nRF9160 FOTA using sdk2.1.0 and SPM fails to get flash area from ID
sdk v2.1.0
nRF9160 modem v1.3.5
I am changing my application, based on a LWM2M client, from SDK 1.9.1 to SDK 2.1.0 while maintaining the use of SPM.
Everything works correctly except when I try to do a FOTA...
After completing the image download, the dfu_target_mcuboot library returns error -14 (-ENOENT) and FOTA is cancelled.
Log output:
[00:03:19.476,837] <inf> UC__FOTA: HTTPS download: 99%
[00:03:19.477,294] <dbg> fota_download: download_client_callback: Progress: 520192/524903 bytes
[00:03:19.860,076] <dbg> fota_download: download_client_callback: Progress: 521216/524903 bytes
[00:03:20.115,844] <dbg> fota_download: download_client_callback: Progress: 522240/524903 bytes
[00:03:20.342,803] <dbg> fota_download: download_client_callback: Progress: 523264/524903 bytes
[00:03:20.573,913] <dbg> fota_download: download_client_callback: Progress: 524288/524903 bytes
[00:03:20.853,637] <inf> UC__FOTA: HTTPS download: 100%
[00:03:20.854,125] <dbg> fota_download: download_client_callback: Progress: 524903/524903 bytes
[00:03:20.918,609] <err> dfu_target_mcuboot: boot_request_upgrade_multi for image-0 error -14
[00:03:20.919,830] <err> fota_download: dfu_target_done error: -14
After digging into the SDK I notice that the flash_area_open() function cannot get the area with ID=2 (mcuboot_secondary) from the list of existing areas...
int flash_area_open(uint8_t id, const struct flash_area **fap)
	const struct flash_area *area;
	if (flash_map == NULL) {
		return -EACCES;
	/* RC add */
	LOG_DBG("flashID:%d | flash_map_entries:%d", id, flash_map_entries);
	for (int i = 0; i < flash_map_entries; i++) {
		LOG_DBG("flash_map[%d].fa_id=%d", i, flash_map[i].fa_id);
	/* RC end */
	area = get_flash_area_from_id(id);
	if (area == NULL) {
		return -ENOENT;
	if (!area->fa_dev || !device_is_ready(area->fa_dev)) {
		return -ENODEV;
	*fap = area;
	return 0;
Log output using sdk2.1.0
[01:25:12.470,458] <inf> UC__FOTA: HTTPS download: 100%
[01:25:12.470,916] <dbg> fota_download: download_client_callback: Progress: 524903/524903 bytes
[01:25:12.523,162] <dbg> fota_download: download_client_callback: dfu_target_done error: 0
[01:25:12.523,712] <dbg> flash_map: flash_area_open: flashID:2 | flash_map_entries:16
[01:25:12.524,261] <dbg> flash_map: flash_area_open: flash_map[0].fa_id=0
[01:25:12.524,780] <dbg> flash_map: flash_area_open: flash_map[1].fa_id=1
[01:25:12.525,299] <dbg> flash_map: flash_area_open: flash_map[2].fa_id=3
[01:25:12.525,817] <dbg> flash_map: flash_area_open: flash_map[3].fa_id=4
[01:25:12.526,336] <dbg> flash_map: flash_area_open: flash_map[4].fa_id=5
[01:25:12.526,855] <dbg> flash_map: flash_area_open: flash_map[5].fa_id=6
[01:25:12.527,343] <dbg> flash_map: flash_area_open: flash_map[6].fa_id=7
[01:25:12.527,862] <dbg> flash_map: flash_area_open: flash_map[7].fa_id=8
[01:25:12.528,381] <dbg> flash_map: flash_area_open: flash_map[8].fa_id=9
[01:25:12.528,900] <dbg> flash_map: flash_area_open: flash_map[9].fa_id=10
[01:25:12.529,418] <dbg> flash_map: flash_area_open: flash_map[10].fa_id=11
[01:25:12.529,937] <dbg> flash_map: flash_area_open: flash_map[11].fa_id=12
[01:25:12.530,487] <dbg> flash_map: flash_area_open: flash_map[12].fa_id=13
[01:25:12.531,005] <dbg> flash_map: flash_area_open: flash_map[13].fa_id=14
[01:25:12.531,524] <dbg> flash_map: flash_area_open: flash_map[14].fa_id=15
[01:25:12.532,043] <dbg> flash_map: flash_area_open: flash_map[15].fa_id=17
[01:25:12.532,592] <dbg> mcuboot_util: boot_set_pending_multi: flash_area_open id:2 error: -2
[01:25:12.533,172] <err> dfu_target_mcuboot: boot_request_upgrade_multi for image-0 error -14
[01:25:12.533,752] <dbg> dfu_target: dfu_target_schedule_update: dfu_target_schedule_update error: -14
[01:25:12.534,332] <err> fota_download: dfu_target_done error: -14
[01:25:12.534,790] <err> UC__FOTA: Error while downloading new firmware
Log output using sdk1.9.1
[00:00:34.082,061] <dbg> flash_map.flash_area_open: flashID:2 | flash_map_entries:18
[00:00:34.082,550] <dbg> flash_map.flash_area_open: flash_map[0].fa_id=0
[00:00:34.083,007] <dbg> flash_map.flash_area_open: flash_map[1].fa_id=1
[00:00:34.083,465] <dbg> flash_map.flash_area_open: flash_map[2].fa_id=2
[00:00:34.083,923] <dbg> flash_map.flash_area_open: flash_map[3].fa_id=3
[00:00:34.084,381] <dbg> flash_map.flash_area_open: flash_map[4].fa_id=4
[00:00:34.084,808] <dbg> flash_map.flash_area_open: flash_map[5].fa_id=5
[00:00:34.085,266] <dbg> flash_map.flash_area_open: flash_map[6].fa_id=6
[00:00:34.085,723] <dbg> flash_map.flash_area_open: flash_map[7].fa_id=7
[00:00:34.086,181] <dbg> flash_map.flash_area_open: flash_map[8].fa_id=8
[00:00:34.086,639] <dbg> flash_map.flash_area_open: flash_map[9].fa_id=9
[00:00:34.087,066] <dbg> flash_map.flash_area_open: flash_map[10].fa_id=10
[00:00:34.087,554] <dbg> flash_map.flash_area_open: flash_map[11].fa_id=11
[00:00:34.088,012] <dbg> flash_map.flash_area_open: flash_map[12].fa_id=12
[00:00:34.088,470] <dbg> flash_map.flash_area_open: flash_map[13].fa_id=13
[00:00:34.088,928] <dbg> flash_map.flash_area_open: flash_map[14].fa_id=14
[00:00:34.089,385] <dbg> flash_map.flash_area_open: flash_map[15].fa_id=15
[00:00:34.089,843] <dbg> flash_map.flash_area_open: flash_map[16].fa_id=16
[00:00:34.090,332] <dbg> flash_map.flash_area_open: flash_map[17].fa_id=17
But consulting the build\pm.config and partitions.yml file, the areas are there and correctly defined...
pm.config using sdk 2.1.0:
PM_B0_OFFSET=0x0
PM_B0_ADDRESS=0x0
PM_B0_END_ADDRESS=0x8000
PM_B0_SIZE=0x8000
PM_B0_NAME=b0
PM_B0_ID=0
PM_b0_ID=PM_B0_ID
PM_b0_IS_ENABLED=1
PM_0_LABEL=B0
PM_B0_CONTAINER_OFFSET=0x0
PM_B0_CONTAINER_ADDRESS=0x0
PM_B0_CONTAINER_END_ADDRESS=0x8000
PM_B0_CONTAINER_SIZE=0x8000
PM_B0_CONTAINER_NAME=b0_container
PM_B0_CONTAINER_ID=1
PM_b0_container_ID=PM_B0_CONTAINER_ID
PM_b0_container_IS_ENABLED=1
PM_1_LABEL=B0_CONTAINER
PM_B0_CONTAINER_SPAN="b0"
PM_MCUBOOT_SECONDARY_OFFSET=0x0
PM_MCUBOOT_SECONDARY_ADDRESS=0x0
PM_MCUBOOT_SECONDARY_END_ADDRESS=0xd0000
PM_MCUBOOT_SECONDARY_SIZE=0xd0000
PM_MCUBOOT_SECONDARY_NAME=mcuboot_secondary
PM_MCUBOOT_SECONDARY_ID=2
PM_mcuboot_secondary_ID=PM_MCUBOOT_SECONDARY_ID
PM_mcuboot_secondary_IS_ENABLED=1
PM_2_LABEL=MCUBOOT_SECONDARY
PM_S0_OFFSET=0x8000
PM_S0_ADDRESS=0x8000
PM_S0_END_ADDRESS=0x18000
PM_S0_SIZE=0x10000
PM_S0_NAME=s0
PM_S0_ID=3
PM_s0_ID=PM_S0_ID
PM_s0_IS_ENABLED=1
PM_3_LABEL=S0
PM_S0_SPAN="s0_pad mcuboot"
PM_S0_PAD_OFFSET=0x8000
PM_S0_PAD_ADDRESS=0x8000
PM_S0_PAD_END_ADDRESS=0x8200
PM_S0_PAD_SIZE=0x200
PM_S0_PAD_NAME=s0_pad
PM_S0_PAD_ID=4
PM_s0_pad_ID=PM_S0_PAD_ID
PM_s0_pad_IS_ENABLED=1
PM_4_LABEL=S0_PAD
PM_MCUBOOT_OFFSET=0x8200
PM_MCUBOOT_ADDRESS=0x8200
PM_MCUBOOT_END_ADDRESS=0x18000
PM_MCUBOOT_SIZE=0xfe00
PM_MCUBOOT_NAME=mcuboot
PM_MCUBOOT_ID=5
PM_mcuboot_ID=PM_MCUBOOT_ID
PM_mcuboot_IS_ENABLED=1
PM_5_LABEL=MCUBOOT
PM_S0_IMAGE_OFFSET=0x8200
PM_S0_IMAGE_ADDRESS=0x8200
PM_S0_IMAGE_END_ADDRESS=0x18000
PM_S0_IMAGE_SIZE=0xfe00
PM_S0_IMAGE_NAME=s0_image
PM_S0_IMAGE_ID=6
PM_s0_image_ID=PM_S0_IMAGE_ID
PM_s0_image_IS_ENABLED=1
PM_6_LABEL=S0_IMAGE
PM_S0_IMAGE_SPAN="mcuboot"
PM_S1_OFFSET=0x18000
PM_S1_ADDRESS=0x18000
PM_S1_END_ADDRESS=0x28000
PM_S1_SIZE=0x10000
PM_S1_NAME=s1
PM_S1_ID=7
PM_s1_ID=PM_S1_ID
PM_s1_IS_ENABLED=1
PM_7_LABEL=S1
PM_S1_SPAN="s1_pad s1_image"
PM_S1_PAD_OFFSET=0x18000
PM_S1_PAD_ADDRESS=0x18000
PM_S1_PAD_END_ADDRESS=0x18200
PM_S1_PAD_SIZE=0x200
PM_S1_PAD_NAME=s1_pad
PM_S1_PAD_ID=8
PM_s1_pad_ID=PM_S1_PAD_ID
PM_s1_pad_IS_ENABLED=1
PM_8_LABEL=S1_PAD
PM_S1_IMAGE_OFFSET=0x18200
PM_S1_IMAGE_ADDRESS=0x18200
PM_S1_IMAGE_END_ADDRESS=0x28000
PM_S1_IMAGE_SIZE=0xfe00
PM_S1_IMAGE_NAME=s1_image
PM_S1_IMAGE_ID=9
PM_s1_image_ID=PM_S1_IMAGE_ID
PM_s1_image_IS_ENABLED=1
PM_9_LABEL=S1_IMAGE
PM_MCUBOOT_PAD_OFFSET=0x28000
PM_MCUBOOT_PAD_ADDRESS=0x28000
PM_MCUBOOT_PAD_END_ADDRESS=0x28200
PM_MCUBOOT_PAD_SIZE=0x200
PM_MCUBOOT_PAD_NAME=mcuboot_pad
PM_MCUBOOT_PAD_ID=10
PM_mcuboot_pad_ID=PM_MCUBOOT_PAD_ID
PM_mcuboot_pad_IS_ENABLED=1
PM_10_LABEL=MCUBOOT_PAD
PM_MCUBOOT_PRIMARY_OFFSET=0x28000
PM_MCUBOOT_PRIMARY_ADDRESS=0x28000
PM_MCUBOOT_PRIMARY_END_ADDRESS=0xf8000
PM_MCUBOOT_PRIMARY_SIZE=0xd0000
PM_MCUBOOT_PRIMARY_NAME=mcuboot_primary
PM_MCUBOOT_PRIMARY_ID=11
PM_mcuboot_primary_ID=PM_MCUBOOT_PRIMARY_ID
PM_mcuboot_primary_IS_ENABLED=1
PM_11_LABEL=MCUBOOT_PRIMARY
PM_MCUBOOT_PRIMARY_SPAN="app spm mcuboot_pad"
PM_APP_IMAGE_OFFSET=0x28200
PM_APP_IMAGE_ADDRESS=0x28200
PM_APP_IMAGE_END_ADDRESS=0xf8000
PM_APP_IMAGE_SIZE=0xcfe00
PM_APP_IMAGE_NAME=app_image
PM_APP_IMAGE_ID=12
PM_app_image_ID=PM_APP_IMAGE_ID
PM_app_image_IS_ENABLED=1
PM_12_LABEL=APP_IMAGE
PM_APP_IMAGE_SPAN="spm app"
PM_MCUBOOT_PRIMARY_APP_OFFSET=0x28200
PM_MCUBOOT_PRIMARY_APP_ADDRESS=0x28200
PM_MCUBOOT_PRIMARY_APP_END_ADDRESS=0xf8000
PM_MCUBOOT_PRIMARY_APP_SIZE=0xcfe00
PM_MCUBOOT_PRIMARY_APP_NAME=mcuboot_primary_app
PM_MCUBOOT_PRIMARY_APP_ID=13
PM_mcuboot_primary_app_ID=PM_MCUBOOT_PRIMARY_APP_ID
PM_mcuboot_primary_app_IS_ENABLED=1
PM_13_LABEL=MCUBOOT_PRIMARY_APP
PM_MCUBOOT_PRIMARY_APP_SPAN="app spm"
PM_SPM_OFFSET=0x28200
PM_SPM_ADDRESS=0x28200
PM_SPM_END_ADDRESS=0x38200
PM_SPM_SIZE=0x10000
PM_SPM_NAME=spm
PM_SPM_ID=14
PM_spm_ID=PM_SPM_ID
PM_spm_IS_ENABLED=1
PM_14_LABEL=SPM
PM_APP_OFFSET=0x38200
PM_APP_ADDRESS=0x38200
PM_APP_END_ADDRESS=0xf8000
PM_APP_SIZE=0xbfe00
PM_APP_NAME=app
PM_APP_ID=15
PM_app_ID=PM_APP_ID
PM_app_IS_ENABLED=1
PM_15_LABEL=APP
PM_EXTERNAL_FLASH_OFFSET=0xd0000
PM_EXTERNAL_FLASH_ADDRESS=0xd0000
PM_EXTERNAL_FLASH_END_ADDRESS=0x800000
PM_EXTERNAL_FLASH_SIZE=0x730000
PM_EXTERNAL_FLASH_NAME=external_flash
PM_EXTERNAL_FLASH_ID=16
PM_external_flash_ID=PM_EXTERNAL_FLASH_ID
PM_external_flash_IS_ENABLED=1
PM_16_LABEL=EXTERNAL_FLASH
PM_SETTINGS_STORAGE_OFFSET=0xf8000
PM_SETTINGS_STORAGE_ADDRESS=0xf8000
PM_SETTINGS_STORAGE_END_ADDRESS=0x100000
PM_SETTINGS_STORAGE_SIZE=0x8000
PM_SETTINGS_STORAGE_NAME=settings_storage
PM_SETTINGS_STORAGE_ID=17
PM_settings_storage_ID=PM_SETTINGS_STORAGE_ID
PM_settings_storage_IS_ENABLED=1
PM_17_LABEL=SETTINGS_STORAGE
PM_PROVISION_OFFSET=0x0
PM_PROVISION_ADDRESS=0xff8108
PM_PROVISION_END_ADDRESS=0xff8388
PM_PROVISION_SIZE=0x280
PM_PROVISION_NAME=provision
PM_OTP_OFFSET=0x280
PM_OTP_ADDRESS=0xff8388
PM_OTP_END_ADDRESS=0xff83fc
PM_OTP_SIZE=0x74
PM_OTP_NAME=otp
PM_SPM_SRAM_OFFSET=0x0
PM_SPM_SRAM_ADDRESS=0x20000000
PM_SPM_SRAM_END_ADDRESS=0x20004000
PM_SPM_SRAM_SIZE=0x4000
PM_SPM_SRAM_NAME=spm_sram
PM_SRAM_SECURE_OFFSET=0x0
PM_SRAM_SECURE_ADDRESS=0x20000000
PM_SRAM_SECURE_END_ADDRESS=0x20004000
PM_SRAM_SECURE_SIZE=0x4000
PM_SRAM_SECURE_NAME=sram_secure
PM_SRAM_SECURE_SPAN="spm_sram"
PM_NRF_MODEM_LIB_CTRL_OFFSET=0x4000
PM_NRF_MODEM_LIB_CTRL_ADDRESS=0x20004000
PM_NRF_MODEM_LIB_CTRL_END_ADDRESS=0x200044e8
PM_NRF_MODEM_LIB_CTRL_SIZE=0x4e8
PM_NRF_MODEM_LIB_CTRL_NAME=nrf_modem_lib_ctrl
PM_NRF_MODEM_LIB_SRAM_OFFSET=0x4000
PM_NRF_MODEM_LIB_SRAM_ADDRESS=0x20004000
PM_NRF_MODEM_LIB_SRAM_END_ADDRESS=0x200084e8
PM_NRF_MODEM_LIB_SRAM_SIZE=0x44e8
PM_NRF_MODEM_LIB_SRAM_NAME=nrf_modem_lib_sram
PM_NRF_MODEM_LIB_SRAM_SPAN="nrf_modem_lib_ctrl nrf_modem_lib_tx nrf_modem_lib_rx"
PM_SRAM_NONSECURE_OFFSET=0x4000
PM_SRAM_NONSECURE_ADDRESS=0x20004000
PM_SRAM_NONSECURE_END_ADDRESS=0x20040000
PM_SRAM_NONSECURE_SIZE=0x3c000
PM_SRAM_NONSECURE_NAME=sram_nonsecure
PM_SRAM_NONSECURE_SPAN="sram_primary nrf_modem_lib_ctrl nrf_modem_lib_tx nrf_modem_lib_rx"
PM_NRF_MODEM_LIB_TX_OFFSET=0x44e8
PM_NRF_MODEM_LIB_TX_ADDRESS=0x200044e8
PM_NRF_MODEM_LIB_TX_END_ADDRESS=0x200064e8
PM_NRF_MODEM_LIB_TX_SIZE=0x2000
PM_NRF_MODEM_LIB_TX_NAME=nrf_modem_lib_tx
PM_NRF_MODEM_LIB_RX_OFFSET=0x64e8
PM_NRF_MODEM_LIB_RX_ADDRESS=0x200064e8
PM_NRF_MODEM_LIB_RX_END_ADDRESS=0x200084e8
PM_NRF_MODEM_LIB_RX_SIZE=0x2000
PM_NRF_MODEM_LIB_RX_NAME=nrf_modem_lib_rx
PM_SRAM_PRIMARY_OFFSET=0x84e8
PM_SRAM_PRIMARY_ADDRESS=0x200084e8
PM_SRAM_PRIMARY_END_ADDRESS=0x20040000
PM_SRAM_PRIMARY_SIZE=0x37b18
PM_SRAM_PRIMARY_NAME=sram_primary
PM_NUM=18
PM_ALL_BY_SIZE="otp mcuboot_pad s0_pad s1_pad provision nrf_modem_lib_ctrl nrf_modem_lib_rx nrf_modem_lib_tx spm_sram sram_secure nrf_modem_lib_sram b0 settings_storage b0_container mcuboot s1_image s0_image spm s0 s1 sram_primary sram_nonsecure app app_image mcuboot_primary_app mcuboot_secondary mcuboot_primary external_flash"
partitions.yml using sdk 2.1.0:
app:
  address: 0x38200
  end_address: 0xf8000
  region: flash_primary
app_image:
  address: 0x28200
  orig_span: &id001
  - spm
  - app
  span: *id001
b0:
  address: 0x0
  end_address: 0x8000
  placement:
    after:
    - start
b0_container:
  address: 0x0
  end_address: 0x8000
  orig_span: &id002
  - b0
  span: *id002
external_flash:
  address: 0xd0000
  end_address: 0x800000
  region: external_flash
mcuboot:
  address: 0x8200
  end_address: 0x18000
  placement:
    before:
    - mcuboot_primary
  sharers: 0x1
mcuboot_pad:
  address: 0x28000
  end_address: 0x28200
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
  sharers: 0x2
mcuboot_primary:
  address: 0x28000
  orig_span: &id003
  - app
  - spm
  - mcuboot_pad
  span: *id003
mcuboot_primary_app:
  address: 0x28200
  orig_span: &id004
  - app
  - spm
  span: *id004
mcuboot_secondary:
  address: 0x0
  device: /soc/peripheral@40000000/spi@b000/mx25l6433f@0
  end_address: 0xd0000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
nrf_modem_lib_ctrl:
  address: 0x20004000
  end_address: 0x200044e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - spm_sram
    - start
  region: sram_primary
nrf_modem_lib_rx:
  address: 0x200064e8
  end_address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20004000
  orig_span: &id005
  - nrf_modem_lib_ctrl
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id005
nrf_modem_lib_tx:
  address: 0x200044e8
  end_address: 0x200064e8
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8388
  end_address: 0xff83fc
  region: otp
provision:
  address: 0xff8108
  end_address: 0xff8388
  region: otp
s0:
  address: 0x8000
  orig_span: &id006
  - s0_pad
  - mcuboot
  span: *id006
s0_image:
  address: 0x8200
  orig_span: &id007
  - mcuboot
  span: *id007
s0_pad:
  address: 0x8000
  end_address: 0x8200
  placement:
    after:
    - b0_container
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
s1:
  address: 0x18000
  end_address: 0x28000
  orig_span: &id008
  - s1_pad
  - s1_image
  span: *id008
s1_image:
  address: 0x18200
  placement:
    after:
    - s1_pad
    - s0
  share_size:
  - mcuboot
s1_pad:
  address: 0x18000
  end_address: 0x18200
  placement:
    after:
    - s0
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
settings_storage:
  address: 0xf8000
  end_address: 0x100000
  placement:
    before:
    - end
spm:
  address: 0x28200
  end_address: 0x38200
  inside:
  placement:
    before:
    - app
spm_sram:
  address: 0x20000000
  end_address: 0x20004000
  inside:
  - sram_secure
  placement:
    after:
    - start
sram_nonsecure:
  address: 0x20004000
  end_address: 0x20040000
  orig_span: &id009
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id009
sram_primary:
  address: 0x200084e8
sram_secure:
  address: 0x20000000
  orig_span: &id010
  - spm_sram
  span: *id010
pm.config using sdk 1.9.1:
PM_B0_OFFSET=0x0
PM_B0_ADDRESS=0x0
PM_B0_SIZE=0x8000
PM_B0_NAME=b0
PM_B0_ID=0
PM_b0_ID=PM_B0_ID
PM_b0_IS_ENABLED=1
PM_0_LABEL=B0
PM_S0_OFFSET=0x8000
PM_S0_SIZE=0x10000
PM_S0_NAME=s0
PM_S0_ID=3
PM_s0_ID=PM_S0_ID
PM_s0_IS_ENABLED=1
PM_3_LABEL=S0
PM_S0_SPAN="mcuboot s0_pad"
PM_S0_PAD_ID=4
PM_4_LABEL=S0_PAD
PM_MCUBOOT_ID=5
PM_5_LABEL=MCUBOOT
PM_S0_IMAGE_ID=6
PM_6_LABEL=S0_IMAGE
PM_S1_SIZE=0x10000
PM_S1_NAME=s1
PM_S1_ID=7
PM_s1_ID=PM_S1_ID
PM_s1_IS_ENABLED=1
PM_7_LABEL=S1
PM_S1_PAD_ID=8
PM_8_LABEL=S1_PAD
PM_S1_IMAGE_ID=9
PM_9_LABEL=S1_IMAGE
PM_MCUBOOT_PRIMARY_SPAN="spm app mcuboot_pad"
PM_MCUBOOT_PRIMARY_APP_ID=12
PM_12_LABEL=MCUBOOT_PRIMARY_APP
PM_SPM_SIZE=0x10000
PM_SPM_NAME=spm
PM_SPM_ID=13
PM_spm_ID=PM_SPM_ID
PM_spm_IS_ENABLED=1
PM_13_LABEL=SPM
PM_SPM_APP_OFFSET=0x28200
PM_SPM_APP_ADDRESS=0x28200
PM_SPM_APP_END_ADDRESS=0xf8000
PM_SPM_APP_SIZE=0xcfe00
PM_SPM_APP_NAME=spm_app
PM_SPM_APP_ID=14
PM_spm_app_ID=PM_SPM_APP_ID
PM_spm_app_IS_ENABLED=1
PM_14_LABEL=SPM_APP
PM_SPM_APP_SPAN="spm app"
PM_APP_SIZE=0xbfe00
PM_APP_NAME=app
PM_APP_ID=15
PM_app_ID=PM_APP_ID
PM_app_IS_ENABLED=1
PM_15_LABEL=APP
PM_OTP_OFFSET=0x280
PM_OTP_SIZE=0x74
PM_OTP_NAME=otp
PM_NUM=18
PM_ALL_BY_SIZE="otp mcuboot_pad s0_pad s1_pad provision nrf_modem_lib_ctrl nrf_modem_lib_rx nrf_modem_lib_tx spm_sram sram_secure nrf_modem_lib_sram b0 settings_storage b0_container mcuboot s1_image s0_image spm s0 s1 sram_primary sram_nonsecure app mcuboot_primary_app spm_app mcuboot_secondary mcuboot_primary external_flash"
partitions.yml using sdk 1.9.1:
app:
  address: 0x38200
b0:
  address: 0x0
  end_address: 0x8000
  placement:
    after:
    - start
b0_container:
  address: 0x0
  end_address: 0x8000
  orig_span: &id001
  - b0
  span: *id001
external_flash:
  address: 0xd0000
mcuboot:
  address: 0x8200
  placement:
    before:
    - mcuboot_primary
  sharers: 0x1
mcuboot_pad:
  address: 0x28000
  placement:
    align:
      start: 0x8000
    before:
  sharers: 0x2
mcuboot_primary:
  address: 0x28000
  orig_span: &id002
  - spm
  - app
  - mcuboot_pad
  span: *id002
  address: 0x28200
  orig_span: &id003
  - app
  - spm
  span: *id003
mcuboot_secondary:
  address: 0x0
  device: MX25L64
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
nrf_modem_lib_ctrl:
  address: 0x20004000
  inside:
  - sram_nonsecure
  placement:
    after:
    - spm_sram
    - start
nrf_modem_lib_rx:
  address: 0x200064e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20004000
  orig_span: &id004
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id004
nrf_modem_lib_tx:
  address: 0x200044e8
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8388
  region: otp
provision:
  address: 0xff8108
  region: otp
s0:
  address: 0x8000
  orig_span: &id005
  - mcuboot
  - s0_pad
  span: *id005
s0_image:
  address: 0x8200
  orig_span: &id006
  - mcuboot
  span: *id006
s0_pad:
  address: 0x8000
  end_address: 0x8200
  placement:
    after:
    - b0_container
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
s1:
  address: 0x18000
  orig_span: &id007
  - s1_pad
  - s1_image
  span: *id007
s1_image:
  address: 0x18200
  placement:
    after:
    - s1_pad
    - s0
  share_size:
  - mcuboot
s1_pad:
  address: 0x18000
  placement:
    after:
    - s0
    align:
      start: 0x8000
  share_size:
  - mcuboot_pad
settings_storage:
  address: 0xf8000
  placement:
    before:
    - end
spm:
  address: 0x28200
  inside:
  placement:
    before:
    - app
spm_app:
  address: 0x28200
  orig_span: &id008
  - spm
  - app
  span: *id008
spm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
sram_nonsecure:
  address: 0x20004000
  orig_span: &id009
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id009
sram_primary:
  address: 0x200084e8
sram_secure:
  address: 0x20000000
  orig_span: &id010
  - spm_sram
  span: *id010
External flash settings on DT:
&spi3 {
	status = "okay";
	pinctrl-0 = <&spi3_default_overlay>;
	pinctrl-1 = <&spi3_sleep_overlay>;
	cs-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
	mx25l64: mx25l6433f@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <100000000>;    //100MHz
		//label = "MX25L64";
		size = <67108864>;    //64Mbit - 8MByte
		has-dpd;
		t-enter-dpd = <10000>;    //10usec
		t-exit-dpd = <100000>;    //100usec
	chosen {
		nordic,pm-ext-flash = &mx25l64;
Why is the pointer to the mcuboot_secondary area not defined in *flash_map?
It seems that the areas defined in the external flash are ignored (ID=2 and ID=16)!
What am I doing wrong?
Ricardo
  • Hi Jonathan,
    You're right, there is only this line that references the QSPI in the .config file in the build output files.
    But it seems to me that the problem was really related to the QSPI, I tested this:
    If the external flash device is not using the QSPI NOR driver, you must enable CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK
    and now the regions.yml file has changed and has this override:
    external_flash:
      base_address: 0x0
      default_driver_kconfig: CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK
      dynamic_partition: null
      placement_strategy: start_to_end
    flash_primary:
      base_address: 0x0
      default_driver_kconfig: CONFIG_SOC_FLASH_NRF
      device: flash_controller
      placement_strategy: complex
    otp:
      base_address: 0xff8108
      default_driver_kconfig: ''
      device: ''
    sram_primary:
      base_address: 0x20000000
      device: ''
      dynamic_partition: sram_primary
    and thus recognizes all areas created in the external flash!
    However, I still can't do FOTA but it seems to me that now the problem is related to MCUBoot... Disappointed
    So I'm going to close this case.
    EDIT: my FOTA problem was resolved by applying this patch
    Thanks for your help!
    Ricardo
