download_client: Unexpected HTTP response: 400 bad request when CONFIG_MCUBOOT_IMG_MANAGER=n
If we enable MCUBOOT_IMG_MANAGER, SECURE_BOOT and BUILD_S1_VARIANT, FOTA works fine. However,
there is a constant 150mA power draw. If we disable them, power draw is normal but we then get "400 bad request" error.
Any idea why just enabling those three options causing the power draw or why not configuring them causes the bad request?
[00:00:18.082,580] <inf> download_client: Connecting to www.website.com
[00:00:18.339,508] <err> download_client: Unexpected HTTP response: 400 bad request
[00:00:18.339,996] <err> fota_download: Download client error
Received error from fota_download
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y #
#CONFIG_MCUBOOT_IMG_MANAGER=y
#CONFIG_SECURE_BOOT=y
#CONFIG_BUILD_S1_VARIANT=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
  • Here is the overlay file in the boards directory and in the child_image/mcuboot/boards directory:
    &uart0 {
    	status="disabled";
    &uart1 {
    	status="disabled";
    &uart2 {
    	status="disabled";
    CONFIG_SERIAL=n is set as well.
    Any additional thoughts?
  • Hmm, then I'm starting to run out of suggestions. Can you check if any UARTE instance are running at all in your project, and also double check the GPIOTE differences between the two zephyr.dts files?
    Simon
  • Here is the diff:
    $ diff build/zephyr/zephyr.dts build/mcuboot/zephyr/zephyr.dts
    9c9
    <               zephyr,entropy = &psa_rng;
    >               zephyr,entropy = &cryptocell;
    13a14
    >               zephyr,sram = &sram0_s;
    15,16c16,18
    <               zephyr,sram = &sram0_ns;
    <               zephyr,code-partition = &slot0_ns_partition;
    >               zephyr,code-partition = &slot0_partition;
    >               zephyr,sram-secure-partition = &sram0_s;
    >               zephyr,sram-non-secure-partition = &sram0_ns;
    34d35
    <               ext-flash = &mx25r16;
    60c61
    <               peripheral@40000000 {
    >               peripheral@50000000 {
    63c64
    <                       ranges = < 0x0 0x40000000 0x10000000 >;
    >                       ranges = < 0x0 0x50000000 0x10000000 >;
    102a104,107
    >                                               storage_partition: partition@fa000 {
    >                                                       label = "storage";
    >                                                       reg = < 0xfa000 0x6000 >;
    326,335c331
    <                                       status = "ok";
    <                                       partitions {
    <                                               compatible = "fixed-partitions";
    <                                               #address-cells = < 0x1 >;
    <                                               #size-cells = < 0x1 >;
    <                                               storage_partition: partition@0 {
    <                                                       label = "external-flash";
    <                                                       reg = < 0x0 0x1000000 >;
    >                                       status = "okay";
    475c471,488
    <               gpiote: gpiote@40031000 {
    >               cryptocell: crypto@50840000 {
    >                       compatible = "nordic,nrf-cc310";
    >                       reg = < 0x50840000 0x1000 >;
    >                       status = "okay";
    >                       cryptocell310: crypto@50841000 {
    >                               compatible = "arm,cryptocell-310";
    >                               reg = < 0x50841000 0x1000 >;
    >                               interrupts = < 0x40 0x1 >;
    >               ctrlap: ctrlap@50006000 {
    >                       compatible = "nordic,nrf-ctrlapperi";
    >                       reg = < 0x50006000 0x1000 >;
    >                       status = "okay";
    >               gpiote: gpiote@5000d000 {
    477,478c490,507
    <                       reg = < 0x40031000 0x1000 >;
    <                       interrupts = < 0x31 0x5 >;
    >                       reg = < 0x5000d000 0x1000 >;
    >                       interrupts = < 0xd 0x5 >;
    >                       status = "okay";
    >               spu: spu@50003000 {
    >                       compatible = "nordic,nrf-spu";
    >                       reg = < 0x50003000 0x1000 >;
    >                       interrupts = < 0x3 0x1 >;
    >                       status = "okay";
    >               ficr: ficr@ff0000 {
    >                       compatible = "nordic,nrf-ficr";
    >                       reg = < 0xff0000 0x1000 >;
    >                       status = "okay";
    >               uicr: uicr@ff8000 {
    >                       compatible = "nordic,nrf-uicr";
    >                       reg = < 0xff8000 0x1000 >;
    576,579d604
    <       psa_rng: psa-rng {
    <               compatible = "zephyr,psa-crypto-rng";
    <               status = "okay";
  • Hmm, okay, I'm not able to see any glaring issues in this diff at least, and so we think this must be a HW issue with some bad soldering perhaps. Can you upload the schematics and PCB layout for your custom board so we can review them on our end to confirm everything is as it should be. Also please double check that the board you're seeing this issue on is soldered correctly.
    Simon
  • It happens on multiple, professionally manufactured boards. Can't imagine a soldering issues when the only change is in prj.conf. Schematic was previously sent privately and said it was ok.
