NRF5340 HCI_USB & HCI_UART Stop Scanning
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all of the base functionality in the nrf5340 module, but also adds an external FEM in increase the TX power. I am utilizing the Zephyr/nrf SDK version 2.4.1 (received from Laird for updated TX power setting rules: GitHub - LairdCP/bl5340pa_manifest: Manifest for the Laird Connectivity fork of the nRF Connect SDK with support for the BL5340PA). I am attempting to utilize either the HCI_USB or HCI_UART firmware projects, that come with Zephyr, in order to make this custom board a reliable BLE adapter for Linux. My Linux device is running off of kernel version 5.4.0-174-generic and is connected to the custom board through the NRF USB interface on the nrf5340. My BlueZ is version 5.66. The below actions are what I am trying to accomplish:
  1. Reliable BLE Adapter over USB or CDC-ACM USB
  2. Application Core Firmware Update over CDC-ACM USB
    1. Currently using MCUMGR
  3. Network Core Firmware Update over CDC-ACM USB
    1. Not functional, as no external flash on custom board. Need method to use internal flash
The items above I would like to complete in that priority as well. Therefore I will focus on the BLE Adapter functionality with mentions to the others.
My Issue:
  • Utilizing the HCI_USB or HCI_USB project, HCI_UART is sent through the CDC-ACM driver and setup with BTATTACH (HCIATTACH tried too, same effect, and it is deprecated now) in Linux as H4 protocol with 1000000 speed, whereas HCI_USB is automatically recognized by BTUSB driver in Linux and setup. I can communicate, connect, pair, and perform all necessary BT actions between both of these projects (this has been tested using BluetoothCTL and HCI_BUS commands in C++ code). After some time (HCI_UART, few minutes to an hour. HCI_USB, hour to two hours) of Scanning for devices the adapter will stop functioning, communication will halt on a timeout (This is shown in the image below, as output from DMESG, below that is what appears in BTMON). In some Debug Messages from the custom board I have received a "<wrn> bt_hci_driver: Couldn't allocate a buffer after waiting 10 seconds." error when this occurs. After this error occurs there are a few different methods of resetting the board that work to recover and regain BLE functionality with BlueZ.
    • Recovery Methods
      • HCI_USB
        • bluetoothctl.power off -> bluetoothctl.power on
        • Or any hard power reset of board
          • Details: Default Zephyr Project
      • HCI_UART
        • Hard power reset of board
          • Details: Default Zephyr Project, with addition of CDC-ACM configuration for bt-c2h-uart redirection.
      • HCI_USB with MCUMGR
        • MCUMGR reset
        • or any hard power reset of board
          • Details:
            • This project is implemented with a change in the SDK to allow the CDC-ACM interface to always be second, allowing HCI_USB to use the first interface and BTUSB to recognize this. Both USB interfaces are active at the same time, as seen when plugging into Windows, but Linux only allows one to be active as the BTUSB and CDC drivers conflict on assignment. Meaning that in order to switch the USB interface of the board has to be unbinded.
      • HCI_UART with MCUMGR
        • MCUMGR reset
          • Details:
            • 2 CDC-ACM ports, one for MCUMGR and one for HCI_UART
I have seen this issue across every attempt with these firmware projects, and any configuration I try with them. Eventually the board will stop functioning as a BT adapter and some, possibly extensive, actions have to be taken to recover it. From my investigation, this seems to be, on the surface, a memory or issue in the speed of communication. As the issue occurs faster when there are many more Bluetooth devices available to be scanned. I tried using the same testing methods with another Linux BT Adapter (Intel AX210) and they did not occur, which let me know that this is an issue within my Zephyr firmware. This issue seems to occur faster with the HCI_UART version of the firmware, as opposed to HCI_USB.
I have researched this issue everywhere and cannot find a good solution or any solution to resolve this. Below are some links that I have gone to find any solution:
https://lists.zephyrproject.org/g/devel/topic/hci_interface_stopped_working/71746540?p=,,,20,0,0,0::recentpostdate%2Fsticky,,,20,2,640,71746540
https://github.com/zephyrproject-rtos/zephyr/issues/20250
https://github.com/zephyrproject-rtos/zephyr/issues/37731
Code from my HCI_UART_MCUMGR project:
-  prj.conf
"prj.conf"
#  Custom-Board Project Configuration
## HCI_UART Project Configuration --------------------------------------
# --- Sets up the UART interface for HCI control of the BT Carrier Board
# -- From default HCI_UART project with few removals due to conflicts
CONFIG_STDOUT_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_BT=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_HCI_RAW_H4=y
CONFIG_BT_HCI_RAW_H4_ENABLE=y
CONFIG_BT_BUF_ACL_RX_SIZE=255
CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
CONFIG_BT_MAX_CONN=16
CONFIG_BT_TINYCRYPT_ECC=n
# Workaround: Unable to allocate command buffer when using K_NO_WAIT since
# Host number of completed commands does not follow normal flow control.
CONFIG_BT_BUF_CMD_TX_COUNT=10
## HCI -> USB Project Configuration --------------------------------------
# --- Sets up the USB interface to be used for communication
# --- USB Interface is used for MCUMGR and HCI_UART
# --- Composite USB configuration allowing multiple USB interfaces
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Custom-Board"
#CONFIG_USB_DEVICE_PID=
#CONFIG_USB_DEVICE_VID=
CONFIG_USB_CDC_ACM=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_UART_LINE_CTRL=y
## MCUMGR/MCUBOOT Project Configuration --------------------------------------
# --- Enables MCUMGR that is used for Image Management
# --- Enables MCUBOOT bootloader to handle the images on the carrier board, as well as booting
# Enable MCUmgr and dependencies.
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
CONFIG_MAIN_STACK_SIZE=2048
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable flash operations.
CONFIG_FLASH=y
# Required by the `taskstat` command.
CONFIG_THREAD_MONITOR=y
# Support for taskstat command
CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
# Enable statistics and statistic names.
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
# Enable most core commands.
CONFIG_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_STAT=y
# Enable logging
CONFIG_LOG=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
# Disable debug logging
CONFIG_LOG_MAX_LEVEL=3
CONFIG_MCUMGR_TRANSPORT_UART=y
CONFIG_BASE64=y
- mcuboot.conf
"mcuboot.conf"
#  MCUBOOT Child Image Configuration
# Enable Pin Control
CONFIG_PINCTRL=y
# Enable code size optimization on the compiler
CONFIG_SIZE_OPTIMIZATIONS=y
# Enable multi threading.
CONFIG_MULTITHREADING=y
# Add private key for MCUboot. Refer to these sites for more information:
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/app_dev/bootloaders_and_dfu/bootloader_adding.html#id11
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/app_dev/bootloaders_and_dfu/fw_update.html#ug-fw-update-keys-python
CONFIG_BOOT_SIGNATURE_KEY_FILE="custom_file_and_path_here.pem"
- hci_rpmsg.conf (to setup FEM)
"hci_rpmsg.conf"
#  HCI_RPMSP Child Image Configuration
CONFIG_PINCTRL=y
# Enable SPI
# Enabled for FEM control
CONFIG_SPI=y
# Enable MPSL and FEM
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_NRF21540_GPIO=y
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20
CONFIG_BT_CTLR_TX_PWR_ANTENNA=20
CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
- bl5340pa_dvk_cpuapp.overlay (I have custom board files made for my board, but for ease of testing it also works with the bl5340pa DVK default board files. Both configurations give the same results)
"bl5340pa_dvk_cpuapp.overlay"
	chosen {
	   zephyr,uart-mcumgr = &cdc_acm1;
	   zephyr,bt-c2h-uart = &cdc_acm0;
&zephyr_udc0 {
	cdc_acm0: cdc_acm0 {
		compatible = "zephyr,cdc-acm-uart";
	cdc_acm1: cdc_acm1 {
&uart0 {
	current-speed = <1000000>;
	status = "disabled";
	hw-flow-control;
The Main.C src file of HCI_USB and HCI_UART is unedited from either of the examples.
As a note on the above, this has also been tested without any of the FEM or MCUBOOT/MCUMGR configurations to ensure that is not affecting the projects. Same effect observed.
Questions:
  1. Is there something that I am missing that is causing this issue?
    1. On the Zephyr Configuration side?
    2. On the Linux/BlueZ setup side?
  2. Is there another method to perform my desired actions that would avoid these issues?
  3. Is this the right place to investigate this?
  4. Or any other advice would be greatly appreciated.
Thank you to whomever can help with this issue, as it has been causing me a lot of troubles. Let me know if I can supply any addition information that would assist in resolving this.
