Configuring Observer example to only accept Coded Phy messages
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode.   I've updaed prj.conf to take what I believe to be the correct settings to allow coded phy.   What I see is that the code is only seeing a coded phy message about once a minute even though the beacon is transmitting every 8s.
I've heard it mentioned that maybe the stack is switching between modes, and that could be the cause of the message loss.   Is there any function I can call to fix it in the Coded Phy mode?
I've seen examples for the older SDK, but they do not compile on zephr.
Can anyone point me in the right direction please?  I'm trying to compile the code for the MG100 gateway that uses the nRF52840 SOC.
Here's my prj.conf updates
CONFIG_BT=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_CENTRAL=y
# Coded PHY support
CONFIG_BT_CTLR=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_USER_PHY_UPDATE=y
