iOS CoreBluetooth reconnecting device with pair
now,i pairing my peripheral and Communication read/write data. but have some issue for disconnect/reconnect .
1.disconnect: when i disconnect (call didDisconnectPeripheral) the iOS not disconnect my peripheral why that not disconnect ? how to disconnect ?
2.reconnect: other i turn off my peripheral , and re-connect (connectperipheral) but can't read/write how to solve " 2013-12-05 21:16:52.206 Alarm Clock 1.0[1542:60b] CoreBluetooth[WARNING] is not a valid characteristic for peripheral "
iWatchApp.zip
  • I'm sorry, but I'm having some trouble understanding the problem here.
    First of all, as the person below says, you should not use directed advertising with iOS devices, as that will not work correctly.
    Secondly, from your app you should just do a regular service discovery each time you connect. If you are already bonded, iOS will most likely just return the cached values, without doing anything over the air.
    Thirdly, as I said, doing a cancelPeripheralConnection will not necessarily actually disconnect the link.
    If you still can't get things working, I'd be happy if you could upload your complete source code, either here or in a regular support case. It's not really possible to help you without it.
  • Hi, Previous issue, 1.reset power ,the device auto link 2.app write data get "cancelPeripheralConnect:self.currentPeripheral.peripheral]
    these is my App issue, it should be store the bond information and call retrievePeripheralsWithIdentifiers when you reconnect.
    follow attachment file:
