casting pointers
Hello!
I've bumped into the issue with casting...
main.c:
static ble_gap_addr_t addr0;
static uint16_t *p_host0;
int main(void) {
    p_host0 = (void*)&addr0.addr[0];
works fine, but...
beacon.c:
static ble_gap_addr_t addr1;
static uint16_t *p_host1;
void init_beacon(void) {
   p_host1 = (void*)&addr1.addr[0];
hungs in assignment when I call init_beacon() from main()
Where is rake?
  • I tried to avoid editing SDK, but the only plausible solution I see, is to switch places of struct. members and add alignment (not sure, either it is really required):
    ble_gap.h:
    /**@brief Bluetooth Low Energy address. */
    typedef struct
      uint8_t addr[BLE_GAP_ADDR_LEN];       /**< 48-bit address, LSB format. */
      uint8_t addr_type;                    /**< See @ref BLE_GAP_ADDR_TYPES. */
    } ble_gap_addr_t __attribute__((aligned(16)));
  • .. even editing SDK's internals will not help though.. SoftDevice expects the intact ble_gap_addr_t struct.
    So, the only option is to copy the address from/to SDK's structs into specially aligned space:
    typedef struct {
       uint16_t extra_aligner; // required to access addr[2] by uint32_t pointer
    } aligned_addr __attribute__((aligned(32)));
    static aligned_addr addr;
    static uint32_t *const p_net = (void*)&aligned_addr.addr[2];
    static uint16_t *const p_host = (void*)&aligned_addr.addr[0];
    and now it is possible to assign some (see BL specs. as per PUBLIC address!) address in the form NE:TW:OR:K_:HO:ST
  • I have tested in another way.
    #pragma anon_unions
    typedef struct {
        union {
            __packed struct {
                uint16_t host;
                uint32_t net;
    } my_gap_addr_t;
    static ble_gap_addr_t addr1 = { 0x00, { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06 } };
    static ble_gap_addr_t *p_addr;
    static my_gap_addr_t  *p_mddr;
    #define show(P) \
        printf("(0x%02x, 0x%02x, 0x%02x, 0x%02x, 0x%02x, 0x%02x)\r\n", \
            P->addr[0], P->addr[1], P->addr[2], P->addr[3], P->addr[4], P->addr[5])
    void test_something(void)
        p_addr = &addr1;
        p_mddr = (my_gap_addr_t*)&addr1;
        show(p_addr);
        show(p_mddr);
        printf("0x%04x\r\n", p_mddr->host);
        puts("---");
        addr1.addr[0] = 0xab;
        addr1.addr[1] = 0xcd;
        show(p_addr);
        show(p_mddr);
        puts("---");
        const uint8_t buffer[] = { 0xfe, 0xdc, 0xba, 0x98, 0x76, 0x54 };
        memcpy((void*)addr1.addr, (const void*)buffer, sizeof(buffer));
        show(p_addr);
        show(p_mddr);
        puts("---");
  • Awesome. although gcc doesn't want this pragma, it just works!
