ESB High frequency transmission
Hi:
I have the following hardware structure:
FPGA < -- SPI -- > NRF5340 (TX)  -- !    (ESB)   ! -- NRF5340 (RX) < -- USB -- > PC
Due to the nature of my application, I need to send a lot of data through the ESB with high frequency. (250 bytes of data are transferred every 2ms.)
As a result, I've achieved what I needed. But the transfer was erratic, even when I put the two DK boards close together:
-->  I control IO level flipping at SPI receive, ESB send, and ESB receive, respectively.
--> The results show that the ESB receives no more than 30s. And I need to reset PTX to have a high probability to work again.
Here is my project with the code configuration:
PTX and PRX:
CONFIG_ESB_NEVER_DISABLE_TX=y
CONFIG_ESB_TX_FIFO_SIZE=64
CONFIG_ESB_RX_FIFO_SIZE=64
ret..delay = 150, ret...count = 1, tx_mode = manual_start, fast_ramp_up = true, auto_ack = true, crc = off
PTX:
spis_handler:
write_payload, toggle pin 1, set spis buffer
main:
start_tx, toggle pin 2
PRX:
esb_handler:
read_payload, toggle pin 3
The core code is as above, omitting some other code, but I don't think it will affect the solution of the problem, of course, if you need to provide other content or source code is ok.
For the transfer of data, I allow a small amount of data packet loss.
Thanks !
  • Hi
    Have you tried to implement a simple test where you just send dummy data from a timer, to double check if the problem is related to the handover of data between the SPI interface and the ESB library?
    1) Looking through your code I found a potential issue in the SPI_Thread(..) thread function:
    if (likely(!k_fifo_is_empty(&SPI_DATA_FIFO)))
        rx_data = k_fifo_get(&SPI_DATA_FIFO, K_FOREVER);
        if (rx_data)
            memcpy(tx_payload.data, rx_data->data, rx_data->data_size);
            tx_payload.length = rx_data->data_size;
            esb_write_payload(&tx_payload);
            gpio_pin_toggle_dt(&(test_gpios[1]));
    If I read this code correctly it will call k_fifo_is_empty(..) repeatedly as long as the FIFO is empty, without yielding the thread, which will block other threads in the system. You should be able to simply remove this if check, and just call k_fifo_get(&SPI_DATA_FIFO, K_FOREVER). In that case the thread will yield as long as there is no data in the FIFO, and only be resumed once the data is there.
    2) Did you consider running the SPI coms from the appcore, so you didn't need to bit bang the SPI master?
    3) Why is CRC disabled?
    4) What kind of hardware are you using? Is this standard devkits or custom hardware?
    Best regards
    Torbjørn
  • I'm sorry to reply you so late. I solved the problem from the backup program, but your advice is very useful, thank you!
  • Hi
    Good to hear you found the problem. I will close the ticket then Slight smile
    Regards
    Torbjørn
