esb, shockburst, running on nrf5340dk's
I have 3 nrf boards connected. 2x nrf52832 and 1x nrf5340.
esb_tx is running on nrf52832(682782977)
esb_rx is running on nrf52832(682497942) & nrf5340(1050025410)
west build -b nrf5340dk_nrf5340_cpunet -p builds correctly and flashes without error
PS C:\nrf\esb_prx> west flash -d build_1
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
There are multiple boards connected.
1. 1050025410
2. 682782977
Please select one with desired serial number (1-2): 1
-- runners.nrfjprog: Flashing file: build_1\zephyr\zephyr.hex
[ #################### ] 2.055s | Erase file - Done erasing
[ #################### ] 0.243s | Program file - Done programming
[ #################### ] 0.243s | Verify file - Done verifying
Applying pin reset.
-- runners.nrfjprog: Board with serial number 1050025410 flashed successfully.
esb_rx is working on the nrf52, but not on the nrf53.
... To be through, I powered down esb_tx_nrf52832(682782977) and flashed another nrf5340dk(1050077823) and programmed it to be esb_tx:
PS C:\nrf\esb_ptx> west flash -d build_1
1. 1050025410
2. 1050077823
3. 682497942
Please select one with desired serial number (1-3): 2
[ #################### ] 2.044s | Erase file - Done erasing
[ #################### ] 0.235s | Program file - Done programming
[ #################### ] 0.236s | Verify file - Done verifying
Applying pin reset.
-- runners.nrfjprog: Board with serial number 1050077823 flashed successfully.
Although 1050077823 (nrf5340-esb_tx) flashed correctly. Blinky continues to run (as it already had) on nrf5340-esb_tx, which probably makes sense, but I'm not getting any kind of esb response from either (nrf52832 or nrf5340) esb-rx.
There is something I am not understanding about how to flash to nrf5340_CPUNET? Maybe it's flashing correctly, but esb needs to be called from CPUAPP to start it working?? I'm close, but missing something...
Ultimately the goal is to have a network of nrf5340's in a Star configuration. I see that there is shared memory between CPUAPP and CPUNET. I assume somehow it's used to pass data from CPUAPP to CPUNET for transmission/reception. I don't exactly understand how that works either, but I figure the first step is to get the esb Sample to work on nrf5340dk's without modification. But, if there are additional samples that target this use case I would be interested in reviewing those too.
The final configuration goal is to have the center of the star network also be running BLE-UART (so the central esb in the Star Network will relay the esb data from the nodes to a BLE app). I am assuming that there is no problem running both esb and BLE at the same time.
esb_prx_ptx.zip
  • Hi Mike
    That's a weird issue on the phone side, I am not sure what might be going on there. You could see other devices in LightBlue? Could some filters be enabled?
    Clearly it's a hint you should be using the nRF Connect app instead of LightBlue Wink
    All the Bluetooth functionality is covered by the app_bt_lbs.c file, which is basically just a slightly modified copy of the main file from the lbs sample. The idea is to extend app_bt_lbs.c and app_bt_lbs.h with whatever functions you need in order for the application to interface with the Bluetooth connection. Right now there is only an init function, but typically you would want some functions to handle data send/receive, advertising start/stop and so forth.
    It seems I removed the reference to dk_leds_init(), which is probably why LED's don't work. If you try to call this either inside app_bt_init() or inside your main function I would expect LED's to be updated by the app_bt_lbs.c module.
    mej7000 said:
    I am curious about this. Yes, I did read that, but I can't find esb_peripherals.h in my local repo or on yours. Am I doing something wrong
    No, this is one of the SDK files, not one of the project files. You can find it in the nrf/subsys/esb folder in the SDK.
    A quick tip to find files in VS Code is to press ctrl + P, and type the name in the text box.
    mej7000 said:
    I would think that would make a killer Nordic Sample/Solution for a lot of users. I have done something similar with ESP32 using UART peripheral.
    Maybe a silly question, but couldn't you just use BLE for all the links? Make one device a concurrent central/peripheral, and use this as a relay between the phone and the other device?
    mej7000 said:
    This Sample is brilliant and 90% of what I was looking for. Thanks!
    I'm very happy to hear you found it useful Slight smile
    I hope to have some time eventually to clean it up a little, make the app_bt module a bit more full featured, and remove the need to change the SDK files directly.
    Best regards
    Torbjørn
  • Thanks! I just discovered what dk_buttons_and_leds.h is and that I couldn't find dk_leds_init(), but you beat me to it! Slight smile  Yesterday, I did a device tree overlay and got the LED working, which will be useful for my custom PCB eventually.
    This isn't a silly question at all and is the reason we are migrating gen2 of this project to Nordic. I would love to get your opinion...
    we have:
    1. Network of devices (beam break sensors)
    2. Must maintain strict (ms) timing synchronization between devices
    3. Must resync regularly
    4. Sensors must respond immediately to random events (<=1ms)
    5. Sensors must be capable of receiving commands from App
    6. Beam break and HW_ID data to be reported to an App
    7. npm1300 fuel gauge data, etc to be reported to App
    8. Network range <=~200m
    9. Battery operated, low power, etc.
    Given the above my thought was that:
    1. BLE connection to App
    2. Shockburst with "parent" uptime preloaded into ACK
    3. "child" sending actual or dummy data to get current parent uptime
    I chose the above because I was concerned that BLE wouldn't have the range and/or the speed to reliably support the communication and clock sync requirements?
    That's kind of the thinking thus far, however I would love explore any alternative ideas.
  • Hi Mike
    Accurate time synchronization is certainly a reason to chose ESB over BLE. When running Bluetooth the link layer will take care of packet timing, retransmits etc, and the delay between uploading the data and receiving it on the other side will be very erratic.
    Very short latency is another bonus of the ESB protocol, you have more control of packet timing, and in theory you can send a packet and receive an ACK in less than a millisecond.
    How many devices would you typically have for each gateway?
    If performance is very critical you would probably get a more robust solution by having two nRF devices on the gateway (one for BLE and one for ESB), but this would obviously increase the BOM and the hardware complexity. The higher the number of sensors the smaller the impact would be on the total system cost, relatively speaking.
    The range is a bit of a concern, it is hard to guarantee up to 200m of range over 2.4GHz, since these signals are heavily affected by environmental factors (in particular humidity/water, and metals).
    Also, low power and low latency is a challenging combination of factors. If the sensors need to respond immediately to commands it means the radio needs to be available most of the time, which means you are looking at an idle current close to the radio peak current (around 5mA in RX).
    One advantage again to ESB is that you are able to tune the protocol if you have more power available on one side of the link (such as the gateway in your case). But if you need very low latency in both directions then your hands are tied in this regard, since the sensors will not be able to sleep for long.
    Best regards
    Torbjørn
  • Thanks. I'm convinced ESB is the correct solution for the network, and BLE is required for the App connection. Using the Ack to sync the parent time and child times works really well.
    This question just came up yesterday. I think I have it worked out, but I want to make sure I have this correct... I have one "Parent" (BLE/ESB-PRX) and many (~30) children (ESB-PTX).
    I think (if I understand ESB correctly) I can have all communication happen on PTX0? Because Child nodes communicate directly with the Parent (never child to child), but the Parent always communicates (timestamp or command) as a "Broadcast" to the children. So the children can share the same pipe address? (ie.  uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};)
    One hesitation is that I don't fully understand "pipes". It looks like the pipe is like a GHz channel and that PRX can monitor up to 8 pipes/channels at the same time? Which is potentially very useful for me as long as that doesn't actually mean I am limited to only 8 PTX "children". That would be a disaster for me...
  • Hi
    Yes, you can have multiple (more than 2) devices communicating over the same pipe without issue as long as only one device is in PRX mode, or you disable ACK. If you have multiple devices in PRX mode and use ACK then you will run into issues where multiple devices are sending ACK's at the same time, which will lead to unpredictable behavior.
    In your case it sounds like this should work fine since only the parent node will be in PRX mode.
    Please note that you can get issues with this method if the PTX's send data very often, and you don't have any way of synchronizing them in time to avoid collisions.
    They can all share the same address, yes, but please don't use the default 0xE7 address in production Wink
    A pipe is just an abstraction of an address. Essentially the radio receiver can look for up to 8 different addresses simultaneously when decoding the incoming data stream, and it can then report to the application from which pipe the packet was received. Historically this feature was used mostly with a single PTX pr pipe, but like mentioned before it is possible to have multiple PTX devices all transmitting to the same pipe.
    The advantage of only having 1 PTX pr pipe is that you don't need any other identifying markers in the payload to differentiate the different PTX's. When multiple devices are sharing pipes then you need to include some additional information in the payload to keep them apart, but in your case you probably need this anyway since you will have up to 30 devices talking to one 'parent'.
    One comment to your diagram: Another advantage of the pipe system is that the PRX can pre-load ACK payloads for the different pipes in advance, so that whichever PTX sends data to you next will get the correct ACK payload in return. In order to make this system look at some part of the payload instead of the pipe to send the correct ACK payload the ESB protocol will need some changes.
    Same if you want to include an accurate timestamp in the payload, this would require some modifications to the protocol as well.
    Best regards
    Torbjørn
