OTA DFU on NORA B1
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need to add the OTA DFU to update the program from the nrf Connect mobile app. I changed the prj.conf and main according to this tutorial
https://getwavecake.com/blog/adding-ota-dfu-to-a-nordic-zephyr-project/
It works perfectly, when I am testing it on the Development Kit, but it does not work at all on the Nora B1. The flash is succesful, but the BLE can't get initialised.
I tried a bit and it seems like the problem is caused by the line
CONFIG_BOOTLOADER_MCUBOOT=y
when I add this to the prj. conf, BLE does not work, even when I did not do any changes in the main.
Is there anything special I should take care about while configuring bootloader on the NoraB1?
Thanks a lot for any answer
    I went through the project you shared, and I couldn't find any issues there. Is there any error message or log to share? It would be nice if I got any clue as to where the application was crashing. How can you confirm that this application is not working for your module?
    Kind Regards,
    Abhijith
  • Hello Abhijith
    Thank you a lot for the answer,
    as the aplication is working on the Development Kit, I do not have many options to Debug it on the Module. What I checked: The BLE does not advertise, the defined GPIO does not work. When I do not configure CONFIG_BOOTLOADER_MCUBOOT, all this works.
    I suppose that the module does not boot at all, because there is no output (GPIO) at all. Maybe you can give me some advice, how could I find out more information about where exactly the application crashes.
    Kind regards
    Jiri
    To narrow down this issue, try adding each configuration and seeing when and which configuration is triggering the issue. For doing this, take a simple sample (may be Hello World), include each configuration one by one, and see the result for each. See if it's the bootloader (MCUBOOT) triggering the issue.
    Kind Regards,
    Abhijith
  • Hello Abhijith,
    sorry for the late answer, I was out for a few days. I tested it as you suggested and the issue is really the MCUBOOT. Is there actualy any reason, why the NORA B1 can't do this? (Hardware)
    Kind regards
    Jiri
    Sorry for the late response; I was on vacation for some days.
    I don't know why it's behaving like this, and it's hard for me to reproduce this as I don't have the module you are working with. I am not sure on this, but is this a problem regarding the DC_DC being enabled for the module you are working on? Try disabling the DC_DC inside the prj.config and MCUboot.config.
    CONFIG_BOARD_ENABLE_DCDC=n
    CONFIG_BOARD_ENABLE_DCDC_APP=n
    CONFIG_BOARD_ENABLE_DCDC_NET=n
    Kind Regards,
    Abhijith
