Can't get BLE device to sleep
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then set a timer to wake the `app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL);`
And I expect the device to go into sleep whilst its BLE is not advertising. Here's my main.c file:
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_crypto_init.h"
#include "nrfx_clock.h"
#include "SEGGER_RTT.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "customble.h"
#include "peripheral.h"
#include "encryption.h"
void timers_init(void)
    nrf_pwr_mgmt_run();
void power_management_init(void)
  ret_code_t err_code;
  NRF_LOG_INIT(NULL);
  ret_code_t reta = nrf_crypto_init();
  APP_ERROR_CHECK(reta);
  timers_init();
  ble_timers_init();
  ble_stack_init();
  power_management_init();
  gap_params_init();
  advertising_init();
  advertising_start();
  for (;;)
    idle_state_handle();
and here's the relevant sections of the customble.c code
void awake_timer_handler()
  NRF_LOG_INFO("Awake and start advertising");
  update_advertising_data_while_advertising();
void sleep_timer_handler()
  NRF_LOG_INFO("asleep");
  sd_ble_gap_adv_stop(m_advertising.adv_handle); // i've tried with and without this
  // Proceed with setting the device to low power mode
  app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL); // 60 seconds
void on_adv_evt(ble_adv_evt_t ble_adv_evt)
  NRF_LOG_INFO("BLE EVENT");
  switch (ble_adv_evt)
  case BLE_ADV_EVT_IDLE:
    NRF_LOG_INFO("Advertising event: Idle");
    sleep_timer_handler();
I have measured the amps on the device and during advertising it jumps to about 3mA and when it's not advertising (when I thought it would sleep) it's using ~1.48mA. What exactly am I doing wrong here?
I have commented lots of things out, and it's not the TWI causing the issue, it's definitely the BLE. When I comment out starting BLE, I get ~400uA constant.
  • NRF_LOG_BACKEND_RTT_ENABLED doesn't control the UART. It is possible to have both RTT and UART Logging at the same time. Just make sure you don't have NRF_LOG_BACKEND_UART_ENABLED set to 1. If you do, then the UART will be left on.
    Yes, I was under the belief that RTT could also cause the device not to sleep, so was just confirming that was also disabled during my tests.
    I just checked and NRF_LOG_BACKEND_UART_ENABLED is indeed set to 0 so that's not the problem.
    > What is NON_CONNECTABLE_ADV_INTERVAL? 160 (100ms)?
    Yep, it's set to:
    #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS)
  • I've attached the ZIP file, I don't have a device on me at the moment to verify it works but it's building successfully and should work. If you can't get it to run on the device I'll have to upload another ZIP in a few days when I'm back home.
    The path you can extract this to for all of the paths to align with the SDK:
    nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_alert_notification
    output.zip
  • Thank you. I found it:
    Two things you need to change:
    1. In your preprocessor definitions, you need to remove DEVELOP_IN_NRF52832 if you are actually running on an nRF52810. If you are simulating the nRF52810 on an nRF52 DK, you should keep that definition.
    2. In your sdk_config.h (this took some time to find, because you had your list on the top Slight smile), you need to set the LFCLK source to be either XTAL or the RC Oscillator. It was currently set to SYNTH, which will use the HFCLK to synthesize the LFCLK. This means that the HFCLK will be running at all times when you otherwise would use just the LFCLK. And the BLE stack enables the LFCLK, which was why you saw this behavior when enabling the softdevice.
    So remove DEVELOP_IN_NRF52832 if you are actually running the application on an nRF52810, and change the LFCLK source to either XTAL (if you have an XTAL) or RC_OSCILLATOR if you don't have an XTAL.
    Edvin
  • Amazing, thank you so much! I'll give this a go as soon as I get back to my DK and let you know the results!
    I honestly would never have been able to work this out - it's interesting that setting LFCLK to SYNTH causes this behaviour!
    Quick question, what's the best way to conditionally include DEVELOP_IN_NRF52832? I will alternate between the DK and my PCBA, so would prefer not to have to constantly switch.
    edit: apologies for making your life more difficult by modifying the LFCLK value inline instead of defining it at the top!
  • Hey Edvin!
    I set the LFCLK source to RC but unfortunately I was reminded as to why it was set to SYNTH to start with - without setting it to SYNTH the BLE module would not work.
    I'm looking at getting a hardware review (and adding a external HF clock to the PCBA).
    Nathan
