I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb'
254 | .cte_report_cb = cte_recv_cb,
../src/main.c:254:26: warning: initialization of '_Bool (*)(struct bt_conn *, struct bt_le_conn_param *)' from incompatible pointer type 'void (*)(struct bt_conn *, const struct bt_df_conn_iq_samples_report *)' [-Wincompatible-pointer-types]
../src/main.c:254:26: note: (near initialization for 'bt_conn_cb_conn_callbacks.le_param_req')
[27/118] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'd:\AoAAoD\direction_finding_central\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
In VSCode:
I found two similar problems in Nordic DevZone, but it doesn't seem to be solved:
Direction_finding_central test
Problems building Direction_finding_central sample
Other than that, I didn't find any helpful posts using Google.
I am a beginner in BLE and just finished the basic Bluetooth course in Nordic a few days ago. So, I don't think I had any problems with my environment, In that I was able to run all the demos In Bluetooth Low Energy Fundamentals.
I directly built the demo named direction finding central without any modification, because I did not see any information in the document that necessary to be changed to build successfully. Note that I just built it, it doesn't involve flash, so I don't think it's hardware related.
In contrast, the associated demo called direction finding peripheral was build successfully without any modification.
My operating system is Windows 10.
My nRF Connect SDK is v2.5.1.in VSCode.
My Zephyr version: 3.4.99
I don't know if this is an official Sample Bug, because I'm just getting started with embedded development. Is there any information that can help me?
