nrf5340 audio: FOTA Firmware can't build
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `text' will not fit in region `FLASH'
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 20308 bytes
I know this problem exists in NCS2.5.99 and the reason is, but NCS2.6 should have fixed it?
I know that I need to cut the controller. For BIS headset and BIS gateway, what configurations can I use to reduce the size?
  • Hi Reskyllr,
    Which features of SoftDevice Controller have you tried to disable? What was the result? How big improvement did you get on the initial overflow of 20308 bytes?
    Dejan
  • Hi,dejans,
    It's my hci_ipc.conf.
    CONFIG_BT_ISO_PERIPHERAL=y
    # CONFIG_BT_ISO_CENTRAL=y
    # CONFIG_BT_ISO_BROADCASTER=y
    # CONFIG_BT_ISO_SYNC_RECEIVER=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER=n
    CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER=n
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    CONFIG_BT_CTLR_CONN_ISO_GROUPS=1
    CONFIG_BT_CTLR_CONN_ISO_STREAMS=2
    CONFIG_BT_CTLR_SYNC_ISO_STREAM_COUNT=2
    CONFIG_BT_CTLR_ADV_ISO_SET=1
    CONFIG_BT_CTLR_ADV_ISO_STREAM_COUNT=2
    # Support two links as a central, or one link as a peripheral
    CONFIG_BT_MAX_CONN=3
    # Allow using more than default advertising event length
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=251
    # To present the audio at the right point in time, we need the controller and
    # audio clock to be synchronized
    CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START=y
    CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START_CHANNEL=4
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    # If using FEM the CONFIG_BT_CTLR_TX_PWR_ANTENNA should be set here if the
    # value required is not 10 dBm
    # hdeadset needn't
    CONFIG_BT_ISO_CENTRAL=n
    CONFIG_DEBUG=n
    CONFIG_ASSERT=n
    CONFIG_STACK_USAGE=n
    CONFIG_THREAD_MONITOR=n
    CONFIG_SERIAL=n
    CONFIG_CONSOLE=n
    CONFIG_PRINTK=n
    CONFIG_UART_CONSOLE=n
    CONFIG_BOOT_BANNER=n
    now log:
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 3604 bytes.
    For Le audio BIS,I don't know what improvements could be made, that's what I want to know.
    Reskyllr.
  • Hi Reskyllr,
    Can you check if 3 options shown below are set to 'n' in your output files?
    Dejan
  • Hi,dejans,
    I've tried this, I've set:
    CONFIG_BT_ISO_CENTRAL=n,this is already the result after setting.
    For:
    If I set either to n, I can't synchronize with bis gateway.
    For Le audio, are there any other options that can be turned off?
    Reskyllr
