Flash area error while doing DFU using nRF Connect
Dear support team,
I am getting an error while performing DFU using nRF Connect.
[00:02:39.702,697] <inf> mcuboot_util: Swap type: none
[00:02:39.702,972] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
My SDK version is 2.4.2, I need to do DFU using BLE simultaneously, for that i tried to modify Example mcuboot_smp_ble_simultaneous , but without modifying anything, while performing DFU by compiling this code i am getting this error, Even after getting this error new imaged is flashed successfully after DFU. i don't know the reason. my complete serial log is attached bellow.
D: RDSR 40 QE 1 need 1: no-change
I: Starting bootloader
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
*** Booting Zephyr OS build 28a3fca7da5c ***
Change this to see it change.
[00:00:00.030,853] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,883] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,914] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,623] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,653] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,653] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Bluetooth initialized
Advertising successfully started
[00:02:39.978,576] <inf> mcuboot_util: Swap type: none
I: Swap type: perm
I: Swap type: perm
I: Image upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Copying the secondary slot to the primary slot: 0x1af50 bytes
D: writing magic; fa_id=4 off=0xf3ff0 (0xffff0)
D: erasing secondary header
D: erasing secondary trailer
I: Copying the secondary slot to the primary slot: 0x2e8d4 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Turned on network core
I: Turned off network core
ÿ*** Booting Zephyr OS build 28a3fca7da5c ***
Krishnachandran_Test....
[00:00:00.030,883] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,914] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,944] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,653] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,684] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,684] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
If any idea regarding this, please help. Thanks in advance.
  • is there any solution to exclude these workaround from code.?
  • This is still an issue in SDK 2.9.0, when you try to do an mcumgr image list or upload any FW, but it does not affect it's functionality.
    It is worth mentioning, that in some smaller firmware adding the flash_sim.overlay for the application with low memory consumption gets rid of the message, but in applications that consume more RAM, the message still appears:
    GW [15:40:55.824,859] <inf> [mcumgr smp] mcuboot_util: Image index: 0, Swap type: none
    GW [15:40:55.825,195] <inf> [mcumgr smp] mcuboot_util: Image index: 1, Swap type: none
    GW [15:40:55.825,195] <err> [mcumgr smp] mcumgr_img_grp: Failed to open flash area ID 3: -2
    GW [17:16:41.167,358] <inf> [mcumgr smp] mcuboot_util: Image index: 1, Swap type: none
    GW [17:16:43.895,568] <inf> [mcumgr smp] mcumgr_img_grp: Erased 0x36000 bytes of image slot
    GW [17:16:43.986,389] <inf> [mcumgr smp] mcumgr_img_grp: Erased 0x1000 bytes of image slot trailer
    The rest of the update works fine for both App and Net Core, but the error is off-putting.
    And even trying to build bigger consumption memory application won't build and fail with:
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `noinit' will not fit in region `RAM'
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `RAM' overflowed by 84764 bytes
    collect2.exe: error: ld returned 1 exit status
