dfu with IS_SRVC_CHANGED_CHARACT_PRESENT set to 0
Hi, I am develop a project with dfu and bond features. I found that in dfu project, IS_SRVC_CHANGED_CHARACT_PRESENT is always set to 1. In my understanding, if set this to 1, each time phone connect to my device, it will read the services, then slow down the connection process. Am I right? If above is true, is it possible to set IS_SRVC_CHANGED_CHARACT_PRESENT to 0, that I make bootloader and my application project with the same services?
  • I use SDK 12.2.0.
    I agree that removing pstorage_clear() is not a good idea but when i call pstorage_clear() i not received any pstorage callback, it make the dfu process timeout. My problem here is i don't understand why disabling service change characteristic is make that error. When i enable service change characteristic, everything work fine, i can received the pstorage callback, the dfu process completed successfully.
  • If you test with the unmodified bootloader, do you see the same thing ? I would suggest you to create a new case for your issue.
  • Thanks for your suggestion. I have test the unmodified bootloader with nRF-Toolbox and see the same result. If you are working with some kind of bootloader project, can you test and confirm my issue?
  • Hi Hoai,
    I'm sorry, the issue happenned when you change IS_SRVC_CHANGED_CHARACT_PRESENT = 0 , right  ? Then if you test with the unmodified bootloader, there would be an problem because the phone will cache the attribute table and wouldn't see the DFU service.
    I assume you would need to modify the bootloader to have your application's service as well ?
    I would suggest you to create a private case that you can share with us your firmware. You can create a dummy version of your application that only do the buttonless DFU (but has all the service of your application). And the bootloader that you modified to have the services of your application as well.
    Please mention my name in the case so the system knows to assign to me.
  • Thanks
    That the reason my bootloader and my application project have the same attribute table.
    Finally i found where my code go wrong.
    /**@brief Function for the Application's S110 SoftDevice event handler.
     * @param[in] p_ble_evt S110 SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t                              err_code;
        ble_gatts_rw_authorize_reply_params_t auth_reply;
            case BLE_GAP_EVT_CONNECTED:
                m_conn_handle    = p_ble_evt->evt.gap_evt.conn_handle;
                m_is_advertising = false;
                    uint8_t  sys_attr[128];
                    uint16_t sys_attr_len = 128;
                    m_direct_adv_cnt = APP_DIRECTED_ADV_TIMEOUT;
                    err_code = sd_ble_gatts_sys_attr_get(m_conn_handle,
                                                         sys_attr,
                                                         &sys_attr_len,
                                                         BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                if (!m_tear_down_in_progress)
                    // The Disconnected event is because of an external event. (Link loss or
                    // disconnect triggered by the DFU Controller before the firmware update was
                    // complete).
                    // Restart advertising so that the DFU Controller can reconnect if possible.
                    advertising_start();
    In above function, when we get BLE_GAP_EVT_DISCONNECTED,
    we also call
                                                         sys_attr,
                                                         &sys_attr_len,
    I don't know why we call that function, but it will return an NRF_ERROR_NOT_FOUND and make system reboot. I think that removing service change characteristic make my Generic Attribute Service empty and make that error. So my current solution is remove APP_ERROR_CHECK(err_code); line and use the original bootloader_settings_save method.
