nRF52840 with MCUBOOT over SMP using SPI Flash - Fails to boot
I'm trying to use MCUBOOT with external flash on a nRF52840 board that has 4MB SPI flash. I'm using nRF Connect SDK v2.6.0.
I've verified that the SPI flash works fine using the "spi_flash" sample.
With CONFIG_BOOTLOADER_MCUBOOT=n, SMP with SPI flash runs fine. I'm able to connect to the "Zephyr" BLE device from nRF Connect for mobile.
However, with CONFIG_BOOTLOADER_MCUBOOT=y, the build is successful but the nRF52840 board fails to boot.
As the nRF52840 board (particle_xenon) has SPI flash instead of QSPI, I've set CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=n and added the required Kconfig dependencies.
Here is the prj.conf:
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_MCUMGR=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_BASE64=y
CONFIG_MCUMGR_TRANSPORT_SHELL=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_NORDIC_QSPI_NOR=n
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_CONSOLE=y
CONFIG_SERIAL=y
# Preferred SHELL options
CONFIG_SHELL=y
CONFIG_BOOT_BANNER=y
CONFIG_DATE_SHELL=y
CONFIG_POSIX_CLOCK=y
CONFIG_DEVICE_SHELL=n
CONFIG_INIT_STACKS=y
CONFIG_KERNEL_SHELL=y
CONFIG_SHELL_STATS=n
The board configuration "particle_xenon.conf" is set to use SPI flash:
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_SPI_NOR=y
The board "particle_xenon.overlay" is configured to use the external SPI flash (
&mx25l32 is defined in "particle_xenon.dts" board):
	chosen {
		nordic,pm-ext-flash = &mx25l32;
For MCUBOOT, folder "child_image > mcuboot > boards" has the board configuration & overlay files as,
particle_xenon.conf:
CONFIG_PM=n
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_IMAGE=n
CONFIG_BOOT_UPGRADE_ONLY=n
CONFIG_BOOT_BOOTSTRAP=n
### mbedTLS has its own heap
# CONFIG_HEAP_MEM_POOL_SIZE is not set
### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
### MCUboot has its own copy in tree.
# CONFIG_TINYCRYPT is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
# CONFIG_TINYCRYPT_SHA256 is not set
CONFIG_FLASH=y
CONFIG_FPROTECT=y
### Various Zephyr boards enable features that we don't want.
# CONFIG_BT is not set
# CONFIG_BT_CTLR is not set
# CONFIG_I2C is not set
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
### Ensure Zephyr logging changes don't use more resources
CONFIG_LOG_DEFAULT_LEVEL=0
### Use info log level by default
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
### Use the minimal C library to reduce flash usage
CONFIG_MINIMAL_LIBC=y
### Enable serial recovery
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_BOOT_SERIAL_NO_APPLICATION=y
CONFIG_UART_CONSOLE=n
### Increase receive buffer to improve transfer speed in serial recovery mode
CONFIG_BOOT_MAX_LINE_INPUT_LEN=8192
CONFIG_BOOT_SERIAL_MAX_RECEIVE_SIZE=4096
### Enable SPI flash
CONFIG_SPI=y
CONFIG_SPI_NOR=y
### Partition size allocated to bootloader - can be reduced if logging is disabled
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x12000
particle_xenon.overlay:
	chosen {
	aliases {
		mcuboot-button0 = &mode_button;
MCUBOOT > zephyr > zephyr.dts does include the "nordic,pm-ext-flash".
Here's a snippet from the file:
	model = "Particle Xenon";
	compatible = "particle,xenon", "particle,feather";
	chosen {
		zephyr,entropy = &cryptocell;
		zephyr,flash-controller = &flash_controller;
		zephyr,console = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,ieee802154 = &ieee802154;
What could be the reason for the application not running?
Am I missing some configuration or is part of it incorrect?  Thank you.
Ravi
  • Hello Andreas,
    Success! Thank you for providing the correct configuration for project and mcuboot.
    I changed the project structure a little as I want to use it to target another board as well.
    ├── CMakeLists.txt
    ├── README.rst
    ├── boards
    │   ├── particle_xenon.conf
    │   └── particle_xenon.overlay
    ├── build_xenon
    ├── child_image
    │   └── mcuboot
    │       └── boards
    ├── prj.conf
    ├── sample.yaml
    └── src
        ├── bluetooth_smp.c
        ├── bluetooth_smp.h
        └── main.c
    Here's the partition manager report showing external_flash (4MB) and mcuboot_secondary partition.
    quark11:smp_ble_feat_spi quark11$ west build -t partition_manager_report -b particle_xenon -d build_xenon
    -- west build: running target partition_manager_report
    [1/1] cd /Users/quark11/Documents/2024_dfu_projects/smp_ble...24_dfu_projects/smp_ble_feat_spi/build_xenon/partitions.yml
      external_flash (0x400000 - 4096kB):
    | 0x0: mcuboot_secondary (0xf0000 - 960kB)    |
    | 0xf0000: external_flash (0x310000 - 3136kB) |
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0x10000 - 64kB)                    |
    +---0x10000: mcuboot_primary (0xf0000 - 960kB)-----+
    | 0x10000: mcuboot_pad (0x200 - 512B)              |
    +---0x10200: mcuboot_primary_app (0xefe00 - 959kB)-+
    | 0x10200: app (0xefe00 - 959kB)                   |
      sram_primary (0x40000 - 256kB):
    | 0x20000000: sram_primary (0x40000 - 256kB) |
    I've used nRF Connect iOS to verify DFU over BLE with the secondary application slot (mcuboot_secondary) located on the external flash.
    I did notice that in the nRF Connect iOS, after selecting "DFU" and uploading the "app_update_bin" file, I got "Error: Not supported" message.
    After power cycling the Particle Xenon board, the new firmware ran successfully on the device. So, DFU over BLE seems to work fine.
    I'll review and clean up prj.conf later.
    Here is the console output showing initial firmware and then upload after a minor code change.
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    Hello World! particle_xenon
    Sample for BLE DFU feat SPI and external flash!
    [00:00:00.003,967] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                36 f0 e5 0e 87 68 48 fb  02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
                                                91 b1 5c ed                                      |..\.
    [00:00:00.005,920] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.005,920] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.005,950] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:00.006,713] <inf> bt_hci_core: Identity: DF:FA:B3:62:79:11 (random)
    [00:00:00.006,744] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:00:00.006,774] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:00.006,774] <inf> smp_bt_sample: Bluetooth initialized
    [00:00:00.007,598] <inf> smp_bt_sample: Advertising successfully started
    This is version 2.
    [00:00:23.039,611] <inf> smp_bt_sample: Connected
    [00:00:23.238,067] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
    [00:00:34.385,314] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:00:34.492,156] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:00:34.492,431] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:00:35.695,312] <inf> mcumgr_img_grp: Erased 0x40000 bytes of image slot
    [00:00:36.020,721] <inf> mcumgr_img_grp: Erased 0x10000 bytes of image slot trailer
    [00:01:07.249,877] <inf> mcuboot_util: Image index: 0, Swap type: none
    [00:01:07.251,037] <inf> mcuboot_util: Image index: 0, Swap type: perm
    uart:~$ *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    [00:00:00.251,617] <inf> mcuboot: Starting bootloader
    [00:00:00.252,471] <inf> mcuboot: Primary image: magic=good, swap_type=0x3, copy_done=0x1, image_ok=0x1
    [00:00:00.252,746] <inf> mcuboot: Secondary image: magic=good, swap_type=0x3, copy_done=0x3, image_ok=0x1
    [00:00:00.252,746] <inf> mcuboot: Boot source: none
    [00:00:00.253,204] <inf> mcuboot: Image index: 0, Swap type: perm
    [00:00:00.913,269] <inf> mcuboot: Starting swap using move algorithm.
    [00:00:00.003,784] <inf> app: DFU test #2
    [00:00:00.004,455] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                91 b1 5c ed                                      |..\.
    [00:00:00.006,378] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.006,408] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.006,439] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:00.007,171] <inf> bt_hci_core: Identity: DF:FA:B3:62:79:11 (random)
    [00:00:00.007,202] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:00:00.007,232] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:00.007,263] <inf> smp_bt_sample: Bluetooth initialized
    [00:00:00.008,087] <inf> smp_bt_sample: Advertising successfully started
    This is version 2.
    uart:~$
    In my mcuboot overlay (particle_xenon.overlay), I have
    	chosen {
    	aliases {
    		mcuboot-led0 = &status_green;
    I can get into MCUBOOT mode using "mode button" & "reset button" but the defined led doesn't turn on.
    Any idea why that may be the case? Thanks.
  • HI Andreas,
    It's ok. I forgot to add the following in the mcuboot configuration.
    CONFIG_MCUBOOT_INDICATION_LED=y
    Thank you for your
    assistance. It's much appreciated!
    Ravi
  • Hi again Ravi,
    Glad to hear that the sample was good enough to show you how it could be set up for your device!
    And yes, that would be the missing configuration you needed!
    I will mark this case as verified solved/but feel free to open new cases for new topics or reopen this case if you have additional questions related to this cases topic
    Andreas
  • Hi Andreas,
    Thank you for your assistance in resolving my issues. Greatly appreciated!
    The ticket can be marked as closed.
    Best Regards,
    Ravi
