HI Nordic support team.
I have a question relate to TX power in ANT application:
- ANT Tx application using: ant_broadcast ->Tx
- ANT Rx application using: ant_continuous_scanning_controller
- SDK 17.1, segger embedded studio
We using ANT application connect to sensor. Each 6s sensor wakeup Ant appliction by external interupt and transmit data by call ant_message_send();
It mean we can see Tx power each 6s.
When we using power consumtion monitor i see that it seem ANT appliction transmit power each 1s instead 6s as my target.
You can see in PIC bellow:
Here is som configure and function in my code:
// ANT sTx configuration
static void application_initialize()
uint32_t err_code;
/* Set library config to report RSSI and Device ID */
//err_code = sd_ant_lib_config_set(ANT_LIB_CONFIG_MESG_OUT_INC_RSSI | ANT_LIB_CONFIG_MESG_OUT_INC_DEVICE_ID);
//APP_ERROR_CHECK(err_code);
const uint16_t dev_num = (uint16_t)NRF_FICR->DEVICEID[0];
const ant_channel_config_t ms_channel_config =
.channel_number = ANT_MS_CHANNEL_NUMBER,
.channel_type = CHANNEL_TYPE_MASTER,
.ext_assign = 0x00,
.rf_freq = RF_FREQ, // channel 25
.transmission_type = CHAN_ID_TRANS_TYPE,
.device_type = CHAN_ID_DEV_TYPE,
.device_number = dev_num,
.channel_period = CHAN_PERIOD, // PERIOD 32767
.network_number = ANT_NETWORK_NUM,
err_code = ant_channel_init(&ms_channel_config);
// Fill tx buffer for the first frame
ant_message_send();
err_code = sd_ant_channel_open(ANT_MS_CHANNEL_NUMBER);
//Callback function for external interupt
//each time interupt happened will send Tx messa, period is 6s
static void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
NRF_LOG_INFO("Int example0\n");
Qflag = true;
//nrf_drv_gpiote_out_toggle(PIN_OUT);
ant_message_send();
//NRF_LOG_INFO("Message sent %s", string);
NRF_LOG_INFO("Index %d", index);
index++;
// <o> RF_FREQ - RF Frequency. #ifndef RF_FREQ #define RF_FREQ 25 #endif // <o> CHAN_PERIOD - Channel Period (in 32 kHz counts). #ifndef CHAN_PERIOD #define CHAN_PERIOD 32767 #endif
Can you help me explain, why Tx power is transmited each 1s instead 6s.
I try to change period of sensor to 30s, i receive same result. Tx transmit power each 1s.
=> it take so much power, and our production cannot running in target time(2-3 year)
