zigbee: similar issue as KRKNWK-12017
SDK: nRF5 SDK for Thread and Zigbee v4.2.0
Chip: nRF52840
We're experiencing a very rare behavior on an end device implementation.
We haven't able to reproduce with logs due to the rare occurrence of the issue but we have some live instrumentation that allows us to get the history of ZBOSS signals.
When the issue happens we get a ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE and the device doesn't try to rejoin the coordinator anymore.
It looks very similar to the KRKNWK-12017 issue bu there is no broken rejoin procedure happening before the ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE event.
Here is the historic of ZBOSS signals for a device which was up for several days and then stops interaction with the coordinator:
  1. ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY
  2. ZB_ZDO_SIGNAL_SKIP_STARTUP
  3. ZB_BDB_SIGNAL_DEVICE_REBOOT
  4. ZB_NLME_STATUS_INDICATION  => ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE
Could you recommend a procedure to fix this ? Maybe trigger a rejoin when the ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE occurs ?
FYI, resetting the device makes the device rejoin the network immediately
Sebastien
  • Yes, that should take care of both types of failures. However, I recommend testing it to verify that it works as expected.
    Let me be clear here. It's the second major issue we had with nrf52840 and Zigbee SDK 4.2.0 (released recently which was supposed to be a stable production release)
    We had to recall products because of stability issues of the SDK / ZBOSS stack.
    With the closed source ZBOSS stack and the binary trace it's impossible to debug by ourselves and it's time and resource consuming to debug with the support.
    KRKNWK-12017 is clearly a production stop issue. Why hasn't it be fixed by ZBoss stack ? Why the workaround isn't officially integrated ?
    I really like the software ecosystem, the SDK and such but quality should be highly prioritized in Nordic.
    So in conclusion, yes, don't worry, we will test.
  • FYI
    In the current product we have 2 watchdogs, 1 periodic reset every 12 hours and the KRKNWK-12017 workaround to manage having a stable product
    The issue has been reported to DSR. However, the nRF5 SDK for Thread and Zigbee is deprecated and will not be upgraded.
    Marte
    Some feedback from the tests.
    We added some counters that we can get via BLE and this what we observed.
    One device ran a few times into the forced rejoined and finally hit the broken rejoin case and rebooted (good)
    One other device ran into the forced rejoin once and that's all. Device not visible on the network anymore.
    It seems to me that even if not in the broken rejoin logic the ZBOSS stack can be KO.
    Can you check with zigbee team if it would be safe to reset the device for any parent link failure ?
    KRKNWK-12017  doesn't seem top be enough.
    FYI, a few weeks ago we managed to reproduce with the serial output and when the parent link failure happened there were no ZB sleeping event at all anymore which makes me think the stack was dead.
    Thx
    Do you only get ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE once or do you get this signal multiple times when it fails? The best option is to have a failure counter that checks how many times the device has received ZB_NWK_COMMAND_STATUS_PARENT_LINK_FAILURE, and then have a threshold for when it should reset.
    Marte
