nRF5340 Audio DK: Audio Loosing sync both with I2S and U
Hi All,
       I have been using nRF5340 DK audio with toolchain Version 2.5.2 and using the Audio Demo (nrf5340_audio_dk_nrf5340_cpuapp_common) for gateway and headset (Broadcast source and Sink). I have not changed anything and used script to build and flash the binaries.
  • The source and sink is able to manage sync only for ~10s in I2S case (Audio in at Source using I2S).
  • The source and sink is able to manage sync for ~ 1s in USB case.
This means audio plays for 10s/1s and then the sink is unable to get the audio afterwards.
As it is experimental SDK any suggestion to improve it or am I missing any configuration.
Regards
Sainath
  •          nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.5.2
             Cmake run : Wed Feb 07 13:56:49 2024
    HL [00:00:00.257,507] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.257,507] <inf> fw_info: HEADSET left device
    HL [00:00:00.268,127] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.306,488] <inf> bt_mgmt_ctlr_cfg: Controller: LL_ACS_NRF53. Version: 3424
    HL [00:00:00.308,471] <inf> bt_mgmt: Local identity addr: C5:D6:54:30:04:B0 (random)
    HL [00:00:00.344,757] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:00.437,866] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:00.437,866] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:00.618,377] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:01.417,510] <inf> broadcast_sink: Syncing to broadcast stream index 0
    HL [00:00:01.417,694] <inf> streamctrl_broadcast_sink: Presentation delay 10000 us is set
    HL [00:00:02.217,803] <inf> broadcast_sink: Stream index 0 started
    HL [00:00:02.217,803] <inf> broadcast_sink: Codec config for LC3:
    HL [00:00:02.217,834] <inf> broadcast_sink:     Frequency: 48000 Hz
    HL [00:00:02.217,834] <inf> broadcast_sink:     Frame Duration: 10000 us
    HL [00:00:02.217,834] <inf> broadcast_sink:     Octets per frame: 120 (96000 kbps)
    HL [00:00:02.217,834] <inf> broadcast_sink:     Frames per SDU: 1
    HL [00:00:02.217,864] <inf> broadcast_sink:     Channel allocation: 0x1
    HL [00:00:02.219,726] <wrn> le_audio_rx: Not in streaming state, throwing data: 1
    HL [00:00:02.229,705] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:02.231,689] <wrn> audio_datapath: Data received, total underruns: 2
    HL [00:00:02.242,675] <wrn> audio_datapath: Data received, total underruns: 3
    HL [00:00:02.329,711] <inf> audio_datapath: Drft comp state: OFFSET
    HL [00:00:02.930,145] <inf> audio_datapath: Drft comp state: LOCKED
    HL [00:00:02.939,208] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:03.049,194] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:00:03.189,208] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:03.199,218] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:03.309,234] <inf> audio_datapath: Pres comp state: LOCKED
    HL [00:00:10.378,540] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:10.380,615] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:10.380,615] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:10.380,645] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:10.395,294] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:10.618,072] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:10.618,591] <inf> broadcast_sink: Stream stopped by user
    HL [00:00:10.618,591] <inf> broadcast_sink: Stream index 0 stopped. Reason: 22
    HL [00:00:10.618,927] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:10.621,002] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:10.621,032] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:10.621,032] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:10.624,145] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:10.645,294] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:10.818,115] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:10.818,389] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:10.820,434] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:10.820,434] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:10.820,465] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:10.834,075] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:11.022,369] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:11.022,644] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:11.024,719] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:11.024,749] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:11.024,749] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:11.025,299] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:11.220,153] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:11.220,428] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:11.222,473] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:11.222,503] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:11.222,503] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:11.285,339] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:11.618,164] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:11.618,408] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:11.620,483] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:11.620,483] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:11.620,513] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:11.638,458] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:11.818,176] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:11.818,450] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:11.820,495] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:11.820,495] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:11.820,495] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:11.835,357] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:12.018,188] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:12.018,432] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:12.020,507] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:12.020,507] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:12.020,507] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:12.045,379] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:12.218,200] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:12.218,444] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:12.220,520] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:12.220,520] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:12.220,520] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:12.225,402] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:12.618,225] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:12.618,469] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:12.620,544] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:12.620,544] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:12.620,544] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:12.645,385] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:12.818,206] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:12.818,481] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:12.820,556] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:12.820,556] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:12.820,556] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:12.847,930] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:13.220,306] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:13.220,581] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:13.222,625] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:13.222,625] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:13.222,656] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:13.246,063] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:13.418,243] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:13.418,518] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:13.420,593] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:13.420,593] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:13.420,593] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:13.425,445] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:13.818,267] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:13.818,542] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:13.820,587] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:13.820,617] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:13.820,617] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:13.888,580] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:14.037,261] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:14.037,536] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:14.039,581] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:14.039,581] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:14.039,611] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:14.134,246] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:14.218,292] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:14.218,566] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:14.220,611] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:14.220,611] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:14.220,642] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:14.246,124] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:14.418,304] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:14.418,579] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:14.420,623] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:14.420,654] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:14.420,654] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:14.465,515] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:14.818,328] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:14.818,603] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:14.820,648] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:14.820,678] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:14.820,678] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:14.825,531] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:15.019,012] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:15.019,256] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:15.021,331] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:15.021,331] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:15.021,331] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:15.067,443] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:15.218,353] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:15.218,627] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:15.220,672] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:15.220,672] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:15.220,703] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:15.254,302] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:15.418,365] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:15.418,640] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:15.420,684] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:15.420,684] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:15.420,715] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:15.435,577] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:15.618,377] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:15.618,652] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:15.620,697] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:15.620,697] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:15.620,727] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:15.638,702] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:16.020,202] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:16.020,477] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:16.022,552] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:16.022,552] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:16.022,552] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:16.048,095] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:16.218,414] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:16.218,688] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:16.220,733] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:16.220,733] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:16.220,764] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:16.248,718] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:16.618,438] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:16.618,713] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:16.620,758] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:16.620,758] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:16.620,758] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:16.645,629] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:16.818,481] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:16.818,725] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:16.820,800] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:16.820,800] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:16.820,831] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:16.864,166] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:17.018,463] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:17.018,707] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:17.020,782] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:17.020,782] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:17.020,782] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:17.045,654] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:17.218,475] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:17.218,719] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:17.220,825] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:17.220,825] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:17.220,825] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:17.255,645] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:17.418,487] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:17.418,731] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:17.420,837] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:17.420,837] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:17.420,837] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:17.445,678] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:17.618,499] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:17.618,743] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:17.620,819] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:17.620,819] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:17.620,849] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:17.625,671] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:17.819,183] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:17.819,458] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:17.821,533] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:17.821,533] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:17.821,533] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:17.835,693] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:18.018,524] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:18.018,768] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:18.020,843] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:18.020,874] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:18.020,874] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:18.047,576] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:18.218,505] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:18.218,780] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:18.220,886] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:18.220,886] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:18.220,886] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:18.274,261] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    HL [00:00:18.418,518] <inf> streamctrl_broadcast_sink: PA synced
    HL [00:00:18.418,792] <inf> streamctrl_broadcast_sink: PA sync lost
    HL [00:00:18.420,867] <inf> bt_mgmt_scan: Local addr: C5:D6:54:30:04:B0 (random). May time out. Updates not printed
    HL [00:00:18.420,898] <inf> bt_mgmt_scan: Scanning successfully started
    HL [00:00:18.420,898] <inf> streamctrl_broadcast_sink: Restarted scanning for broadcaster
    HL [00:00:18.445,709] <inf> bt_mgmt_scan: Broadcast source NRF5340_BROADCASTER found, id: 0x23a689
    Logs for Sink
  • GW [00:00:00.256,286] <inf> fw_info:
             Cmake run : Fri Feb 09 15:53:18 2024
    GW [00:00:00.256,286] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.256,317] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.266,937] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.303,070] <inf> bt_mgmt_ctlr_cfg: Controller: LL_ACS_NRF53. Version: 3424
    GW [00:00:00.304,321] <inf> bt_mgmt: Local identity addr: FA:52:F7:5D:AE:A8 (random)
    GW [00:00:00.332,580] <inf> broadcast_source: Enabling broadcast_source NRF5340_BROADCASTER
    GW [00:00:00.335,968] <inf> bt_mgmt_adv: Local addr: 3A:E4:AC:51:5C:3C (random)
    GW [00:00:00.337,951] <inf> streamctrl_brcast_src: Ext adv ready
    GW [00:00:00.338,531] <inf> bt_mgmt_adv: Advertising successfully started
    GW [00:00:00.456,390] <inf> broadcast_source: Broadcast source 0x2000bc98 started
    GW [00:00:00.456,665] <inf> broadcast_source: Broadcast source 0x2000bcbc started
    GW [00:00:00.483,337] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:00.583,343] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:00.584,350] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:00.684,356] <inf> audio_datapath: Drft comp state: OFFSET
    GW [00:00:01.184,692] <inf> audio_datapath: Drft comp state: LOCKED
    Link for source
  • I have updated the logs , kindly check below and let me know incase anyother details is required
    Logs Scenario : Audio over I2S on Source <-> Sink
  • Great. Sorry about the delay from my side here, things are really busy these days.
    So I heard that this can theoretically happen with the current Audio controller, as it prioritizes ISO over ACL. Though for it to be this bad your connection would really have to so suffering. Do you just have the two audio devices next to each other on a desk, or far away from each other? Is there anything close by that could interfere with the connection? If the DKs were wrapped in tin-foil it might explain this.
    Elfving
