PSA import key / sign hash not working after SDK update
I am currently updating from SDK v2.3.0 to v2.5.2 but I am not able to get the 'psa' functions working correctly (as they did with previous SDKs).
I am trying to import a private key, with oberon driver I get the error -134 = PSA_ERROR_NOT_SUPPORTED,
with cc3xx driver the import itself is working but the next operations (psa_export_public_key and/or psa_sign_hash) will fail with error -147 = PSA_ERROR_HARDWARE_FAILURE
The problem seems familiar to:
     nRF9160 RSA crypto changes from v2.3.0 to v2.4.0 SHA-1 signing
(I was also able to get error 135 in some cases) but the solution (to use CONFIG_PSA_CORE_BUILTIN=y) was removed in SDK v2.5.2
Initially I also thought it's because of the usage of a 512 bit key, which according to upper answer and to
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.1/nrfxlib/crypto/doc/nrf_oberon.html
is not supported anymore -> therefore we specially changed our server to 2048 bit, but results stayed the same.
I have experimented with variations of following settings, but neither combination was working:
CONFIG_CRYPTO=y
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y
CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR=y
CONFIG_PSA_WANT_ALG_SHA_256=y
CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
I am testing with following code:
STATUS_CODE rsa_import_prv_key(void)
	/* Configure the key attributes */
	psa_key_attributes_t key_attributes = PSA_KEY_ATTRIBUTES_INIT;
	psa_status_t status;
	size_t olen;
	int rc;
	unsigned char buffer[2048];
	size_t len;
	psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_SIGN_HASH | PSA_KEY_USAGE_EXPORT);
	psa_set_key_lifetime(&key_attributes, PSA_KEY_LIFETIME_VOLATILE);
	psa_set_key_algorithm(&key_attributes, PSA_ALG_RSA_PKCS1V15_SIGN(PSA_ALG_SHA_256));
	psa_set_key_type(&key_attributes, PSA_KEY_TYPE_RSA_KEY_PAIR );
	psa_set_key_bits(&key_attributes, RSA_KEY_BITS);
	rc = base64_decode(buffer, sizeof(buffer), &len, &CONF_API_PRIVATE_KEY[0], strlen(CONF_API_PRIVATE_KEY) );
	if(rc!=0) {
		LOG_ERR("Base64 decode error: %d", rc);
//	PRINT_HEX("Base64 decoded", buffer, sizeof(buffer));
	status = psa_import_key(&key_attributes, buffer, len, &keypair_handle);
	if (status != PSA_SUCCESS) {
		LOG_INF("psa_import_key failed! (Error: %d)", status);
		return STATUS_ERROR;
	/* Export the public key */
	status = psa_export_public_key(keypair_handle, m_pub_key, sizeof(m_pub_key), &olen);
		LOG_INF("psa_export_public_key failed! (Error: %d)", status);
//	PRINT_HEX("Second (exported) puclic key", m_pub_key, sizeof(m_pub_key));
	/* After the key handle is acquired the attributes are not needed */
	psa_reset_key_attributes(&key_attributes);
	return STATUS_OK;
And also tested some variations here (for example did I add the 'PSA_KEY_USAGE_EXPORT' flag due to an answer in the forum, this was not necessary in SDK2.3.0).
I was not able to find any solution, although I searched for a long time in the changelogs and in the forum, so I hope for some useful input...
Thank you, best regards,
Bernhard
  • Hello Dejan,
    What was the most recent NCS version which you used and did not get any issues?
    The main difference (at least what I can see) seems to be between SDK versions v2.4.3 and v2.5.0, but I was actually working with v2.3.0
    I was trying to make you a minimal example (since my application is already big and complex), thereby I noticed that even the RSA samples (e.g. C:\ncs\v2.x.x\nrf\samples\crypto) are not working on the nRF9160DK:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    [00:00:00.633,911] <inf> rsa: Starting the RSA example...
    [00:00:00.633,941] <inf> rsa: Generating random RSA keypair...
    [00:00:00.634,094] <inf> rsa: psa_generate_key failed! (Error: -134)
    [00:00:00.634,094] <inf> rsa: Example exited with error!
    It seems that some additional configuration is needed, especially CONFIG_TFM_PROFILE_TYPE_NOT_SET=y, but that produces some further errors:
    c:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: platform/libplatform_s.a(tfm_hal_platform_common.o): in function `tfm_hal_platform_common_init':
    C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.c:36: undefined reference to `stdio_init'
    c:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: platform/libplatform_s.a(tfm_hal_spm_logdev_peripheral.o): in function `tfm_hal_output_spm_log':
    C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/tfm_hal_spm_logdev_peripheral.c:14: undefined reference to `stdio_output_string'
    So for my understanding some addtional undocumented configurations are necessary which changed between the SDK versions.
    Could you provide both configuration files and relevant code (as you did in your initial post) when you had everything working as expected?
    Attached is an excerpt:
    rsa_working_2.3.0.zip
    Thank you and best regards,
    Bernhard
  • Hi Bernhard,
    I have tested unmodified RSA sample using NCS v2.5.0 and building for nrf9160dk_nrf9160. Here is my log:
    As you can see, RSA sample runs fine on my nrf9160-dk.
    Here is prj.conf from the same working RSA sample:
    CONFIG_MAIN_STACK_SIZE=16384
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    # Enable logging
    CONFIG_CONSOLE=y
    CONFIG_LOG=y
    # Enable nordic security backend and PSA APIs
    # Mbedtls configuration
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=16384
    Here is nrf9160dk_nrf9160.conf from the same RSA sample:
    CONFIG_SRAM_SIZE=256
    # Using hardware crypto accelerator
    Dejan
  • Hello Dejan,
    I tested different versions but it's always the same output for me, e.g. SDK v2.5.2
    *** Booting nRF Connect SDK v2.5.2 ***
    [00:00:00.389,129] <inf> rsa: Starting the RSA example...
    [00:00:00.389,160] <inf> rsa: Generating random RSA keypair...
    [00:00:00.389,312] <inf> rsa: psa_generate_key failed! (Error: -134)
    [00:00:00.389,343] <inf> rsa: Example exited with error!
    What I noticed is this message:
    Is it possible that you are working with a different TF-M version?
    I don't really feel like the problem is on my side since other users were reporting the same problems in the forum without real solutions (just using different libraries at all). For example a year ago (with older TF-M version?) you just answered that the project is able to compile but not that it is working:
     Error -134 running Crypto samples on Thingy91
  • Hi Bernhard,
    It seems that you tried to build the sample with TF-M support. Documentation specifies what happens when you build for _ns target. Could you try to run RSA sample using the same build target as me (nrf9160dk_nrf9160)?
    Dejan
  • Hello dejans,
    just as a short note for anybody else with the same problem...
    I finally found out that the newer drivers = oberon & cc3xx (in difference to older 'builtin') are not able to handle the "PrivateKeyInfo" header anymore, so as a bugfix I just removed the first 26 bytes of the key and than its working fine again.
    Thanks for not supporting the topic at all.
    Bernhard
