Hello guys,
I want to test SMP DFU function by uart. I use "E:\Spec\bluetooth\Nordic\nRF52820\ncs2.5.0\v2.5.0\zephyr\samples\subsys\mgmt\mcumgr\smp_svr" example and add below Macro in prj.conf.
Hello guys,
Hi Dejan,
I remove the existing build folder and rebuild again. Yes, I got the updated release .hex. But device still didn't run which means cannot output logs via uart.
BR,
Treacy
Hi Treacy,
Treacy said:I remove the existing build folder and rebuild again. Yes, I got the updated release .hex.
It seems that the build process was successful. Could you confirm?
Treacy said:But device still didn't run which means cannot output logs via uart.
Was flashing also successful? Did you get any errors during the process?
Dejan
The build process and flash program are all successful. The only problem is that I can't judge if the FW can run normally, because I think it should output logs when device start but unfortunatelly, no any logs print in UART
You could try to remove hci_rpmsg and add CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y to your child_image\mcuboot.conf file, and rebuild your project.
Dejan
