Nordic nrf52840DK board is failing to connect w/ newest NRF Connect Desktop v4.4.0 and w/ Segger Embedded Studio
I need help with my Nordic nrf52840DK board. Its is now failing to connect with the latest NRF Connect Desktop v4.4.0
I plug the board into the USB port of my macbook pro (MacOS BigSur v11.7.0) and the RSSI desktop app sees the jlink serial number but there's always an error that says failed to open device. and I tried to match what the NRF Connect version wants (it's looking for 7.88j) but there's only version 7.88n that is downloadable and upgrading to that version doesn't work either and fails the same.
The additional problem now is I cannot use my nrf52840DK board which Segger Embedded Studio (using several versions: 7.12a, 5.68, 5.34) stopped finding.
Any ideas or fixes to this recent observed failures w/ 52840DK boards working w/ NRF Connect Desktop and Segger Embedded Studio ?
  • 2024-03-09T18:26:42.740Z DEBUG Application data folder: /Users/antsgp/Library/Application Support/nrfconnect/pc-nrfconnect-rssi
    2024-03-09T18:26:42.921Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:26:42.926Z DEBUG App pc-nrfconnect-rssi v1.6.0 (official)
    2024-03-09T18:26:42.926Z DEBUG App path: /Users/antsgp/.nrfconnect-apps/node_modules/pc-nrfconnect-rssi
    2024-03-09T18:26:42.926Z DEBUG nRFConnect 4.4.0, required by the app is (>=4.3.0)
    2024-03-09T18:26:42.926Z DEBUG nRFConnect path: /Applications/nRF Connect for Desktop.app/Contents/Resources/app.asar
    2024-03-09T18:26:42.926Z DEBUG HomeDir: /Users/antsgp
    2024-03-09T18:26:42.927Z DEBUG TmpDir: /var/folders/rg/2cvbzprd5_vfbs_10f_979140000gn/T/
    2024-03-09T18:26:43.036Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:26:43.040Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:26:43.139Z INFO [PID:63320] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with list --traits nordicUsb,serialPorts,jlink,nordicDfu --hotplug --json --log-output=stdout --log-level trace
    2024-03-09T18:26:43.139Z INFO [PID:63320] Starting parent process watchdog, current parent process ID: 63321
    2024-03-09T18:26:43.139Z DEBUG [PID:63320] cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    2024-03-09T18:26:43.139Z DEBUG [PID:63320] Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device
    2024-03-09T18:26:43.190Z VERBOSE [PID:63320] [devkit] C API function: get_version_list
    2024-03-09T18:26:43.190Z DEBUG [PID:63320] [devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:26:43.205Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:26:43.205Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:26:43.224Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command open executed for 16 milliseconds with result 0
    2024-03-09T18:26:43.224Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] jlink_dll_version
    2024-03-09T18:26:43.224Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.227Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:26:43.227Z DEBUG [PID:63320] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:26:43.228Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:26:43.229Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0
    2024-03-09T18:26:43.229Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] dll_version
    2024-03-09T18:26:43.229Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:43.229Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:26:43.229Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.229Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:26:43.230Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:43.230Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:26:43.230Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:26:43.230Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:26:43.230Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:26:43.231Z INFO Using nrfutil-device version: 2.0.3
    2024-03-09T18:26:43.231Z INFO Using nrf-device-lib version: 0.17.3
    2024-03-09T18:26:43.231Z INFO Using nrfjprog DLL version: 10.23.1
    2024-03-09T18:26:43.231Z INFO Using JLink version: JLink_V7.80c
    2024-03-09T18:26:43.231Z WARN Installed JLink version does not match the expected version (JLink_V7.88j)
    2024-03-09T18:26:43.238Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:26:43.238Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:43.238Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.238Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:26:43.238Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.238Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 17 milliseconds
    2024-03-09T18:26:43.260Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:26:43.260Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 31 milliseconds
    2024-03-09T18:26:43.261Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:43.271Z WARN [PID:63320] [JlinkARM] JlinkARM version non expected one found: JLink_V7.80c, expected: JLink_V7.88j
    2024-03-09T18:26:43.272Z VERBOSE [PID:63320] [boardController] C API function: get_version_list
    2024-03-09T18:26:43.273Z DEBUG [PID:63320] [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:26:43.273Z VERBOSE [PID:63320] DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2024-03-09T18:26:43.273Z VERBOSE [PID:63320] DeviceLister::enumerate::enumerate_task: Start
    2024-03-09T18:26:43.273Z VERBOSE [PID:63320] DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    2024-03-09T18:26:43.273Z DEBUG [PID:63320] USBLister: enumerate
    2024-03-09T18:26:43.273Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:26:43.274Z INFO [PID:63320] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:26:43.274Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:26:43.274Z VERBOSE [PID:63320] DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    2024-03-09T18:26:43.274Z VERBOSE [PID:63320] [devkit] C API function: enumerate
    2024-03-09T18:26:43.274Z DEBUG [PID:63320] Enumeration for plugin 'devkit' took 0 ms
    2024-03-09T18:26:43.274Z VERBOSE [PID:63320] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:26:43.274Z VERBOSE [PID:63320] DeviceLister::enumerate: Waiting for enumerate task to complete
    2024-03-09T18:26:43.290Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:26:43.290Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:26:43.300Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:26:43.301Z DEBUG [PID:63320] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:26:43.301Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:26:43.304Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:26:43.305Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:26:43.305Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:26:43.309Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command open executed for 17 milliseconds with result 0
    2024-03-09T18:26:43.310Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:26:43.310Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.310Z DEBUG [PID:63320] [jlink] Found 0 JLink devices connected
    2024-03-09T18:26:43.311Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:26:43.311Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:26:43.311Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:26:43.312Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:26:43.312Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:26:43.323Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:26:43.326Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:26:43.327Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:43.327Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.337Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:43.337Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 18 milliseconds
    2024-03-09T18:26:43.348Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:26:43.349Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:26:43.350Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Tried to wait on already ended process: wait error: No child processes
    2024-03-09T18:26:43.350Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:26:43.350Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 32 milliseconds
    2024-03-09T18:26:43.351Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:43.356Z DEBUG [PID:63320] Enumeration for plugin 'jlink' took 85 ms
    2024-03-09T18:26:43.357Z VERBOSE [PID:63320] [boardController] C API function: enumerate
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [boardController] Found 18 HID devices.
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] Enumeration for plugin 'BOARDCONTROLLER' took 4 ms
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:26:43.361Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:26:43.362Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:26:43.363Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:26:43.363Z DEBUG [PID:63320] Enumeration for plugin 'serialport' took 0 ms
    2024-03-09T18:26:43.363Z DEBUG [PID:63320] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:26:43.363Z DEBUG [PID:63320] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:26:43.363Z VERBOSE [PID:63320] [broken] BrokenPlugin::enumerate
    2024-03-09T18:26:43.363Z DEBUG [PID:63320] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:26:43.363Z VERBOSE [PID:63320] DeviceLister::enumerate: Finished in 92 ms
    2024-03-09T18:26:43.363Z VERBOSE [PID:63320] DeviceLister::enumerate: Completed waiting for enumerate task
    2024-03-09T18:26:43.363Z VERBOSE [PID:63320] DeviceLister::enumerate: done
    2024-03-09T18:26:57.024Z DEBUG [PID:63320] USBLister: enumerate
    2024-03-09T18:26:57.024Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:26:57.025Z INFO [PID:63320] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:26:57.463Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:26:57.465Z DEBUG [PID:63320] USBLister: Adding new device with id 1 and serial number: '000683994613'
    2024-03-09T18:26:57.472Z VERBOSE [PID:63320] [devkit] C API function: enumerate
    2024-03-09T18:26:57.474Z VERBOSE [PID:63320] [devkit] enumerate: Inspecting device with ID 1
    2024-03-09T18:26:57.474Z DEBUG [PID:63320] [devkit] enumerate: Device with ID 1 has board version PCA10056
    2024-03-09T18:26:57.475Z DEBUG [PID:63320] Enumeration for plugin 'devkit' took 6 ms
    2024-03-09T18:26:57.475Z VERBOSE [PID:63320] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:26:57.508Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:26:57.508Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:26:57.519Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:26:57.519Z DEBUG [PID:63320] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:26:57.519Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:26:57.519Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:26:57.519Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:26:57.520Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:26:57.525Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command open executed for 15 milliseconds with result 0
    2024-03-09T18:26:57.526Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:26:57.527Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 1 milliseconds with result 0
    2024-03-09T18:26:57.527Z DEBUG [PID:63320] [jlink] Found 1 JLink devices connected
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:26:57.531Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:26:57.531Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 1 milliseconds with result 0
    2024-03-09T18:26:57.531Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:26:57.532Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:57.532Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:26:57.532Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:26:57.532Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:26:57.532Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:26:57.544Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:26:57.545Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:57.545Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command close executed for 13 milliseconds with result 0
    2024-03-09T18:26:57.546Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command terminate executed for 2 milliseconds with result 0
    2024-03-09T18:26:57.553Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:57.553Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 21 milliseconds
    2024-03-09T18:26:57.565Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:26:57.565Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 33 milliseconds
    2024-03-09T18:26:57.565Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:57.573Z DEBUG [PID:63320] Enumeration for plugin 'jlink' took 103 ms
    2024-03-09T18:26:57.573Z VERBOSE [PID:63320] [boardController] C API function: enumerate
    2024-03-09T18:26:57.578Z DEBUG [PID:63320] [boardController] Found 18 HID devices.
    2024-03-09T18:26:57.578Z DEBUG [PID:63320] Enumeration for plugin 'BOARDCONTROLLER' took 4 ms
    2024-03-09T18:26:57.578Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:26:57.578Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:57.578Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:26:57.579Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleUSBACMData
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUSBInterface
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUSBDevice
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] [serialport] serialport enumerate update device: '000683994613'
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] Enumeration for plugin 'serialport' took 1 ms
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:26:57.580Z VERBOSE [PID:63320] [broken] BrokenPlugin::enumerate
    2024-03-09T18:26:57.580Z DEBUG [PID:63320] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:26:57.581Z INFO Device Connected SN:000683994613
    2024-03-09T18:26:57.582Z INFO Getting serialport options from persistent store 000683994613.pc-nrfconnect-rssi
    2024-03-09T18:26:57.582Z DEBUG [PID:63320] USBLister: enumerate
    2024-03-09T18:26:57.582Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:26:57.583Z INFO [PID:63320] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:26:57.584Z DEBUG Sending usage data "device connected"
    2024-03-09T18:26:57.602Z DEBUG [PID:63320] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:26:57.602Z VERBOSE [PID:63320] [devkit] C API function: enumerate
    2024-03-09T18:26:57.602Z VERBOSE [PID:63320] [devkit] enumerate: Inspecting device with ID 1
    2024-03-09T18:26:57.602Z DEBUG [PID:63320] [devkit] enumerate: Device with ID 1 has board version PCA10056
    2024-03-09T18:26:57.602Z DEBUG [PID:63320] Enumeration for plugin 'devkit' took 0 ms
    2024-03-09T18:26:57.602Z VERBOSE [PID:63320] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:26:57.676Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command open executed for 15 milliseconds with result 0
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:26:57.676Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 1 milliseconds with result 0
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] Found 1 JLink devices connected
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:26:57.676Z DEBUG [PID:63320] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:26:57.677Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:57.677Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:26:57.682Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:26:57.682Z DEBUG [PID:63320] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:26:57.688Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:26:57.689Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:26:57.690Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:57.690Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:57.699Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:26:57.700Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 17 milliseconds
    2024-03-09T18:26:57.712Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:26:57.712Z VERBOSE [PID:63320] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 31 milliseconds
    2024-03-09T18:26:57.712Z DEBUG [PID:63320] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:26:57.723Z DEBUG [PID:63320] Enumeration for plugin 'jlink' took 137 ms
    2024-03-09T18:26:57.724Z VERBOSE [PID:63320] [boardController] C API function: enumerate
    2024-03-09T18:26:57.725Z DEBUG [PID:63320] [boardController] Found 18 HID devices.
    2024-03-09T18:26:57.725Z DEBUG [PID:63320] Enumeration for plugin 'BOARDCONTROLLER' took 5 ms
    2024-03-09T18:26:57.726Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:26:57.726Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:57.726Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:26:57.727Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: AppleUSBACMData
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUSBInterface
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] Class is: IOUSBDevice
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] [serialport] serialport enumerate update device: '000683994613'
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] Enumeration for plugin 'serialport' took 1 ms
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:26:57.728Z VERBOSE [PID:63320] [broken] BrokenPlugin::enumerate
    2024-03-09T18:26:57.728Z DEBUG [PID:63320] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:26:57.729Z INFO Getting serialport options from persistent store 000683994613.pc-nrfconnect-rssi
    2024-03-09T18:26:57.730Z DEBUG Sending usage data "device connected"
    2024-03-09T18:27:05.504Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:27:05.578Z INFO [PID:63344] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with device-info --serial-number 000683994613 --json --log-output=stdout --log-level trace
    2024-03-09T18:27:05.579Z DEBUG [PID:63344] cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    2024-03-09T18:27:05.579Z DEBUG [PID:63344] Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device
    2024-03-09T18:27:05.579Z INFO [PID:63344] Starting parent process watchdog, current parent process ID: 63345
    2024-03-09T18:27:05.588Z VERBOSE [PID:63344] [devkit] C API function: get_version_list
    2024-03-09T18:27:05.589Z DEBUG [PID:63344] [devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:05.624Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:05.624Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:05.646Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:05.646Z DEBUG [PID:63344] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:05.646Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:05.647Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:05.647Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:05.647Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:05.647Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:05.647Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:05.647Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:05.648Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command open executed for 21 milliseconds with result 0
    2024-03-09T18:27:05.648Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] jlink_dll_version
    2024-03-09T18:27:05.648Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] dll_version
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:05.658Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:05.658Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:05.663Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:27:05.663Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:05.663Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.668Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:27:05.668Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.668Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 18 milliseconds
    2024-03-09T18:27:05.679Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:27:05.679Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Tried to wait on already ended process: wait error: No child processes
    2024-03-09T18:27:05.679Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:05.679Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 36 milliseconds
    2024-03-09T18:27:05.679Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:05.688Z WARN [PID:63344] [JlinkARM] JlinkARM version non expected one found: JLink_V7.80c, expected: JLink_V7.88j
    2024-03-09T18:27:05.689Z VERBOSE [PID:63344] [boardController] C API function: get_version_list
    2024-03-09T18:27:05.689Z DEBUG [PID:63344] [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:05.689Z VERBOSE [PID:63344] DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2024-03-09T18:27:05.689Z VERBOSE [PID:63344] DeviceLister::enumerate: Waiting for enumerate task to complete
    2024-03-09T18:27:05.689Z VERBOSE [PID:63344] DeviceLister::enumerate::enumerate_task: Start
    2024-03-09T18:27:05.689Z VERBOSE [PID:63344] DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    2024-03-09T18:27:05.689Z DEBUG [PID:63344] USBLister: enumerate
    2024-03-09T18:27:05.689Z DEBUG [PID:63344] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:27:05.689Z INFO [PID:63344] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:27:05.692Z DEBUG [PID:63344] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:27:05.692Z DEBUG [PID:63344] USBLister: Adding new device with id 1 and serial number: '000683994613'
    2024-03-09T18:27:05.693Z VERBOSE [PID:63344] DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    2024-03-09T18:27:05.693Z VERBOSE [PID:63344] [devkit] C API function: enumerate
    2024-03-09T18:27:05.693Z VERBOSE [PID:63344] [devkit] enumerate: Inspecting device with ID 1
    2024-03-09T18:27:05.693Z DEBUG [PID:63344] [devkit] enumerate: Device with ID 1 has board version PCA10056
    2024-03-09T18:27:05.694Z DEBUG [PID:63344] Enumeration for plugin 'devkit' took 1 ms
    2024-03-09T18:27:05.694Z VERBOSE [PID:63344] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:27:05.741Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:05.742Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:05.756Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:05.757Z DEBUG [PID:63344] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:05.757Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:05.758Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:05.759Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:05.759Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:05.766Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command open executed for 22 milliseconds with result 0
    2024-03-09T18:27:05.766Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:27:05.767Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:05.767Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:05.767Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command open executed for 8 milliseconds with result 0
    2024-03-09T18:27:05.768Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:27:05.768Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 1 milliseconds with result 0
    2024-03-09T18:27:05.768Z DEBUG [PID:63344] [jlink] Found 1 JLink devices connected
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:27:05.778Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:05.778Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:05.783Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:27:05.783Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:05.783Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.788Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:27:05.788Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:05.788Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 19 milliseconds
    2024-03-09T18:27:05.802Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:27:05.802Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Tried to wait on already ended process: wait error: No child processes
    2024-03-09T18:27:05.802Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:05.803Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 38 milliseconds
    2024-03-09T18:27:05.803Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:05.809Z DEBUG [PID:63344] Enumeration for plugin 'jlink' took 114 ms
    2024-03-09T18:27:05.811Z VERBOSE [PID:63344] [boardController] C API function: enumerate
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [boardController] Found 18 HID devices.
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] Enumeration for plugin 'BOARDCONTROLLER' took 5 ms
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:05.814Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: AppleUSBACMData
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOUSBInterface
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] Class is: IOUSBDevice
    2024-03-09T18:27:05.815Z DEBUG [PID:63344] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:27:05.816Z DEBUG [PID:63344] [serialport] serialport enumerate update device: '000683994613'
    2024-03-09T18:27:05.816Z DEBUG [PID:63344] Enumeration for plugin 'serialport' took 1 ms
    2024-03-09T18:27:05.816Z DEBUG [PID:63344] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:27:05.816Z DEBUG [PID:63344] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:27:05.816Z VERBOSE [PID:63344] [broken] BrokenPlugin::enumerate
    2024-03-09T18:27:05.816Z DEBUG [PID:63344] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] DeviceLister::enumerate: Found device with serial number: '000683994613'
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] DeviceLister::enumerate: device registered to device list
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] DeviceLister::enumerate: Finished in 127 ms
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] DeviceLister::enumerate: Completed waiting for enumerate task
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] DeviceLister::enumerate: done
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] [devkit] C API function: supports_device_operations
    2024-03-09T18:27:05.818Z INFO [PID:63344] Loaded plugin /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
    2024-03-09T18:27:05.818Z VERBOSE [PID:63344] [jlink] NRFDL::JLinkPlugin::JLinkPLugin()
    2024-03-09T18:27:05.818Z DEBUG [PID:63344] [jlink] Initializing Jlink debug probe for device {"devkit":{"boardVersion":"PCA10056","deviceFamily":"NRF52_FAMILY"},"id":1,"serialNumber":"000683994613","serialPorts":[{"comName":"/dev/tty.usbmodem0006839946131","manufacturer":"SEGGER","path":"/dev/tty.usbmodem0006839946131","productId":"1015","serialNumber":"000683994613","vcom":0,"vendorId":"1366"}],"traits":{"boardController":false,"broken":false,"devkit":true,"jlink":true,"mcuBoot":false,"modem":false,"nordicDfu":false,"nordicUsb":false,"seggerUsb":true,"serialPorts":true,"usb":true},"usb":{"device":{"address":5,"busNumber":0,"descriptor":{"bDescriptorType":1,"bcdDevice":256,"idProduct":4117,"idVendor":4966}},"manufacturer":"SEGGER","product":"J-Link","serialNumber":"000683994613"},"usbIdentifier":"14500000"} with serial number 000683994613
    2024-03-09T18:27:05.818Z DEBUG [PID:63344] [jlink] Opening JLink DLL
    2024-03-09T18:27:05.863Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] open
    2024-03-09T18:27:05.863Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] start
    2024-03-09T18:27:05.881Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Command open executed for 15 milliseconds with result 0
    2024-03-09T18:27:05.881Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:05.884Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Logger sink registered in Segger backend logger
    2024-03-09T18:27:05.884Z DEBUG [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] Logger sink registered in JLink logger
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] open
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] just_check_family
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] open_dll
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Set batch mode
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] dll_version
    2024-03-09T18:27:05.885Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_enum_emu_snr
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_get_num_emus
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_with_snr
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_without_snr
    2024-03-09T18:27:05.885Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger logging enabled.
    2024-03-09T18:27:05.916Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Nov  7 2022 16:21:57
    2024-03-09T18:27:05.918Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] Hardware: V1.00
    2024-03-09T18:27:05.918Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] S/N: 683994613
    2024-03-09T18:27:05.918Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] OEM: SEGGER
    2024-03-09T18:27:05.918Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2024-03-09T18:27:05.923Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Command connect_to_emu_with_snr executed for 42 milliseconds with result 0
    2024-03-09T18:27:05.923Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] read_device_family
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] USB speed mode: High speed (480 MBit/s)
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] TELNET listener socket opened on port 19021
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV Webserver running on local port 19080
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 15.724ms returns "O.K."
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2024-03-09T18:27:05.926Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.223ms returns 0x01
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("DisableFlashDL", ...).
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.022ms returns 0x00
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.002ms returns 0x00
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog(...)
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.010ms returns 0
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.153ms returns 0x00
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeedInfo()
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] 10000000 Hz / n, n >= 10
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.009ms
    2024-03-09T18:27:05.927Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Connected emulator supports SWD speeds up to 1000kHz
    2024-03-09T18:27:05.927Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Requested speed 2000kHz is higher than the emulator max speed of 1000kHz
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetSpeed(2000)
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.437ms
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeed()
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.003ms returns 1000
    2024-03-09T18:27:05.927Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] SWD speed was reported as 1000kHz after requesting 2000kHz. Check the capabilities of the selected emulator.
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSN()
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns 683994613
    2024-03-09T18:27:05.927Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms
    2024-03-09T18:27:05.927Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Command connect_to_emu_with_snr executed for 40 milliseconds with result 0
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.012ms returns 0x01
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:05.928Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] coresight_configure
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetHWStatus(...)
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.258ms returns 0
    2024-03-09T18:27:05.928Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_Configure()
    2024-03-09T18:27:06.030Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 100.765ms returns 0
    2024-03-09T18:27:06.030Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.030Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:06.030Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:06.030Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:06.030Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:06.030Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:06.030Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.030Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.828ms returns -1
    2024-03-09T18:27:06.031Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.031Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.031Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.031Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.928ms returns -1
    2024-03-09T18:27:06.031Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.031Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.804ms returns -1
    2024-03-09T18:27:06.031Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.834ms returns -1
    2024-03-09T18:27:06.042Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.846ms returns -1
    2024-03-09T18:27:06.042Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.042Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.042Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.829ms returns -1
    2024-03-09T18:27:06.042Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.837ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.817ms returns -1
    2024-03-09T18:27:06.043Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.043Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.820ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.854ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.836ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.810ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.654ms returns 0
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.831ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.784ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.889ms returns -1
    2024-03-09T18:27:06.043Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.894ms returns -1
    2024-03-09T18:27:06.052Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.869ms returns -1
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.928ms returns -1
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.891ms returns -1
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.053Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.798ms returns -1
    2024-03-09T18:27:06.053Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.053Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.054Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.919ms returns -1
    2024-03-09T18:27:06.054Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.054Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.055Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.861ms returns -1
    2024-03-09T18:27:06.055Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.055Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.055Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.830ms returns -1
    2024-03-09T18:27:06.056Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.057Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.057Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.766ms returns -1
    2024-03-09T18:27:06.057Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.057Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.920ms returns -1
    2024-03-09T18:27:06.058Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.856ms returns -1
    2024-03-09T18:27:06.058Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.058Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.059Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.843ms returns -1
    2024-03-09T18:27:06.059Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.059Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.059Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.059Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.063Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.964ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.846ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.895ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.001ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.951ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.888ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.045ms returns -1
    2024-03-09T18:27:06.064Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.064Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.861ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.804ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.831ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.799ms returns -1
    2024-03-09T18:27:06.064Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.871ms returns -1
    2024-03-09T18:27:06.065Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.065Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.065Z ERROR [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Encountered error -102: Command read_device_family executed for 141 milliseconds with result -102
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.833ms returns -1
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.601ms
    2024-03-09T18:27:06.074Z ERROR [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] An unknown error.
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Command read_device_family executed for 141 milliseconds with result -102
    2024-03-09T18:27:06.074Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] close
    2024-03-09T18:27:06.074Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:06.074Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.009ms returns 0x01
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] close
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] disconnect_from_emu
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_disconnect_from_emu
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_device
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsConnected()
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns FALSE
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_is_debug_region_powered
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.849ms returns -1
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.075Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.851ms returns -1
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.000ms returns -1
    2024-03-09T18:27:06.075Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.803ms returns -1
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.861ms returns -1
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.824ms returns -1
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.872ms returns -1
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.076Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.873ms returns -1
    2024-03-09T18:27:06.076Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.076Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.907ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.804ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.836ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.835ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.974ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.851ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.861ms returns -1
    2024-03-09T18:27:06.087Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.087Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.854ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.809ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.816ms returns -1
    2024-03-09T18:27:06.087Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.828ms returns -1
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.791ms returns -1
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.811ms returns -1
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.088Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.832ms returns -1
    2024-03-09T18:27:06.088Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.088Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.097Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.823ms returns -1
    2024-03-09T18:27:06.097Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.097Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.097Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.854ms returns -1
    2024-03-09T18:27:06.097Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.938ms returns -1
    2024-03-09T18:27:06.098Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.845ms returns -1
    2024-03-09T18:27:06.099Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.099Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.099Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.826ms returns -1
    2024-03-09T18:27:06.099Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.898ms returns -1
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.845ms returns -1
    2024-03-09T18:27:06.101Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.101Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.768ms returns -1
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.781ms returns -1
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.794ms returns -1
    2024-03-09T18:27:06.101Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.843ms returns -1
    2024-03-09T18:27:06.102Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.102Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.848ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.950ms returns -1
    2024-03-09T18:27:06.109Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.109Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.965ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.827ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 1.083ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.889ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.881ms returns -1
    2024-03-09T18:27:06.109Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.873ms returns -1
    2024-03-09T18:27:06.110Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.110Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Ignore exception An unknown error.
    2024-03-09T18:27:06.110Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] - 0.072ms
    2024-03-09T18:27:06.121Z VERBOSE [PID:63344] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Close()
    2024-03-09T18:27:06.132Z DEBUG [PID:63344] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger Backend closed.
    2024-03-09T18:27:06.132Z DEBUG [PID:63344] [jlink] [NRFJPROG][nRFXX][000683994613] nRF family DLL closed
    2024-03-09T18:27:06.145Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Command close executed for 76 milliseconds with result 0
    2024-03-09T18:27:06.145Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Command close executed for 79 milliseconds with result 0
    2024-03-09T18:27:06.146Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:06.146Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.156Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.157Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Worker][000683994613] Executed 5 commands for 264 milliseconds
    2024-03-09T18:27:06.158Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Child process terminated with result 0
    2024-03-09T18:27:06.158Z VERBOSE [PID:63344] [jlink] [NRFJPROG][Client][000683994613] Executed 5 commands for 277 milliseconds
    2024-03-09T18:27:06.158Z DEBUG [PID:63344] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:06.167Z DEBUG [PID:63344] Task 2379410832483 is already completed
    2024-03-09T18:27:06.168Z DEBUG [PID:63344] ~async_task id: 2379410832483
    2024-03-09T18:27:06.168Z INFO [PID:63344] close plugin dll at path: /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl
    2024-03-09T18:27:06.172Z ERROR [PID:63344] Error: Failed with exit code 1.
    Failed to device info one or more devices:
     * 683994613: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink.
    Message: Operation device-info failed, [jlink] JLINKARM_DLL_ERROR.
    2024-03-09T18:27:06.175Z INFO Selected device with s/n 000683994613
    2024-03-09T18:27:06.176Z INFO Checking readback protection on device
    2024-03-09T18:27:06.179Z DEBUG Sending usage data "device selected"
    2024-03-09T18:27:06.179Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:27:06.262Z INFO [PID:63350] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with fw-info --serial-number 000683994613 --json --log-output=stdout --log-level trace
    2024-03-09T18:27:06.262Z INFO [PID:63350] Starting parent process watchdog, current parent process ID: 63351
    2024-03-09T18:27:06.262Z DEBUG [PID:63350] cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    2024-03-09T18:27:06.262Z DEBUG [PID:63350] Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device
    2024-03-09T18:27:06.273Z VERBOSE [PID:63350] [devkit] C API function: get_version_list
    2024-03-09T18:27:06.274Z DEBUG [PID:63350] [devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:06.308Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:06.308Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:06.319Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:06.320Z DEBUG [PID:63350] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:06.320Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:06.320Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:06.320Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:06.320Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:06.331Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:06.331Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:06.331Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:06.331Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command open executed for 20 milliseconds with result 0
    2024-03-09T18:27:06.331Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] jlink_dll_version
    2024-03-09T18:27:06.331Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.343Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] dll_version
    2024-03-09T18:27:06.343Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:06.343Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:06.344Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:06.344Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command close executed for 15 milliseconds with result 0
    2024-03-09T18:27:06.370Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command close executed for 13 milliseconds with result 0
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 20 milliseconds
    2024-03-09T18:27:06.370Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:27:06.370Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:06.370Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 35 milliseconds
    2024-03-09T18:27:06.376Z WARN [PID:63350] [JlinkARM] JlinkARM version non expected one found: JLink_V7.80c, expected: JLink_V7.88j
    2024-03-09T18:27:06.376Z VERBOSE [PID:63350] [boardController] C API function: get_version_list
    2024-03-09T18:27:06.377Z DEBUG [PID:63350] [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:06.378Z VERBOSE [PID:63350] DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2024-03-09T18:27:06.378Z VERBOSE [PID:63350] DeviceLister::enumerate: Waiting for enumerate task to complete
    2024-03-09T18:27:06.379Z VERBOSE [PID:63350] DeviceLister::enumerate::enumerate_task: Start
    2024-03-09T18:27:06.380Z VERBOSE [PID:63350] DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    2024-03-09T18:27:06.380Z DEBUG [PID:63350] USBLister: enumerate
    2024-03-09T18:27:06.381Z DEBUG [PID:63350] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:27:06.381Z INFO [PID:63350] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:27:06.381Z DEBUG [PID:63350] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:27:06.381Z DEBUG [PID:63350] USBLister: Adding new device with id 1 and serial number: '000683994613'
    2024-03-09T18:27:06.381Z VERBOSE [PID:63350] DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    2024-03-09T18:27:06.381Z VERBOSE [PID:63350] [devkit] C API function: enumerate
    2024-03-09T18:27:06.382Z VERBOSE [PID:63350] [devkit] enumerate: Inspecting device with ID 1
    2024-03-09T18:27:06.382Z DEBUG [PID:63350] [devkit] enumerate: Device with ID 1 has board version PCA10056
    2024-03-09T18:27:06.382Z DEBUG [PID:63350] Enumeration for plugin 'devkit' took 1 ms
    2024-03-09T18:27:06.382Z VERBOSE [PID:63350] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:27:06.431Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:06.431Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:06.442Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:06.443Z DEBUG [PID:63350] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:06.443Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:06.443Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:06.443Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:06.444Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:06.454Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command open executed for 20 milliseconds with result 0
    2024-03-09T18:27:06.454Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:27:06.455Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:06.456Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:06.457Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:06.457Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:27:06.457Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:06.457Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:27:06.457Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:27:06.457Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:27:06.457Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 1 milliseconds with result 0
    2024-03-09T18:27:06.459Z DEBUG [PID:63350] [jlink] Found 1 JLink devices connected
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:06.465Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:06.465Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:06.471Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command close executed for 16 milliseconds with result 0
    2024-03-09T18:27:06.471Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:06.472Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.475Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command close executed for 10 milliseconds with result 0
    2024-03-09T18:27:06.475Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.475Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 17 milliseconds
    2024-03-09T18:27:06.487Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:06.487Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 37 milliseconds
    2024-03-09T18:27:06.487Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:06.496Z DEBUG [PID:63350] Enumeration for plugin 'jlink' took 113 ms
    2024-03-09T18:27:06.498Z VERBOSE [PID:63350] [boardController] C API function: enumerate
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] [boardController] Found 18 HID devices.
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] Enumeration for plugin 'BOARDCONTROLLER' took 4 ms
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:06.500Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:06.501Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:06.502Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:27:06.505Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: AppleUSBACMData
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOUSBInterface
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] Class is: IOUSBDevice
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [serialport] serialport enumerate update device: '000683994613'
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] Enumeration for plugin 'serialport' took 1 ms
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] [broken] BrokenPlugin::enumerate
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] DeviceLister::enumerate: Found device with serial number: '000683994613'
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] DeviceLister::enumerate: device registered to device list
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] DeviceLister::enumerate: Finished in 125 ms
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] DeviceLister::enumerate: Completed waiting for enumerate task
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] DeviceLister::enumerate: done
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] [devkit] C API function: supports_device_operations
    2024-03-09T18:27:06.506Z INFO [PID:63350] Loaded plugin /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
    2024-03-09T18:27:06.506Z VERBOSE [PID:63350] [jlink] NRFDL::JLinkPlugin::JLinkPLugin()
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [jlink] Initializing Jlink debug probe for device {"devkit":{"boardVersion":"PCA10056","deviceFamily":"NRF52_FAMILY"},"id":1,"serialNumber":"000683994613","serialPorts":[{"comName":"/dev/tty.usbmodem0006839946131","manufacturer":"SEGGER","path":"/dev/tty.usbmodem0006839946131","productId":"1015","serialNumber":"000683994613","vcom":0,"vendorId":"1366"}],"traits":{"boardController":false,"broken":false,"devkit":true,"jlink":true,"mcuBoot":false,"modem":false,"nordicDfu":false,"nordicUsb":false,"seggerUsb":true,"serialPorts":true,"usb":true},"usb":{"device":{"address":5,"busNumber":0,"descriptor":{"bDescriptorType":1,"bcdDevice":256,"idProduct":4117,"idVendor":4966}},"manufacturer":"SEGGER","product":"J-Link","serialNumber":"000683994613"},"usbIdentifier":"14500000"} with serial number 000683994613
    2024-03-09T18:27:06.506Z DEBUG [PID:63350] [jlink] Opening JLink DLL
    2024-03-09T18:27:06.556Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] open
    2024-03-09T18:27:06.557Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] start
    2024-03-09T18:27:06.567Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Logger sink registered in Segger backend logger
    2024-03-09T18:27:06.569Z DEBUG [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] Logger sink registered in JLink logger
    2024-03-09T18:27:06.569Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] open
    2024-03-09T18:27:06.570Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] just_check_family
    2024-03-09T18:27:06.570Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] open_dll
    2024-03-09T18:27:06.570Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:06.575Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Command open executed for 15 milliseconds with result 0
    2024-03-09T18:27:06.576Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:06.581Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Set batch mode
    2024-03-09T18:27:06.581Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] dll_version
    2024-03-09T18:27:06.582Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:06.582Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:06.582Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.586Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:06.586Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.586Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_enum_emu_snr
    2024-03-09T18:27:06.586Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_get_num_emus
    2024-03-09T18:27:06.586Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_with_snr
    2024-03-09T18:27:06.587Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_without_snr
    2024-03-09T18:27:06.587Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger logging enabled.
    2024-03-09T18:27:06.605Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Command connect_to_emu_with_snr executed for 29 milliseconds with result 0
    2024-03-09T18:27:06.605Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] read_device_family
    2024-03-09T18:27:06.605Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Nov  7 2022 16:21:57
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] Hardware: V1.00
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] S/N: 683994613
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] OEM: SEGGER
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] USB speed mode: High speed (480 MBit/s)
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] TELNET listener socket opened on port 19021
    2024-03-09T18:27:06.606Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    2024-03-09T18:27:06.607Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV Webserver running on local port 19080
    2024-03-09T18:27:06.607Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 13.787ms returns "O.K."
    2024-03-09T18:27:06.607Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.608Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:06.608Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2024-03-09T18:27:06.608Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms returns 0x01
    2024-03-09T18:27:06.608Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.608Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("DisableFlashDL", ...).
    2024-03-09T18:27:06.609Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms returns 0x00
    2024-03-09T18:27:06.609Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.609Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2024-03-09T18:27:06.609Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.002ms returns 0x00
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog(...)
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.009ms returns 0
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.846ms returns 0x00
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeedInfo()
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] 10000000 Hz / n, n >= 10
    2024-03-09T18:27:06.610Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Connected emulator supports SWD speeds up to 1000kHz
    2024-03-09T18:27:06.610Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Requested speed 2000kHz is higher than the emulator max speed of 1000kHz
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetSpeed(2000)
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.542ms
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeed()
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns 1000
    2024-03-09T18:27:06.610Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] SWD speed was reported as 1000kHz after requesting 2000kHz. Check the capabilities of the selected emulator.
    2024-03-09T18:27:06.610Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSN()
    2024-03-09T18:27:06.611Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.003ms returns 683994613
    2024-03-09T18:27:06.611Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.611Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms
    2024-03-09T18:27:06.611Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:06.611Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Command connect_to_emu_with_snr executed for 28 milliseconds with result 0
    2024-03-09T18:27:06.617Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:06.617Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.617Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.012ms returns 0x01
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:06.618Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.618Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:06.618Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:06.618Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:06.618Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] coresight_configure
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetHWStatus(...)
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.266ms returns 0
    2024-03-09T18:27:06.618Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_Configure()
    2024-03-09T18:27:06.707Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 100.573ms returns 0
    2024-03-09T18:27:06.708Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:06.708Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.708Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.856ms returns -1
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.708Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.708Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.944ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.891ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.833ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.774ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.985ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.818ms returns -1
    2024-03-09T18:27:06.721Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.721Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.876ms returns -1
    2024-03-09T18:27:06.721Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.785ms returns -1
    2024-03-09T18:27:06.722Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.961ms returns -1
    2024-03-09T18:27:06.722Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.722Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.722Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.818ms returns -1
    2024-03-09T18:27:06.722Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.830ms returns -1
    2024-03-09T18:27:06.728Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.705ms returns 0
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.872ms returns -1
    2024-03-09T18:27:06.729Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.729Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.861ms returns -1
    2024-03-09T18:27:06.729Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.961ms returns -1
    2024-03-09T18:27:06.730Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.730Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.916ms returns -1
    2024-03-09T18:27:06.730Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.730Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.894ms returns -1
    2024-03-09T18:27:06.731Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.731Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 1.015ms returns -1
    2024-03-09T18:27:06.731Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.731Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.839ms returns -1
    2024-03-09T18:27:06.731Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.732Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.830ms returns -1
    2024-03-09T18:27:06.732Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.732Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.732Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.732Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.732Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.832ms returns -1
    2024-03-09T18:27:06.735Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.860ms returns -1
    2024-03-09T18:27:06.735Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.735Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.739Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.868ms returns -1
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.813ms returns -1
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.851ms returns -1
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.804ms returns -1
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.929ms returns -1
    2024-03-09T18:27:06.740Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.740Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.942ms returns -1
    2024-03-09T18:27:06.740Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.803ms returns -1
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.868ms returns -1
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.831ms returns -1
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.826ms returns -1
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.803ms returns -1
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.741Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.959ms returns -1
    2024-03-09T18:27:06.741Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.741Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.870ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.899ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.939ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.852ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.829ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.841ms returns -1
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.109ms
    2024-03-09T18:27:06.776Z ERROR [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] An unknown error.
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Command read_device_family executed for 139 milliseconds with result -102
    2024-03-09T18:27:06.776Z ERROR [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Encountered error -102: Command read_device_family executed for 145 milliseconds with result -102
    2024-03-09T18:27:06.776Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] close
    2024-03-09T18:27:06.776Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:06.776Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.011ms returns 0x01
    2024-03-09T18:27:06.777Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] close
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] disconnect_from_emu
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_disconnect_from_emu
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_device
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsConnected()
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns FALSE
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_is_debug_region_powered
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.940ms returns -1
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.778Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.800ms returns -1
    2024-03-09T18:27:06.778Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.837ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 1.072ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.830ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.837ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.831ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.820ms returns -1
    2024-03-09T18:27:06.785Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.785Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.835ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.980ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.840ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.816ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.784ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.838ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.819ms returns -1
    2024-03-09T18:27:06.785Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.813ms returns -1
    2024-03-09T18:27:06.786Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.786Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.786Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.810ms returns -1
    2024-03-09T18:27:06.790Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.790Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.853ms returns -1
    2024-03-09T18:27:06.790Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.834ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.836ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.847ms returns -1
    2024-03-09T18:27:06.791Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.791Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.882ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.846ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.828ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.848ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.965ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.930ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 1.119ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.947ms returns -1
    2024-03-09T18:27:06.791Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.830ms returns -1
    2024-03-09T18:27:06.792Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.792Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.931ms returns -1
    2024-03-09T18:27:06.792Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.792Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.845ms returns -1
    2024-03-09T18:27:06.794Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.795Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.854ms returns -1
    2024-03-09T18:27:06.795Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.795Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.796Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.795ms returns -1
    2024-03-09T18:27:06.800Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.800Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.982ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:06.806Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:06.806Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.948ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.899ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 1.098ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.851ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.821ms returns -1
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.804ms returns -1
    2024-03-09T18:27:06.806Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Ignore exception An unknown error.
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] - 0.082ms
    2024-03-09T18:27:06.806Z VERBOSE [PID:63350] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Close()
    2024-03-09T18:27:06.816Z DEBUG [PID:63350] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger Backend closed.
    2024-03-09T18:27:06.816Z DEBUG [PID:63350] [jlink] [NRFJPROG][nRFXX][000683994613] nRF family DLL closed
    2024-03-09T18:27:06.820Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Command close executed for 67 milliseconds with result 0
    2024-03-09T18:27:06.821Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:06.821Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Command terminate executed for 1 milliseconds with result 0
    2024-03-09T18:27:06.827Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Command close executed for 66 milliseconds with result 0
    2024-03-09T18:27:06.827Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:06.827Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Worker][000683994613] Executed 5 commands for 240 milliseconds
    2024-03-09T18:27:06.838Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Child process terminated with result 0
    2024-03-09T18:27:06.838Z VERBOSE [PID:63350] [jlink] [NRFJPROG][Client][000683994613] Executed 5 commands for 257 milliseconds
    2024-03-09T18:27:06.838Z DEBUG [PID:63350] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:06.848Z DEBUG [PID:63350] ~async_task id: 2379411519424
    2024-03-09T18:27:06.848Z DEBUG [PID:63350] Task 2379411519424 is already completed
    2024-03-09T18:27:06.848Z INFO [PID:63350] close plugin dll at path: /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl
    2024-03-09T18:27:06.851Z VERBOSE [PID:63350] DeviceLister::shutDown()
    2024-03-09T18:27:06.856Z ERROR [PID:63350] Error: Failed with exit code 1.
    Failed to get firmware info for one or more devices:
    Message: Operation fw-read-info failed, [jlink] JLINKARM_DLL_ERROR.
    2024-03-09T18:27:11.367Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:27:11.459Z INFO [PID:63358] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with reset --generate --core Application --json --log-output=stdout --log-level trace
    2024-03-09T18:27:11.459Z INFO [PID:63358] Starting parent process watchdog, current parent process ID: 63361
    2024-03-09T18:27:11.460Z INFO [PID:63356] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with recover --generate --core Application --json --log-output=stdout --log-level trace
    2024-03-09T18:27:11.460Z INFO [PID:63356] Starting parent process watchdog, current parent process ID: 63360
    2024-03-09T18:27:11.465Z INFO [PID:63357] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with program --generate --core Application --firmware /Users/antsgp/.nrfconnect-apps/node_modules/pc-nrfconnect-rssi/fw/rssi-10040.hex --json --log-output=stdout --log-level trace
    2024-03-09T18:27:11.466Z INFO [PID:63357] Starting parent process watchdog, current parent process ID: 63359
    2024-03-09T18:27:11.473Z DEBUG Sending usage data "running nrfutil device"
    2024-03-09T18:27:11.578Z INFO [PID:63365] nrfutil-device (version = 2.0.3, platform = x86_64-apple-darwin) invoked with x-execute-batch --serial-number 000683994613 --batch-json {"operations":[{"operationId":"0","core":"NRFDL_DEVICE_CORE_APPLICATION","operation":{"type":"recover"}},{"operationId":"1","core":"NRFDL_DEVICE_CORE_APPLICATION","operation":{"experimental":{"boot_sdfw":false},"firmware":{"file":"/Users/antsgp/.nrfconnect-apps/node_modules/pc-nrfconnect-rssi/fw/rssi-10040.hex"},"type":"program"}},{"operationId":"2","core":"NRFDL_DEVICE_CORE_APPLICATION","operation":{"option":"RESET_SYSTEM","type":"reset"}}]} --json --log-output=stdout --log-level trace
    2024-03-09T18:27:11.578Z DEBUG [PID:63365] cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    2024-03-09T18:27:11.578Z DEBUG [PID:63365] Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device
    2024-03-09T18:27:11.578Z INFO [PID:63365] Starting parent process watchdog, current parent process ID: 63366
    2024-03-09T18:27:11.586Z VERBOSE [PID:63365] [devkit] C API function: get_version_list
    2024-03-09T18:27:11.586Z DEBUG [PID:63365] [devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:11.606Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:11.607Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:11.640Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command open executed for 16 milliseconds with result 0
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] jlink_dll_version
    2024-03-09T18:27:11.641Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:11.641Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:11.642Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:11.642Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:11.642Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] dll_version
    2024-03-09T18:27:11.642Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:11.643Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:11.657Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:11.658Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:11.658Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:11.659Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:27:11.659Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command close executed for 16 milliseconds with result 0
    2024-03-09T18:27:11.659Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:11.659Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command terminate executed for 6 milliseconds with result 0
    2024-03-09T18:27:11.679Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.680Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 18 milliseconds
    2024-03-09T18:27:11.680Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    2024-03-09T18:27:11.680Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] Tried to wait on already ended process: wait error: No child processes
    2024-03-09T18:27:11.680Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:11.680Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 38 milliseconds
    2024-03-09T18:27:11.680Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:11.709Z WARN [PID:63365] [JlinkARM] JlinkARM version non expected one found: JLink_V7.80c, expected: JLink_V7.88j
    2024-03-09T18:27:11.709Z VERBOSE [PID:63365] [boardController] C API function: get_version_list
    2024-03-09T18:27:11.709Z DEBUG [PID:63365] [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    2024-03-09T18:27:11.709Z VERBOSE [PID:63365] DeviceLister::enumerate: Checking future_status of enumerate_task_status
    2024-03-09T18:27:11.709Z VERBOSE [PID:63365] DeviceLister::enumerate: Waiting for enumerate task to complete
    2024-03-09T18:27:11.709Z VERBOSE [PID:63365] DeviceLister::enumerate::enumerate_task: Start
    2024-03-09T18:27:11.709Z VERBOSE [PID:63365] DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate
    2024-03-09T18:27:11.709Z DEBUG [PID:63365] USBLister: enumerate
    2024-03-09T18:27:11.709Z DEBUG [PID:63365] USBPlatformAPI::Apple: Apple USB enumerate.
    2024-03-09T18:27:11.709Z INFO [PID:63365] USBPlatformAPI::Apple: skip apple product
    2024-03-09T18:27:11.709Z DEBUG [PID:63365] USBPlatformAPI::Apple: Apple USB enumerate done.
    2024-03-09T18:27:11.710Z DEBUG [PID:63365] USBLister: Adding new device with id 1 and serial number: '000683994613'
    2024-03-09T18:27:11.710Z VERBOSE [PID:63365] DeviceLister::enumerate::enumerate_task: After async_lister->enumerate
    2024-03-09T18:27:11.710Z VERBOSE [PID:63365] [devkit] C API function: enumerate
    2024-03-09T18:27:11.710Z VERBOSE [PID:63365] [devkit] enumerate: Inspecting device with ID 1
    2024-03-09T18:27:11.710Z DEBUG [PID:63365] [devkit] enumerate: Device with ID 1 has board version PCA10056
    2024-03-09T18:27:11.710Z DEBUG [PID:63365] Enumeration for plugin 'devkit' took 1 ms
    2024-03-09T18:27:11.710Z VERBOSE [PID:63365] [jlink] JLinkPlugin::enumerate
    2024-03-09T18:27:11.717Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] open
    2024-03-09T18:27:11.718Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] start
    2024-03-09T18:27:11.740Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command open executed for 18 milliseconds with result 0
    2024-03-09T18:27:11.742Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] enum_emu_snr
    2024-03-09T18:27:11.751Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    2024-03-09T18:27:11.757Z DEBUG [PID:63365] [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    2024-03-09T18:27:11.758Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 2 milliseconds with result 0
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] Found 1 JLink devices connected
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] open
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] just_check_family
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    2024-03-09T18:27:11.758Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    2024-03-09T18:27:11.758Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    2024-03-09T18:27:11.759Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] close
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] close
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    2024-03-09T18:27:11.759Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    2024-03-09T18:27:11.765Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command close executed for 22 milliseconds with result 0
    2024-03-09T18:27:11.765Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:11.765Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.768Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command close executed for 11 milliseconds with result 0
    2024-03-09T18:27:11.769Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:11.769Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][-] Executed 4 commands for 18 milliseconds
    2024-03-09T18:27:11.782Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    2024-03-09T18:27:11.782Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][-] Executed 4 commands for 42 milliseconds
    2024-03-09T18:27:11.783Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][-] terminate
    2024-03-09T18:27:11.788Z DEBUG [PID:63365] Enumeration for plugin 'jlink' took 92 ms
    2024-03-09T18:27:11.789Z VERBOSE [PID:63365] [boardController] C API function: enumerate
    2024-03-09T18:27:11.793Z DEBUG [PID:63365] [boardController] Found 18 HID devices.
    2024-03-09T18:27:11.804Z DEBUG [PID:63365] Enumeration for plugin 'BOARDCONTROLLER' took 4 ms
    2024-03-09T18:27:11.807Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Apple serialport enumerate.
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:11.808Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOPCIDevice
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleACPIPCI
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOACPIPlatformDevice
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleSimpleUARTSync
    2024-03-09T18:27:11.809Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleIntelLpssUARTv1
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleACPIPlatformExpert
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOPlatformExpertDevice
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IORegistryEntry
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOUserSerial
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOUserService
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOBluetoothDevice
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOBluetoothHCIController
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOResources
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: AppleUSBACMData
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOUSBInterface
    2024-03-09T18:27:11.810Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] Class is: IOUSBDevice
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] [SerialPortListerHW::APPLE] try to map FTDI to segger device
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] [serialport] serialport enumerate update device: '000683994613'
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] Enumeration for plugin 'serialport' took 1 ms
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] Enumeration for plugin 'sdfu' took 0 ms
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] Enumeration for plugin 'mcuBoot' took 0 ms
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] [broken] BrokenPlugin::enumerate
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] Enumeration for plugin 'broken' took 0 ms
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] DeviceLister::enumerate: Found device with serial number: '000683994613'
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] DeviceLister::enumerate: device registered to device list
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] DeviceLister::enumerate: Finished in 102 ms
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] DeviceLister::enumerate: Completed waiting for enumerate task
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] DeviceLister::enumerate: done
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] [devkit] C API function: supports_device_operations
    2024-03-09T18:27:11.811Z INFO [PID:63365] Loaded plugin /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
    2024-03-09T18:27:11.811Z VERBOSE [PID:63365] [jlink] NRFDL::JLinkPlugin::JLinkPLugin()
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] [jlink] Initializing Jlink debug probe for device {"devkit":{"boardVersion":"PCA10056","deviceFamily":"NRF52_FAMILY"},"id":1,"serialNumber":"000683994613","serialPorts":[{"comName":"/dev/tty.usbmodem0006839946131","manufacturer":"SEGGER","path":"/dev/tty.usbmodem0006839946131","productId":"1015","serialNumber":"000683994613","vcom":0,"vendorId":"1366"}],"traits":{"boardController":false,"broken":false,"devkit":true,"jlink":true,"mcuBoot":false,"modem":false,"nordicDfu":false,"nordicUsb":false,"seggerUsb":true,"serialPorts":true,"usb":true},"usb":{"device":{"address":5,"busNumber":0,"descriptor":{"bDescriptorType":1,"bcdDevice":256,"idProduct":4117,"idVendor":4966}},"manufacturer":"SEGGER","product":"J-Link","serialNumber":"000683994613"},"usbIdentifier":"14500000"} with serial number 000683994613
    2024-03-09T18:27:11.811Z DEBUG [PID:63365] [jlink] Opening JLink DLL
    2024-03-09T18:27:11.820Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] open
    2024-03-09T18:27:11.820Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] start
    2024-03-09T18:27:11.838Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Command open executed for 15 milliseconds with result 0
    2024-03-09T18:27:11.839Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:11.842Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Logger sink registered in Segger backend logger
    2024-03-09T18:27:11.843Z DEBUG [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] Logger sink registered in JLink logger
    2024-03-09T18:27:11.845Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] open
    2024-03-09T18:27:11.852Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] just_check_family
    2024-03-09T18:27:11.855Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] open_dll
    2024-03-09T18:27:11.857Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] No J-Link DLL path was provided. Attempting to auto detect.
    2024-03-09T18:27:11.858Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Set batch mode
    2024-03-09T18:27:11.858Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] dll_version
    2024-03-09T18:27:11.858Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Command open executed for 7 milliseconds with result 0
    2024-03-09T18:27:11.859Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:11.859Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:11.859Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] connect_to_emu_with_snr
    2024-03-09T18:27:11.859Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_enum_emu_snr
    2024-03-09T18:27:11.860Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_get_num_emus
    2024-03-09T18:27:11.860Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_with_snr
    2024-03-09T18:27:11.860Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_connect_to_emu_without_snr
    2024-03-09T18:27:11.860Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger logging enabled.
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Nov  7 2022 16:21:57
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] Hardware: V1.00
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] S/N: 683994613
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] OEM: SEGGER
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] USB speed mode: High speed (480 MBit/s)
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] TELNET listener socket opened on port 19021
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] WEBSRV Webserver running on local port 19080
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 14.106ms returns "O.K."
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms returns 0x01
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("DisableFlashDL", ...).
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns 0x00
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.002ms returns 0x00
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetHookUnsecureDialog(...)
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.047ms returns 0
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2024-03-09T18:27:11.867Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.843ms returns 0x00
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeedInfo()
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] 10000000 Hz / n, n >= 10
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.009ms
    2024-03-09T18:27:11.868Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Connected emulator supports SWD speeds up to 1000kHz
    2024-03-09T18:27:11.868Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Requested speed 2000kHz is higher than the emulator max speed of 1000kHz
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_SetSpeed(2000)
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.108ms
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSpeed()
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.003ms returns 1000
    2024-03-09T18:27:11.868Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] SWD speed was reported as 1000kHz after requesting 2000kHz. Check the capabilities of the selected emulator.
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetSN()
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.003ms returns 683994613
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.005ms
    2024-03-09T18:27:11.868Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:11.868Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Command connect_to_emu_with_snr executed for 28 milliseconds with result 0
    2024-03-09T18:27:11.871Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Command connect_to_emu_with_snr executed for 32 milliseconds with result 0
    2024-03-09T18:27:11.871Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] read_device_family
    2024-03-09T18:27:11.876Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] read_device_family
    2024-03-09T18:27:11.876Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:11.876Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:11.876Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.010ms returns 0x01
    2024-03-09T18:27:11.876Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.876Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:11.876Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:11.877Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:11.877Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:11.877Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] coresight_configure
    2024-03-09T18:27:11.877Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_GetHWStatus(...)
    2024-03-09T18:27:11.877Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.254ms returns 0
    2024-03-09T18:27:11.877Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.877Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_Configure()
    2024-03-09T18:27:11.983Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 101.050ms returns 0
    2024-03-09T18:27:11.992Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_idr
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] read_debug_port_register
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:11.992Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:11.992Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 5.815ms returns -1
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:11.992Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:11.992Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:11.992Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 3.268ms returns -1
    2024-03-09T18:27:11.996Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.480ms returns -1
    2024-03-09T18:27:11.996Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.996Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:11.996Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.991ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.938ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.916ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 2.264ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.023ms returns -1
    2024-03-09T18:27:11.998Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:11.998Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.227ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.942ms returns -1
    2024-03-09T18:27:11.998Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.052ms returns -1
    2024-03-09T18:27:12.004Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.289ms returns -1
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.887ms returns -1
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.977ms returns -1
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.845ms returns -1
    2024-03-09T18:27:12.005Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.005Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.823ms returns -1
    2024-03-09T18:27:12.005Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.839ms returns -1
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.843ms returns -1
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.875ms returns -1
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.792ms returns -1
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.783ms returns -1
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.006Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.982ms returns -1
    2024-03-09T18:27:12.006Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.006Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.015Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.791ms returns -1
    2024-03-09T18:27:12.015Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.015Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.842ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.814ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.765ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.868ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.965ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.787ms returns -1
    2024-03-09T18:27:12.016Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.016Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.799ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.852ms returns -1
    2024-03-09T18:27:12.016Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.853ms returns -1
    2024-03-09T18:27:12.025Z ERROR [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Encountered error -102: Command read_device_family executed for 154 milliseconds with result -102
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.821ms returns -1
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.835ms returns -1
    2024-03-09T18:27:12.026Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.026Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.826ms returns -1
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.810ms returns -1
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.923ms returns -1
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.926ms returns -1
    2024-03-09T18:27:12.026Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.894ms returns -1
    2024-03-09T18:27:12.027Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.136ms
    2024-03-09T18:27:12.027Z ERROR [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] An unknown error.
    2024-03-09T18:27:12.027Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Command read_device_family executed for 150 milliseconds with result -102
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] close
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_emu
    2024-03-09T18:27:12.036Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsOpen()
    2024-03-09T18:27:12.036Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.017ms returns 0x01
    2024-03-09T18:27:12.036Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.036Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Lock()
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] close
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] disconnect_from_emu
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_disconnect_from_emu
    2024-03-09T18:27:12.036Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] is_connected_to_device
    2024-03-09T18:27:12.036Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_IsConnected()
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.004ms returns FALSE
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_is_debug_region_powered
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_read_debug_port_register
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_select_debug_port_register
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Select AP 255, DP Bank 0, AP Bank 255
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.903ms returns -1
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.037Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.824ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.800ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.803ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.929ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.864ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.853ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.833ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.876ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:12.037Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.897ms returns -1
    2024-03-09T18:27:12.048Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.995ms returns -1
    2024-03-09T18:27:12.048Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.048Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.048Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.964ms returns -1
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.819ms returns -1
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.833ms returns -1
    2024-03-09T18:27:12.049Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.049Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.876ms returns -1
    2024-03-09T18:27:12.049Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.889ms returns -1
    2024-03-09T18:27:12.050Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.810ms returns -1
    2024-03-09T18:27:12.050Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.050Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.050Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.800ms returns -1
    2024-03-09T18:27:12.051Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.051Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.051Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.842ms returns -1
    2024-03-09T18:27:12.051Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.051Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.769ms returns -1
    2024-03-09T18:27:12.052Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.052Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.052Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.054Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.781ms returns -1
    2024-03-09T18:27:12.055Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.055Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.055Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.919ms returns -1
    2024-03-09T18:27:12.058Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.863ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.809ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.868ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.867ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.022ms returns -1
    2024-03-09T18:27:12.059Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.059Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.036ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.213ms returns -1
    2024-03-09T18:27:12.059Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.131ms returns -1
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.815ms returns -1
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.854ms returns -1
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.843ms returns -1
    2024-03-09T18:27:12.060Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2024-03-09T18:27:12.069Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.791ms returns -1
    2024-03-09T18:27:12.069Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.069Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] ---just_abort_debug_action
    2024-03-09T18:27:12.069Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Attempting to clear any configuration errors in debug port before closing connection.
    2024-03-09T18:27:12.070Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.070Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.845ms returns -1
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_HasError()
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 1.021ms returns -1
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.824ms returns -1
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.866ms returns -1
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.870ms returns -1
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.820ms returns -1
    2024-03-09T18:27:12.071Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Ignore exception An unknown error.
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] - 0.065ms
    2024-03-09T18:27:12.071Z VERBOSE [PID:63365] [jlink] [NRFJPROG][JLink][000683994613] JLINK_Close()
    2024-03-09T18:27:12.090Z DEBUG [PID:63365] [jlink] [NRFJPROG][SeggerBackend][000683994613] Segger Backend closed.
    2024-03-09T18:27:12.091Z DEBUG [PID:63365] [jlink] [NRFJPROG][nRFXX][000683994613] nRF family DLL closed
    2024-03-09T18:27:12.098Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Command close executed for 72 milliseconds with result 0
    2024-03-09T18:27:12.098Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:12.098Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:12.101Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Command close executed for 68 milliseconds with result 0
    2024-03-09T18:27:12.101Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Command terminate executed for 0 milliseconds with result 0
    2024-03-09T18:27:12.101Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Worker][000683994613] Executed 5 commands for 253 milliseconds
    2024-03-09T18:27:12.112Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Child process terminated with result 0
    2024-03-09T18:27:12.112Z VERBOSE [PID:63365] [jlink] [NRFJPROG][Client][000683994613] Executed 5 commands for 273 milliseconds
    2024-03-09T18:27:12.112Z DEBUG [PID:63365] [jlink] [NRFJPROG][Client][000683994613] terminate
    2024-03-09T18:27:12.121Z DEBUG [PID:63365] ~async_task id: 2379416813177
    2024-03-09T18:27:12.121Z DEBUG [PID:63365] Task 2379416813177 is already completed
    2024-03-09T18:27:12.121Z WARN [PID:63365] Error executing operations for device with ID 1: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    2024-03-09T18:27:12.121Z INFO [PID:63365] close plugin dll at path: /Users/antsgp/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.0.3/lib/nrfutil-device/10-nrfdl-jlink-plugin.nrfdl
    2024-03-09T18:27:12.122Z INFO Device protected, recovering device
    2024-03-09T18:27:12.122Z INFO Finished recovering device.
    2024-03-09T18:27:12.122Z VERBOSE [PID:63365] DeviceLister::shutDown()
    2024-03-09T18:27:12.126Z ERROR [PID:63365] Error: Failed with exit code 1.
    One or more batch tasks failed:
     - [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink.
    Message: Batch task recover failed, [jlink] JLINKARM_DLL_ERROR.
    2024-03-09T18:27:12.127Z ERROR Failed with exit code 1.
    2024-03-09T18:27:12.127Z ERROR Error while setting up device 000683994613
    2024-03-09T18:27:12.127Z ERROR Error: Error when programming Failed with exit code 1.
    2024-03-09T18:27:12.128Z INFO Deselected device
    2024-03-09T18:27:12.129Z DEBUG Sending usage data "device deselected "
    Your log shows that used JLink version is not an expected one. Could you try to upgrade your nRF Connect for Desktop to the newest version?
    Dejan
  • Hi
    I did that, but it did not make any difference after updating to the Segger site which only had the 7.88n version
    Can you flash any firmware to your nrf52840-dk board using (nRF Connect for Desktop) Programmer application?
    Dejan
  • Unfortunately as we started our discussion on this track, NRF Connect Desktop cannot program the nrf52840DK board and I get the following under Programmer v4.2.0 when I select the nRF52840DK board
    10:59:52.665
    Getting serialport options from persistent store 000050112046.pc-nrfconnect-programmer
    10:59:57.548
    Error: Failed with exit code 1. Failed to device info one or more devices: * 683994613: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink. Message: Operation device-info failed, [jlink] JLINKARM_DLL_ERROR.
    10:59:57.553
    Using nrfutil device to communicate with target via JLink
    10:59:58.150
    Reading readback protection status for Application core
    10:59:58.151
    Failed to reading readback protection status for application core core. Error: [object Object], message: Batch task protection-get failed, [jlink] JLINKARM_DLL_ERROR
    10:59:58.154
    Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink. Message: Batch task protection-get failed, [jlink] JLINKARM_DLL_ERROR.
    10:59:58.155
