nrf5340 audio: FOTA Firmware can't build
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `text' will not fit in region `FLASH'
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 20308 bytes
I know this problem exists in NCS2.5.99 and the reason is, but NCS2.6 should have fixed it?
I know that I need to cut the controller. For BIS headset and BIS gateway, what configurations can I use to reduce the size?
  • Hi  ,
    I hope you don't mind sharing how you managed to solve it.
    Could you share the configuration you used?
    Ahmed
  • Be sure,
    hci_ipc.conf
    # Copyright (c) 2023 Nordic Semiconductor ASA
    CONFIG_BT_ISO_PERIPHERAL=y
    # CONFIG_BT_ISO_CENTRAL=y
    # CONFIG_BT_ISO_BROADCASTER=y
    # CONFIG_BT_ISO_SYNC_RECEIVER=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER=n
    CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER=n
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    CONFIG_BT_CTLR_CONN_ISO_GROUPS=1
    CONFIG_BT_CTLR_CONN_ISO_STREAMS=2
    CONFIG_BT_CTLR_SYNC_ISO_STREAM_COUNT=2
    CONFIG_BT_CTLR_ADV_ISO_SET=1
    CONFIG_BT_CTLR_ADV_ISO_STREAM_COUNT=2
    # Support two links as a central, or one link as a peripheral
    CONFIG_BT_MAX_CONN=3
    # Allow using more than default advertising event length
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=251
    # To present the audio at the right point in time, we need the controller and
    # audio clock to be synchronized
    CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START=y
    CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START_CHANNEL=4
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    # If using FEM the CONFIG_BT_CTLR_TX_PWR_ANTENNA should be set here if the
    # value required is not 10 dBm
    # hdeadset needn't
    CONFIG_BT_ISO_CENTRAL=n
    #CONFIG_BT_PERIPHERAL=n
    CONFIG_BT_ISO_PERIPHERAL=n
    CONFIG_DEBUG=n
    CONFIG_ASSERT=n
    CONFIG_STACK_USAGE=n
    CONFIG_THREAD_MONITOR=n
    CONFIG_SERIAL=n
    CONFIG_CONSOLE=n
    CONFIG_PRINTK=n
    CONFIG_UART_CONSOLE=n
    CONFIG_BOOT_BANNER=n
    Please note that it only supports BIS.
    Reskyllr
  • Hi Reskyllr,
    Thank you for sharing your configuration. It is good to hear that you managed to find working configuration. With your current configuration that supports BIS, how much space on the flash has been used?
    Dejan
