Zigbee Communication with Network Coordinator with Light Switch
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made board which having nrf52840 configured as Zigbee light switch.
I Established connection and created Binding between both. But am not able to communicate with Light Switch from Coordinator through ZCL Commands.
Please find the attached document which i tried in shell command.
1) How to establish communication between network coordinator with end device or router using Zigbee.
please guide me to solve the issue.
2) What is the Traffic Key Zigbee coordinator Example using ? where can we change (API To change traffice Key) it?
I: nRF5 802154 radio initialized
*** Booting nRF Connect SDK v2.5.2 ***
I: Starting ZBOSS Coordinator example
I: ZBOSS Coordinator example started
uart:~$ E: Zigbee shell endpoint: 1 is not registered.
I: Production configuration is not present or invalid (status: -1)
I: Zigbee stack initialized
I: Device started for the first time
I: Start network formation
I: Unimplemented signal (signal: 54, status: 0)
I: Network formed successfully, start network steering (Extended PAN ID: f4ce365044756cb7, PAN ID: 0xb435)
I: Allow pre-Zigbee 3.0 devices to join the network
I: Network steering started
  bdb                clear              device             devmem
  flash              help               history            kernel
  nbr                nrf_clock_control  resize             retval
  sensor             shell              version            zcl
  zdo
uart:~$ bdb role set zc
role: wrong parameter count
role - Set/get role.
Subcommands:
  zc   :Set Coordinator role.
  zed  :Set End Device role.
  zr   :Set Router role.
uart:~$ bdb role
zc
Done
uart:~$ bdb start
Done
uart:~$ I: Unimplemented signal (signal: 54, status: 0)
I: Network steering finished
I: Network formed successfully, start network steering (Extended PAN ID: f4ce365044756cb7, PAN ID: 0x7a66)
bdb start
Done
bdb roI: Device update received (short: 0x9153, long: f4ce369e3f3451ab, status: 1)
lI: New device commissioned or rejoined (short: 0x9153)
I: Joining period extended.
eI: Device authorization event received (short: 0x9153, long: f4ce369e3f3451ab, authorization type: 1, authorization status: 0)
  zdo
uart:~$ zdo match_desc 0xfffd 0xfffd 0x0104 1 0 0
Sending broadcast request.
src_addr=9153 ep=1
uart:~$ zdo ieee_addr 9153
f4ce369e3f3451ab
Done
uart:~$ zdo eui64
f4ce365044756cb7
Done
uart:~$ zdo mgmt_bind 9153
[idx] src_address      src_endp cluster_id dst_addr_mode dst_addr         dst_endp
Total entries for the binding table: 0
Done
Done
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 2 0 3 0
on: wrong parameter count
on - Create bind entry.
     Usage: on <h:source_eui64> <d:source_ep> <h:destination_addr>
     <d:destination_ep> <h:source_cluster_id> <h:request_dst_addr>
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 2 0 3I: Network steering finished
zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 I: Network steering finished
zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 0x0000 9153
Done
[  0] f4ce369e3f3451ab        1       0000           003 f4ce365044756cb7      010
Total entries for the binding table: 1
Done
uart:~$ zcl attr read 9153 1 0x0000 0x0104 0
Error: Request timed out
src_addr=9153 ep=1
Done
uart:~$ zcl attr read 9153 1 0x0000 0x0104 0x00 0x21 0x0F
read: wrong parameter count
read - Send Read Attribute Zigbee command.
       Usage: read <h:dst_addr> <d:ep> <h:cluster> [-c] <h:profile> <h:attr_id>
       -c switches the server-to-client direction.
       h: is for hex, d: is for decimal.
uart:~$ zcl attr write 9153 1 0x0000 0x0104 0x00 0x21 0x0F
uart:~$ I: Enter identify mode
zdo nwk_addr f4ce365044756cb7
Error: Network address request timed out
src_addr=9153 ep=1
Done
uart:~$ zdo match_desc 0xfffd 0xfffd 0x0104 1 0 0I: Find and bind target finished (status: 0)
zdo simple_desc_req 9153 1
src_addr=9153 ep=1
uart:~$ zdo simple_desc_req 0x9153 1
src_addr=0x9153 ep=1 profile_id=0x0104 app_dev_id=0x104 app_dev_ver=0x0 in_clusters=0x0000,0x0003 out_clusters=0x0003,0x0005,0x0004,0x0006,0x0008
Done
Done
uart:~$ zdo cmd f4ce369e3f3451ab 1 0x0008 -p 0x0104 0x00 -l 0affff
zdo - ZDO manipulation.
Subcommands:
  active_ep        :Send active endpoint request.
                    Usage: active_ep <h:16-bit destination_address>
  simple_desc_req  :Send simple descriptor request.
                    Usage: simple_desc_req <h:16-bit destination_address>
                    <d:endpoint>
  match_desc       :Send match descriptor request.
                    Usage: match_desc <h:16-bit destination_address>
                    <h:requested address/type> <h:profile ID> <d:number of input
                    clusters> [<h:input cluster IDs> ...] <d:number of output
                    clusters> [<h:output cluster IDs> ...] [-t | --timeout
                    d:number of seconds to wait for answers]
  nwk_addr         :Resolve EUI64 address to short network address.
                    Usage: nwk_addr <h:EUI64>
  ieee_addr        :Resolve network short address to EUI64 address.
                    Usage: ieee_addr <h:short_addr>
  eui64            :Get/set the eui64 address of the node.
                    Usage: eui64 [<h:eui64>]
  short            :Get the short address of the node.
  bind             :Create/remove the binding entry in the remote node.
  mgmt_bind        :Get binding table (see spec. 2.4.3.3.4)
                    Usage: <h:short> [d:start_index]
  mgmt_leave       :Perform mgmt_leave_req (see spec. 2.4.3.3.5)
                    Usage: mgmt_leave <h:16-bit dst_addr> [h:device_address
                    eui64] [--children] [--rejoin]
                    --children - Device should also remove its children when
                    leaving.
                    --rejoin - Device should rejoin network after leave.
  mgmt_lqi         :Perform mgmt_lqi request.
                    Usage: mgmt_lqi <h:short> [d:start index]
uart:~$ zdo
Subcommands:
                    <d:endpoint>
                    leaving.
uart:~$ zdo active_ep 0x9153
src_addr=9153 ep=1
Done
uart:~$ zcl cmd f4ce369e3f3451ab 1 0x0008 -p 0x0104 0x00 -l 0affff
uart:~$ zdo ping f4ce369e3f3451ab 30
Subcommands:
                    <d:endpoint>
                    leaving.
uart:~$ zcl ping f4ce369e3f3451ab 30
Error: Request timed out after 9900 ms.
Done
Subcommands:
                    <d:endpoint>
                    leaving.
uart:~$ zdo simple_desc_req 0x9153 10
Error: Simple descriptor request failed
Done
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 3
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 3 0
Error: Incorrect destination network address for the request
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 2 3 0
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 3 0 0
uart:~$ zdo bind on f4ce369e3f3451ab 1 f4ce365044756cb7 10 0x0003 9153
Done
[  1] f4ce369e3f3451ab        1     0x0003           003 f4ce365044756cb7      010
Total entries for the binding table: 2
Done
uart:~$ zcl attr read 9153 1 0x0003 0x0104 0
uart:~$ zcl attr write 9153 1 0x0003 0x0104 0x00 0x21 0x0F
uart:~$
uart:~$
uart:~$
  • HI,
    I have tried following points in Shell Sample code which as working as Coordinator.
    1) coordinator Send : ZCL attr read 0xA009 2 0x0000 0x0104 0
    Responds Received from Node and printed on terminal.
    2) Similarly
    coordinator Send : ZCL cmd 0x5df 2 0x0000 0x0104 0
    uart:~$ zcl cmd 65df 2 0x0000 0x0104 0
    Default Response received: Command: 4, Status: 129
    Error: Command not successful
    Done
    [00:15:45.006,256] <inf> zigbee_shell: RECEIVED CMD zbshellutil.c
    [00:15:45.006,652] <inf> zigbee.eprxzcl: Received ZCL command (4): src_addr=0x65df(short) src_ep=2 dst_ep=64 cluster_id=0x0000 profile_id=0x0104 cmd_dir=1 common_cmd=1 cmd_id=0x0b cmd_seq=10 disable_def_resp=0 manuf_code=void payload=[0481] (4)
    3) End Device sending ZCL CMD in every seconds but not receiving at zigbee_logger_eprxzcl_ep_handler().
    Attached herewith the traffic captured for reference.
    Kindly find the attachment and let me know why it is not receiving the ZCL generic command.
    the only difference i found is manufacturing specific bit  in ZCL Frame Control.
    how to overcome this issue.
    I also tried the following callback
    1)  ZB_ZCL_REGISTER_CALLBACK();
    2)  ZB_ZCL_SET_DISC_MANUFACTURE_COMMAND_CALLBACK();
    3) ZB_AF_SET_ENDPOINT_HANDLER();
    The incoming message is not hitting any of the above callback which i tried one by one.
    i have observed that if i try ZCL on-off command from end device it is hitting at ZB_ZCL_Handler().
    if i add a callback does the stack callback will disabled or not?
    _nikhil
    Done
    Status 129 (0x81) is unsupported command or unsupported cluster command (zb_zcl_common.h#L371-L372).
    You are trying to send command 0 to the Basic cluster on the device, which is "Reset to Factory Defaults":
    This command is optional, so it could be that the device doesn't support it.
    Please upload the sniffer log as a pcap file, and to clarify what command you are sending and which device you are sending it to/from.
    -Amanda H.
    Done
    They are trying to send command 0 to the Basic cluster on the device, which is "Reset to Factory Defaults":
    Q1a : could you tell which handler or callback is processing the received ZCL generic command.
    Q1b : Which function receives and process the incoming packets.
    2)Please upload the sniffer log as a pcap file, and to clarify what command you are sending and which device you are sending it to/from.
    Here follows the pcap file.
    Also adding captured traffic image for reference.
    zigbeeROuter traffic.pcapng
    3)
    The End Device sending Customized manufacturing data in ZCL Generic Commands.
    Here follows the details.
    Profile :  0x0104
    Cluster ID : 0xFF01
    Manufacture ID : 0x1002
    Q 3a: where can we receive the manufacture specific data ?
    Q1a.
    See the example here and here.
    There is also some information about this in the documentation here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/zboss/3.11.3.0/using_zigbee__z_c_l.html#process_zcl_cmd
    Q1b.
    If you mean Zigbee packets in general then this is handled internally by the stack and is not visible to the application.
    2) The packets in the sniffer log are encrypted. Please share the network key or capture a new sniffer log where they start the sniffer before the coordinator starts the network.
    Q3a.
    You should be able to handle this in the ZCL handler
  • HI,
    I tried to capture the traffic using sniffer tool which is not working well. Bit slow to start and capturing logs.
    I have compared the previous captured pcap data which i uploaded in previous post with Captured data on Simplicity Studio which also posted in previous post as Image.
    while comparing i have found that the zigbee packets are same as pcap. So i am posting here the full packet which i received on other device which act as sniffer for reference.
    Please check the packet data and let me know how can i handle the packet in Shell or Coordinator sample.
    _nikhil
