log from device:
    00> [00:00:00.000][silabs ]Starting scheduler
    00> [00:00:00.000][silabs ]==================================================
    00> [00:00:00.000][silabs ]SiLabs-Sensor starting
    00> [00:00:00.000][silabs ]Init CHIP Stack
    00> [00:00:00.001][info ][DL] Setting device name to : "SiLabs-Sensor"
    00> [00:00:00.001][silabs ]Initializing OpenThread stack
    00> [00:00:00.021][info ][DL] OpenThread started: OK
    00> [00:00:00.021][info ][DL] Setting OpenThread device type to ROUTER
    00> [00:00:00.021][silabs ]Starting OpenThread task
    00> [00:00:00.022][info ][SVR] Initializing subscription resumption storage...
    00> [00:00:00.023][info ][SVR] Server initializing...
    00> [00:00:00.023][detail][FP] Initializing FabricTable from persistent storage
    00> [00:00:00.024][info ][TS] Last Known Good Time: [unknown]
    00> [00:00:00.024][info ][TS] Setting Last Known Good Time to firmware build time 2023-10-10T16:28:52
    00> [00:00:00.025][info ][DMG] AccessControl: initializing
    00> [00:00:00.026][info ][DMG] [00:00:02.406][silabs ]App Task started
    00> [00:00:30.058][detail][DL] bleAdv Timeout : Start slow advertissment
    00> [00:01:04.243][silabs ][INFO] SensorsCallback.UpdateTemperatureMeasurement: reportedTemperature=1900
    00> [00:01:04.243][detail][DMG] Endpoint 1, Cluster 0x0000_0402 update version to f6806e2a
    00> [00:01:04.243][info ][ZCL] Cluster callback: 0x0000_0402
    00> [00:01:09.899][info ][DL] Connect Event for handle : 1
    00> [00:01:10.002][info ][DL] evt_UNKNOWN id = 090600a0
    00> [00:01:11.464][info ][DL] Char Write Req, char : 23
    00> [00:01:11.465][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 9)
    00> [00:01:11.465][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:11.465][info ][BLE] local and remote recv window sizes = 5
    00> [00:01:11.465][info ][BLE] selected BTP version 4
    00> [00:01:11.465][info ][BLE] using BTP fragment sizes rx 244 / tx 244.
    00> [00:01:11.562][info ][DL] HandleTXcharCCCDWrite - Config Flags value : 2
    00> [00:01:11.562][info ][DL] CHIPoBLE subscribe received
    00> [00:01:11.563][info ][DL] _OnPlatformEvent kCHIPoBLESubscribe
    00> [00:01:11.563][detail][IN] BLE EndPoint 0x2000eb20 Connection Complete
    00> [00:01:11.563][info ][DL] _OnPlatformEvent default: event->Type = 32775
    00> [00:01:11.660][info ][DL] Tx Confirmation received
    00> [00:01:11.660][info ][DL] stop soft timer
    00> [00:01:11.660][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:11.661][info ][DL] Char Write Req, char : 23
    00> [00:01:11.661][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 73)
    00> [00:01:11.662][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:11.662][info ][EM] >>> [E:23564r S:0 M:65966330] (U) Msg RX from 0:DD2B23349F2E6C22 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    00> [00:01:11.662][detail][EM] Handling via exchange: 23564r, Delegate: 0x2000e188
    00> [00:01:11.662][detail][SC] Received PBKDF param request
    00> [00:01:11.663][detail][SC] Peer assigned session ID 29128
    00> [00:01:11.663][detail][SC] Including MRP parameters in PBKDF param response
    00> [00:01:11.664][info ][EM] <<< [E:23564r S:0 M:266217851] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    00> [00:01:11.665][detail][SC] Sent PBKDF param response
    00> [00:01:11.665][info ][SVR] Commissioning session establishment step started
    00> [00:01:11.757][info ][DL] Tx Confirmation received
    00> [00:01:11.757][info ][DL] stop soft timer
    00> [00:01:11.757][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:11.758][info ][DL] Char Write Req, char : 23
    00> [00:01:11.758][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 97)
    00> [00:01:11.759][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:11.759][info ][EM] >>> [E:23564r S:0 M:65966331] (U) Msg RX from 0:DD2B23349F2E6C22 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    00> [00:01:11.759][detail][EM] Found matching exchange: 23564r, Delegate: 0x2000e188
    00> [00:01:11.759][detail][SC] Received spake2p msg1
    00> [00:01:11.839][info ][EM] <<< [E:23564r S:0 M:266217852] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    00> [00:01:11.840][detail][SC] Sent spake2p msg2
    00> [00:01:11.903][info ][DL] Tx Confirmation received
    00> [00:01:11.903][info ][DL] stop soft timer
    00> [00:01:11.904][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:11.905][info ][DL] Char Write Req, char : 23
    00> [00:01:11.905][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 64)
    00> [00:01:11.905][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:11.905][info ][EM] >>> [E:23564r S:0 M:65966332] (U) Msg RX from 0:DD2B23349F2E6C22 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    00> [00:01:11.906][detail][EM] Found matching exchange: 23564r, Delegate: 0x2000e188
    00> [00:01:11.906][detail][SC] Received spake2p msg3
    00> [00:01:11.906][detail][SC] Sending status report. Protocol code 0, exchange 23564
    00> [00:01:11.907][info ][EM] <<< [E:23564r S:0 M:266217853] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport)
    00> [00:01:11.910][info ][SC] SecureSession[0x2000baf0, LSID:62583]: State change 'kEstablishing' --> 'kActive'
    00> [00:01:11.911][detail][IN] SecureSession[0x2000baf0]: Activa[00:01:12.000][info ][DL] Tx Confirmation received
    00> [00:01:12.000][info ][DL] stop soft timer
    00> [00:01:12.001][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.002][info ][DL] Char Write Req, char : 23
    00> [00:01:12.002][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 136)
    00> [00:01:12.003][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:12.003][info ][EM] >>> [E:23565r S:62583 M:61819004] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    00> [00:01:12.004][detail][EM] Handling via exchange: 23565r, Delegate: 0x20008bac
    00> [00:01:12.004][detail][IM] Received Read request
    00> [00:01:12.006][detail][DMG] IM RH moving to [CanStartReporting]
    00> [00:01:12.006][detail][DMG] Building Reports for ReadHandler with LastReportGeneration = lu DirtyGeneration = lu
    00> [00:01:12.007][detail][DMG] <RE:Run> Cluster 31, Attribute 3 is dirty
    00> [00:01:12.007][detail][DMG] Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_0003 (expanded=1)
    00> [00:01:12.007][detail][DMG] <RE:Run> Cluster 28, Attribute 4 is dirty
    00> [00:01:12.007][detail][DMG] Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId[00:01:12.011][info ][EM] <<< [E:23565r S:62583 M:263416815] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    00> [00:01:12.012][detail][DMG] <RE> OnReportConfirm: NumReports = 0
    00> [00:01:12.012][detail][DMG] <RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
    00> [00:01:12.012][detail][DMG] IM RH moving to [AwaitingDestruction]
    00> [00:01:12.021][detail][DMG] All ReadHandler-s are clean, clear GlobalDirtySet
    00> [00:01:12.098][info ][DL] Tx Confirmation received
    00> [00:01:12.098][info ][DL] stop soft timer
    00> [00:01:12.099][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.196][info ][DL] Tx Confirmation received
    00> [00:01:12.196][info ][DL] stop soft timer
    00> [00:01:12.196][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.197][info ][DL] Char Write Req, char : 23
    00> [00:01:12.197][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 70)
    00> [00:01:12.198][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:12.198][info ][EM] >>> [E:23566r S:62583 M:61819005] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:12.199][detail][EM] Handling via exchange: 23566r, Delegate: 0x20008bac
    00> [00:01:12.199][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
    00> [00:01:12.199][info ][FS] GeneralCommissioning: Received ArmFailSafe (60s)
    00> [00:01:12.200][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e87b
    00> [00:01:12.200][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:01:12.200][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:12.200][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:12.200][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:12.200][detail][DMG] Decreasing [00:01:12.342][info ][DL] Tx Confirmation received
    00> [00:01:12.342][info ][DL] stop soft timer
    00> [00:01:12.342][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.343][info ][DL] Char Write Req, char : 23
    00> [00:01:12.343][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 75)
    00> [00:01:12.343][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:12.344][info ][EM] >>> [E:23567r S:62583 M:61819006] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:12.345][detail][EM] Handling via exchange: 23567r, Delegate: 0x20008bac
    00> [00:01:12.345][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002
    00> [00:01:12.346][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e87c
    00> [00:01:12.346][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:01:12.346][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:12.346][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:12.346][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:12.346][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:12.347][info ][EM] <[00:01:12.439][info ][DL] Tx Confirmation received
    00> [00:01:12.440][info ][DL] stop soft timer
    00> [00:01:12.440][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.441][info ][DL] Char Write Req, char : 23
    00> [00:01:12.441][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 67)
    00> [00:01:12.441][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:12.442][info ][EM] >>> [E:23568r S:62583 M:61819007] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:12.442][detail][EM] Handling via exchange: 23568r, Delegate: 0x20008bac
    00> [00:01:12.443][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
    00> [00:01:12.443][info ][ZCL] OpCreds: Certificate Chain request received for PAI
    00> [00:01:12.443][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:12.443][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:12.444][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:12.444][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:12.445][info ][EM] <<< [E:23568r S:62583 M:263416818] (S) Msg TX to 0:FFFFFFFB00000000[00:01:12.538][info ][DL] Tx Confirmation received
    00> [00:01:12.538][info ][DL] stop soft timer
    00> [00:01:12.538][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.634][info ][DL] Tx Confirmation received
    00> [00:01:12.634][info ][DL] stop soft timer
    00> [00:01:12.635][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.732][info ][DL] Tx Confirmation received
    00> [00:01:12.732][info ][DL] stop soft timer
    00> [00:01:12.732][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.733][info ][DL] Char Write Req, char : 23
    00> [00:01:12.733][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 67)
    00> [00:01:12.734][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:12.734][info ][EM] >>> [E:23569r S:62583 M:61819008] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:12.735][detail][EM] Handling via exchange: 23569r, Delegate: 0x20008bac
    00> [00:01:12.735][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
    00> [00:01:12.735][info ][ZCL] OpCreds: Certificate Chain request received for DAC
    00> [00:01:12.736][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:12.736][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:12.736][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:12.736][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:12.737][info ][E[00:01:12.830][info ][DL] Tx Confirmation received
    00> [00:01:12.830][info ][DL] stop soft timer
    00> [00:01:12.830][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:12.927][info ][DL] Tx Confirmation received
    00> [00:01:12.927][info ][DL] stop soft timer
    00> [00:01:12.927][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.025][info ][DL] Tx Confirmation received
    00> [00:01:13.025][info ][DL] stop soft timer
    00> [00:01:13.025][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.026][info ][DL] Char Write Req, char : 23
    00> [00:01:13.026][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 99)
    00> [00:01:13.027][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:13.027][info ][EM] >>> [E:23570r S:62583 M:61819009] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:13.028][detail][EM] Handling via exchange: 23570r, Delegate: 0x20008bac
    00> [00:01:13.028][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0000
    00> [00:01:13.028][info ][ZCL] OpCreds: Received an AttestationRequest command
    00> [00:01:13.035][info ][ZCL] OpCreds: AttestationRequest successful.
    00> [00:01:13.035][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:13.035][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:13.035][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:13.035][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:13.036][info ][EM] <<< [E:23570r S:62583 M:263416820] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    00> [00:01:13.037][detail][DMG] Command handler moving to [CommandSen]
    00> [00:01:13.037][detail][DMG] Command handler moving to [AwaitingDe]
    00> [00:01:13.123][info ][DL] Tx Confirmation received
    00> [00:01:13.123][info ][DL] stop soft timer
    00> [00:01:13.123][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.219][info ][DL] Tx Confirmation received
    00> [00:01:13.220][info ][DL] stop soft timer
    00> [00:01:13.220][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.317][info ][DL] Tx Confirmation received
    00> [00:01:13.317][info ][DL] stop soft timer
    00> [00:01:13.317][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.319][info ][DL] Char Write Req, char : 23
    00> [00:01:13.319][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 99)
    00> [00:01:13.319][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:13.320][info ][EM] >>> [E:23571r S:62583 M:61819010] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:13.320][detail][EM] Handling via exchange: 23571r, Delegate: 0x20008bac
    00> [00:01:13.321][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0004
    00> [00:01:13.321][info ][ZCL] OpCreds: Received a CSRRequest command
    00> [00:01:13.321][detail][ZCL] OpCreds: Finding fabric with fabricIndex 0x0
    00> [00:01:13.334][info ][ZCL] OpCreds: AllocatePendingOperationalKey succeeded
    00> [00:01:13.340][info ][ZCL] OpCreds: CSRRequest successful.
    00> [00:01:13.340][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:13.340][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:13.340][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:13.340][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:13.341][info ][EM] <<< [E:23571r S:62583 M:263416821] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    00> [00:01:13.342][detail][DMG] Command handler moving to [CommandSen]
    00> [00:01:13.342][detail][DMG] Command handler moving to [AwaitingDe]
    00> [00:01:13.415][info ][DL] Tx Confirmation received
    00> [00:01:13.415][info ][DL] stop soft timer
    00> [00:01:13.415][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.512][info ][DL] Tx Confirmation received
    00> [00:01:13.512][info ][DL] stop soft timer
    00> [00:01:13.512][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.515][info ][DL] Char Write Req, char : 23
    00> [00:01:13.515][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 244)
    00> [00:01:13.515][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:13.659][info ][DL] Char Write Req, char : 23
    00> [00:01:13.659][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 56)
    00> [00:01:13.660][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:13.660][info ][EM] >>> [E:23572r S:62583 M:61819011] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:13.661][detail][EM] Handling via exchange: 23572r, Delegate: 0x20008bac
    00> [00:01:13.661][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B
    00> [00:01:13.661][info ][ZCL] OpCreds: Received an AddTrustedRootCertificate command
    00> [00:01:13.668][info ][ZCL] OpCreds: AddTrustedRootCertificate successful.
    00> [00:01:13.668][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:13.668][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:13.668][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:13.669][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:13.669][info ][EM] <<< [E:23572r S:62583 M:263416822] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    00> [00:01:13.670][detail][DMG] Command handler moving to [CommandSen]
    00> [00:01:13.670][detail][DMG] Command handler moving to [AwaitingDe]
    00> [00:01:13.755][info ][DL] Tx Confirmation received
    00> [00:01:13.755][info ][DL] stop soft timer
    00> [00:01:13.756][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:13.758][info ][DL] Char Write Req, char : 23
    00> [00:01:13.758][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 244)
    00> [00:01:13.759][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:13.856][info ][DL] Char Write Req, char : 23
    00> [00:01:13.856][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 244)
    00> [00:01:13.856][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:14.000][info ][DL] Char Write Req, char : 23
    00> [00:01:14.000][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 87)
    00> [00:01:14.000][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:14.001][info ][EM] >>> [E:23573r S:62583 M:61819012] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:14.002][detail][EM] Handling via exchange: 23573r, Delegate: 0x20008bac
    00> [00:01:14.002][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0006
    00> [00:01:14.002][info ][ZCL] OpCreds: Received an AddNOC command
    00> [00:01:14.004][info ][FP] Validating NOC chain
    00> [00:01:14.021][info ][FP] NOC chain validation successful
    00> [00:01:14.021][info ][FP] Added new fabric at index: 0x1
    00> [00:01:14.021][info ][FP] Assigned compressed fabric ID: 0xBA8284A0AC0FAA35, node ID: 0x000000000000000A
    00> [00:01:14.022][info ][TS] Last Known Good Time: 2023-10-10T16:28:52
    00> [00:01:14.022][info ][TS] New proposed Last Known Good Time: 2021-01-01T00:00:00
    00> [00:01:14.022][info ][TS] Retaining current Last Known Good Time
    00> [00:01:14.022][detail][DMG] Endpoint 0, Cluster 0x0000_003E update version to 7604300f
    00> [00:01:14.022][detail][DMG] Endpoint 0, Cluster 0x0000_003E update version to 76043010
    00> [00:01:14.033][detail][EVL] LogEvent event number: 0x0000000000000002 priority: 1, endpoint id: 0x0 cluster id: 0x0000_001F event id: 0x0 Sys timestamp: 0x000000000001211A
    00> [00:01:14.034][info ][ZCL] OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
    00> [00:01:14.034][detail][DL] Using Thread extended MAC for hostname.
    00> [00:01:14.034][info ][DIS] Advertise operational node BA8284A0AC0FAA35-000000000000000A
    00> [00:01:14.034][detail][DMG] Endpoint 0, Cluster 0x0000_003E update version to 76043011
    00> [00:01:14.034][detail][DMG] Endpoint 0, Cluster 0x0000_003E update version to 76043012
    00> [00:01:14.035][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:14.035][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:14.035][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:14.035][info ][ZCL] OpCreds: successfully created fabric index 0x1 via AddNOC
    00> [00:01:14.035][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:14.036][info [00:01:14.097][info ][DL] Tx Confirmation received
    00> [00:01:14.097][info ][DL] stop soft timer
    00> [00:01:14.097][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:14.099][info ][DL] Char Write Req, char : 23
    00> [00:01:14.099][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 175)
    00> [00:01:14.099][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:14.100][info ][EM] >>> [E:23574r S:62583 M:61819013] (S) Msg RX from 1:FFFFFFFB00000000 [AA35] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:14.101][detail][EM] Handling via exchange: 23574r, Delegate: 0x20008bac
    00> [00:01:14.101][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0003
    00> [00:01:14.102][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:14.102][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:14.103][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:14.103][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e87d
    00> [00:01:14.103][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:01:14.103][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:01:14.104][info ][EM] [00:01:14.195][info ][DL] Tx Confirmation received
    00> [00:01:14.195][info ][DL] stop soft timer
    00> [00:01:14.195][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:14.196][info ][DL] Char Write Req, char : 23
    00> [00:01:14.196][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 70)
    00> [00:01:14.196][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:14.197][info ][EM] >>> [E:23575r S:62583 M:61819014] (S) Msg RX from 1:FFFFFFFB00000000 [AA35] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:14.197][detail][EM] Handling via exchange: 23575r, Delegate: 0x20008bac
    00> [00:01:14.198][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
    00> [00:01:14.198][info ][FS] GeneralCommissioning: Received ArmFailSafe (73s)
    00> [00:01:14.198][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e87e
    00> [00:01:14.199][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:01:14.199][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:14.199][detail][DMG] Command handler moving to [AddingComm]
    00> [00:01:14.199][detail][DMG] Command handler moving to [AddedComma]
    00> [00:01:14.199][detail][DMG] Decreasing [00:01:14.291][info ][DL] Tx Confirmation received
    00> [00:01:14.292][info ][DL] stop soft timer
    00> [00:01:14.292][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:14.293][info ][DL] Char Write Req, char : 23
    00> [00:01:14.293][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 78)
    00> [00:01:14.293][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:14.294][info ][EM] >>> [E:23576r S:62583 M:61819015] (S) Msg RX from 1:FFFFFFFB00000000 [AA35] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:01:14.294][detail][EM] Handling via exchange: 23576r, Delegate: 0x20008bac
    00> [00:01:14.295][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0006
    00> [00:01:14.317][detail][DMG] Decreasing reference count for CommandHandler, remaining 1
    00> [00:01:14.317][info ][DL] _OnPlatformEvent default: event->Type = 32772
    00> [00:01:14.319][info ][DL] _OnPlatformEvent default: event->Type = 32777
    00> [00:01:14.319][detail][DL] OpenThread State Changed (Flags: 0x111fd11d)
    00> [00:01:14.319][detail][DL] Device Role: DETACHED
    00> [00:01:14.319][detail][DL] Network Name: OpenThreadDemo
    00> [00:01:14.319][detail][DL] PAN Id: 0x1234
    00> [00:01:14.319][detail][DL] Extended PAN Id: 0x1111111122222222
    00> [00:01:14.320][detail][DL] Channel: 15
    00> [00:01:14.320][detail][DL] Mesh Prefix: fd47:c866:a2d5:bb8d:0:0:0:0/64
    00> [00:01:14.320][detail][DL] Thread Unicast Addresses:
    00> [00:01:14.320][detail][DL] fd47:c866:a2d5:bb8d:6040:aed7:95eb:ec86/64 valid
    00> [00:01:14.320][detail][DL] fe80:0:0:0:7c63:33c:b39:4a81/64 valid preferred
    00> [00:01:15.774][info ][DL] SRP Client was started, detected server: fd47:c866:a2d5:bb8d:df49:b731:3ec7:717c
    00> [00:01:15.775][info ][DL] _OnPlatformEvent default: event->Type = 32777
    00> [00:01:15.775][detail][DL] OpenThread State Changed (Flags: 0x200012a4)
    00> [00:01:15.775][detail][DL] Device Role: CHILD
    00> [00:01:15.775][detail][DL] Partition Id: 0x39FB9696
    00> [00:01:15.778][info ][DL] _OnPlatformEvent default: event->Type = 32777
    00> [00:01:15.778][detail][DL] Thread Attached updating Multicast address
    00> [00:01:15.778][info ][SVR] Joining Multicast groups
    00> [00:01:15.779][detail][DL] OpenThread State Changed (Flags: 0x00000001)
    00> [00:01:15.779][detail][DL] Thread Unicast Addresses:
    00> [00:01:15.779][detail][DL] fd11:22:0:0:171b:1417:af40:ef39/64 valid preferred
    00> [00:01:15.780][detail][DL] fd47:c866:a2d5:bb8d:0:ff:fe00:6401/64 valid rloc
    00> [00:01:15.780][detail][DL] fd47:c866:a2d5:bb8d:6040:aed7:95eb:ec86/64 valid
    00> [00:01:15.780][detail][DL] fe80:0:0:0:7c63:33c:b39:4a81/64 valid preferred
    00> [00:01:15.783][info ][DL] _OnPlatformEvent default: event->Type = 32769
    00> [00:01:15.783][silabs ]Scheduling OTA Requestor initialization
    00> [00:01:15.783][detail][DMG] Command handler moving to [ Preparing]
    00> [00:01:15.783][detail][DMG] Command han[00:01:15.785][info ][EM] <<< [E:23576r S:62583 M:263416826] (S) Msg TX to 1:FFFFFFFB00000000 [AA35] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    00> [00:01:15.785][detail][DMG] Command handler moving to [CommandSen]
    00> [00:01:15.786][detail][DMG] Command handler moving to [AwaitingDe]
    00> [00:01:15.786][info ][DL] _OnPlatformEvent default: event->Type = 32783
    00> [00:01:15.786][detail][DL] Using Thread extended MAC for hostname.
    00> [00:[00:01:15.852][info ][DL] Tx Confirmation received
    00> [00:01:15.852][info ][DL] stop soft timer
    00> [00:01:15.853][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:16.522][detail][DL] SRP update succeeded
    00> [00:01:16.522][info ][DL] _OnPlatformEvent default: event->Type = 32784
    00> [00:01:16.522][info ][SVR] Server initialization complete
    00> [00:01:16.522][info ][DIS] Updating services using commissioning mode 0
    00> [00:01:16.522][detail][DL] Using Thread extended MAC for hostname.
    00> [00:01:16.522][info ][DIS] Advertise operational node BA8284A0AC0FAA35-000000000000000A
    00> [00:01:16.523][info ][DL] advertising srp service: BA8284A0AC0FAA35-000000000000000A._matter._tcp
    00> [00:01:16.523][info ][DL] _OnPlatformEvent default: event->Type = 32788
    00> [00:01:16.532][info ][IM] No subscriptions to resume
    00> [00:01:17.380][detail][DL] SRP update succeeded
    00> [00:01:18.338][info ][DL] Char Write Req, char : 23
    00> [00:01:18.339][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:18.339][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:18.785][info ][SWU] Stopping the watchdog timer
    00> [00:01:18.785][info ][SWU] Starting the periodic query timer, timeout: 86400 seconds
    00> [00:01:18.786][detail][DMG] Endpoint 0, Cluster 0x0000_002A update version to 689f7c79
    00> [00:01:18.786][info ][ZCL] Cluster callback: 0x0000_002A
    00> [00:01:18.786][detail][DMG] Endpoint 0, Cluster 0x0000_002A update version to 689f7c7a
    00> [00:01:20.922][info ][DL] Tx Confirmation received
    00> [00:01:20.922][info ][DL] stop soft timer
    00> [00:01:20.923][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:23.458][info ][DL] Char Write Req, char : 23
    00> [00:01:23.458][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:23.458][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:26.041][info ][DL] Tx Confirmation received
    00> [00:01:26.041][info ][DL] stop soft timer
    00> [00:01:26.041][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:28.528][info ][DL] Char Write Req, char : 23
    00> [00:01:28.528][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:28.529][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:31.112][info ][DL] Tx Confirmation received
    00> [00:01:31.112][info ][DL] stop soft timer
    00> [00:01:31.112][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:33.598][info ][DL] Char Write Req, char : 23
    00> [00:01:33.598][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:33.598][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:36.181][info ][DL] Tx Confirmation received
    00> [00:01:36.181][info ][DL] stop soft timer
    00> [00:01:36.182][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:38.667][info ][DL] Char Write Req, char : 23
    00> [00:01:38.668][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:38.668][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:41.251][info ][DL] Tx Confirmation received
    00> [00:01:41.251][info ][DL] stop soft timer
    00> [00:01:41.251][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:43.738][info ][DL] Char Write Req, char : 23
    00> [00:01:43.738][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:43.739][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:46.322][info ][DL] Tx Confirmation received
    00> [00:01:46.322][info ][DL] stop soft timer
    00> [00:01:46.322][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:48.808][info ][DL] Char Write Req, char : 23
    00> [00:01:48.808][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:48.808][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:51.392][info ][DL] Tx Confirmation received
    00> [00:01:51.392][info ][DL] stop soft timer
    00> [00:01:51.392][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:53.878][info ][DL] Char Write Req, char : 23
    00> [00:01:53.878][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:53.878][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:01:56.461][info ][DL] Tx Confirmation received
    00> [00:01:56.462][info ][DL] stop soft timer
    00> [00:01:56.462][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:01:58.948][info ][DL] Char Write Req, char : 23
    00> [00:01:58.949][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:01:58.949][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:00.850][info ][DL] Char Write Req, char : 23
    00> [00:02:00.850][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 69)
    00> [00:02:00.850][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:00.851][info ][EM] >>> [E:23577r S:62583 M:61819016] (S) Msg RX from 1:FFFFFFFB00000000 [AA35] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:02:00.851][detail][EM] Handling via exchange: 23577r, Delegate: 0x20008bac
    00> [00:02:00.852][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
    00> [00:02:00.852][info ][FS] GeneralCommissioning: Received ArmFailSafe (120s)
    00> [00:02:00.852][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e880
    00> [00:02:00.853][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:02:00.853][detail][DMG] Command handler moving to [ Preparing]
    00> [00:02:00.853][detail][DMG] Command handler moving to [AddingComm]
    00> [00:02:00.853][detail][DMG] Command handler moving to [AddedComma]
    00> [00:02:00.853][detail][DMG] Decreasing[00:02:00.854][info ][EM] <<< [E:23577r S:62583 M:263416827] (S) Msg TX to 1:FFFFFFFB00000000 [AA35] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    00> [00:02:00.855][detail][DMG] Command handler moving to [CommandSen]
    00> [00:02:[00:02:00.947][info ][DL] Tx Confirmation received
    00> [00:02:00.947][info ][DL] stop soft timer
    00> [00:02:00.948][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:03.433][info ][DL] Char Write Req, char : 23
    00> [00:02:03.433][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:03.434][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:04.252][silabs ][INFO] SensorsCallback.UpdateTemperatureMeasurement: reportedTemperature=1887
    00> [00:02:04.252][detail][DMG] Endpoint 1, Cluster 0x0000_0402 update version to f6806e2b
    00> [00:02:04.252][info ][ZCL] Cluster callback: 0x0000_0402
    00> [00:02:06.017][info ][DL] Tx Confirmation received
    00> [00:02:06.017][info ][DL] stop soft timer
    00> [00:02:06.017][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:08.503][info ][DL] Char Write Req, char : 23
    00> [00:02:08.503][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:08.503][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:11.087][info ][DL] Tx Confirmation received
    00> [00:02:11.087][info ][DL] stop soft timer
    00> [00:02:11.087][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:13.574][info ][DL] Char Write Req, char : 23
    00> [00:02:13.574][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:13.574][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:16.157][info ][DL] Tx Confirmation received
    00> [00:02:16.158][info ][DL] stop soft timer
    00> [00:02:16.158][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:18.644][info ][DL] Char Write Req, char : 23
    00> [00:02:18.644][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:18.644][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:19.410][info ][DL] _OnPlatformEvent default: event->Type = 32777
    00> [00:02:19.410][detail][DL] OpenThread State Changed (Flags: 0x00000064)
    00> [00:02:19.410][detail][DL] Device Role: ROUTER
    00> [00:02:21.227][info ][DL] Tx Confirmation received
    00> [00:02:21.227][info ][DL] stop soft timer
    00> [00:02:21.228][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:23.713][info ][DL] Char Write Req, char : 23
    00> [00:02:23.713][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:23.714][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:26.297][info ][DL] Tx Confirmation received
    00> [00:02:26.297][info ][DL] stop soft timer
    00> [00:02:26.297][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:28.784][info ][DL] Char Write Req, char : 23
    00> [00:02:28.784][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:28.784][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:31.368][info ][DL] Tx Confirmation received
    00> [00:02:31.368][info ][DL] stop soft timer
    00> [00:02:31.368][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:33.854][info ][DL] Char Write Req, char : 23
    00> [00:02:33.854][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:33.854][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:36.438][info ][DL] Tx Confirmation received
    00> [00:02:36.438][info ][DL] stop soft timer
    00> [00:02:36.438][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:38.924][info ][DL] Char Write Req, char : 23
    00> [00:02:38.924][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:38.924][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:41.507][info ][DL] Tx Confirmation received
    00> [00:02:41.507][info ][DL] stop soft timer
    00> [00:02:41.508][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:43.994][info ][DL] Char Write Req, char : 23
    00> [00:02:43.995][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:43.995][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:45.847][info ][DL] Char Write Req, char : 23
    00> [00:02:45.847][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 69)
    00> [00:02:45.847][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:45.848][info ][EM] >>> [E:23578r S:62583 M:61819017] (S) Msg RX from 1:FFFFFFFB00000000 [AA35] --- Type 0001:08 (IM:InvokeCommandRequest)
    00> [00:02:45.848][detail][EM] Handling via exchange: 23578r, Delegate: 0x20008bac
    00> [00:02:45.849][detail][DMG] Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
    00> [00:02:45.849][info ][FS] GeneralCommissioning: Received ArmFailSafe (120s)
    00> [00:02:45.849][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e881
    00> [00:02:45.849][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:02:45.850][detail][DMG] Command handler moving to [ Preparing]
    00> [00:02:45.850][detail][DMG] Command handler moving to [AddingComm]
    00> [00:02:45.850][detail][DMG] Command handler moving to [AddedComma]
    00> [00:02:45.850][detail][DMG] Decreasing reference count for CommandHandler, remaining 0
    00> [00:02:45.851][info ][EM] <<< [E:23578r S:62583 M:263416828] (S) Msg TX to 1:FFFFFFFB00000000 [AA35] [BLE] --[00:02:45.993][info ][DL] Tx Confirmation received
    00> [00:02:45.993][info ][DL] stop soft timer
    00> [00:02:45.993][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:48.479][info ][DL] Char Write Req, char : 23
    00> [00:02:48.479][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:48.479][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:51.063][info ][DL] Tx Confirmation received
    00> [00:02:51.063][info ][DL] stop soft timer
    00> [00:02:51.063][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:53.549][info ][DL] Char Write Req, char : 23
    00> [00:02:53.549][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:53.549][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:02:56.133][info ][DL] Tx Confirmation received
    00> [00:02:56.133][info ][DL] stop soft timer
    00> [00:02:56.133][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:02:58.620][info ][DL] Char Write Req, char : 23
    00> [00:02:58.620][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:02:58.620][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:03:01.203][info ][DL] Tx Confirmation received
    00> [00:03:01.203][info ][DL] stop soft timer
    00> [00:03:01.204][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:03:03.689][info ][DL] Char Write Req, char : 23
    00> [00:03:03.690][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:03:03.690][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:03:04.252][silabs ][INFO] SensorsCallback.UpdateTemperatureMeasurement: reportedTemperature=1875
    00> [00:03:04.252][detail][DMG] Endpoint 1, Cluster 0x0000_0402 update version to f6806e2c
    00> [00:03:04.252][info ][ZCL] Cluster callback: 0x0000_0402
    00> [00:03:06.273][info ][DL] Tx Confirmation received
    00> [00:03:06.273][info ][DL] stop soft timer
    00> [00:03:06.274][info ][DL] _OnPlatformEvent kCHIPoBLEIndicateConfirm
    00> [00:03:08.759][info ][DL] Char Write Req, char : 23
    00> [00:03:08.759][detail][DL] Write request/command received for CHIPoBLE RX characteristic (con 1, len 3)
    00> [00:03:08.760][info ][DL] _OnPlatformEvent kCHIPoBLEWriteReceived
    00> [00:03:09.393][info ][DL] HandleTXcharCCCDWrite - Config Flags value : 0
    00> [00:03:09.393][info ][DL] CHIPoBLE unsubscribe received
    00> [00:03:09.393][info ][DL] _OnPlatformEvent kCHIPoBLEUnsubscribe
    00> [00:03:09.394][detail][IN] Clearing BLE pending packets.
    00> [00:03:09.394][info ][BLE] Releasing end point's BLE connection back to application.
    00> [00:03:11.197][info ][DL] Disconnect Event for handle : 1
    00> [00:03:11.197][info ][DL] BLE GATT connection closed (con 1, reason 4115)
    00> [00:03:11.198][info ][DL] _OnPlatformEvent kCHIPoBLEConnectionError
    00> [00:04:02.527][silabs ][ERROR] DS2480B::ReadSerialByte: ReadBytes bytesRead=2.
    00> [00:04:02.527][silabs ][ERROR] OneWire::Reset: Failed.
    00> [00:04:02.527][silabs ][ERROR] DS18B20::TemperatureConversion: Call to OneWire::Reset #1 failed.
    00> [00:04:02.527][silabs ][ERROR] DS18B20::MeasureTemperature: Call to TemperatureConversion failed.
    00> [00:04:45.850][info ][FS] Fail-safe timer expired
    00> [00:04:45.850][info ][DL] _OnPlatformEvent default: event->Type = 32782
    00> [00:04:45.850][error ][SVR] Failsafe timer expired
    00> [00:04:45.850][detail][IN] SecureSession[0x2000baf0]: MarkForEviction Type:1 LSID:62583
    00> [00:04:45.850][info ][SC] SecureSession[0x2000baf0, LSID:62583]: State change 'kActive' --> 'kPendingEviction'
    00> [00:04:45.850][detail][IN] SecureSession[0x2000baf0]: Released - Type:1 LSID:62583
    00> [00:04:45.850][error ][SVR] Commissioning failed (attempt 1): 32
    00> [00:04:45.851][detail][IN] SecureSession[0x2000baf0]: Allocated Type:1 LSID:62585
    00> [00:04:45.851][detail][SC] Assigned local session key ID 62585
    00> [00:04:45.852][detail][SC] Waiting for PBKDF param request
    00> [00:04:45.852][info ][DIS] Updating services using commissioning mode 1
    00> [00:04:45.852][detail][DL] Using Thread extended MAC for hostname.
    00> [00:04:45.852][info ][DIS] Advertise operational node BA8284A0AC0FAA35-000000000000000A
    00> [00:04:45.853][info ][DIS] Advertise[00:04:45.861][detail][DMG] Endpoint 0, Cluster 0x0000_003E update version to 76043014
    00> [00:04:45.891][info ][TS] Pending Last Known Good Time: 2023-10-10T16:28:52
    00> [00:04:45.892][info ][TS] Previous Last Known Good Time: 2023-10-10T16:28:52
    00> [00:04:45.892][info ][TS] Reverted Last Known Good Time to previous value
    00> [00:04:45.892][detail][EVL] LogEvent event number: 0x0000000000000004 priority: 1, endpoint id: 0x0 cluster id: 0x0000_0028 event id: 0x2 Sys timestamp: 0x0000000000045CAD
    00> [00:04:45.892][detail][DMG] All ReadHandler-s are clean, clear GlobalDirtySet
    00> [00:04:45.893][error ][FP] Warning: metadata not found during delete of fabric 0x1
    00> [00:04:45.894][error ][ZCL] OpCreds: failed to delete fabric at index 1: d8
    00> [00:04:45.894][detail][DMG] Endpoint 0, Cluster 0x0000_0030 update version to 95f7e882
    00> [00:04:45.894][info ][ZCL] Cluster callback: 0x0000_0030
    00> [00:04:45.895][detail][ZCL] Failsafe timeout, tell platform driver to revert network credentials.
    00> [00:04:45.895][info ][NP] Reverting Thread operational dataset
    00> [00:04:45.900][info ][FS] Fail-safe cleanly disarmed
    00> [00:04:45.900][detail][DL] Start BLE advertissement
    00> [00:04:45.903][info ][DL] _OnPlatformEvent default: event->Type = 32772
    00> [00:04:45.903][info ][DL] _OnPlatformEvent default: event->Type = 32777
    00> [00:04:45.903][detail][DL] OpenThread State Changed (Flags: 0x11002046)
    00> [00:04:45.903][detail][DL] Device Role: DISABLED
    00> [00:04:45.903][detail][DL] Thread Unicast Addresses:
    00> [00:04:45.904][detail][DL] fd11:22:0:0:171b:1417:af40:ef39/64 valid preferred
    00> [00:04:45.904][info ][DL] _OnPlatformEvent default: event->Type = 32769
    00> [00:05:04.243][silabs ][INFO] SensorsCallback.UpdateTemperatureMeasurement: reportedTemperature=2018
    00> [00:05:04.243][detail][DMG] Endpoint 1, Cluster 0x0000_0402 update version to f6806e2d
    00> [00:05:04.243][info ][ZCL] Cluster callback: 0x0000_0402
    00> [00:05:15.903][detail][DL] bleAdv Timeout : Start slow advertissment
    00> [00:06:04.252][silabs ][INFO] SensorsCallback.UpdateTemperatureMeasurement: reportedTemperature=2062
    00> [00:06:04.252][detail][DMG] Endpoint 1, Cluster 0x0000_0402 update version to f6806e2e
    00> [00:06:04.252][info ][ZCL] Cluster callback: 0x0000_0402
  • When posting long logs, please use the Insert->Code functionality to help us keep devzone tidy.
    This time I edited your comment to fix it, but remember to do this yourself in the future. Thanks!
    I will look through your logs and get back to you.
  • I see from your logs that you are not running any of our Matter samples. Are you getting the same issue with our Matter samples as well? You can find a list of samples here: Matter samples.
    Which board are you using?
