Which is the best way of sending the data read from a sensor?
I need to read the data from an acceleration sensor. I tried with a custom program of mine to simulate some data, but it is delaying too much.
I tried reducing the notification interval, but sometimes it just jumps numbers so to say, it should show 1,2,3. But now it shows 1,3,5.
Am I missing something?
Thank you!
  • Hi Karl,
    Again, thank you for your detailed and helpful answer.
    Which value did you change here exactly?
    The value that I changed here was the Notify interval.
    I went through the code that you mentioned, and it looks like it can be really helpful, I just have some doubts:
    In the function mentioned (ble_write thread), there is no notify_interval, this is not necessary for notifications? I also saw that the function being used is bt_nus_send(), here I could also use the bt_gatt_notify function? Or this function(bt_nus_send) is specific for sending buffers?
    And last, I guess that instead of the line 638, instead of using k_fifo_get, I should put the function which with I will read the information of my sensor? or it should be the function that will put the information in the buffer?
    Sorry for so many questions, but thank you for your help!
    Adrian Lopez
  • Hello Adrian Lopez,
    No need to apologize, I am happy to help! :)
    By this I assume you mean the connection interval?
    It would be great if you could be explicit about the changes you made, so that I can know with certainty which value or parameter was changed, since it seems to me that the change was unsuccessful.
    You are correct that there is no notify_interval directly, and this is because the peripheral will send the notification in the next possible connection event - there is one connection event each time the connection interval has elapsed.
    So for example, if you queue a notification for sending every 500 ms, and your connection have a connection interval of 250 ms, then your peripheral will send one empty packet in the first connection event (because it did not have any notification to send), and then send queued notification in the next connection event, then it will revert to sending an empty packet again to maintain the connection until a new notification is queued for sending.
    You are also correct that this particular example uses the bt_nus_send function to send the notification, because the example is made to showcase the use of the Nordic UART service in particular - but if you look into the implementation of this service you will see that it also uses the bt_gatt_notify functionality behind the scenes :)
    This depends on the requirements to your application - such as whether it would be acceptable or perhaps important to drop older sensor measurements, or whether it is important that all measurements make it across the link.
    In your case, I would recommend using a FIFO buffer in the same way that the NUS does, since this lets you gather data for sending independently of the BLE notification queueing.
    Karl
  • Hi Karl,
    No, here I meant that there was a sleeping function after the notification for delaying the notification process. But now I deleted it. I also created a buffer of size 80 and each position has a 3 variable struct. Now I am able to get 11 buffers per second (That is 2640 bytes per second which is nothing if we convert it to Mbps). To be able to achieve this, because I was getting only 2 buffers per second, in the prj.conf I changed the following parameters:
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=10
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=10
    Why am i getting so little?
    Would it be useful for me to send my code?
    Adrian Lopez
    This way it does not actually matter when you queue the notification, since the check in essence is 'is there a notification ready for sending' when a connection event is upcoming.
    Those kconfig options only sets the peripheral's preferences, while it is still the central that decides which connection interval that will actually be used. What does your central's device log say when you connect to your peripheral device?
    Does it log the used connection parameters that it uses?
    The peripheral may send a connection parameter update request, to suggest to use its preferred connection parameters, but the central may reject this update request and instead use whichever connection parameters it would like. The peripheral may then either accept this, or terminate the connection.
    I think the key to your throughput in this case is the connection parameters. Please change these on your central device, or make sure that the central device will accept any connection parameter update request from the peripheral, and then use one of the connection parameter configurations shown here to achieve higher throughput.
    Karl
  • Hi Karl,
    When I connect my device it prints this notifications in the nrf Connect app:
    • PHY updated (TX: LE 2M, RX: LE 2M)
    • Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 10000ms)
    And in the terminal I am getting this messages:
    • MTU exchange successful, new MTU: 244 bytes
    • Data length updated. Length 251/27 bytes, time 2120/2120 us
    So I think that the central is accepting the changes successfully and is setting the same parameters as in the link you provided me.
    I will leave here a stackoverflow link that I created in case you can have a look at some of the code I have.
     stackoverflow.com/.../nrf52840-not-achieving-sending-2-mbps
    Thank you so much for your time.
    Adrian Lopez.
