Feeding Independent Current-Measurements to Fuel-Gauge Algorithm
In a system that incorporates an nPM1300 (PMIC), we draw large amounts of current from our battery for certain portions of our circuit, and we must bypass the PMIC for this portion of the circuit.  Specifically, we have a high-current DC/DC circuit which has its input directly connected to the battery (bypassing the PMIC, and the VSYS output), however, the rest of the system runs off of the PMIC output (VSYS).  Because of this bypass, we must measure/estimate the battery current draw of this DC/DC circuit independently of the PMIC battery-current measurements, and feed this independent measurement to the fuel-gauge algorithm.
The question is:  Is there any precedent for doing this?  Is it expected that this would succeed or fail, with regards to getting accurate fuel-gauge information?
Thank you,
Ted
  • Thank you for the response.  It looks like this is unexplored territory!  We will run some tests, and I will report some results here, for anyone else interested.
    Thanks!
    Ted
  • No problem, that's why we are here. Sounds good to me, don't hesitate to ask if there are any questions or issues along the way
    Regards
    Runar
  • 1st update on test results.  For this test, I use the nPM1300 EK loaded with a battery model that was created by profiling our exact battery.  At the battery terminal of the EK, I also connected an external electronic load (thus bypassing the PMIC).  With the EK running, and communicating with the nPM-PowerUP PC application, I discharged the battery using the external electronic load (at a rate of about 0.6C).  On the graphs in the application, the battery drop was clearly visible, and the application also reported decreased remaining battery capacity.  The battery was completely discharge, and then I allowed the EK to charge the battery, figuring that might improve the fuel-gauge estimate.  I then discharged the battery a 2nd time, hoping the fuel-gauge estimate would give better results.  However, the capacity estimate was very inaccurate (off by ~70%), i.e., when the battery was actually completely discharged, the fuel-gauge said there was still 70% remaining.
    So it seems using only battery voltage, the fuel-gauge isn't very accurate.  Not an unexpected result.  The next test will also feed the fuel gauge algorithm estimated current on the path the bypasses the PMIC.  However, I don't think I'll be able to use the EK and PowerUp application for this, I'll have to use a custom application on an nRF device so that I can input the estimated current into the function calls of the fuel-gauge.
  • Thanks for the update. I don't have to much to say myself but I have passed on the information to the PMIC team in case they have some observations
    Regards
    Runar
  • Update: The PMIC team asked the following: If it was possible to repeat the test with logging enabled? If you could share the logged files so that we can have a look what's going on there. Also some screenshots of the graph window will help.
    Regards
    Runar
