Ble Central and Usb
We want to develop a product in which ble central device will take data from peripherals and send it using usb. Currently taking trials on nrf52840 dk. In this sample USB/ACM code is running. We merge ble central and usb code together in this central part is working but usb part is not working, when connected to pc not able to detect usb port.
below is code
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @brief BLE LED Button Service central and client application main file.
* This example can be a central for up to 8 peripherals.
* The peripheral is called ble_app_blinky and can be found in the ble_peripheral
* folder.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_lbs_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_drv_usbd.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "boards.h"
#include "nrf_drv_power.h"
#include "nrf_drv_clock.h"
#include "app_util.h"
//#include "app_uart.h"
//#include "app_uart_fifo.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//#define RX_PIN_NUMBER 16
//#define TX_PIN_NUMBER 17
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration that is set with @ref sd_ble_cfg_set. The default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define CENTRAL_SCANNING_LED BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1
#define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the Button characteristic on the peer. */
#define LED_USB_RESUME (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX (BSP_BOARD_LED_3)
#define LEDBUTTON_BUTTON BSP_BUTTON_0 /**< Button that writes to the LED characteristic of the peer. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
static char const m_target_periph_name[] = "Craidlr_Peripheral" ;
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
#define CSS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
#define ECHOBACK_BLE_UART_DATA 1
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_CSS_SERVICE,
.type = CSS_SERVICE_UUID_TYPE
//for usb
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE 0
#define CDC_ACM_COMM_EPIN NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE 1
#define CDC_ACM_DATA_EPIN NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT NRF_DRV_USBD_EPOUT1
* @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
cdc_acm_user_ev_handler,
CDC_ACM_COMM_INTERFACE,
CDC_ACM_DATA_INTERFACE,
CDC_ACM_COMM_EPIN,
CDC_ACM_DATA_EPIN,
CDC_ACM_DATA_EPOUT,
APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
* @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
switch (event)
case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
bsp_board_led_on(LED_CDC_ACM_OPEN);
/*Setup first transfer*/
ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
m_rx_buffer,
READ_SIZE);
UNUSED_VARIABLE(ret);
case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
bsp_board_led_off(LED_CDC_ACM_OPEN);
case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
bsp_board_led_invert(LED_CDC_ACM_TX);
case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
ret_code_t ret;
NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
do
/*Get amount of data transfered*/
size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
/* Fetch data until internal buffer is empty */
m_rx_buffer,
READ_SIZE);
} while (ret == NRF_SUCCESS);
bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
switch (event)
case APP_USBD_EVT_DRV_SUSPEND:
bsp_board_led_off(LED_USB_RESUME);
case APP_USBD_EVT_DRV_RESUME:
bsp_board_led_on(LED_USB_RESUME);
case APP_USBD_EVT_STARTED:
case APP_USBD_EVT_STOPPED:
app_usbd_disable();
bsp_board_leds_off();
case APP_USBD_EVT_POWER_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
app_usbd_enable();
case APP_USBD_EVT_POWER_REMOVED:
NRF_LOG_INFO("USB power removed");
app_usbd_stop();
case APP_USBD_EVT_POWER_READY:
NRF_LOG_INFO("USB ready");
app_usbd_start();
/**@brief Function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is only an example and is not meant for the final product. You need to analyze
* how your product is supposed to react in case of an assert.
* @param[in] line_num Line number of the failing assert call.
* @param[in] p_file_name File name of the failing assert call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the LED Button Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void lbs_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for the LEDs initialization.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
/**@brief Function for starting scanning. */
static void scan_start(void)
ret_code_t ret;
NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
// Turn on the LED to signal scanning.
bsp_board_led_on(CENTRAL_SCANNING_LED);
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
bsp_board_led_on(CENTRAL_CONNECTED_LED);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
p_gap_evt->conn_handle,
p_gap_evt->params.disconnected.reason);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported.
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
///**@brief LED Button collector initialization. */
static void lbs_c_init(void)
ble_lbs_c_init_t lbs_c_init_obj;
//lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
lbs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
lbs_c_init_obj.error_handler = lbs_error_handler;
for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
// err_code = ble_lbs_c_init(&m_lbs_c[i], &lbs_c_init_obj);
* @details Initializes the SoftDevice and the BLE event interrupts.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
// The array must be static because a pointer to it is saved in the button handler module.
//static app_button_cfg_t buttons[] =
// {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
// err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
//static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
// NRF_LOG_DEBUG("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!",
// p_evt->conn_handle,
// p_evt->conn_handle);
// ble_lbs_on_db_disc_evt(&m_lbs_c[p_evt->conn_handle], p_evt);
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
* @details This function handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to the peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
//ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
bsp_board_led_invert(LEDBUTTON_LED);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
static void nus_error_handler(uint32_t nrf_error)
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
init.error_handler = nus_error_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler
// Initialize.
log_init();
ret = nrf_drv_clock_init();
while(!nrf_drv_clock_lfclk_is_running())
/* Just waiting */
timer_init();
leds_init();
buttons_init();
power_management_init();
ble_stack_init();
gatt_init();
db_discovery_init();
nus_c_init();
ble_conn_state_init();
app_usbd_serial_num_generate();
ret = app_usbd_init(&usbd_config);
NRF_LOG_INFO("USBD CDC ACM example started.");
app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
ret = app_usbd_class_append(class_cdc_acm);
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
scan_init();
// Start execution.
NRF_LOG_INFO("Multilink example started.");
// printf("Multilink example started.");
scan_start();
for (;;)
//idle_state_handle();
while (app_usbd_event_queue_process())
/* Nothing to do */
  • Hi
    It fails to build just like before, which makes sense if it is the same project.
    Can you clarify if you are trying to use the NUS or LBS service? The main file seems to refer to either one at different places, and this is causing some of the build errors.
    For instance you call BLE_NUS_C_DEF on line 122 of main.c, but you include ble_lbs_c.h on the top of main rather than ble_nus_c.h, so this macro fails.
    I fixed that, but it still fails on line 439 of main.c where it is trying to initialize the LBS service, not NUS:
    Then there is also the BLE_UUID_CSS_SERVICE define on line 133 of main.c which can not be found anywhere.
    Are you sure you have sent the right version of your code?
    Can you double check that the services in main are set up correctly, and that all the custom definitions are included?
    Best regards
    Torbjørn
