I want to integrate the PDM microphone with thingy53, I found no particular sample code for it
Would be needing help from scratch
Hi Rakshita
I set the PDM_CLK to P0.08 and the data pin to P0.09, as you can see from the overlay:
psels = <NRF_PSEL(PDM_CLK, 0, 8)>, <NRF_PSEL(PDM_DIN, 0, 9)>;
Which SDK version are you using to build it?
Can you share the full build output with me so I can try to figure out what is happening?
Please use the Insert -> Code feature in devzone to add a larger block of text, or attach the build output as a text file.
Best regards
Torbjørn
Yes but as per the thingy's schematic the clk pin is P1.09 and data pin is P0.27
sdk v2.5.2
Executing task: nRF Connect: Build: dmic_thingy53/build (active) Building dmic_thingy53 west build --build-dir c:/nrf/samples/bluetooth/dmic_thingy53/build c:/nrf/samples/bluetooth/dmic_thingy53 -- west build: generating a build system Loading Zephyr default modules (Zephyr base (cached)). -- Application: C:/nrf/samples/bluetooth/dmic_thingy53 -- CMake version: 3.20.5 -- Cache files will be written to: C:/ncs/v2.5.2/zephyr/.cache -- Zephyr version: 3.4.99 (C:/ncs/v2.5.2/zephyr) -- Found west (found suitable version "1.1.0", minimum required is "0.14.0") -- Board: thingy53_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk) -- Found BOARD.dts: C:/ncs/v2.5.2/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp.dts -- Found devicetree overlay: C:/nrf/samples/bluetooth/dmic_thingy53/boards/thingy53_nrf5340_cpuapp.overlay devicetree error: pinctrl-names property in /soc/peripheral@50000000/pdm@26000 in C:/ncs/v2.5.2/zephyr/misc/empty_file.c has 1 strings, expected 2 strings -- In: C:/nrf/samples/bluetooth/dmic_thingy53/build/zephyr, command: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe;C:/ncs/v2.5.2/zephyr/scripts/dts/gen_defines.py;--dts;C:/nrf/samples/bluetooth/dmic_thingy53/build/zephyr/zephyr.dts.pre;--dtc-flags;'-Wno-unique_unit_address_if_enabled';--bindings-dirs;C:/ncs/v2.5.2/nrf/dts/bindings;C:/ncs/v2.5.2/zephyr/dts/bindings;--header-out;C:/nrf/samples/bluetooth/dmic_thingy53/build/zephyr/include/generated/devicetree_generated.h.new;--dts-out;C:/nrf/samples/bluetooth/dmic_thingy53/build/zephyr/zephyr.dts.new;--edt-pickle-out;C:/nrf/samples/bluetooth/dmic_thingy53/build/zephyr/edt.pickle;--vendor-prefixes;C:/ncs/v2.5.2/nrf/dts/bindings/vendor-prefixes.txt;--vendor-prefixes;C:/ncs/v2.5.2/zephyr/dts/bindings/vendor-prefixes.txt -- Configuring incomplete, errors occurred! CMake Error at C:/ncs/v2.5.2/zephyr/cmake/modules/dts.cmake:279 (message): gen_defines.py failed with return code: 1 Call Stack (most recent call first): C:/ncs/v2.5.2/zephyr/cmake/modules/zephyr_default.cmake:129 (include) C:/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) C:/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate) CMakeLists.txt:5 (find_package) FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe '-Bc:\nrf\samples\bluetooth\dmic_thingy53\build' -GNinja '-Sc:\nrf\samples\bluetooth\dmic_thingy53' * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Can you tell me what to do next, I am kind of stuck on this microphone thing only
There is also an error in main function
Can u please help me out to solve it
