I want to integrate the PDM microphone with thingy53, I found no particular sample code for it
Would be needing help from scratch
Hi
Rakshita said:Can u tell me how to attach a zip file
You can just drag drop a file into the reply window. Alternatively you can click on Insert -> Image/Video/File
Rakshita said:I went through the snoring example and added the necessary files into my code so right now getting the attached below result
This looks like real audio data to me, just very low amplitude. You would expect values that oscillate between positive and negative values, like in your log.
I also did a quick test changing my modified dmic sample to use the proper PDM pins, and I seem to get valid audio data as well (but I haven't verified this properly by playing the audio back).
Best regards
Torbjørn
So should I change the gain value?
And what about this
RMS value: 43.991271
RMS value: 54.246826
RMS value: 75.447407
RMS value: 97.405862
RMS value: 99.503123
RMS value: 99.571268
RMS value: 478.356399
RMS value: 492.462257
RMS value: 501.362197
RMS value: 502.130812
RMS value: 491.400654
RMS value: 473.611738
If some sound is also detected there should be a threshold value right to compare so how is that decided
