Multiple IPC channels
Referencing this link here, I am looking for any updates to using IPC for some custom inter-core communication WHILE ALSO running Bluetooth on an nrf5340.
Long story short, I have a project with custom code for both the cpu_app and cpu_net cores of an nrf5340, and I am looking for a way to communicate between both. Right now, the cpu_net code is running the hci_rpmsg sample so that I can use BLE from the application core. I have not found a clean way to modify this to provide some hooks for my custom use case, nor do I want to try.
If there are any updates on being able to use a custom IPC channel and BLE at the same time, or if IPC is not the right abstraction layer to go through, please let me know! The link I provided mention using the BTS but I am not sure how that is relevant or possible.
I know that there are some complex structures being put to use here and I have tried to spend some time learning it but perhaps there is an easy-to-follow overview of inter-process communication that shows us how IPC, RMPSG, ICMSG, MBOX, shared SRAM and all other abstraction layers play together.
Thank you much.
  • The hci_rpmsg uses some IPC channels.
    If you are using e.g. channel 0, then try using a different one, e.g. 5 , and see if that improves anything.
  • Sigurd,
    That makes sense, but I just tried a few different channels (channel 2, 5, and 15) and they all did not work. I tried to inspect the peripherals at a breakpoint to see which are being used but I was unable to figure it out. How can I tell which ones are being used by HCI?
    What else can I look for to prevent this issue? I used the code from the nrf53_sync_rtc sample - is there an example of this merged with a BLE sample?
    Thanks.
  • Hi!
    Did you do it on both cores? If yes, then I will try to reproduce and debug this.
    I tried just reading out the IPC registers, looks like channel 0 and 1 was used.
  • Yes I tried on both cores. If you can try it that would be helpful, thanks.
  • Hi!
    I was able to get it to run in a BLE application. I'm not seeing any crashes here.
    Did some minor modifications to the original example code.
    Network core:
    On hci_rpmsg sample I added this:
    #include <nrfx_timer.h>
    #include <nrfx_dppi.h>
    #include <nrfx_ipc.h>
    // Get a reference to the TIMER instance
    static const nrfx_timer_t sync_timer = NRFX_TIMER_INSTANCE(2);
    // Interrupt handler for the timer
    // NOTE: This callback is triggered by an interrupt. Many drivers or modules in Zephyr can not be accessed directly from interrupts,
    //		 and if you need to access one of these from the timer callback it is necessary to use something like a k_work item to move execution out of the interrupt context.
    void sync_timer_event_handler(nrf_timer_event_t event_type, void * p_context)
    	static int counter = 0;
    	switch(event_type) {
    		case NRF_TIMER_EVENT_COMPARE0:
    			printk("Sync timer callback. Counter = %d\n", counter++);
    // Function for initializing the TIMER peripheral using the nrfx driver
    static void sync_timer_init(void)
    	uint32_t base_frequency = NRF_TIMER_BASE_FREQUENCY_GET(sync_timer.p_reg);
    	nrfx_timer_config_t timer_config = NRFX_TIMER_DEFAULT_CONFIG(base_frequency);
    	timer_config.bit_width = NRF_TIMER_BIT_WIDTH_16;
    	int err = nrfx_timer_init(&sync_timer, &timer_config, sync_timer_event_handler);
    	if (err != NRFX_SUCCESS) {
    		printk("Error initializing timer: %x\n", err);
    	// Trigger a callback 10us after the timer is reloaded by the appcore
    	nrfx_timer_extended_compare(&sync_timer, NRF_TIMER_CC_CHANNEL0, 10, 0, true);
    	IRQ_DIRECT_CONNECT(TIMER2_IRQn, 1, nrfx_timer_2_irq_handler, 0);
    	irq_enable(TIMER2_IRQn);
    static void synchronized_start_init(void)
    	uint8_t dppi_ch;
    	// DPPI init
    	nrfx_dppi_channel_alloc(&dppi_ch);
    	NRF_TIMER0->SUBSCRIBE_CLEAR = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_ch;
    	nrfx_dppi_channel_enable(dppi_ch);
    	// IPC init
    	uint8_t ipc_ch = 5;
    	NRF_IPC->RECEIVE_CNF[ipc_ch] = BIT(ipc_ch);
    	NRF_IPC->PUBLISH_RECEIVE[ipc_ch] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_ch;
    	nrfx_timer_enable(&sync_timer);
    	int err;
    	sync_timer_init();
    	synchronized_start_init();
    Added to prj.conf (samples\bluetooth\hci_rpmsg\prj.conf)
    CONFIG_NRFX_DPPI=y
    CONFIG_NRFX_EGU1=y
    CONFIG_NRFX_IPC=y
    CONFIG_NRFX_TIMER2=y
    Application core:
    On the BLE app:
    #include <nrfx_egu.h>
    		case NRF_TIMER_EVENT_COMPARE1:
    // Function for scheduling repeated callbacks from the timer
    static void sync_timer_repeated_configure(uint32_t timeout_us)
    	nrfx_timer_extended_compare(&sync_timer, NRF_TIMER_CC_CHANNEL0, timeout_us,
                                    NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    	nrfx_timer_extended_compare(&sync_timer, NRF_TIMER_CC_CHANNEL1, 10, 0, true);
    	uint8_t dppi_ch;
    	// DPPI init
    	//NRF_EGU1->PUBLISH_TRIGGERED[0] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_ch;
    	NRF_TIMER2->PUBLISH_COMPARE[0] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_ch;
    	// IPC init
    	uint8_t ipc_ch = 5;
    	NRF_IPC->SEND_CNF[ipc_ch] = BIT(ipc_ch);
    	NRF_IPC->SUBSCRIBE_SEND[ipc_ch] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_ch;
    static void synchronized_start_activate(void)
    	NRF_TIMER2->TASKS_START = 1;
    Added to prj.conf
    CONFIG_NRFX_DPPI=y
    CONFIG_NRFX_EGU1=y
    CONFIG_NRFX_IPC=y
    BR,
    Sigurd
