Configuration for native tls (no offload to modem)
Dear Support-Team,
due to the 2KB limitation of the secure buffers of the nrf9160 modem I am trying to setup native tls. I found the https_client sample which sounded promising, but when I use the same configuration as described in the sample (prj.conf + overlay-tfm_mbedtls.conf) I get a "region FLASH overflow", so I am a trying to figure out which settings do what.
Using https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/kconfig/index.html does not help as the description gives no clue at all:
Examples:
CONFIG_NRF_SECURITY_ADVANCED
Advanced mbed TLS Configuration Settings
This configuration has no effect and will be deprecated. It is kept in to ensure projects setting this aren't affected.
or
CONFIG_TFM_PROFILE_TYPE_NOT_SET
TF-M build profile is not set
Is there any other documentation for those configurations?
Best regards
Context: I am working on a MQTT project and I have provisioned the certificates to the modem. With setting set_native_tls in the mqtt_sec_config struct I am able to connect to the server and get the data I expect (> offloading to the modem). Now I have to change to native tls in order to receive some other data which does not fit into the 2kB secure buffer of the modem.
    Are you targeting to not use any TFM PSA APIs for crypto?
    As you originally mention, this overlay conf file shows how to setup mbedtls in the application space, using TFM crypto:
    https://github.com/nrfconnect/sdk-nrf/blob/v2.5.2/samples/net/https_client/overlay-tfm_mbedtls.conf
    Stefan Schmidt said:
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=8192
    Note that the modem cannot handle more than 4k on non-secure sockets, so no need to exceed 4096 bytes on this configuration.
    Is your posted configuration complete? I cannot see "CONFIG_MODEM_KEY_MGMT=n" in there.
    Håkon
  • Hi Håkon,
     I see in my .config that CONFIG_MODEM_KEY_MGMT is not set.
    I have to get data from a server which does not support chunked encoding or similar techniques to break down the data into chunks that would fit into the nrf9160 modem tls buffer (Limitations in the release notes of the 1.3.5 modem firmware - TLS/DTLS - Secure socket buffer size is 2kB.).
    Therefore I use mbedtls with raw sockets. With the configuration above I am able to receive the 5949 Bytes in one chunk, this is what I get from my call to zsock_recv():
    [00:00:31.687,713] <err> fetch_data: zsock_recv() gave 5949 bytes
    But the configuration dependencies are not clear to me and I think the documentation is a mess.
    Another example:
    In this post RE: Crypto (PSA/mbedtls) ERRORS when migrating from SDK 2.1.1 to SDK 2.5.0 the author mentions "You use both CONFIG_NRF_SECURITY=y and CONFIG_NORDIC_SECURITY_BACKEND=y in your configuration. Unfortunately, this combination makes PSA unavailable."
    But CONFIG_NORDIC_SECURITY_BACKEND is selected by CONFIG_BUILD_WITH_TFM (which is selected when I build a _ns image):
    Use nRF Security with Mbed TLS legacy crypto APIs support
    Using this configuration enables legacy support for mbed TLS APIs This configuration is not to be used for PSA API support. Note that this will enable nrf_oberon by default. Multiple backends is not supported.
    Dependencies
    CONFIG_SOC_FAMILY_NRF
    Defaults
    y if CONFIG_BUILD_WITH_TFM
    And CONFIG_NRF_SECURITY is required to enable PSA:
    Enable nRF Security
    Set this configuration to enable nRF Security. This provides Arm PSA cryptography APIs with RNG support (optionally).
    Dependencies
    Defaults
    So my understanding is that both are set to y by CONFIG_BUILD_WITH_TFM, but they should not be both enabled if I want to use the PSA API?!?!?
    What would be the correct minimal configuration when I need tls1.2 with x509 certificates and a data chunks size exceeding the limitation of the modem? On a nrf9160 with nrf Connect SDK v 2.5.0 and a non-secure application....
    Your mentioning of CONFIG_MODEM_KEY_MGMT makes me a bit nervous: Is it possible to use raw sockets with mbedtls and offloaded secure sockets in the same firmware? I thought I just set the SOCK_NATIVE_TLS to choose which tls implementation I am using on the socket?!?
    The reason I was asking is because of the https_client sample.
    If you are testing with the https_client sample, this is a check in main on where to store the certificate, either via the modem API or via tls_credentials_* API.
    In general, you can add this to add debug prints (note: there will be a lot...) from mbedtls:
    CONFIG_MBEDTLS_DEBUG=y
    CONFIG_MBEDTLS_DEBUG_C=y
    CONFIG_MBEDTLS_DEBUG_LEVEL=4
    CONFIG_MBEDTLS_LOG_LEVEL_DBG=y
    CONFIG_MBEDTLS_SSL_DEBUG_ALL=y
    CONFIG_LOG_BUFFER_SIZE=20000
    If you do not want to use PSA APIs with mbedtls, here is an example with a modified https_client sample (note: using DigiCertGlobalG2.pem and not DigiCertGlobalRootCA.pem as originally used in ncs v2.5.x! host has changed root since this time).
    https_client_mbedtls_nrf9160.zip
    Again, the above uses mbedtls in the non-secure application, and not via PSA APIs. Please also see the defines/checks in main.c to match against your own application.
    Håkon
  • Hi Håkon,
     I have everything working now: I fetch the credentials with mbedtls and raw socket and store them to the modem, so that I can use them later with offloaded sockets.
    I started my journey with the https_client sample you mentioned and I have replaced the root certificate locally.
    Although everything is working I am still confused about the configurations of legacy and PSA APIs: Which one should I use? And how do I configure the usage of the PSA API? See my last post in our thread, it seems contradicting (CONFIG_NRF_SECURITY <> CONFIG_NORDIC_SECURITY_BACKEND).
    Best regards
    Stefan
  • Hi Stefan,
    Glad to hear that you got it running.
    Both work. Using PSA (ie. using TF-M to do the actual crypto-operations) will be more secure, but it will likely take up a bit more flash.
    https_client sample has an overlay for this, with PSA crypto enabled:
    Håkon
