Device crash when doing a software reset
I'm developing a software with the nRF Connect SDK v2.5.1. This software runs Matter on the nRF5340.
I need to reset the MCU from my app. To do so, I use the sys_reboot(SYS_REBOOT_COLD) function. But this makes the OS crash with the following trace:
uart:~$ E: IPC endpoint bind timed out
ASSERTION FAIL @ WEST_TOPDIR/zephyr/drivers/ieee802154/ieee802154_nrf5.c:1153
E: r0/a1:  0x00000004  r1/a2:  0x00000481  r2/a3:  0x2000ca30
E: r3/a4:  0x00000000 r12/ip:  0x00000000 r14/lr:  0x00023e0f
E:  xpsr:  0x69100000
E: s[ 0]:  0xffffffff  s[ 1]:  0x000134c5  s[ 2]:  0x00000000  s[ 3]:  0x00038607
E: s[ 4]:  0x00008000  s[ 5]:  0x000aeab4  s[ 6]:  0x000a6548  s[ 7]:  0x000aebf0
E: s[ 8]:  0x00000000  s[ 9]:  0x00072377  s[10]:  0x00008000  s[11]:  0x20027404
E: s[12]:  0x20002f40  s[13]:  0x00023e05  s[14]:  0x000ac36c  s[15]:  0x000aeab4
E: fpscr:  0x00000481
E: Faulting instruction address (r15/pc): 0x00072362
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
E: Current thread: 0x2000ca30 (main)
E: Halting system
Is there a way to make it better ?
  • The changes doesn't improve the result, here is the log with thread analysis a few seconds before the crash.
    uart:~$ Thread analyze:
     CHIP                : STACK: unused 4360 usage 1720 / 6080 (28 %); CPU: 1 %
          : Total CPU cycles used: 16408
     BT RX               : STACK: unused 1008 usage 192 / 1200 (16 %); CPU: 0 %
          : Total CPU cycles used: 0
     BT TX               : STACK: unused 696 usage 328 / 1024 (32 %); CPU: 0 %
          : Total CPU cycles used: 54
     thread_command      : STACK: unused 816 usage 208 / 1024 (20 %); CPU: 18 %
          : Total CPU cycles used: 256407
     thread_analyzer     : STACK: unused 544 usage 480 / 1024 (46 %); CPU: 0 %
          : Total CPU cycles used: 6329
     spinel_packet_send_thread: STACK: unused 840 usage 184 / 1024 (17 %); CPU: 0 %
     rx_q[0]             : STACK: unused 1288 usage 248 / 1536 (16 %); CPU: 0 %
          : Total CPU cycles used: 9
     openthread          : STACK: unused 2032 usage 2000 / 4032 (49 %); CPU: 0 %
          : Total CPU cycles used: 4657
     ot_radio_workq      : STACK: unused 1168 usage 816 / 1984 (41 %); CPU: 0 %
          : Total CPU cycles used: 1553
     nrf5_rx             : STACK: unused 1296 usage 688 / 1984 (34 %); CPU: 0 %
          : Total CPU cycles used: 39
     0x20006e88          : STACK: unused 336 usage 624 / 960 (65 %); CPU: 0 %
          : Total CPU cycles used: 2303
     sysworkq            : STACK: unused 1856 usage 192 / 2048 (9 %); CPU: 0 %
     shell_uart          : STACK: unused 1712 usage 336 / 2048 (16 %); CPU: 0 %
          : Total CPU cycles used: 43
     idle                : STACK: unused 184 usage 72 / 256 (28 %); CPU: 59 %
          : Total CPU cycles used: 838850
     main                : STACK: unused 1248 usage 2784 / 4032 (69 %); CPU: 19 %
          : Total CPU cycles used: 272747
     ISR0                : STACK: unused 856 usage 1192 / 2048 (58 %)
    I: Received command over UART
    W: Device will restart !
    E: r0/a1:  0x00000004  r1/a2:  0x00000481  r2/a3:  0x2000d018
    E: r3/a4:  0x00000000 r12/ip:  0x00000000 r14/lr:  0x00023fa3
    E:  xpsr:  0x69100000
    E: s[ 0]:  0xffffffff  s[ 1]:  0x000134e1  s[ 2]:  0x00000000  s[ 3]:  0x000388c3
    E: s[ 4]:  0x00008000  s[ 5]:  0x000af25c  s[ 6]:  0x000a6b84  s[ 7]:  0x000af398
    E: s[ 8]:  0x00000000  s[ 9]:  0x000728a3  s[10]:  0x00008000  s[11]:  0x20026344
    E: s[12]:  0x20002f40  s[13]:  0x00023f99  s[14]:  0x000aca20  s[15]:  0x000af25c
    E: Faulting instruction address (r15/pc): 0x0007288e
    E: Current thread: 0x2000d018 (main)
    E: Halting system
    I think that to reproduce, you can use the Matter light bulb sample on a nRF5340DK, commission it into a Matter over Thread fabric then trigger the reset from a command or such.
  • I stumbled upon this thread which looks to be pretty similar issue to yours. The cause here seems to be the issue in the DFU.
    Can you check if you also need to change the clock config that suits your board?
  • My projects doesn't uses DFU nor McuBoot as I don't have an external flash. But the following configs are set.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
  • We will try to reproduce this at our end and will come back to you mostly next week.
  • This could be related to this and this errata. It is possible that the appcore is resetting but the netcore is not and the serial communication with the app and the netcore is falling apart. Try implementing the workarounds for that erratas at the init code and see if that helps.
