how to achieve the ble shift between keyboard and different ble host in ncs sdk?
hello
dear nordic team,im use the nrf5284 develop a keyboard by nrf desktop sdk ,but i dont konw how to chang the ble status in ncs sdk .i hope my keyboard can connect different ble host at certain time,for example,my keyboard be connected by host A,and than i change the mac id in ble adv,it is connected by host B.even i want change the connect between host A and B by key press.for example now it is connected by host A,then i want it disconnect to host A,and connect to host B.but i dont kown how to operate.i see the ble_bond.c code,but i cant gusse the meaning of enum.
  • it report as fllow:
    Building nrf_desktop_1
    C:\windows\system32\cmd.exe /d /s /c "west build --build-dir d:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build d:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1 --pristine --board nrf52840dk_nrf52840 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -Db0_CONF_FILE=D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/child_image/b0/prj.conf -Db0_OVERLAY_CONFIG=D:/NCS/V2.6/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -Ds1_image_OVERLAY_CONFIG=D:/NCS/V2.6/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -DCACHED_CONF_FILE=d:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/prj.conf -DDTC_OVERLAY_FILE=d:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/app.overlay"
    -- Application: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1
    -- CMake version: 3.21.0
    -- Found Python3: D:/NCS/V2.6/toolchains/cf2149caf2/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: D:/NCS/V2.6/v2.6.0/zephyr/.cache
    -- Zephyr version: 3.5.99 (D:/NCS/V2.6/v2.6.0/zephyr)
    -- Board: nrf52840dk_nrf52840
    -- Found host-tools: zephyr 0.16.5 (D:/NCS/V2.6/toolchains/cf2149caf2/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.5 (D:/NCS/V2.6/toolchains/cf2149caf2/opt/zephyr-sdk)
    -- Found Dtc: D:/NCS/V2.6/toolchains/cf2149caf2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/NCS/V2.6/v2.6.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: d:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/app.overlay
    -- Generated zephyr.dts: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/dts.cmake
    Parsing D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/Kconfig
    Loaded configuration 'D:/NCS/V2.6/v2.6.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
    Merged configuration 'd:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/prj.conf'
    Configuration saved to 'D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/.config'
    Kconfig header saved to 'D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: d:/ncs/v2.6/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: D:/NCS/V2.6/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    === child image b0 - begin ===
    loading initial cache file D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/child_image_preload.cmake
    -- Application: D:/NCS/V2.6/v2.6.0/nrf/samples/bootloader
    -- Generated zephyr.dts: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/zephyr/dts.cmake
    warning: HW_STACK_PROTECTION (defined at arch/Kconfig:259) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: ARCH_HAS_STACK_PROTECTION (=n). See
    docs.zephyrproject.org/.../kconfig.html and/or look up
    HW_STACK_PROTECTION in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    Parsing D:/NCS/V2.6/v2.6.0/zephyr/Kconfig
    Merged configuration 'D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/child_image/b0/prj.conf'
    Merged configuration 'D:/NCS/V2.6/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Configuration saved to 'D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/zephyr/.config'
    Kconfig header saved to 'D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0/zephyr/include/generated/autoconf.h'
    CMake Warning at D:/NCS/V2.6/v2.6.0/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
    --- WARNING: To maintain the integrity of secure boot, ---
    --- enable CONFIG_DISABLE_FLASH_PATCH in production. ---
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/b0
    === child image b0 - end ===
    === child image s1_image - begin ===
    loading initial cache file D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/image_preload.cmake
    -- Generated zephyr.dts: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/s1_image/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/s1_image/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/s1_image/zephyr/dts.cmake
    CMake Warning at D:/NCS/V2.6/v2.6.0/zephyr/CMakeLists.txt:1957 (message):
    -- Found partition manager static configuration: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840/pm_static.yml
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/s1_image
    === child image s1_image - end ===
    Partition 'b0_container' is not included in the dynamic resolving since it is statically defined.
    Partition 'b0' is not included in the dynamic resolving since it is statically defined.
    Partition 'provision' is not included in the dynamic resolving since it is statically defined.
    Partition 's0' is not included in the dynamic resolving since it is statically defined.
    Partition 's0_image' is not included in the dynamic resolving since it is statically defined.
    Partition 's1' is not included in the dynamic resolving since it is statically defined.
    Partition 's1_image' is not included in the dynamic resolving since it is statically defined.
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
    Dropping partition 's0_pad' since its size is 0.
    Dropping partition 's1_pad' since its size is 0.
    -- Configuring done
    -- Generating done
    [5/351] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (D:/NCS/V2.6/v2.6.0/zephyr), build: v3.5.99-ncs1
    [2/134] Generating include/generated/version.h
    [134/134] Linking C executable zephyr\zephyr.elf
    Memory region Used Size Region Size %age Used
    FLASH: 12612 B 20 KB 61.58%
    RAM: 38288 B 256 KB 14.61%
    IDT_LIST: 0 GB 32 KB 0.00%
    [45/351] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    FAILED: zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    D:\NCS\V2.6\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,78850 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,78850 -D__PROGRAM_START -D__ZEPHYR__=1 -ID:/NCS/V2.6/v2.6.0/zephyr/kernel/include -ID:/NCS/V2.6/v2.6.0/zephyr/arch/arm/include -ID:/NCS/V2.6/v2.6.0/nrf/drivers/mpsl/clock_control -ID:/NCS/V2.6/v2.6.0/zephyr/include -ID:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/include/generated -ID:/NCS/V2.6/v2.6.0/zephyr/soc/arm/nordic_nrf/nrf52 -ID:/NCS/V2.6/v2.6.0/zephyr/soc/common/nordic_nrf/. -ID:/NCS/V2.6/v2.6.0/zephyr/soc/arm/nordic_nrf/common/. -ID:/NCS/V2.6/v2.6.0/zephyr/subsys/usb/device -ID:/NCS/V2.6/v2.6.0/zephyr/subsys/bluetooth -ID:/NCS/V2.6/v2.6.0/zephyr/subsys/settings/include -ID:/NCS/V2.6/v2.6.0/zephyr/drivers/usb/common/nrf_usbd_common/. -ID:/NCS/V2.6/v2.6.0/nrf/include -ID:/NCS/V2.6/v2.6.0/nrf/lib/multithreading_lock/. -ID:/NCS/V2.6/v2.6.0/nrf/subsys/bluetooth/controller/. -ID:/NCS/V2.6/v2.6.0/nrf/subsys/app_event_manager/. -ID:/NCS/V2.6/v2.6.0/nrf/subsys/app_event_manager_profiler_tracer/. -ID:/NCS/V2.6/v2.6.0/zephyr/drivers/flash -ID:/NCS/V2.6/v2.6.0/nrf/tests/include -ID:/NCS/V2.6/v2.6.0/modules/hal/cmsis/CMSIS/Core/Include -ID:/NCS/V2.6/v2.6.0/zephyr/modules/cmsis/. -ID:/NCS/V2.6/v2.6.0/modules/hal/nordic/nrfx -ID:/NCS/V2.6/v2.6.0/modules/hal/nordic/nrfx/drivers/include -ID:/NCS/V2.6/v2.6.0/modules/hal/nordic/nrfx/mdk -ID:/NCS/V2.6/v2.6.0/zephyr/modules/hal_nordic/nrfx/. -ID:/NCS/V2.6/v2.6.0/modules/debug/segger/SEGGER -ID:/NCS/V2.6/v2.6.0/modules/debug/segger/Config -ID:/NCS/V2.6/v2.6.0/modules/crypto/tinycrypt/lib/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/common/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio_spi/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/simple_gpio/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/fem/include/protocol -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/include -ID:/NCS/V2.6/v2.6.0/nrfxlib/mpsl/include/protocol -ID:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/common -ID:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/configuration/nrf52840dk_nrf52840 -ID:/NCS/V2.6/v2.6.0/nrfxlib/softdevice_controller/include -isystem D:/NCS/V2.6/v2.6.0/zephyr/lib/libc/minimal/include -isystem D:/NCS/V2.6/v2.6.0/zephyr/lib/libc/common/include -isystem d:/ncs/v2.6/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem d:/ncs/v2.6/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem D:/NCS/V2.6/v2.6.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -O2 -imacros D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=D:/NCS/V2.6/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros D:/NCS/V2.6/v2.6.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1=CMAKE_SOURCE_DIR -fmacro-prefix-map=D:/NCS/V2.6/v2.6.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=D:/NCS/V2.6/v2.6.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -MF zephyr\CMakeFiles\zephyr.dir\misc\generated\configs.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -c D:/NCS/V2.6/v2.6.0/nrf/applications/nrf_desktop_1/build/zephyr/misc/generated/configs.c
    C:\Users\ADMINI~1\AppData\Local\Temp\ccMBwIH4.s: Assembler messages:
    C:\Users\ADMINI~1\AppData\Local\Temp\ccMBwIH4.s:728: Error: missing expression
    [57/351] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    FATAL ERROR: command exited with status 1: 'D:\NCS\V2.6\toolchains\cf2149caf2\opt\bin\cmake.EXE' --build 'd:\NCS\V2.6\v2.6.0\nrf\applications\nrf_desktop_1\build'
  • I can't see from the build log that the extra overlay config file prk_keyboard.conf was included in this case. Can you show me a picture of what your build configuration in NCS looks like? You can right click the build configuration in the menu on the left in VS Code and select "Edit build configuration":
    BR,
    Edvin
