implementing custom service
product details:
nRF52840 custom board
nRFConnectSDK 2.2.0
we want to implement custom service interacting with the Android app.
Where we will receive on command from Android app and we will do some processing and sending the data back to the android app.
For this what and all we need to do.
for ex: service
what characteristics and what descriptors are needed and their properties.
All we need to know is how to write custom service and for our requirement what we need to add.
  • Srikara said:
    Still we need CONFIG_NRFX_UARTE0=y with CDC_ACM interface to iMX and also UART interface?
    I do not think you need UARTE drivers to do CDC_ACM, no.
    Srikara said:
    Is this both possible in single application. Currently as you suggested we are in process to move UART method to serial recovery method. But before that making our code work with BLE over UART has become priority. So requesting this in paralllel to other ticket.
    MCUmgr only supports one interface at a time for its DFU, unfortunally. It is probably possible to work around this somehow, but I do not think it will be easy.
    I think that generally, it will be easier to make the app if you have different application code for the UART device and the CDC ACM device.
  • Hi
    Sorry, ithink misunderstood.
    I am asking about second picture where it is UART interface to iMX.
    In this case UARTE0 is needed and it uses uart0 and in actual communication case also
    #define UART_DEVICE_NODE DT_CHOSEN(zephyr_shell_uart)
    struct device *uart_dev = DEVICE_DT_GET(UART_DEVICE_NODE);
    uart0 is used.
    So we want both BLE and uart communication need to be worked.
    Please gothrough the code i ahve shared. YOu will have a clue what i am asking.
    This code is merging of two nRF connect SDK sample applications.
    C:\ncs\v2.2.0\nrf\samples\bluetooth\peripheral_uart
    and C:\ncs\v2.2.0\zephyr\samples\drivers\uart\echo_bot
    these two together should work on uart communication.
    The peripheral_uart sample already does UART for your.
    I do not think merging these two samples makes much sense.
    You have two alternatives, and I am not sure which one you need. Here they are, with suggested solutions:
    1. Receive data over UART from iMX and send directly over BLE without changing data:
      1. Run Peripheral UART sample as is. Minor changes needed.
    2. Receive data over UART from iMX. Do operations with data on nRF. Then send something else over BLE.
      1. Learn how to implement Bluetooth applications from DevAcademy Bluetooth course. Specifically its Lesson on Bluetooth and UART will be useful for you.
    Do I understand correctly? Does my suggestions make sense?
  • we need both, same customer may send the data from iMX and android app.
    If he is sending request from android app, he will receive response to android app.
    for example: read command is sent
    then all the nearby RFID tags details will be sent to android app
    If he is sending from iMX he will be received to iMX
    then all the nearby RFID tags details will be sent to iMx
    Like read we have lot of commands so usage may be iMX/Android app.
    This is our requirement. Will this can be done? If so How we will do it.
    Based on our requirement i think this is not useful i Believe.
    These sound like custom requirements for Bluetooth LE operations.
    I suggest that you take the DevAcademy Bluetooth Course and learn how to implement your own Bluetooth LE applications so you can make it custom to match your requirements.
    EDIT:
    And when I say "custom", I mean that we do not have any samples that does exactly this
