The official demo of AoA/AoD shows an error about cte_report_cb
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb'
254 | .cte_report_cb = cte_recv_cb,
../src/main.c:254:26: warning: initialization of '_Bool (*)(struct bt_conn *, struct bt_le_conn_param *)' from incompatible pointer type 'void (*)(struct bt_conn *, const struct bt_df_conn_iq_samples_report *)' [-Wincompatible-pointer-types]
../src/main.c:254:26: note: (near initialization for 'bt_conn_cb_conn_callbacks.le_param_req')
[27/118] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'd:\AoAAoD\direction_finding_central\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
In VSCode:
I found two similar problems in Nordic DevZone, but it doesn't seem to be solved:
Direction_finding_central test
Problems building Direction_finding_central sample
Other than that, I didn't find any helpful posts using Google.
I am a beginner in BLE and just finished the basic Bluetooth course in Nordic a few days ago. So, I don't think I had any problems with my environment, In that I was able to run all the demos In Bluetooth Low Energy Fundamentals.
I directly built the demo named direction finding central without any modification, because I did not see any information in the document that necessary to be changed to build successfully. Note that I just built it, it doesn't involve flash, so I don't think it's hardware related.
In contrast, the associated demo called direction finding peripheral was build successfully without any modification.
My operating system is Windows 10.
My nRF Connect SDK is v2.5.1.in VSCode.
My Zephyr version: 3.4.99
I don't know if this is an official Sample Bug, because I'm just getting started with embedded development. Is there any information that can help me?
    I once tried to copy this project to the same disk, but it didn't work [sad].
    Actually, when I was learning the Nordic Bluetooth course, all the new projects on the D disk were built very well.
    So I still think there is something wrong (at least something not very universal) in this sample.
    Now I'm testing the connectionless sample which can be built properly at least. But since it doesn't meet all my needs, I'm still following this error on the connection-based example.
    I hope this problem can attract the attention of your direction finding engineers. There are three people have already encountered this problem as I mentioned earlier, but none of them have been solved yet.
    Zihao
  • I strongly believe that this issue is related to the version or configuration of Zephyr. Is there anything specific I should know about configuring Zephyr?
    My Zephyr installation was automated by the Toolchain during the installation of the nRF Connect SDK, and it is currently at version 3.5.99. I wrote 3.4.99 in this post, but as I later tried to update to nRF Connect SDK v2.6.0, it was changed to 3.5.99.
    I would greatly appreciate any possible clues you could provide. Thank you!
    Yours,
    Zihao
  • hello, could you please provide your nRF Connect SDK version and Zephyr version? Because you said you successfully built this project on your end.I think this is probably due to the API related to BLE direction finding in Zephyr.
    Thank you very much.
    Yours,
    Zihao
  • Hi
    I have contacted the DF developers now, and will see if they have some input on this, as I can't think of what it would be either then. On my end I'm able to build it for both NCS 2.5.1 and 2.6.0 with the Zephyr versions 3.4.99 and 3.5.99, so I don't see why it would be a Zephyr configuration issue either...
    I'll let you know when I hear from them. Thank you for being patient and thorough on your end!
    Simon
  • Hi Simon
    Thanks for your reply. But I now think this issue is not related to the version. I have also built this project on my end with the same version as yours(include NCS and Zephyr), but still encountered this issue.
    I think I can make this problem clearer. I didn't notice the warning before:
    warning: BT_DF_CONNECTION_CTE_RX (defined at C:/ncs/v2.5.1/zephyr/subsys/bluetooth/host/Kconfig:847,
    subsys/bluetooth\host/Kconfig:847) was assigned the value 'y' but got the value 'n'. Check these
    unsatisfied dependencies: (((!BT_CTLR || BT_CTLR_DF_CTE_RX_SUPPORT) && BT_DF && BT_HCI_HOST &&
    BT_RPC_STACK) || ((!BT_CTLR || BT_CTLR_DF_CTE_RX_SUPPORT) && BT_DF && BT_HCI_HOST && BT_HCI && BT))
    (=n). See docs.zephyrproject.org/.../kconfig.html and/or
    look up BT_DF_CONNECTION_CTE_RX in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    warning: BT_DF_CONNECTION_CTE_REQ (defined at
    C:/ncs/v2.5.1/zephyr/subsys/bluetooth/host/Kconfig:861, subsys/bluetooth\host/Kconfig:861) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    ((BT_DF_CONNECTION_CTE_RX && BT_DF && BT_HCI_HOST && BT_RPC_STACK) || (BT_DF_CONNECTION_CTE_RX &&
    BT_DF && BT_HCI_HOST && BT_HCI && BT)) (=n). See
    docs.zephyrproject.org/.../kconfig.html and/or look up
    BT_DF_CONNECTION_CTE_REQ in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    I am a beginner in BLE. When I studied the Nordic BLE course, my understanding was:
    If I set
    CONFIG_BT_DF_CONNECTION_CTE_RX=y
    CONFIG_BT_DF_CONNECTION_CTE_REQ=y
    in prj.conf,
    but didn't set any options in nrf52833dk_nrf52833.conf, then the final settings will be y. Actually, the official sample settings are same as mine(Because I just want to build and flash them without any modification.).
    However, in build it's 'n ' instead of  'y'.
    The same question is occurred in the direction finding connectionless rx sample on my end.
    It's like:
    CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y In build:n
    Also, I just tried to build the official sample without any modification.
    In Zephyr, the BLE direction finding code is wrapped in:
    #if defined(CONFIG_BT_DF_CONNECTIONLESS_CTE_RX)
    So these code is not recognized when compiling.
    Then the error occureed:
    D:/AoAoD2/direction_finding_connectionless_rx/src/main.c:249: undefined reference to `bt_df_per_adv_sync_cte_rx_enable'
    D:/AoAAoD/direction_finding_central/src/main.c:254:10: error:  'const struct bt_conn_cb' has no member named 'cte_report_cb'
    VSCode tells me about Missing dependencies which led to this error:
    CONFIG_BT_DF_CONNECTIONLESS_CTE_RX was assigned the value y, but got the value n. Missing dependencies:
    ((!BT_CTLR || BT_CTLR_DF_CTE_RX_SUPPORT) && BT_DF && BT_HCI_HOST && BT_RPC_STACK) || ((!BT_CTLR || BT_CTLR_DF_CTE_RX_SUPPORT) && BT_DF && BT_HCI_HOST && BT_HCI && BT)
    Support for receive of CTE in connectionless mode
    Type: bool
    Value: n
    Enable support for reception and sampling of Constant Tone Extension in connectionless mode.
    I have tried to add them in prj.conf like:
    CONFIG_BT_HCI=y
    CONFIG_BT_CTLR=y
    CONFIG_BT_CTLR_DF_CTE_RX_SUPPORT=y
    CONFIG_BT_HCI_HOST=y
    CONFIG_BT_RPC_STACK=y
    Then it show me that:
    CONFIG_BT_CTLR_DF_CTE_RX_SUPPORT was assigned the value y, but got the value n. Missing dependencies:
    BT_HCI
    Symbol CONFIG_BT_HCI_HOST cannot be set (has no prompt)
    So now I'm confused and don't know how to solve the missing dependencies problem.
    Any useful information would be appreciated, thanks!
    Yours,
    Zihao
