LwM2M client: registration SOMETIMES fails; observers not set.
We're developing an LwM2M application based on the lwm2m client sample with the goal of sending data to ThingsBoard as our main telemetry platform.
The Application in based on the v2.4.2 SDK, running modem firmware mfw_nrf9160_1.3.4 on the nRF9160 SICA B1 on a custom board. Thingsboard has recently implemented a fix which allowed us to start testing on ThingsBoard instead of Coiote 1-2 weeks ago and we now have a lot more logging available to us (ThingsBoard transport log and wireshark for network traffic).
Registration generally works well; all attributes are exchanged and observers are set and later regularly updated. However, SOMETIMES (in ~15% of registrations) registration fails and the device stops sending responses to the server's requests and fails to set the defined observers.
There is no change in the logs of the client device between successful and unsuccessful attempts, except of course for the observers not being set, although outgoing and incoming coap packages are currently not being logged on our lwm2m client device (I haven't looked into this yet).
Is this a configuration issue or some compatibility problem with thingsboard?
Here is the .config file of the build followed by screenshots of the server and network logs. (CONFIG_LWM2M_ENGINE_MAX_MESSAGES, MAX_PENDING, MAX_REPLIES and MAX OBSERVER were only recently increased from 15 to 30, and I've since run into other problems, but I think it wasn't the issue?)
# Application sample
CONFIG_UI_LED=y
# CONFIG_UI_SENSE_LED is not set
# Modules
CONFIG_SENSOR_MODULE=y
CONFIG_SENSOR_MODULE_WATER_PRIOT=y
CONFIG_SENSOR_MODULE_PRIOT_RAKE_TEMP=y
CONFIG_SENSOR_MODULE_PRIOT_RAKE_HUM=y
CONFIG_SENSOR_MODULE_READ_FREQUENCY=5
# end of Modules
CONFIG_LWM2M_APP_WATER_SENSOR_PRIOT=y
# LwM2M objects
# CONFIG_APP_PUSH_BUTTON is not set
# CONFIG_APP_LIGHT_CONTROL is not set
# CONFIG_APP_BUZZER is not set
# CONFIG_APP_LIGHT_SENSOR is not set
# CONFIG_APP_ENV_SENSOR is not set
# CONFIG_APP_ACCELEROMETER is not set
# CONFIG_APP_GNSS is not set
# end of LwM2M objects
CONFIG_APP_LWM2M_PSK=""
CONFIG_APP_ENDPOINT_PREFIX="urn:imei:"
# Device info
CONFIG_APP_MANUFACTURER="PRiOT AG"
CONFIG_APP_DEVICE_TYPE="OMA-LWM2M Client"
# end of Device info
CONFIG_APP_CUSTOM_VERSION="dev_ver_05_noSec"
# CONFIG_APP_LWM2M_CONFORMANCE_TESTING is not set
# CONFIG_APP_LOG_LEVEL_OFF is not set
# CONFIG_APP_LOG_LEVEL_ERR is not set
# CONFIG_APP_LOG_LEVEL_WRN is not set
# CONFIG_APP_LOG_LEVEL_INF is not set
CONFIG_APP_LOG_LEVEL_DBG=y
# CONFIG_APP_LOG_LEVEL_DEFAULT is not set
CONFIG_APP_LOG_LEVEL=4
# end of Application sample
# Zephyr Kernel
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_NET_L2_ETHERNET is not set
CONFIG_SPI=y
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_UHC_DRIVER is not set
# CONFIG_REGULATOR is not set
CONFIG_SENSOR=y
# CONFIG_WATCHDOG is not set
# CONFIG_MODEM is not set
CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
# CONFIG_NET_IPV6 is not set
# CONFIG_NET_CONFIG_NEED_IPV6 is not set
# CONFIG_DISPLAY is not set
CONFIG_I2C=y
CONFIG_BOARD="thingy91_nrf9160"
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_FLASH_MERGED_BINARY=y
CONFIG_FLASH_LOAD_SIZE=0x0
CONFIG_FLASH_LOAD_OFFSET=0x0
CONFIG_HW_STACK_PROTECTION=y
CONFIG_SOC="nRF9160_SICA"
CONFIG_SOC_SERIES="nrf91"
CONFIG_NUM_IRQS=65
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_CLOCK_CONTROL=y
# CONFIG_RESET is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
# CONFIG_FPU is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_NET_L2_IEEE802154 is not set
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NET_UDP_CHECKSUM=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SENSIRION_SHT4X_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_TI_ADS1015_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.4.2/nrf)
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_LOG_BUFFER_SIZE=1024
CONFIG_INIT_STACKS=y
CONFIG_NET_PKT_RX_COUNT=4
CONFIG_NET_PKT_TX_COUNT=4
# CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set
# CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set
CONFIG_MBEDTLS_CIPHER_MODE_CFB=y
CONFIG_MBEDTLS_CIPHER_MODE_OFB=y
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_DHM_C is not set
# CONFIG_MBEDTLS_RSA_C is not set
CONFIG_MBEDTLS_SHA512_C=y
# CONFIG_MBEDTLS_GCM_C is not set
# CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set
CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y
# CONFIG_NET_PKT_TXTIME is not set
# CONFIG_NET_PKT_TIMESTAMP is not set
# Nordic nRF Connect
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_BOARD_THINGY91_NRF9160_NS=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_GETOPT=y
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=1
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_DFU_TARGET_STREAM=y
# CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
# CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set
CONFIG_DFU_TARGET_MODEM_DELTA=y
CONFIG_DFU_TARGET_MODEM_TIMEOUT=60
# CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
# CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
CONFIG_DFU_TARGET_LOG_LEVEL=3
# CONFIG_FMFU_FDEV is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_ESB_LOG_LEVEL_OFF is not set
# CONFIG_ESB_LOG_LEVEL_ERR is not set
# CONFIG_ESB_LOG_LEVEL_WRN is not set
# CONFIG_ESB_LOG_LEVEL_INF is not set
# CONFIG_ESB_LOG_LEVEL_DBG is not set
CONFIG_ESB_LOG_LEVEL_DEFAULT=y
CONFIG_ESB_LOG_LEVEL=3
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_AGPS is not set
# CONFIG_NRF_CLOUD_PGPS is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_ALERT is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2048
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE=1024
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048 is not set
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512 is not set
# CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_256 is not set
CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE=5
CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_512=y
# CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_256 is not set
# CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_128 is not set
# Thread and stack buffers
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=64
CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=192
CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=30000
CONFIG_DOWNLOAD_CLIENT_COAP_MAX_RETRANSMIT_REQUEST_COUNT=4
CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=y
# CONFIG_DOWNLOAD_CLIENT_IPV6 is not set
# CONFIG_DOWNLOAD_CLIENT_SHELL is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_WRN is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF is not set
# CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG is not set
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DEFAULT=y
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL=3
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_SOCKET_RETRIES=2
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
# CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE is not set
CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512
# CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set
# CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set
CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DEFAULT=y
CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# CONFIG_ZZHC is not set
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_COAP_UTILS is not set
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_LWM2M_CLIENT_UTILS_DEVICE_OBJ_SUPPORT=y
CONFIG_LWM2M_CLIENT_UTILS_SECURITY_OBJ_SUPPORT=y
CONFIG_LWM2M_CLIENT_UTILS_SERVER="coap://dev001.measuremind.ch"
CONFIG_LWM2M_CLIENT_UTILS_SERVER_TLS_TAG=35724861
CONFIG_LWM2M_CLIENT_UTILS_BOOTSTRAP_TLS_TAG=35724862
CONFIG_LWM2M_CLIENT_UTILS_CONN_MON_OBJ_SUPPORT=y
CONFIG_LWM2M_CONN_MON_BEARER_MAX=2
CONFIG_LWM2M_CONN_HOLD_TIME_RSRP=60
# CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT is not set
CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_OBJ_SUPPORT=y
CONFIG_LWM2M_CLIENT_UTILS_MCUBOOT_FLASH_BUF_SIZE=512
CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG=16842753
# CONFIG_LWM2M_CLIENT_UTILS_ADV_FIRMWARE_UPDATE_OBJ_SUPPORT is not set
# CONFIG_LWM2M_CLIENT_UTILS_GROUND_FIX_OBJ_SUPPORT is not set
# CONFIG_LWM2M_CLIENT_UTILS_GNSS_ASSIST_OBJ_SUPPORT is not set
CONFIG_LWM2M_CLIENT_UTILS_CELL_CONN_OBJ_SUPPORT=y
CONFIG_LWM2M_CELL_CONN_OBJ_VERSION_1_1=y
CONFIG_LWM2M_CELL_CONN_APN_PROFILE_COUNT=3
CONFIG_LWM2M_CLIENT_UTILS_RAI=y
# CONFIG_LWM2M_CLIENT_UTILS_LTE_CONNEVAL is not set
# CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_OFF is not set
# CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_ERR is not set
# CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_WRN is not set
# CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_INF is not set
# CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DBG is not set
CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DEFAULT=y
CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL=3
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_PROVISIONING is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
# CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
CONFIG_APP_EVENT_MANAGER_SHELL=y
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
# CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
# CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
# CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
# CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
# Trusted Execution Non-Secure
# Peripheral Secure mapping
# CONFIG_NRF_FPU_SECURE is not set
# CONFIG_NRF_REGULATORS_SECURE is not set
# CONFIG_NRF_CLOCK_SECURE is not set
# CONFIG_NRF_POWER_SECURE is not set
# CONFIG_NRF_SPIM0_SECURE is not set
# CONFIG_NRF_TWIM0_SECURE is not set
# CONFIG_NRF_UARTE0_SECURE is not set
# CONFIG_NRF_SPIM1_SECURE is not set
# CONFIG_NRF_TWIM1_SECURE is not set
# CONFIG_NRF_UARTE1_SECURE is not set
# CONFIG_NRF_SPIM2_SECURE is not set
# CONFIG_NRF_TWIM2_SECURE is not set
# CONFIG_NRF_UARTE2_SECURE is not set
# CONFIG_NRF_SPIM3_SECURE is not set
# CONFIG_NRF_TWIM3_SECURE is not set
# CONFIG_NRF_UARTE3_SECURE is not set
# CONFIG_NRF_SAADC_SECURE is not set
# CONFIG_NRF_TIMER0_SECURE is not set
# CONFIG_NRF_TIMER1_SECURE is not set
# CONFIG_NRF_TIMER2_SECURE is not set
# CONFIG_NRF_RTC0_SECURE is not set
# CONFIG_NRF_RTC1_SECURE is not set
# CONFIG_NRF_DPPI_SECURE is not set
# CONFIG_NRF_WDT0_SECURE is not set
# CONFIG_NRF_EGU0_SECURE is not set
# CONFIG_NRF_EGU1_SECURE is not set
# CONFIG_NRF_EGU2_SECURE is not set
# CONFIG_NRF_EGU3_SECURE is not set
# CONFIG_NRF_EGU4_SECURE is not set
# CONFIG_NRF_EGU5_SECURE is not set
# CONFIG_NRF_PWM0_SECURE is not set
# CONFIG_NRF_PWM1_SECURE is not set
# CONFIG_NRF_PWM2_SECURE is not set
# CONFIG_NRF_PWM3_SECURE is not set
# CONFIG_NRF_PDM_SECURE is not set
# CONFIG_NRF_I2S_SECURE is not set
# CONFIG_NRF_IPC_SECURE is not set
# CONFIG_NRF_NVMC_SECURE is not set
# CONFIG_NRF_GPIO0_SECURE is not set
# CONFIG_NRF_VMC_SECURE is not set
# CONFIG_NRF_GPIOTE0_SECURE is not set
CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
# end of Peripheral Secure mapping
# end of Trusted Execution Non-Secure
# CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
# CONFIG_NRF_PROFILER is not set
CONFIG_FW_INFO=y
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=91
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_ETB_TRACE is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20020000
# Zephyr subsystem configurations
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x8000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
CONFIG_TFM_BOARD="C:/ncs/v2.4.2/nrf/modules/tfm/tfm/boards/nrf9160"
# Platform partition component configs
CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED=y
# end of Platform partition component configs
# Crypto component configs
# CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
# end of Crypto component configs
# CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
# TF-M SPM component configs
CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
# CONFIG_TFM_DOORBELL_API is not set
# end of TF-M SPM component configs
# Libraries
# Binary libraries
# end of Binary libraries
CONFIG_NRF_MODEM_LIB=y
# CONFIG_NRF_MODEM_LIB_SYS_INIT is not set
# Memory configuration
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8320
CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
# CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set
# end of Memory configuration
# CONFIG_NRF_MODEM_LIB_TRACE is not set
CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING=y
# CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set
# CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC is not set
# CONFIG_NRF_MODEM_LIB_FAULT_STRERROR is not set
CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3
# CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
# Deprecated
# CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO_OVERRIDE is not set
# CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_OFF is not set
# CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_ERR is not set
# CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_WRN is not set
# CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_INF is not set
# CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_DBG is not set
CONFIG_LTE_CONNECTIVITY_LOG_LEVEL_DEFAULT=y
CONFIG_LTE_CONNECTIVITY_LOG_LEVEL=3
CONFIG_ADP536X=y
CONFIG_AT_MONITOR=y
CONFIG_AT_MONITOR_HEAP_SIZE=256
# CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_INF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT=y
CONFIG_AT_MONITOR_LOG_LEVEL=3
CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set
CONFIG_LTE_SHELL=y
# CONFIG_LTE_LOCK_BANDS is not set
# CONFIG_LTE_LOCK_PLMN is not set
# CONFIG_LTE_UNLOCK_PLMN is not set
# CONFIG_LTE_PSM_REQ is not set
CONFIG_LTE_PSM_REQ_RPTAU="00101001"
CONFIG_LTE_PSM_REQ_RAT="00100001"
CONFIG_LTE_EDRX_REQ=y
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0001"
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0010"
CONFIG_LTE_PTW_VALUE_LTE_M="0000"
CONFIG_LTE_PTW_VALUE_NBIOT="0000"
# CONFIG_LTE_NETWORK_DEFAULT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set
# CONFIG_LTE_MODE_PREFERENCE_AUTO is not set
# CONFIG_LTE_MODE_PREFERENCE_LTE_M is not set
# CONFIG_LTE_MODE_PREFERENCE_NBIOT is not set
CONFIG_LTE_MODE_PREFERENCE_LTE_M_PLMN_PRIO=y
# CONFIG_LTE_MODE_PREFERENCE_NBIOT_PLMN_PRIO is not set
CONFIG_LTE_MODE_PREFERENCE=3
CONFIG_LTE_RAI_REQ_VALUE="0"
# CONFIG_LTE_NETWORK_USE_FALLBACK is not set
CONFIG_LTE_NETWORK_TIMEOUT=600
CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y
CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000
CONFIG_LTE_NEIGHBOR_CELLS_MAX=10
# CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS is not set
CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000
# CONFIG_LTE_LC_TRACE is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
CONFIG_FPROTECT_BLOCK_SIZE=0x8000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_AT_HOST_LIBRARY is not set
# CONFIG_DK_LIBRARY is not set
CONFIG_AT_CMD_PARSER=y
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10
CONFIG_MODEM_INFO_BUFFER_SIZE=128
CONFIG_MODEM_INFO_ADD_NETWORK=y
# CONFIG_MODEM_INFO_ADD_DATE_TIME is not set
CONFIG_MODEM_INFO_ADD_SIM=y
CONFIG_MODEM_INFO_ADD_SIM_ICCID=y
CONFIG_MODEM_INFO_ADD_SIM_IMSI=y
CONFIG_MODEM_INFO_ADD_DEVICE=y
# CONFIG_PDN is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
# CONFIG_GCF_SMS is not set
CONFIG_MODEM_KEY_MGMT=y
# CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_OFF is not set
# CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_ERR is not set
# CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_WRN is not set
# CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_INF is not set
# CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DBG is not set
CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DEFAULT=y
CONFIG_MODEM_KEY_MGMT_LOG_LEVEL=3
# CONFIG_SUPL_CLIENT_LIB is not set
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_AUTO_UPDATE=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600
CONFIG_DATE_TIME_MODEM=y
CONFIG_DATE_TIME_NTP=y
CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
# CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
# CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
# CONFIG_DATE_TIME_LOG_LEVEL_INF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set
CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT=y
CONFIG_DATE_TIME_LOG_LEVEL=3
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_MODEM_ATTEST_TOKEN is not set
# CONFIG_MULTICELL_LOCATION is not set
# CONFIG_LOCATION is not set
# CONFIG_AT_SHELL is not set
CONFIG_MODEM_ANTENNA=y
CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y
# CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set
CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set
CONFIG_MODEM_ANTENNA_LOG_LEVEL_DEFAULT=y
CONFIG_MODEM_ANTENNA_LOG_LEVEL=3
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_ETH_RTT is not set
# CONFIG_BH1749 is not set
# CONFIG_SENSOR_SIM is not set
# CONFIG_SENSOR_STUB is not set
# CONFIG_PMW3360 is not set
# CONFIG_PAW3212 is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
CONFIG_NET_CONFIG_INIT_TIMEOUT=30
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.4.2/nrf)
# hostap (C:/ncs/v2.4.2/modules/lib/hostap)
# CONFIG_WPA_SUPP is not set
CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=64
CONFIG_POSIX_MAX_FDS=4
CONFIG_NET_SOCKETS_POLL_MAX=3
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (C:/ncs/v2.4.2/modules/lib/hostap)
# mcuboot (C:/ncs/v2.4.2/bootloader/mcuboot)
# MCUboot
CONFIG_SIGN_IMAGES=y
# CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
CONFIG_MCUBOOT_IMAGE_VERSION="0.0.0+0"
# CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
# CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set
# CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.4.2/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.4.2/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# CONFIG_MBEDTLS_BUILTIN is not set
# CONFIG_MBEDTLS_LIBRARY is not set
CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
# CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
# CONFIG_MBEDTLS_ECP_C is not set
# CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
# CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
# CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
# CONFIG_MBEDTLS_MAC_SHA256_ENABLED is not set
# CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
# CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER is not set
# CONFIG_MBEDTLS_MD is not set
# CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
# CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"
# CONFIG_MBEDTLS_PK_WRITE_C is not set
CONFIG_MBEDTLS_PKCS5_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
# CONFIG_MBEDTLS_ENABLE_HEAP is not set
CONFIG_PSA_WANT_GENERATE_RANDOM=y
# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
CONFIG_PSA_WANT_ALG_HMAC_DRBG=y
# CONFIG_PSA_WANT_ALG_CCM is not set
# CONFIG_PSA_WANT_ALG_GCM is not set
# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_CMAC is not set
# CONFIG_PSA_WANT_ALG_HMAC is not set
# CONFIG_PSA_WANT_ALG_SHA_1 is not set
# CONFIG_PSA_WANT_ALG_SHA_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_256 is not set
# CONFIG_PSA_WANT_ALG_SHA_384 is not set
# CONFIG_PSA_WANT_ALG_SHA_512 is not set
# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
# CONFIG_PSA_WANT_ALG_MD5 is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
# CONFIG_PSA_WANT_ALG_CFB is not set
# CONFIG_PSA_WANT_ALG_CTR is not set
# CONFIG_PSA_WANT_ALG_OFB is not set
CONFIG_PSA_HAS_KEY_DERIVATION=y
# CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y
# CONFIG_PSA_WANT_ALG_ECDH is not set
# CONFIG_PSA_WANT_ALG_ECDSA is not set
# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
# end of mbedtls (C:/ncs/v2.4.2/modules/crypto/mbedtls)
# trusted-firmware-m (C:/ncs/v2.4.2/modules/tee/tf-m/trusted-firmware-m)
CONFIG_TFM_ISOLATION_LEVEL=1
# CONFIG_TFM_BL2 is not set
# CONFIG_TFM_REGRESSION_NS is not set
# CONFIG_TFM_SECURE_UART is not set
# TF-M UART pins
CONFIG_TFM_UART0_TXD_PIN=4294967295
CONFIG_TFM_UART0_RXD_PIN=4294967295
CONFIG_TFM_UART0_RTS_PIN=4294967295
CONFIG_TFM_UART0_CTS_PIN=4294967295
# CONFIG_TFM_UART0_HWFC_ENABLED is not set
# CONFIG_TFM_UART1_HWFC_ENABLED is not set
# end of TF-M UART pins
CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
CONFIG_TFM_QCBOR_PATH="C:/ncs/v2.4.2/modules/tee/tf-m/trusted-firmware-m/../qcbor"
CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=1
CONFIG_TFM_CRYPTO_CONC_OPER_NUM=1
CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=1024
CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x800
# CONFIG_TFM_ITS_ENCRYPTED is not set
CONFIG_TFM_HW_INIT_RESET_ON_BOOT=y
CONFIG_TFM_HW_INIT_NRF_PERIPHERALS=y
# CONFIG_TFM_HALT_ON_CORE_PANIC is not set
CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x144
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.4.2/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.4.2/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
# CONFIG_TFM_PROFILE_TYPE_NOT_SET is not set
# CONFIG_TFM_PROFILE_TYPE_SMALL is not set
# CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
# CONFIG_TFM_PROFILE_TYPE_LARGE is not set
# CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
# CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
# CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set
# CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0"
CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
# CONFIG_TFM_BUILD_NS is not set
# CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
CONFIG_TFM_MCUBOOT_IMAGE_NUMBER=1
CONFIG_TFM_IPC=y
# CONFIG_TFM_SFN is not set
# CONFIG_TFM_REGRESSION_S is not set
# CONFIG_TFM_PSA_TEST_CRYPTO is not set
# CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
# CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
# CONFIG_TFM_PSA_TEST_STORAGE is not set
# CONFIG_TFM_PSA_TEST_INITIAL_ATTESTATION is not set
CONFIG_TFM_PSA_TEST_NONE=y
CONFIG_TFM_LOG_LEVEL_SILENCE=y
# CONFIG_TFM_EXCEPTION_INFO_DUMP is not set
# CONFIG_MBEDTLS_SHA1_C is not set
CONFIG_TFM_PARTITION_CRYPTO=y
CONFIG_TFM_PARTITION_PLATFORM=y
CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
CONFIG_MBEDTLS_MD_C=y
# CONFIG_MBEDTLS_TLS_LIBRARY is not set
# CONFIG_MBEDTLS_X509_LIBRARY is not set
# CONFIG_MBEDTLS_CTR_DRBG_C is not set
# CONFIG_MBEDTLS_CMAC_C is not set
# CONFIG_MBEDTLS_CCM_C is not set
CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000
CONFIG_PM_PARTITION_SIZE_BL2=0
CONFIG_PM_PARTITION_SIZE_TFM=0x7E00
CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0
CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0
CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0
# end of trusted-firmware-m (C:/ncs/v2.4.2/modules/tee/tf-m/trusted-firmware-m)
# cjson (C:/ncs/v2.4.2/modules/lib/cjson)
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.4.2/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.4.2/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.4.2/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.4.2/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.4.2/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.4.2/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.4.2/modules/lib/openthread)
# memfault-firmware-sdk (C:/ncs/v2.4.2/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.4.2/modules/lib/memfault-firmware-sdk)
# canopennode (C:/ncs/v2.4.2/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.4.2/modules/lib/canopennode)
# chre (C:/ncs/v2.4.2/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.4.2/modules/lib/chre)
# fatfs (C:/ncs/v2.4.2/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.4.2/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.4.2/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
CONFIG_NRFX_DPPI=y
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
CONFIG_NRFX_IPC=y
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
CONFIG_NRFX_SPIM=y
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
CONFIG_NRFX_SPIM3=y
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
CONFIG_NRFX_TWIM=y
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
CONFIG_NRFX_TWIM2=y
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v2.4.2/modules/hal/nordic)
# liblc3 (C:/ncs/v2.4.2/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.4.2/modules/lib/liblc3)
# littlefs (C:/ncs/v2.4.2/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.4.2/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.4.2/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.4.2/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.4.2/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.4.2/modules/lib/gui/lvgl)
# lz4 (C:/ncs/v2.4.2/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.4.2/modules/lib/lz4)
# nanopb (C:/ncs/v2.4.2/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.4.2/modules/lib/nanopb)
# picolibc (C:/ncs/v2.4.2/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.4.2/modules/lib/picolibc)
# segger (C:/ncs/v2.4.2/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# end of segger (C:/ncs/v2.4.2/modules/debug/segger)
# TraceRecorder (C:/ncs/v2.4.2/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (C:/ncs/v2.4.2/modules/debug/TraceRecorder)
# uoscore-uedhoc (C:/ncs/v2.4.2/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.4.2/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.4.2/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
CONFIG_ZCBOR=y
CONFIG_ZCBOR_CANONICAL=y
# CONFIG_ZCBOR_STOP_ON_ERROR is not set
# CONFIG_ZCBOR_VERBOSE is not set
CONFIG_ZCBOR_ASSERT=y
# end of zcbor (C:/ncs/v2.4.2/modules/lib/zcbor)
# zscilib (C:/ncs/v2.4.2/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.4.2/modules/lib/zscilib)
# nrfxlib (C:/ncs/v2.4.2/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM=y
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_LINK_BINARY=y
# CONFIG_NRF_MODEM_LOG is not set
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_CRYPTOCELL_CC310_USABLE=y
CONFIG_CRYPTOCELL_USABLE=y
CONFIG_NRF_OBERON=y
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
CONFIG_NORDIC_SECURITY_BACKEND=y
CONFIG_NRF_SECURITY=y
CONFIG_GENERATE_MBEDTLS_CFG_FILE=y
# PSA RNG support
# end of PSA RNG support
# PSA AEAD support
# end of PSA AEAD support
# PSA MAC support
# end of PSA MAC support
# PSA Hash support
# end of PSA Hash support
# PSA Cipher support
# end of PSA Cipher support
# PSA Key derivation support
# end of PSA Key derivation support
# PSA Asymmetric support
# end of PSA Asymmetric support
# CONFIG_PSA_CORE_BUILTIN is not set
CONFIG_PSA_CORE_OBERON=y
# PSA Driver Support
CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
CONFIG_PSA_DEFAULT_OFF=y
CONFIG_PSA_CRYPTO_ACCELERATOR_DRIVER_PRESENT=y
CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
# CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
CONFIG_PSA_CRYPTO_DRIVER_ALG_PRNG_CC3XX_PLATFORM=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_HMAC_DRBG_CC3XX_PLATFORM=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
# CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_NO_PADDING_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_PKCS7_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_CCM_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_CHACHA20_POLY1305_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_CTR_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_DETERMINISTIC_ECDSA_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_ECB_NO_PADDING_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDH_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDSA_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_GCM_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_1_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_224_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_256_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_384_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_512_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_TLS12_PSK_TO_MS_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ALG_STREAM_CIPHER_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ECC_MONTGOMERY_255_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_224_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_256_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_384_OBERON is not set
# CONFIG_PSA_CRYPTO_DRIVER_ECC_TWISTED_EDWARDS_255_OBERON is not set
# PSA API support
CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
# end of PSA API support
CONFIG_MBEDTLS_PLATFORM_MEMORY=y
CONFIG_MBEDTLS_PLATFORM_C=y
CONFIG_MBEDTLS_MEMORY_C=y
CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
CONFIG_MBEDTLS_CHACHA20_ALT=y
CONFIG_MBEDTLS_POLY1305_ALT=y
CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
CONFIG_MBEDTLS_ECJPAKE_ALT=y
CONFIG_MBEDTLS_SHA1_ALT=y
CONFIG_MBEDTLS_SHA224_ALT=y
CONFIG_MBEDTLS_SHA256_ALT=y
CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
# CONFIG_NRF_SECURITY_ADVANCED is not set
CONFIG_OBERON_ONLY_PSA_ENABLED=y
CONFIG_OBERON_ONLY_ENABLED=y
# Legacy mbed TLS crypto APIs
CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
CONFIG_MBEDTLS_MPI_MAX_SIZE=256
# CONFIG_CC3XX_BACKEND is not set
CONFIG_OBERON_BACKEND=y
CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY=y
CONFIG_MBEDTLS_HMAC_DRBG_C=y
CONFIG_MBEDTLS_AES_C=y
# Cipher Selection
# AEAD  - Authenticated Encryption with Associated Data
# end of AEAD  - Authenticated Encryption with Associated Data
CONFIG_MBEDTLS_HKDF_C=y
# SHA - Secure Hash Algorithm
CONFIG_MBEDTLS_SHA224_C=y
CONFIG_MBEDTLS_SHA256_C=y
CONFIG_MBEDTLS_SHA384_C=y
# end of SHA - Secure Hash Algorithm
CONFIG_MBEDTLS_CIPHER_C=y
# CONFIG_MBEDTLS_PK_C is not set
# CONFIG_MBEDTLS_PK_PARSE_C is not set
# end of Legacy mbed TLS crypto APIs
# Zephyr legacy configurations
# end of Zephyr legacy configurations
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_NRF_DM is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.4.2/nrfxlib)
# connectedhomeip (C:/ncs/v2.4.2/modules/lib/matter)
# CONFIG_CHIP is not set
# CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.4.2/modules/lib/matter)
# Optional modules. Make sure they're installed, via the project manifest.
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_DSP is not set
# CONFIG_CMSIS_NN is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
# CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# end of Modules
CONFIG_BOARD_REVISION="$BOARD_REVISION"
# CONFIG_NET_DRIVERS is not set
# CONFIG_BOARD_THINGY91_NRF9160 is not set
# Board Options
CONFIG_BOARD_INIT_PRIORITY=80
# CONFIG_BOARD_LOG_LEVEL_OFF is not set
# CONFIG_BOARD_LOG_LEVEL_ERR is not set
# CONFIG_BOARD_LOG_LEVEL_WRN is not set
# CONFIG_BOARD_LOG_LEVEL_INF is not set
# CONFIG_BOARD_LOG_LEVEL_DBG is not set
CONFIG_BOARD_LOG_LEVEL_DEFAULT=y
CONFIG_BOARD_LOG_LEVEL=3
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAMC20 is not set
# CONFIG_SOC_SERIES_SAMC21 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32A50X is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_GD32L23X is not set
# CONFIG_SOC_SERIES_PSOC_60 is not set
# CONFIG_SOC_SERIES_PSOC_61 is not set
# CONFIG_SOC_SERIES_PSOC_62 is not set
# CONFIG_SOC_SERIES_PSOC_63 is not set
# CONFIG_SOC_SERIES_PSOC_64 is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
# CONFIG_SOC_SERIES_NRF52X is not set
# CONFIG_SOC_SERIES_NRF53X is not set
CONFIG_SOC_SERIES_NRF91X=y
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32BG22 is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_EFR32MG24 is not set
# CONFIG_SOC_SERIES_STM32C0X is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H5X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_IPC=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_PWM2=y
CONFIG_HAS_HW_NRF_REGULATORS=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_TWIM2=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_SOC_NRF9160=y
CONFIG_SOC_NRF9160_SICA=y
# CONFIG_SOC_NRF9161_SICA is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_ARM_NONSECURE_FIRMWARE=y
CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
CONFIG_ARM_STORE_EXC_RETURN=y
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
CONFIG_ARM_TRUSTZONE_M=y
# ARM TrustZone-M Options
# Non-secure firmware
# CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
# end of ARM TrustZone-M Options
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
CONFIG_PIPES=y
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
# end of General Kernel Options
# Device Options
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_BBRAM is not set
# CONFIG_CACHE is not set
# CONFIG_CAN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
CONFIG_CLOCK_CONTROL_NRF_SHELL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_COUNTER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DMA is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
# CONFIG_ENTROPY_LOG_LEVEL_INF is not set
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_FLASH_LOG_LEVEL_INF is not set
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_FLASH_LOG_LEVEL=3
CONFIG_FLASH_SHELL=y
# CONFIG_FLASH_SHELL_TEST_COMMANDS is not set
CONFIG_FLASH_SHELL_BUFFER_SIZE=0x1000
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_SHELL is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
# CONFIG_FXL6408_LOG_LEVEL_INF is not set
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL_DEFAULT=y
CONFIG_FXL6408_LOG_LEVEL=3
# CONFIG_HWINFO is not set
CONFIG_I2C_SHELL=y
# CONFIG_I2C_DUMP_MESSAGES is not set
# CONFIG_I2C_CALLBACK is not set
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
CONFIG_I2C_2_NRF_TWIM=y
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
# CONFIG_I2C_LOG_LEVEL_INF is not set
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL_DEFAULT=y
CONFIG_I2C_LOG_LEVEL=3
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# CONFIG_SMBUS is not set
# CONFIG_IEEE802154 is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MBOX is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DSI is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# CONFIG_SENSOR_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_LOG_LEVEL_WRN is not set
# CONFIG_SENSOR_LOG_LEVEL_INF is not set
# CONFIG_SENSOR_LOG_LEVEL_DBG is not set
CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
CONFIG_SENSOR_LOG_LEVEL=3
CONFIG_SENSOR_INIT_PRIORITY=90
CONFIG_SENSOR_SHELL=y
# CONFIG_SENSOR_SHELL_BATTERY is not set
# CONFIG_SENSOR_INFO is not set
# Device Drivers
CONFIG_SHT4X=y
CONFIG_TMP112_FULL_SCALE_RUNTIME=y
CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
CONFIG_VCMP_IT8XXX2_INIT_PRIORITY=90
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UARTE=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_0_GPIO_MANAGEMENT=y
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# CONFIG_SPI_ASYNC is not set
# CONFIG_SPI_RTIO is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=70
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
# CONFIG_SPI_LOG_LEVEL_INF is not set
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL_DEFAULT=y
CONFIG_SPI_LOG_LEVEL=3
CONFIG_SPI_NRFX=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
# CONFIG_SYSCON is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# C Library
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_SUPPORT_MINIMAL_LIBC=y
CONFIG_PICOLIBC_SUPPORTED=y
# CONFIG_PICOLIBC is not set
CONFIG_NEWLIB_LIBC=y
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# CONFIG_NEWLIB_LIBC_FLOAT_PRINTF is not set
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# Deprecated
# CONFIG_CPLUSPLUS is not set
# CONFIG_LIB_CPLUSPLUS is not set
# end of Deprecated
# end of C++ Language Support
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# OS Support Library
CONFIG_JSON_LIBRARY=y
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
CONFIG_BASE64=y
CONFIG_CRC=y
# CONFIG_CRC_SHELL is not set
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
CONFIG_SYS_HEAP_SMALL_ONLY=y
# CONFIG_SYS_HEAP_BIG_ONLY is not set
# CONFIG_SYS_HEAP_AUTO is not set
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_GETOPT_LONG is not set
# CONFIG_POSIX_API is not set
# CONFIG_PTHREAD_IPC is not set
CONFIG_POSIX_CLOCK=y
CONFIG_MAX_TIMER_COUNT=5
CONFIG_TIMER_CREATE_WAIT=100
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
CONFIG_FNMATCH=y
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_ASSERT=y
CONFIG_ASSERT_LEVEL=2
CONFIG_SPIN_VALIDATE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_SHELL=y
CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
CONFIG_IMG_BLOCK_BUF_SIZE=512
# CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_IMG_MANAGER_LOG_LEVEL=3
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
CONFIG_FCB=y
# CONFIG_FCB_ALLOW_FIXED_ENDMARKER is not set
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# Logging
CONFIG_LOG=y
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_NET is not set
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
# CONFIG_LOG_BACKEND_UART is not set
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG_CMDS=y
CONFIG_LOG_USE_VLA=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
CONFIG_LOG_MEM_UTILIZATION=y
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# CONFIG_EC_HOST_CMD_BACKEND_SHI is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
# CONFIG_NET_BUF_LOG_LEVEL_INF is not set
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NETWORKING=y
# CONFIG_NET_HOSTNAME_ENABLE is not set
# Link layer options
# CONFIG_NET_L2_DUMMY is not set
# CONFIG_NET_L2_BT_SHELL is not set
# CONFIG_NET_L2_VIRTUAL is not set
# CONFIG_NET_L2_PPP is not set
# CONFIG_NET_L2_OPENTHREAD is not set
# CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
# CONFIG_NET_L2_CANBUS_RAW is not set
# CONFIG_NET_L2_WIFI_MGMT is not set
# CONFIG_NET_L2_WIFI_SHELL is not set
# CONFIG_NET_L2_PTP is not set
# end of Link layer options
# IP stack
CONFIG_NET_IP=y
# CONFIG_NET_NATIVE is not set
# CONFIG_NET_OFFLOAD is not set
CONFIG_NET_INIT_PRIO=90
CONFIG_NET_IP_DSCP_ECN=y
CONFIG_NET_IPV4=y
CONFIG_NET_INITIAL_TTL=64
CONFIG_NET_IF_MAX_IPV4_COUNT=1
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
# CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set
# CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set
# CONFIG_NET_IPV4_IGMP is not set
# CONFIG_NET_DHCPV4 is not set
# CONFIG_NET_IPV4_HDR_OPTIONS is not set
# CONFIG_NET_IPV4_FRAGMENT is not set
CONFIG_NET_IPV4_LOG_LEVEL=0
CONFIG_NET_ICMPV4_LOG_LEVEL=0
# CONFIG_NET_SHELL is not set
CONFIG_NET_TC_TX_COUNT=0
CONFIG_NET_TC_RX_COUNT=1
# CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
CONFIG_NET_TC_THREAD_COOPERATIVE=y
# CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
CONFIG_NET_TC_NUM_PRIORITIES=16
CONFIG_NET_TC_MAPPING_STRICT=y
CONFIG_NET_TX_DEFAULT_PRIORITY=1
CONFIG_NET_RX_DEFAULT_PRIORITY=0
CONFIG_NET_IP_ADDR_CHECK=y
CONFIG_NET_MAX_ROUTERS=1
# CONFIG_NET_TCP is not set
# CONFIG_NET_TEST_PROTOCOL is not set
CONFIG_NET_UDP=y
# CONFIG_NET_UDP_MISSING_CHECKSUM is not set
CONFIG_NET_UDP_LOG_LEVEL=0
CONFIG_NET_MAX_CONN=4
CONFIG_NET_MAX_CONTEXTS=6
# CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_NET_CONTEXT_CHECK=y
# CONFIG_NET_CONTEXT_PRIORITY is not set
# CONFIG_NET_CONTEXT_TXTIME is not set
# CONFIG_NET_CONTEXT_RCVTIMEO is not set
# CONFIG_NET_CONTEXT_SNDTIMEO is not set
# CONFIG_NET_CONTEXT_RCVBUF is not set
# CONFIG_NET_CONTEXT_SNDBUF is not set
CONFIG_NET_CONTEXT_DSCP_ECN=y
# CONFIG_NET_TEST is not set
# CONFIG_NET_TRICKLE is not set
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_FIXED_DATA_SIZE=y
# CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
CONFIG_NET_DEFAULT_IF_FIRST=y
# CONFIG_NET_DEFAULT_IF_UP is not set
# CONFIG_NET_PROMISCUOUS_MODE is not set
# CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
# Stack usage
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_NET_RX_STACK_SIZE=1500
# end of Stack usage
# CONFIG_NET_MGMT is not set
# CONFIG_NET_STATISTICS is not set
# CONFIG_NET_LOG is not set
CONFIG_NET_PKT_LOG_LEVEL=0
# CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
# CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
CONFIG_NET_CORE_LOG_LEVEL=0
CONFIG_NET_IF_LOG_LEVEL=0
CONFIG_NET_TC_LOG_LEVEL=0
CONFIG_NET_UTILS_LOG_LEVEL=0
CONFIG_NET_CONTEXT_LOG_LEVEL=0
CONFIG_NET_CONN_LOG_LEVEL=0
CONFIG_NET_ROUTE_LOG_LEVEL=0
# end of IP stack
# Network Packet Filtering
# CONFIG_NET_PKT_FILTER is not set
# end of Network Packet Filtering
# Network Protocols
CONFIG_COAP=y
# CONFIG_COAP_TEST_API_ENABLE is not set
# CONFIG_COAP_WELL_KNOWN_BLOCK_WISE is not set
CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
CONFIG_COAP_RANDOMIZE_ACK_TIMEOUT=y
CONFIG_COAP_ACK_RANDOM_PERCENT=150
CONFIG_COAP_MAX_RETRANSMIT=4
CONFIG_COAP_URI_WILDCARD=y
# CONFIG_COAP_KEEP_USER_DATA is not set
CONFIG_COAP_LOG_LEVEL=0
# CONFIG_DNS_SD is not set
# CONFIG_MQTT_LIB is not set
# CONFIG_MQTT_SN_LIB is not set
# CONFIG_TFTP_LIB is not set
# CONFIG_HTTP_PARSER is not set
CONFIG_HTTP_PARSER_URL=y
# CONFIG_HTTP_PARSER_STRICT is not set
# CONFIG_HTTP_CLIENT is not set
# CONFIG_HTTP_SERVER is not set
CONFIG_NET_HTTP_LOG_LEVEL=0
# CONFIG_WEBSOCKET_CLIENT is not set
CONFIG_LWM2M=y
# CONFIG_LWM2M_LOG_LEVEL_OFF is not set
# CONFIG_LWM2M_LOG_LEVEL_ERR is not set
# CONFIG_LWM2M_LOG_LEVEL_WRN is not set
# CONFIG_LWM2M_LOG_LEVEL_INF is not set
CONFIG_LWM2M_LOG_LEVEL_DBG=y
# CONFIG_LWM2M_LOG_LEVEL_DEFAULT is not set
CONFIG_LWM2M_LOG_LEVEL=4
# CONFIG_LWM2M_VERSION_1_0 is not set
CONFIG_LWM2M_VERSION_1_1=y
CONFIG_LWM2M_SHELL=y
CONFIG_LWM2M_DTLS_SUPPORT=y
# CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_0 is not set
CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_1=y
# CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_0 is not set
CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_1=y
CONFIG_LWM2M_DNS_SUPPORT=y
CONFIG_LWM2M_ENGINE_STACK_SIZE=6144
CONFIG_LWM2M_ENGINE_MAX_MESSAGES=30
CONFIG_LWM2M_COAP_BLOCK_SIZE=512
CONFIG_LWM2M_ENGINE_MESSAGE_HEADER_SIZE=48
CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280
CONFIG_LWM2M_ENGINE_VALIDATION_BUFFER_SIZE=64
CONFIG_LWM2M_ENGINE_MAX_PENDING=30
CONFIG_LWM2M_ENGINE_MAX_REPLIES=30
CONFIG_LWM2M_ENGINE_MAX_OBSERVER=30
# CONFIG_LWM2M_CANCEL_OBSERVE_BY_PATH is not set
CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43200
CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=1800
CONFIG_LWM2M_QUEUE_MODE_ENABLED=y
CONFIG_LWM2M_QUEUE_MODE_UPTIME=30
CONFIG_LWM2M_TLS_SESSION_CACHING=y
CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE=y
# CONFIG_LWM2M_RD_CLIENT_SUPPORT is not set
# CONFIG_LWM2M_RD_CLIENT_SUPPORT_BOOTSTRAP is not set
CONFIG_LWM2M_RD_CLIENT_ENDPOINT_NAME_MAX_LENGTH=33
CONFIG_LWM2M_RD_CLIENT_MAX_RETRIES=5
# CONFIG_LWM2M_ACCESS_CONTROL_ENABLE is not set
CONFIG_LWM2M_ACCESS_CONTROL_INSTANCE_COUNT=50
CONFIG_LWM2M_SERVER_DEFAULT_SSID=101
CONFIG_LWM2M_PEER_PORT=5685
CONFIG_LWM2M_FIRMWARE_PORT_NONSECURE=5683
CONFIG_LWM2M_FIRMWARE_PORT_SECURE=5684
CONFIG_LWM2M_SECURITY_INSTANCE_COUNT=1
CONFIG_LWM2M_SECURITY_KEY_SIZE=33
CONFIG_LWM2M_SECURITY_DTLS_TLS_CIPHERSUITE_MAX=5
CONFIG_LWM2M_SERVER_DEFAULT_PMIN=1
CONFIG_LWM2M_SERVER_DEFAULT_PMAX=300
CONFIG_LWM2M_SERVER_INSTANCE_COUNT=1
CONFIG_LWM2M_CONN_MON_OBJ_SUPPORT=y
# CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_0 is not set
CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_2=y
CONFIG_LWM2M_CONN_MON_APN_MAX=1
CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT=y
# CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT_MULTIPLE is not set
CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_SUPPORT=y
# CONFIG_LWM2M_SWMGMT_OBJ_SUPPORT is not set
CONFIG_LWM2M_PORTFOLIO_OBJ_SUPPORT=y
CONFIG_LWM2M_SWMGMT_PACKAGE_URI_LEN=128
CONFIG_LWM2M_NUM_BLOCK1_CONTEXT=3
# CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_COAP_PROXY_SUPPORT is not set
CONFIG_LWM2M_RW_OMA_TLV_SUPPORT=y
CONFIG_LWM2M_RW_JSON_SUPPORT=y
CONFIG_LWM2M_RW_SENML_JSON_SUPPORT=y
CONFIG_LWM2M_COMPOSITE_PATH_LIST_SIZE=10
CONFIG_LWM2M_RW_CBOR_SUPPORT=y
CONFIG_LWM2M_RW_SENML_CBOR_SUPPORT=y
CONFIG_LWM2M_RW_SENML_CBOR_RECORDS=55
# CONFIG_LWM2M_RESOURCE_DATA_CACHE_SUPPORT is not set
CONFIG_LWM2M_DEVICE_PWRSRC_MAX=5
CONFIG_LWM2M_DEVICE_ERROR_CODE_MAX=10
CONFIG_LWM2M_DEVICE_EXT_DEV_INFO_MAX=5
CONFIG_LWM2M_NUM_ATTR=20
# CONFIG_LWM2M_LOCATION_OBJ_SUPPORT is not set
# CONFIG_LWM2M_GATEWAY_OBJ_SUPPORT is not set
# CONFIG_LWM2M_EVENT_LOG_OBJ_SUPPORT is not set
# CONFIG_LWM2M_BINARYAPPDATA_OBJ_SUPPORT is not set
# IPSO Alliance Smart Object Support
CONFIG_LWM2M_IPSO_SUPPORT=y
CONFIG_LWM2M_IPSO_TEMP_SENSOR=y
CONFIG_LWM2M_IPSO_TEMP_SENSOR_INSTANCE_COUNT=1
# CONFIG_LWM2M_IPSO_TEMP_SENSOR_VERSION_1_0 is not set
CONFIG_LWM2M_IPSO_TEMP_SENSOR_VERSION_1_1=y
# CONFIG_LWM2M_IPSO_GENERIC_SENSOR is not set
CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR=y
CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_INSTANCE_COUNT=1
# CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_VERSION_1_0 is not set
CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_VERSION_1_1=y
# CONFIG_LWM2M_IPSO_PRESSURE_SENSOR is not set
# CONFIG_LWM2M_IPSO_LIGHT_CONTROL is not set
# CONFIG_LWM2M_IPSO_ACCELEROMETER is not set
# CONFIG_LWM2M_IPSO_BUZZER is not set
# CONFIG_LWM2M_IPSO_TIMER is not set
# CONFIG_LWM2M_IPSO_ONOFF_SWITCH is not set
# CONFIG_LWM2M_IPSO_PUSH_BUTTON is not set
# CONFIG_LWM2M_IPSO_CURRENT_SENSOR is not set
CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR=y
CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_INSTANCE_COUNT=1
# CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_VERSION_1_0 is not set
CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_VERSION_1_1=y
# CONFIG_LWM2M_IPSO_FILLING_SENSOR is not set
# end of IPSO Alliance Smart Object Support
# uCIFI Alliance Object Support
# CONFIG_LWM2M_UCIFI_SUPPORT is not set
# end of uCIFI Alliance Object Support
# CONFIG_SOCKS is not set
CONFIG_SNTP=y
CONFIG_SNTP_LOG_LEVEL=0
# end of Network Protocols
# Network Libraries
CONFIG_NET_CONFIG_AUTO_INIT=y
CONFIG_NET_CONFIG_INIT_PRIO=95
# CONFIG_NET_CONFIG_NEED_IPV4 is not set
CONFIG_NET_CONFIG_LOG_LEVEL=0
# CONFIG_NET_CONFIG_SETTINGS is not set
# CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
# CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
CONFIG_NET_SOCKETS_TLS_PRIORITY=45
CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
# CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set
# CONFIG_NET_SOCKETS_PACKET is not set
# CONFIG_NET_SOCKETS_CAN is not set
CONFIG_NET_SOCKETPAIR=y
CONFIG_NET_SOCKETS_LOG_LEVEL=0
# CONFIG_TLS_CREDENTIALS is not set
# end of Network Libraries
# Network additional services
# CONFIG_NET_CAPTURE is not set
# CONFIG_NET_ZPERF is not set
# end of Network additional services
# CONFIG_NET_CONNECTION_MANAGER is not set
# end of Networking
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
# CONFIG_PM_LOG_LEVEL_INF is not set
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL_DEFAULT=y
CONFIG_PM_LOG_LEVEL=3
# CONFIG_PM_S2RAM is not set
CONFIG_PM_POLICY_DEFAULT=y
# CONFIG_PM_POLICY_CUSTOM is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
CONFIG_PM_DEVICE_LOG_LEVEL=3
CONFIG_PM_DEVICE_POWER_DOMAIN=y
# CONFIG_PM_DEVICE_POWER_DOMAIN_DYNAMIC is not set
# CONFIG_PM_DEVICE_RUNTIME is not set
# end of Power Management
# Portability
# end of Portability
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRING_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_SETTINGS_LOG_LEVEL_INF is not set
# CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
CONFIG_SETTINGS_LOG_LEVEL=3
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_FCB=y
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_FCB_NUM_AREAS=8
CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee
# CONFIG_SETTINGS_SHELL is not set
CONFIG_SHELL=y
# CONFIG_SHELL_LOG_LEVEL_OFF is not set
# CONFIG_SHELL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_LOG_LEVEL_WRN is not set
# CONFIG_SHELL_LOG_LEVEL_INF is not set
# CONFIG_SHELL_LOG_LEVEL_DBG is not set
CONFIG_SHELL_LOG_LEVEL_DEFAULT=y
CONFIG_SHELL_LOG_LEVEL=3
CONFIG_SHELL_BACKENDS=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=0
CONFIG_SHELL_PROMPT_UART="uart:~$ "
CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
# CONFIG_SHELL_BACKEND_RTT is not set
# CONFIG_SHELL_BACKEND_DUMMY is not set
# CONFIG_SHELL_MINIMAL is not set
# CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
CONFIG_SHELL_STACK_SIZE=2048
CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
CONFIG_SHELL_CMD_BUFF_SIZE=256
CONFIG_SHELL_PRINTF_BUFF_SIZE=30
CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
CONFIG_SHELL_ARGC_MAX=20
CONFIG_SHELL_TAB=y
CONFIG_SHELL_TAB_AUTOCOMPLETION=y
CONFIG_SHELL_WILDCARD=y
CONFIG_SHELL_ECHO_STATUS=y
# CONFIG_SHELL_START_OBSCURED is not set
CONFIG_SHELL_VT100_COMMANDS=y
CONFIG_SHELL_VT100_COLORS=y
# CONFIG_SHELL_GETOPT is not set
CONFIG_SHELL_METAKEYS=y
CONFIG_SHELL_HELP=y
CONFIG_SHELL_HELP_OPT_PARSE=y
CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
CONFIG_SHELL_HISTORY=y
CONFIG_SHELL_HISTORY_BUFFER=512
CONFIG_SHELL_STATS=y
CONFIG_SHELL_CMDS=y
CONFIG_SHELL_CMDS_RESIZE=y
# CONFIG_SHELL_CMDS_SELECT is not set
CONFIG_SHELL_CMD_ROOT=""
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y
CONFIG_SHELL_AUTOSTART=y
CONFIG_KERNEL_SHELL=y
CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
CONFIG_DEVICE_SHELL=y
CONFIG_DATE_SHELL=y
CONFIG_DEVMEM_SHELL=y
# CONFIG_STATS is not set
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_MAP_SHELL is not set
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
# CONFIG_STREAM_FLASH_PROGRESS is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_STREAM_FLASH_LOG_LEVEL=3
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
CONFIG_USE_DT_CODE_PARTITION=y
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
# CONFIG_COMPILER_FREESTANDING is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
CONFIG_BUILD_OUTPUT_META=y
# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# end of Zephyr Kernel
# CONFIG_APP_PRIOT_i2_CIRCUIT_BOARD_SENSORS is not set
CONFIG_APP_DAMO=y
CONFIG_WATER_SENSOR_LOG_LEVEL=3
# CONFIG_WATER_SENSOR is not set
# CONFIG_APP_WATER_SENSOR_PRIOT is not set
CONFIG_PRIOT_FEATURE_1=y
CONFIG_PRIOT_FEATURE_2=y
CONFIG_PRIOT_FEATURE_3=y
CONFIG_PRIOT_FEATURE_4=y
CONFIG_PRIOT_FEATURE_5=y
CONFIG_PRIOT_FEATURE_6=y
CONFIG_PRIOT_FEATURE_7=y
Here you can see the wireshark log of a failed attempt:
And here a successful attempt:
The content of the messages is identical, up to the point where the failed registration stops answering.
1. client device sends initial message with object versions etc. to the server
2. Server answers with the registration ID, confirming registration and follows up with read requests for all the specified attributes (here 26).
3a. In the failed attempt, 16 requests are answered, then the device stops reacting
3b. In the successful attempt, 18 requests are answered, before the server repeats a few of the unanswered requests, then after a back and forth of requesting 3-4 resources and them being answered, the 4 observe requests are sent, the client confirms, the server sends pmin and pmax, the client sends a 204 response and the registration is complete.
Server-side logs:
Unsuccessful attempt:
Last logs of a successful attempt:
I hope I have provided enough details and thank you for your help
Best Regards
Alan
  • In case we are looking at the same Wireshark capture trace-2024-04-18T12-58-42.577Z.mtrace
    5101 within half a second, there is 40 packets send back and forth.
    Capture is coming from the modem, but I'm unsure if those timestamp means that it is actually pushed to radio layer, or send over the air. I assume that just pushed into radio. So seeing the packet as outgoing, does not necessary mean that it has been send over the air, it might be in queue, but just on different layer.
    5145 network drops the RRC connection. So the device is not connected anymore. I have not seen any LTE networks to drop the connection so fast. What network is this?
    5170 network is re-creating the RRC connection as there is more incoming traffic.
    5185 network drop the RRC connection again.
    5211 device is rebooted.
    All in all, it looks like there is no bandwidth to respond to all CoAP queries that the server is sending. All queues are probably full and server is spamming with more incoming data.
    There is no device logs (from UART) that would show what is going on there. But I assume it is EAGAIN, as there is no bandwidth to send and network seem to drop the RRC connection quite fast.
    The device seems to stick to the error code "-11" (EAGAIN), it doesn't longer ACK nor respond to the retransmissions. the client doesn't send anything at all.
    No it does not "stick" into any error code. EAGAIN is coming from sendto() as long as all the buffers are full.
    which are well according RFC 7252, but the client (device) doesn't comply to RFC 7252.
    It might be true that each packet individually follows the RFC 7252, but it does not mean they can all pass through. Also server does not seem to follow "4.7 Congestion Control" from that RFC, especially the NSTART being equal to one.
    Secondly, RFCs default ACK_TIMEOUT is 2 seconds which works only on perfectly conditions on LTE-M, never on Nb-IOT. Try increasing to 5 seconds on LTE-M and 15 seconds to Nb-IoT.
    So, what is the device strategy to overcome (temporary) errors?
    As RFC recommends. CON messages are retransmitted until CONFIG_COAP_MAX_RETRANSMIT times.
    Non confirmable and Ack are dropped.
  • How long does that client usually run against the AVSystem LwM2M server in your experience before a restart is required?
    Client should not need restart during its lifetime.
    If have clients running 4 months until they ran out of battery. I have newer seen a client that requires restart when client, network and server are properly configured.
    However, pay attention that we are talking here about a client and server that are both lacking more than a year worth of fixes. At least the Zephyr's LwM2M client have been worked quite a lot during that time.
  • However, pay attention that we are talking here about a client and server that are both lacking more than a year worth of fixes.
    I guess, that's the important statement: it's worth to update, both.
  • With "stick" to error code, I don't meant, that the function call doesn't return (it obvious returned the error on return). But at that old version it seems, that the client isn't recover from that error situation. It doesn't send messages, even after several seconds.
    I don't use the lwm2m client, I just looked at the logs and captures. If you read my comments, you will find, that I already pointed to the congestion issue. But as I wrote, beside of that topic, in my opinion, the more general one is, how the client behaves in error situations.
    Not sure. I see 2s, which in my experience indicates AS-RAI. And message 4851 and 4853 at least enables AS-RAI.
  • All in all, it looks like there is no bandwidth to respond to all CoAP queries that the server is sending. All queues are probably full and server is spamming with more incoming data.
    Between the last message from the device in 5141 and the last received retransmission in 5203, "only" 11 messages are received within 25s (929.83 to 954.56). CoAP tries to mitigate congestion by increasing the retransmission time. But it doesn't work here, because the client seems to stop sending after the error.
    In my experience, this depends on the "side". If the modem tries to send something from a wakeup, you need additional time, also when the modem enters RRC idle while waiting for a pending message. From the server, when the device initiated the ip-route, that doesn't apply. AFAIK LTE-M is used, so initial 2s on the server side are not too bad in my experience.
