im trying to do the first exercise in DevAcademy (https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-2-bluetooth-le-advertising/topic/advertising-process/) and i downloaded the relevent git aip file and opened a new project. its path is: C:\nordic\BLEexample\bt-fund\lesson1\blefund_less1_exer1
and my zephyr files are in : C:\ncs\v1.9.0\zephyr\include\sys\printk.h
the CMakeLists.txt are are as downloaded:
# Copyright (c) 2018 Nordic Semiconductor
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(NONE)
# NORDIC SDK APP START
target_sources(app PRIVATE
src/main.c
# NORDIC SDK APP END
zephyr_library_include_directories(.)
and i the build fails:
Building blefund_less1_exer1
west build --build-dir c:/nordic/BLEexample/bt-fund/lesson1/blefund_less1_exer1/build_1 c:/nordic/BLEexample/bt-fund/lesson1/blefund_less1_exer1
[59/215] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DBUILD_VERSION=v2.7.99-ncs1 -DDEVELOP_IN_NRF52833 -DKERNEL -DNRF52820_XXAA -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../. -IC:/ncs/v1.9.0/nrf/drivers/mpsl/clock_control -IC:/ncs/v1.9.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v1.9.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/ncs/v1.9.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v1.9.0/zephyr/subsys/bluetooth -IC:/ncs/v1.9.0/zephyr/subsys/settings/include -IC:/ncs/v1.9.0/nrf/include -IC:/ncs/v1.9.0/nrf/lib/multithreading_lock/. -IC:/ncs/v1.9.0/nrf/subsys/bluetooth/controller/. -IC:/ncs/v1.9.0/zephyr/drivers/flash -IC:/ncs/v1.9.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v1.9.0/modules/hal/nordic/nrfx -IC:/ncs/v1.9.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v1.9.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v1.9.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v1.9.0/modules/debug/segger/SEGGER -IC:/ncs/v1.9.0/modules/debug/segger/Config -IC:/ncs/v1.9.0/zephyr/modules/segger/. -IC:/ncs/v1.9.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v1.9.0/nrfxlib/mpsl/include -IC:/ncs/v1.9.0/nrfxlib/mpsl/include/protocol -I../~C:/ncs/v1.9.0/zephyr/include -IC:/ncs/v1.9.0/nrfxlib/softdevice_controller/include -IC:/ncs/v1.9.0/zephyr/include/posix -isystem C:/ncs/v1.9.0/zephyr/lib/libc/minimal/include -isystem c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -Os -imacros C:/nordic/BLEexample/bt-fund/lesson1/blefund_less1_exer1/build_1/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros C:/ncs/v1.9.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/nordic/BLEexample/bt-fund/lesson1/blefund_less1_exer1=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v1.9.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v1.9.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
../src/main.c:11:10: fatal error: zephyr/sys/printk.h: No such file or directory
11 | #include <zephyr/sys/printk.h>
compilation terminated.
[68/215] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\nordic\BLEexample\bt-fund\lesson1\blefund_less1_exer1\build_1'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
any idea why?
