Is it possible to have a simple example of using PWM with the Zephyr?
With nRF5_SDK_17.1.0 I did this:
void Pwm1Init(void)
ret_code_t err_code;
nrf_pwm_sequence_t const m_seq =
.values.p_individual = &pwm1Values,
.length = NRF_PWM_VALUES_LENGTH(pwm1Values),
.repeats = 0,
.end_delay = 0
nrf_drv_pwm_config_t const config0 =
.output_pins =
BUZZER_PIN | NRF_DRV_PWM_PIN_INVERTED,
LED_R | NRF_DRV_PWM_PIN_INVERTED,
LED_G | NRF_DRV_PWM_PIN_INVERTED,
LED_B | NRF_DRV_PWM_PIN_INVERTED,
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_250kHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 62, // PWM period 4032Hz, 62 -> Duty Cycle = 100%.
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
err_code = nrf_drv_pwm_init(&m_pwm1, &config0, NULL);
pwm1Values.channel_0 = 0x8000;
pwm1Values.channel_1 = 0x8000;
pwm1Values.channel_2 = 0x8000;
pwm1Values.channel_3 = 0x8000;
nrf_drv_pwm_simple_playback(&m_pwm1, &m_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
void Pwm1SetDutyCycle(uint8_t channel, uint16_t value)
((uint16_t *)(&pwm1Values))[channel] = (value | 0x8000);
I used the Pwm1SetDutyCycle function to set the Duty cycle of the 4 channels.
Now what do I do with the Zephyr? Can anyone give me an example? The examples I found didn't help me.
Thank you.
