Bootloader DFU transport - transfer of init packet
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via nrf util from PC. Now I'm wondering of the meaning of transferred bytes, since it's not matching to decription in sdk.
First captured packet is: 0x09 0x01 0xc0; according to dfu transport shall be 0x02 0x00 0x01..
After response 0x60 0x09 0x01 0x01 0xc0, similar packet is sent 0x02 0x00 0x00 0xc0 and finally get response set prn success 0x60 0x02 0x01
Then Get MTU is following... and then I get a bit different response 0x60, 0x07, 0x01, 0x83, 0x00, 0xc0 --->how many bytes are use to represent MTU?
Now I'm wondering if there is any document/manual with detailed description of transfered bytes (somehow I didn't find it), or is there any existing code/library for performing dfu, that could be used for implementing flashing procedure on external mcu via uart.
Thank you in advance.
Matej
  • Hi Matej,
    The error below suggests that the bootloader is receiving a packet that is too large:
    Matej said:
    <error> nrf_dfu_req_handler: Write request too long
    There is also this one that indicates that it is receiving packets that are >64 bytes:
    Matej said:
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0004F040, src=0x2000063C, len=129 bytes), queue usage: 1
    Does your client verify that the reported CRC during DFU is correct?
    BR,
    Vidar
  • True, there was an error of sending one 64 byte to much within 4k chunks.
    I made a bit of rework and I'm able to transffer image, but at the end of transfer when I send out execute cmd I have a bit weird situation:
    • In case that image is not valid I receive a message that whole firmware image is received, but hash verfication failed - it seems ok, since hash is not matching
    • In case that image is valid and sending algorithm is completly the same, I don't get a message that whole firmware is received and bootloader stops at 0xa80
    Would you be please so kind and check attached logs? Where is the reason that I don't get any response on execute command in case that image transfer is valid? I have also performed readout and images are completly the same and in both cases I see with logic analyzer that execute cmd (0x04, 0xc0) is sent out.
    Thank you for your support!
    Matej
    dfu_log_hangs.log
    dfu_log_hash.log
    0xA80 is the address of the mbr's reset handler, and the program should not hang there unless you have this breakpoint enabled in SES:
    Have you tried to see what happens if you continue execution by pressing the 'play' button in SES?
    Vidar
  • Not completly sure (will perform detail test in afternoon), if I'm not wrong I have tried and it seems like reset occur and bootloader boots up normally like nothing happend an previous/old application is booted...
    When I perform flash readout - the new image is stored at 0x4d000 and completely the same as was sent over, on 0x27000 is old application which boots up
    I'm expecting at least a message like whole firmware image is received, but in this case nothing. Are there any differencies how last execute CMD is processed?
    Any idea how to proceed?
    BR,
    Matej
  • Hi Vidar,
    I have performed some additionall tests, also switched to single bank update and figured out that "no jump" or switching to new app happens in case that there is already valid application. And this shows up like at first need to perform one update to invalidate current image, the second round of updated it works properly...
    Attaching part of logs
    1st round - "Invalidating" app
    <info> nrf_dfu_serial_uart: Allocated buffer 200005B8
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:155648, CRC:0x4D88F134
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    At this point stopping at mbr's reset handler 0xa80, pressing continue/play button as suggested
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <debug> app: Enter main loop
    And nothing happens, app is not working, while performing same procedure once again, when I stop at at 0xa80, then I receive execute cmd response and app starts working...
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <debug> nrf_dfu_validation: Hash verification. start address: 0x27000, size: 0x26000
    <debug> nrf_dfu_validation: Invalidating old application in bank 0.
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20000A44, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x200006C4, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
    <debug> app: Shutting down transports (found: 1)
    <debug> app: Resetting bootloader.
    <debug> app: Valid App
    <debug> app: Enter nrf_dfu_app_continue
    <debug> app: No copy needed
    <debug> app: Setting app as valid
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    <debug> app: App is valid
    <warning> nrf_dfu_settings: No additional data erased
    <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
    Any idea? In both cases same length and crc are calculated.
    Thank you for additional inputs.
    Matej
