nRF5340 BLE: the configuration for BLE MTU
Hi Support Team,
I tried the BLE communication with the Nordic UART Service (NUS) and used the code in the 'Bluetooth Low Energy Fundamentals Lesson 4 - Exercise 3' course.
The default MTU size was too small for my application. I preferred not to change the code in the hci_rpmsg on the netCore, so I added the below configuration on the appCore side:
1. In the files \bt-fund-main\lesson4\blefund_less4_exer3_solution\child_image\hci_rpmsg.conf:
#GATT_CLIENT needed for requesting ATT_MTU update
CONFIG_BT_GATT_CLIENT=y
#PHY update needed for updating PHY request
CONFIG_BT_USER_PHY_UPDATE=y
#For data length update
CONFIG_BT_USER_DATA_LEN_UPDATE=y
#This is the maximum data length with Nordic Softdevice controller
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
#These buffers are needed for the data length max.
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
#This is the maximum MTU size with Nordic Softdevice controller
CONFIG_BT_L2CAP_TX_MTU=247
# Maxmum 2 connections are enough
CONFIG_BT_MAX_CONN=2
2. In the \bt-fund-main\lesson4\blefund_less4_exer3_solution\prj.conf:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
CONFIG_BT_NUS_UART_BUFFER_SIZE=400
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_RX_STACK_SIZE=2048
# Enable the NUS service
# STEP 1 - Enable the Kconfig symbol of the NUS service
CONFIG_BT_NUS=y
CONFIG_BT_NUS_AUTHEN=n
CONFIG_BT_NUS_SECURITY_ENABLED=n
# Enable bonding
CONFIG_BT_SETTINGS=n
CONFIG_FLASH=n
CONFIG_FLASH_PAGE_LAYOUT=n
CONFIG_FLASH_MAP=n
CONFIG_NVS=n
CONFIG_SETTINGS=n
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
#########################Added to increase the MTU###############################
# STEP 8 - Enable PHY updates.
# STEP 12 - Update Data Length and MTU
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
But it did not work. Could you help me with the below questions:
(1). Could you help review the above configurations? what was missed for the MTU setting?
(2). I'm a little confused about the configuration alignment on the host and controller sides.  For Data Length, MTU, and PHY_UPDATE, which need to align the configuration on both host and controller? which only needs to change single side configuration? In Lesson 3 – Exercise 2, it sets all in the host's prj.conf file.
Thank you very much,
Yanpeng Wu
  • Hi Edvin,
    I'm now connecting the nRF5340 to a mobile phone with the 'nRF Connect Mobile APP'.
    Is the rx_data_length the result of the negotiation by both sides and can not be set in the application code?
    I just tried to connect with a laptop, and I can see the data length in both tx and rx are 251. But BLE disconnected immediately(reason =19 = 0x13  #define BT_HCI_ERR_REMOTE_USER_TERM_CONN        0x13):
    1. MTU negotiation failed.
    <wrn> ble_host: [Ble Connected]: addr = 68:7A:64:AF:0A:09 (public)
    <wrn> ble_host: [Data len Update]: Updated. Length 251/251 bytes, time 2120/2120 us
    <wrn> ble_host: [Mtu negotiation]: MTU Exchange failed: err 14  //EFAULT 14, Bad address
    <wrn> ble_host: [Ble Disconnected] - current_conn, 68:7A:64:AF:0A:09 (public) (reason 19)
    The error info was printed in callback mtu_exchange_notify_cb(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params).
    2. MTU negotiation succeed, but BLE also disconnected.
    <wrn> ble_host: [Mtu negotiation]: New MTU = 247 bytes, payload_mtu = 244
    <wrn> ble_host: [Data len Update]: Updated. Length 251/251 bytes, time 328/2120 us
    But with 'nRF Connect Mobile APP' the connection is always successful. Need to do some setting when connecting to a laptop?
    Yanpeng Wu
  • I am not sure about the laptop. Do you know if it is the laptop or the nRF that initiates the disconnect? Can you please try to capture a sniffer trace? You can use the nRF Sniffer for Bluetooth LE.
    What kind of phone are you using? You can initiate the MTU exchange from any of the devices, both for TX and RX. In fact, it already does that (if you are using the pfj.conf and hci_rpmsg.conf that we have discussed. And the fact that the laptop gives you max MTU both ways suggests that it is set up correctly from the nRF side.
    What I suspect (a sniffer trace of the connection between the phone and the nRF could give a clear answer) is that the phone doesn't support MTU TX larger than the default. Do you have another phone that you can test on?
    What does your mtu_exchange_notify_cb() look like? And what does your MTU request function look like?
    Edvin
  • Hi Edvin,
    I found that the MTU exchange failure and the different tx/rx data length are caused by the mobile phone. When I used two laptops to connect to nRF5340, both MTU exchange and data length negotiation were successful.
    I will use a laptop connection for future tests.
    One strange is that the connection will be disconnected in a short time with reason=19, that means the connection was terminated by the laptop.
    the trace likes:
        <wrn> ble_host: [Ble Connected]: addr = 74:70:FD:53:85:C6 (public)
        <wrn> ble_host: [Ble Disconnected] - current_conn, 74:70:FD:53:85:C6 (public) (reason 19)
    I will use the Sniffer and debug trace to see more details. If you have any hint for this, which is appreciated.
    Yanpeng Wu
  • Please see the instructions on how to install the sniffer. Then you need to select the advertising device from the dropdown list near the top while sniffing. After that it should follow the peripheral into the connection. If you use encryption (other than "just works" pairing), you need to enter the passkey in the top before you pair.
    You can also compare connecting to the laptop with connecting to the laptop running nRF Connect for Desktop ->Bluetooth Low Energy (which uses a DK/dongle for the BLE operations). Does it disconnect in both cases?
    After capturing a sniffer trace, you can save it as a .pcapng file, and upload it  here.
    BR,
    Edvin
  • Hi Edvin
    The initial question of MTU configuration has been solved in this ticket. I closed it.
    For the connection problem with laptops, I will try it with your suggestions later.
    Thank you very much.
    Yanpeng Wu
