Zephyr base cmake error
Dear team,
I'm facing the problem cmake error in the zephyr base project with nrf9160. While i'm using the following command the error comes. " west build -p -b Nrf9160_minis" I couldn't able to find the issue. Please help me to resolve the issue.
  Invalid usage
  /workspaces/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /workspaces/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
  CMakeLists.txt:3 (find_package)
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/workspaces/mini-nbiot-firmware/build -S/workspaces/mini-nbiot-firmware -GNinja -DBOARD=Nrf9160_minis
  •  --west build: generating a build system
    CMake Deprecation Warning at /home/riosh11/mini/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
      The OLD behavior for policy CMP0079 will be removed from a future version
      of CMake.
      The cmake-policies(7) manual explains that the OLD behaviors of all
      policies are deprecated and that a policy should be set to OLD only under
      specific short-term circumstances.  Projects should be ported to the NEW
      behavior and not rely on setting a policy to OLD.
      CMakeLists.txt:26 (include)
    -- Application: /home/riosh11/mini/mini-nbiot-firmware
    -- Zephyr version: 2.4.0 (/home/riosh11/mini/zephyr)
    -- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
    -- Board: nrf9160dk_minins
    -- Cache files will be written to: /root/.cache/zephyr
    -- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (/root/gcc/gcc-arm-none-eabi-9-2019-q4-major)
    -- Found BOARD.dts: /home/riosh11/mini/mini-nbiot-firmware/boards/arm/nrf9160dk_mini/nrf9160dk_minins.dts
    nrf9160dk_minins.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
    nrf9160dk_minins.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
    nrf9160dk_minins.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
    -- Generated zephyr.dts: /home/riosh11/mini/mini-nbiot-firmware/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/riosh11/mini/mini-nbiot-firmware/build/zephyr/include/generated/devicetree_unfixed.h
    Parsing /home/riosh11/mini/mini-nbiot-firmware/Kconfig
    Loaded configuration '/home/riosh11/mini/mini-nbiot-firmware/build/zephyr/.config'
    No change to configuration in '/home/riosh11/mini/mini-nbiot-firmware/build/zephyr/.config'
    No change to Kconfig header in '/home/riosh11/mini/mini-nbiot-firmware/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: /root/gcc/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
    Changed board to secure nrf9160dk_mini (NOT NS)
    === child image spm -  begin ===
    Including boilerplate (Zephyr base (cached)): /home/riosh11/mini/zephyr/cmake/app/boilerplate.cmake
      of CMake.
      /home/riosh11/mini/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /home/riosh11/mini/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:8 (find_package)
    -- Application: /home/riosh11/mini/nrf/samples/spm
    -- Found BOARD.dts: /home/riosh11/mini/mini-nbiot-firmware/boards/arm/nrf9160dk_mini/nrf9160dk_mini.dts
    nrf9160dk_mini.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
    nrf9160dk_mini.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
    -- Generated zephyr.dts: /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated/devicetree_unfixed.h
    Parsing /home/riosh11/mini/zephyr/Kconfig
    Loaded configuration '/home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/.config'
    No change to configuration in '/home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/.config'
    No change to Kconfig header in '/home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated/autoconf.h'
    CMake Deprecation Warning at /home/riosh11/mini/modules/lib/civetweb/CMakeLists.txt:2 (cmake_minimum_required):
      Compatibility with CMake < 2.8.12 will be removed from a future version of
      CMake.
      Update the VERSION argument <min> value or use a ...<max> suffix to tell
      CMake that the project does not need compatibility with older versions.
    -- Configuring done (3.1s)
    CMake Warning (dev) at /home/riosh11/mini/zephyr/cmake/linker/ld/target.cmake:33 (add_custom_command):
      Policy CMP0116 is not set: Ninja generators transform DEPFILEs from
      add_custom_command().  Run "cmake --help-policy CMP0116" for policy
      details.  Use the cmake_policy command to set the policy and suppress this
      warning.
      /home/riosh11/mini/zephyr/CMakeLists.txt:682 (configure_linker_script)
    This warning is for project developers.  Use -Wno-dev to suppress it.
      warning.
      /home/riosh11/mini/zephyr/CMakeLists.txt:1021 (configure_linker_script)
    -- Generating done (0.1s)
    -- Build files have been written to: /home/riosh11/mini/mini-nbiot-firmware/build/spm
    === child image spm -  end ===
      CMake.
    /home/riosh11/mini/mini-nbiot-firmware/./extra/protobuf/nanopb/generator/nanopb_generator.py:22: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
      import pkg_resources # pyinstaller / protobuf 2.5 seem to need these
    Writing to ./lib/protobuf/command_msg.pb.h and ./lib/protobuf/command_msg.pb.c
    Writing to ./lib/protobuf/event_msg.pb.h and ./lib/protobuf/event_msg.pb.c
    Writing to ./lib/protobuf/event_payload.pb.h and ./lib/protobuf/event_payload.pb.c
    Writing to ./lib/protobuf/event_dev_info.pb.h and ./lib/protobuf/event_dev_info.pb.c
    Writing to ./lib/protobuf/command_payload.pb.h and ./lib/protobuf/command_payload.pb.c
    VERSION NUMBER: v0.1.0
    BUILD DATE: 20-03-2024, 12:23
    BUILD MACHINE: riosh11
    BUILD_INFO: v0.1.0-10-g74d7132+
    BOARD: nrf9160dk_minins
    -- Configuring done (7.0s)
      warning.
      warning.
    [1/250] Preparing syscall dependency handling
    [6/250] Performing build step for 'spm_subimage'
    [1/192] Preparing syscall dependency handling
    [14/192] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
    /home/riosh11/mini/zephyr/scripts/gen_kobject_list.py:66: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
      if LooseVersion(elftools.__version__) < LooseVersion('0.24'):
    [15/192] Generating include/generated/driver-validation.h
    [53/192] Building ASM object zephyr/arch/ar...h__arm__core__aarch32.dir/swap_helper.S.obj
    FAILED: zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    /usr/bin/cc -DBUILD_VERSION=v2.4.0-ncs2 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/home/riosh11/mini/zephyr/kernel/include -I/home/riosh11/mini/zephyr/arch/arm/include -I/home/riosh11/mini/zephyr/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated -I/home/riosh11/mini/zephyr/soc/arm/nordic_nrf/nrf91 -I/home/riosh11/mini/nrf/include -I/home/riosh11/mini/nrfxlib/crypto/nrf_cc310_mbedcrypto/include/mbedtls -I/home/riosh11/mini/nrfxlib/crypto/nrf_cc310_mbedcrypto/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/modules/nrfxlib/nrf_security/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/modules/nrfxlib/nrf_security/include/mbedtls_generated -I/home/riosh11/mini/mbedtls/include -I/home/riosh11/mini/mbedtls/include/mbedtls -I/home/riosh11/mini/modules/hal/cmsis/CMSIS/Core/Include -I/home/riosh11/mini/modules/hal/nordic/nrfx -I/home/riosh11/mini/modules/hal/nordic/nrfx/drivers/include -I/home/riosh11/mini/modules/hal/nordic/nrfx/mdk -I/home/riosh11/mini/modules/hal/nordic/. -I/home/riosh11/mini/nrf/samples/spm/kernel/include -isystem /home/riosh11/mini/zephyr/lib/libc/minimal/include -isystem /root/gcc/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /root/gcc/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /home/riosh11/mini/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -xassembler-with-cpp -imacros /home/riosh11/mini/zephyr/include/toolchain/zephyr_stdint.h -D_ASMLANGUAGE -Wno-unused-but-set-variable -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/home/riosh11/mini/nrf/samples/spm=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/riosh11/mini/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/riosh11/mini=WEST_TOPDIR -ffunction-sections -fdata-sections -mcmse -nostdinc -MD -MT zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj -MF zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj.d -o zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj -c /home/riosh11/mini/zephyr/arch/arm/core/aarch32/swap_helper.S
    cc: warning: ‘-mcpu=’ is deprecated; use ‘-mtune=’ or ‘-march=’ instead
    cc: error: unrecognized argument in option ‘-mabi=aapcs’
    cc: note: valid arguments to ‘-mabi=’ are: ms sysv
    cc: error: unrecognized command-line option ‘-mthumb’
    cc: error: unrecognized command-line option ‘-mfpu=fpv5-sp-d16’
    cc: error: unrecognized command-line option ‘-mfloat-abi=hard’
    cc: error: unrecognized command-line option ‘-mcmse’
    [57/192] Building ASM object zephyr/arch/ar...arch__arm__core__aarch32.dir/cpu_idle.S.obj
    FAILED: zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    /usr/bin/cc -DBUILD_VERSION=v2.4.0-ncs2 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/home/riosh11/mini/zephyr/kernel/include -I/home/riosh11/mini/zephyr/arch/arm/include -I/home/riosh11/mini/zephyr/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated -I/home/riosh11/mini/zephyr/soc/arm/nordic_nrf/nrf91 -I/home/riosh11/mini/nrf/include -I/home/riosh11/mini/nrfxlib/crypto/nrf_cc310_mbedcrypto/include/mbedtls -I/home/riosh11/mini/nrfxlib/crypto/nrf_cc310_mbedcrypto/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/modules/nrfxlib/nrf_security/include -I/home/riosh11/mini/mini-nbiot-firmware/build/spm/modules/nrfxlib/nrf_security/include/mbedtls_generated -I/home/riosh11/mini/mbedtls/include -I/home/riosh11/mini/mbedtls/include/mbedtls -I/home/riosh11/mini/modules/hal/cmsis/CMSIS/Core/Include -I/home/riosh11/mini/modules/hal/nordic/nrfx -I/home/riosh11/mini/modules/hal/nordic/nrfx/drivers/include -I/home/riosh11/mini/modules/hal/nordic/nrfx/mdk -I/home/riosh11/mini/modules/hal/nordic/. -I/home/riosh11/mini/nrf/samples/spm/kernel/include -isystem /home/riosh11/mini/zephyr/lib/libc/minimal/include -isystem /root/gcc/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /root/gcc/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem /home/riosh11/mini/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -xassembler-with-cpp -imacros /home/riosh11/mini/zephyr/include/toolchain/zephyr_stdint.h -D_ASMLANGUAGE -Wno-unused-but-set-variable -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/home/riosh11/mini/nrf/samples/spm=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/riosh11/mini/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/riosh11/mini=WEST_TOPDIR -ffunction-sections -fdata-sections -mcmse -nostdinc -MD -MT zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj -MF zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj.d -o zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj -c /home/riosh11/mini/zephyr/arch/arm/core/aarch32/cpu_idle.S
    [62/192] Building C object zephyr/arch/arch...s/arch__arm__core__aarch32.dir/thread.c.obj
    [11/250] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
    [12/250] Generating include/generated/driver-validation.h
    FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a /home/riosh11/mini/mini-nbiot-firmware/build/modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/zephyr.hex /home/riosh11/mini/mini-nbiot-firmware/build/spm/zephyr/zephyr.elf /home/riosh11/mini/mini-nbiot-firmware/build/spm/libspmsecureentries.a
    cd /home/riosh11/mini/mini-nbiot-firmware/build/spm && /usr/local/lib/python3.10/dist-packages/cmake/data/bin/cmake --build . --
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /home/riosh11/mini/mini-nbiot-firmware/build
    Please find the attached text file of log. while building by using the command "west build -p -b board"
    this error comes.
  • This seems like an issue with the nRF Connect SDK itself and not the project.
    How do you install the nRF Connect SDK?
  • And which distro do you run?
    Have you had the nRF Connect SDK work before?
    Also see these questions:
    Sigurd Hellesvik said:
    Do you see the same issue when building your custom code for a DK?
    Do you see the same issue when building a sample for your custom board?
  • Hi sir,
    This is an docker containers files. the total dependencies working automatically generated once we cloned the files from the git.
    After cloning the project we need to use two commands.
    west init -l
    west update
    by using the above two commands, everything will be downloaded.
    vs code extensions only we need to add, i was does that. while building the project I'm getting above error.
    App-image also not working on Ubuntu 20.04 version. can you share me suitable files with app-image run.
    Thanks and regards,
    Jagadish M
