Resolvable Private Address Generation Cycle
The Central device is using Resolvable Private Addresses.
Even though private_addr_cycle_s is set to BLE_GAP_DEFAULT_PRIVATE_ADDR_CYCLE_INTERVAL_S (15 minutes),
When observed with a BLE sniffer, the Resolvable Private Address changes with each BLE connection.
I thought the address would change according to the set cycle regardless of BLE connections. Is that correct?
We're using a fixed IRK without bonding. Could that be causing this?
We are developing in the following environment:
  • SDK: nRF5 SDK 17.1.0
  • SoftDevice: S140 v7.2.0
  • Hi Amanda,
    Thank you for the prompt confirmation and response.
    > But the thing is that the scanner/initiator regenerates a new address each time softdevice starts a new scanning.
    Can this behavior be considered a bug in the Softdevice?
    The initiator continuing to use the same address for 15 minutes is the correct behavior, right?
    Thank you.
  • The scanner/advertiser regenerates a new address when it starts a new scanning/advertisement.
    Only if the scanning/advertisement is continuously running, the address will be changed every 15 minutes or as configured.
    Hi, Amanda.
    Thank you for your response.
    Would it be appropriate to consider this behavior to correspond to the following description in the Bluetooth SIG Specification?
    > If the Link Layer is reset, a new private address shall be generated and the timer started with any value in the allowed range.
    Thank you.
    From the developer:
    Resolvable Private Address (RPA) is more used to protect an advertising device from being tracked by malicious peers. In the Bluetooth SIG Specification, "If the Link Layer is reset, a new resolvable private address shall be generated and the timer started with any value in the allowed range." Here "Link layer reset" means HCI reset, softdevice regenerates a new address not only on HCI reset and "when the timer expired", but also when starting a new advertising/scanning.
    However, the spec does not prevent us from generating a new address more often. Therefore, the softdevice follows the privacy requirement in the spec.
    -Amanda H.
    Hi, Amanda
    Thank you, my question has been cleared up!
