Problem on nRF9160 making a modified lte_ble_gateway sample
Our application on a nRF9160 to act as intermediary between an AWS cloud and another nRF devicee over bluetooth.  So I attempted to merge the bluetooth IOT sample with the bluetooth portion lte_ble_gateway sample
When I tried running this I got this crash in the early portion of the bluetooth intialization, before any IOT code is running.
[00:00:00.251,251] <inf> health_hub: The AWS IoT sample started, version: v1.0.0
[00:00:00.251,281] <inf> hp_ble: Initializing Bluetooth..
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:338
command opcode 0x0c03 timeout with err -11
[00:00:10.251,617] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000002
[00:00:10.251,647] <err> os: r3/a4: 0x20011498 r12/ip: 0x00000010 r14/lr: 0x00020a35
[00:00:10.251,647] <err> os: xpsr: 0x41000000
[00:00:10.251,678] <err> os: Faulting instruction address (r15/pc): 0x00020a40
[00:00:10.251,708] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:10.251,739] <err> os: Current thread: 0x20014010 (unknown)
*** Booting nRF Connect SDK v2.5.1 ***Resetting system
    net_buf_put(&bt_dev.cmd_tx_queue, net_buf_ref(buf));
    err = k_sem_take(&sync_sem, HCI_CMD_TIMEOUT);
    BT_ASSERT_MSG(err == 0, "command opcode 0x%04x timeout with err %d", opcode, err);
Somewhere in the k_sem_take()  we get that error 11 but it isn't clear what it is looking for at that point and stepping in doesn't work well.
Any ideas of what sort of problem can give this error?
Here is the prj.conf in case this is a missing configuration problem or something
# Copyright (c) 2020 Nordic Semiconductor ASA
#CONFIG_DEBUG=y
# General
CONFIG_LOG=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_HW_ID_LIBRARY=y
CONFIG_ASSERT=y
CONFIG_JSON_LIBRARY=y
# Heap and stacks
#CONFIG_HEAP_MEM_POOL_SIZE=8192
#CONFIG_MAIN_STACK_SIZE=4096
#CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
#CONFIG_BOOTLOADER_MCUBOOT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=y
CONFIG_NET_IPV4=y
CONFIG_NET_CONNECTION_MANAGER=y
# AWS IoT library
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_STATIC="my-thing"
CONFIG_AWS_IOT_BROKER_HOST_NAME="xxx.amazonaws.com"
CONFIG_AWS_IOT_SEC_TAG=201
CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=2
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
CONFIG_AWS_IOT_LAST_WILL=y
# MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
CONFIG_MQTT_KEEPALIVE=1200
CONFIG_MQTT_CLEAN_SESSION=y
# Console for user association
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_GETCHAR=y
# Enable Bluetooth stack and libraries
CONFIG_BT=y
CONFIG_BT_H4=y
CONFIG_BT_WAIT_NOP=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
# Update Data Length and MTU (BT_L2CAP_RX_MTU = CONFIG_BT_BUF_ACL_RX_SIZE - BT_L2CAP_HDR_SIZE)
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
# Little FS
# Optionally force the file system to be recreated
# CONFIG_APP_WIPE_STORAGE=y
# Let __ASSERT do its job
CONFIG_DEBUG=n
#CONFIG_FLASH=n
#CONFIG_FLASH_MAP=n
#CONFIG_FLASH_PAGE_LAYOUT=n
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
# CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
  • If I made the source for these projects available on GitHub would be be able to look at it yourself as well?  This is taking more time and we seem to have even gone backwards a bit, as the device tree wasn't complaining before.  I still don't see why the sample of aws_iot and dev_gateway seem to be so fundamentally incompatible.
  • ../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/bluetooth/libdrivers__bluetooth.a(h4.c.obj):C:/ncs/v2.5.1/zephyr/drivers/bluetooth/hci/h4.c:560: more undefined references to `__device_dts_ord_118' follow
    collect2.exe: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\PhaseMargin\HealthPatch\HealthHub_Dev\HealthHub_NordicDev\HealthHub\build_1'
    ------------- Device Tree Includes --------------
    * 116 /soc/peripheral@40000000/spi@b000/mx25r6435f@1
    * 117 /soc/peripheral@40000000/uart@a000
    * 118 /soc/peripheral@40000000/uart@a000/nrf-sw-lpuart
    * Definitions derived from these nodes in dependency order are next,
    * followed by /chosen nodes.
    ------------  project zephyr.dts
    chosen {
    zephyr,entropy = &psa_rng;
    zephyr,flash-controller = &flash_controller;
    zephyr,console = &uart0;
    zephyr,shell-uart = &uart0;
    zephyr,uart-mcumgr = &uart0;
    zephyr,flash = &flash0;
    zephyr,sram = &sram0_ns;
    zephyr,code-partition = &slot0_ns_partition;
    zephyr,bt-uart = &lpuart;
    nordic,modem-trace-uart = &uart1;
    uart2: uart@a000 {
    reg = < 0xa000 0x1000 >;
    interrupts = < 0xa 0x1 >;
    status = "okay";
    pinctrl-0 = < &uart2_default_alt >;
    pinctrl-1 = < &uart2_sleep_alt >;
    current-speed = < 0xf4240 >;
    lpuart: nrf-sw-lpuart {
    compatible = "nordic,nrf-sw-lpuart";
    status = "okay";
    req-pin = < 0x15 >;
    rdy-pin = < 0x13 >;
    ------------  gateway project zephyr.dts
    chosen {
    uart2: uart@a000 {
    status = "okay";
    status = "okay";
    req-pin = < 0x15 >;
    rdy-pin = < 0x13 >;
    Why can't it find the device tree reference in the other project?
  • Hello again,
    I was under the impression you were doing steady progress, and that you were getting further. But if that is not the case I can try also, not entirely sure if I am able to do so before the weekend since I am out of office on Friday.
    Kenneth
