Sporadic disconnects with reason 8 but good RSSI
I'm having some problems with sporadic disconnects with reason 8 (timeout) although the RSSI values are in a good range.
The disconnects are very rare, I would say maybe every 1-2 hours; if there is more interference, then maybe more.
As peripheral and central I'm using a NRF52840; my RTOS is Zephyr and my NCS Version is 2.5.1
Details:
  • I'm using coded PHY S8
  • RSSI values are all about -70dbm
  • Connection parameter:
    • Interval: 400ms
    • Latency: 4 (means every 2 seconds the sensor must awake and send
    • Timeout 8 seconds
  • External LF crystal, 20ppm
I've already tried to play around with the PPM settings and tried CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM, but there was no improvement. Also the crystal is rated with 20ppm, so I think that should not be the problem.
I've chooses the connection parameter like this, because I really do not have to send much data and want to keep the battery consumption on a minimum.
What could be the problem and how could I improve the connection? What can I try?
Thanks a lot,
Phobios
  • Just to make sure, are both the peripheral and central transmitting at +8 dBm? This is necessary to really increase the link budget. Also, I'm curious if you have done comparisons between coded and 1M in your environment? There is a significant power cost associated with using the CODED PHY since the radio needs to stay on 4 times longer to transmit/receive the same amount of data.
    Phobios said:
    Do you think changing to 1M PHY will help me with the interference, and the range extension IC (but only on the Central) will help me getting longer range?
    I think you need to use the FEM on both sides to improve the link budget. If you have a choice between increasing the power output or using CODED PHY, you should typically see the biggest improvement by increasing the power. Note that ETSI does not permit more than 10 dBm for BLE.
  • Sry for the late reply, I had finally some time to test some more. I'm using CONFIG_BT_CTLR_TX_PWR_PLUS_8=y on both sides, Peripheral and Central.
    For the power cost; since my connection interval is so long (2s with latency) there is really not much difference between 1M and S8, from what I've measured.
    I've done tests with 1M, I see a little improvement but the disconnects are not gone.
    I also tried different connection parameters with success. After setting
    • Interval: 200ms
    • Latency: 9 (means every 2 seconds the sensor must awake and send)
    • Timeout 20 seconds
    The disconnects are gone.
    So for me it looks like, sometimes it misses all connection intervals up to the 8 seconds and the timeout kicks in. If I increase the timeout, then the devices have more chances to get one interval right.
    Is there any downside to such a big timeout? I'm sending only sporadic messages, so I don't have much data throughput.
  • Thank you for the update and the interesting findings. Initially I expected an 8 second timeout to be sufficient. But with your long connection interval, you only had to miss 4 events.
    Whether using a large timeout has any drawbacks depends on the application.  A delay of 20 seconds to detect a lost connection is often not ideal if is for a user facing application.
