Infinite build loop with some examples, dirty build.ninja
With multiple of the provided samples with the SDK, I'm getting a repeated build loop that ultimately fails due to a remaining "dirty build.ninja". This is primarily with some Edge Impulse samples, so I've posted there as well, but these samples are provided in the nRF SDK.
The build output is as follows, from the Wrapper sample using a custom replication of the FOMO sample:
[143/158] No update step for 'edge_impulse_project'
[144/158] Performing patch step for 'edge_impulse_project'
[145/158] Performing configure step for 'edge_impulse_project'
-- Found assembler: /opt/nordic/ncs/toolchains/20d68df7e5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build/edge_impulse/src/edge_impulse_project-build
[145/158] Performing build step for 'edge_impulse_project'
[0/1] Re-running CMake...
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
ninja: error: manifest 'build.ninja' still dirty after 100 tries
FAILED: edge_impulse/src/edge_impulse_project-stamp/edge_impulse_project-build edge_impulse/src/edge_impulse_project-build/libedge_impulse.a
cd /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build/edge_impulse/src/edge_impulse_project-build && /opt/nordic/ncs/toolchains/20d68df7e5/Cellar/cmake/3.20.5/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/20d68df7e5/bin/cmake --build /opt/nordic/ncs/v2.5.2/nrf/samples/edge_impulse/wrapper_2/build
If anyone has seen this before or has a guess of how to fix it, that'd be greatly appreciated.
  • I haven't tried the data_forwarder example as I have no sensors so I'm only using the Wrapper example. It was only reproducible with EI generated code for certain types of projects.
    I ended up figuring it out finally. I'll add that here or edit the original post so anyone else in the future can fix it as well.
  • The issue ended up being from a compile time error that was hidden in the print statements most of the time I tried.
    /opt/nordic/ncs/v2.5.2/nrf/lib/edge_impulse/ei_wrapper.cpp: At global scope:
    /opt/nordic/ncs/v2.5.2/nrf/lib/edge_impulse/ei_wrapper.cpp:56:31: error: static assertion failed
       56 | BUILD_ASSERT(DATA_BUFFER_SIZE > INPUT_WINDOW_SIZE);
    /opt/nordic/ncs/v2.5.2/zephyr/include/zephyr/toolchain/gcc.h:70:50: note: in definition of macro 'BUILD_ASSERT'
       70 | #define BUILD_ASSERT(EXPR, MSG...) static_assert(EXPR, "" MSG)
    /opt/nordic/ncs/v2.5.2/nrf/lib/edge_impulse/ei_wrapper.cpp:56:31: note: the comparison reduces to '(2500 > 9216)'
    By adding CONFIG_EI_WRAPPER_DATA_BUF_SIZE=[bigger size] to the prj.conf I was able to fix this issue.
    Edit (an hour later): This only fixed it for the one project, the Continuous Motion project that was working before is not working currently.
  • Thanks , I've just encountered this issue today
  • Glad to hear, I honestly forgot that I'd put a conclusion to this issue. I'll go ahead and mark it as solved, hopefully that allows it to stay around for others to look at when needed.
    This issue was so weird, it was I guess a compile time error that was shown to the developer as a very different issue. And it doesn't help when there are multiple layers of build systems.
