Device not going to DFU mode on some devices
We are currently stuck with a big issue on as we are not able to update the devices(nRF52840) on field. We have changed the clock source to internal in the last released build. But we changed the settings only in the application and released only an application update. Now when we tried to release a new application many users are not able to update to the new version and we found that they are getting DFU error. Upon searching the devzone we found we should've updated the bootloader also with the same clock settings change as in application. More than 10k devices were able to update to the new version.
Does this says that those devices which were failing has external clock accuracy issue? Why is it failing on certain devices and not on other devices? How to fix this issue?
Also we changed the softdevice version to v7.3 and same like above we didn't change this in bootloader. What is the proper and best way to update SD and bootloader update in this scenarios. Considering the devices on field has bootloader with external clock and application with internal clock and the SD version 7.2. What is the proper DFU package file making process here to update Bootloader+SD+application?
Vishnu
