VS-CODE: build hangs: "Found GnuLd: ld.bfd..."
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The procedure I've found to get around this is to cancel the build, and then open a shell in the app directory and do the following:
% rm -rf build*
% export ZEPHYR_BASE=/opt/nordic/ncs/v2.6.0/zephyr
% west build -b nrf52840dk_nrf52840 -p
I can then use the build & build pristine actions.
It might be my environment is not fully supported. The `app` is stand-alone. There is an out-of-the tree module with source i reference with the following CMakeLists.txt fragment:
cmake_minimum_required(VERSION 3.20.0)
set(my-module "${CMAKE_CURRENT_SOURCE_DIR}/../my-module")
set(EXTRA_ZEPHYR_MODULES ${my-module})
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
This module includes (via settings) board_root, dts_root, & soc_root,  as well as source, library, and include trees picked up from cmake + kconfig variables.
The build environment: Apple M1 Mac, MacOS: 12.6.7 (Monterey), VS-Code: v1.88.1, NRF-Connect: v2024.3.25
The Welcome tab shows SDK + Toolchain: v2.6.0. (I also use stock Zephyr to compile for non-Nordic boards, but am selecting proper SDK + toolchain, and have even removed `.west` directory for stock zephyr installation).
Sorry to keep complaining about a great tool, but it's frustrating when it stops working.
Thanks. Kent
  • You can generate support information in VS Code by pressing this button in the nRF Connect extension. That might be helpful for us.
    Simon
  • // IMPORTANT: The following data can contain sensitive or confidential information about your environment.
    // If you do not want others to see this information, make sure to remove it before sharing the data.
    // For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 22.5.0: Mon Apr 24 20:52:43 PDT 2023; root:xnu-8796.121.2~5/RELEASE_ARM64_T8112",
        "osKernel": "22.5.0",
        "vscode": "1.96.3",
        "electron": "32.2.6",
        "node": "v20.18.1"
      "system": {
        "date": "2025-01-15T16:38:36.686Z",
        "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "vscodeUptime": "06:50:44",
        "osUptime": "06:51:25",
        "cpu": "Apple M2"
      "workspace": {
        "name": "trailpulse-edge",
        "workspaceFile": null,
        "folders": [
          "/Users/sh/dev/git/trailpulse-edge"
      "sdks": [
          "version": "v2.9.0",
          "path": "/opt/nordic/ncs/v2.9.0"
          "version": "v2.7.0",
          "path": "/opt/nordic/ncs/v2.7.0"
          "version": "v2.6.1",
          "path": "/opt/nordic/ncs/v2.6.1"
          "version": "v2.5.2",
          "path": "/opt/nordic/ncs/v2.5.2"
      "apps": [
          "workspace": "/Users/sh/dev/git/trailpulse-edge",
          "uri": "/Users/sh/dev/git/trailpulse-edge",
          "buildConfigurations": []
      "toolchains": [
          "version": "2.9.0",
          "path": "/opt/nordic/ncs/toolchains/b8efef2ad5"
          "version": "2.8.0",
          "path": "/opt/nordic/ncs/toolchains/15b490767d"
          "version": "2.7.0",
          "path": "/opt/nordic/ncs/toolchains/f8037e9b83"
          "version": "2.6.2",
          "path": "/opt/nordic/ncs/toolchains/580e4ef81c"
          "version": "2.6.1",
          "version": "2.6.0",
          "version": "2.5.2",
          "path": "/opt/nordic/ncs/toolchains/20d68df7e5"
      "connectedDevices": [
          "serialNumber": "001050238934"
      "tools": {
        "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.5 (arm64)",
        "/Applications/SEGGER/JLink/JLinkExe": "8.12a (x64,arm64)",
        "/usr/local/bin/nrfjprog": "10.24.0 (x64,arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake": "3.21.0 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/west": "1.2.0",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/python3": "3.9.6 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/ninja": "1.10.2 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/gperf": "3.1 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc": "1.6.1 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/gn": "2154 (arm64)",
        "/opt/nordic/ncs/toolchains/580e4ef81c/bin/git": "2.37.3 (arm64)",
        "arm-gdbPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
        "riscv-gdbPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.7.2",
          "binPath": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64/platform/nrfutil/bin/nrfutil-device",
          "jlinkInfo": {
            "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
            "expectedVersion": {
              "version": "JLink_V7.94i",
              "versionFormat": "string"
            "name": "JlinkARM",
            "version": "JLink_V8.12a",
        "nrfutil-toolchain-manager": {
          "version": "0.14.4",
          "binPath": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64/platform/nrfutil/bin/nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/Cellar/git/2.37.3/libexec/git-core",
          "HOME": "/Users/sh",
          "PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/local/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/Library/Frameworks/Python.framework/Versions/3.12/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/Library/Frameworks/Python.framework/Versions/3.12/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
          "ZEPHYR_BASE": "/opt/nordic/ncs/v2.6.1/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk",
          "USER": "sh"
        "inherited": {
          "ELECTRON_RUN_AS_NODE": "1",
          "PATH": "/opt/homebrew/bin:/opt/homebrew/sbin:/Library/Frameworks/Python.framework/Versions/3.12/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
          "USER": "sh"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "${nrf-connect.sdk:2.6.1}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.6.1}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "terminalProfile": {
            "shell": null
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.12.55",
            "path": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.12.55-darwin-arm64",
            "isActive": true
            "version": "2024.9.14",
            "path": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.9.14",
            "isActive": true
            "version": "2024.12.15",
            "path": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.12.15",
            "isActive": true
            "version": "2024.12.13",
            "path": "/Users/sh/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.12.13",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.22.11",
          "ms-vscode.js-debug": "1.96.0",
          "alexnesnes.teleplot": "1.1.4",
          "bierner.markdown-mermaid": "1.27.0",
          "Continue.continue": "0.8.66",
          "ms-python.debugpy": "2024.14.0",
          "ms-python.python": "2024.22.2",
          "ms-python.vscode-pylance": "2024.12.1",
          "ms-vscode-remote.remote-containers": "0.394.0",
          "ms-vscode.cmake-tools": "1.19.52",
          "ms-vscode.hexeditor": "1.11.1",
          "platformio.platformio-ide": "3.3.4",
          "TabNine.tabnine-vscode": "3.223.0",
          "twxs.cmake": "0.0.17"
    here pls
    thanks in advanced simon
  • Thanks Sebastian. I've forwarded the support info to the internal ticket and we'll get back to you if we find something useful.
    Simon
  • +1, The same issue with vscode and cursor. NCS 3.0.2, M4
  • Same issue for me :(
    Is there a reason why it cannot be fixed?
