Interfacing between MAX86141 and nRF5340dk
I'm currently working on using a MAX86141 sensor (datasheet found here), and I've been running into some issues with communicating with it since this is the first time I've used SPI communication before. I've gone through the Dev Academy course and have been able to get some basic functionality down. For instance, I'm currently able to read from the part ID register (register 0xFF) and get back the expected value (0x25) and print this to a serial monitor. I'm still struggling, however, to actually functionally configure and read from the FIFO. I've been working on this for a while now and still haven't had any luck with it, so I'm hoping someone can help me find where I'm going wrong and point me in the right direction.
Currently, I've set up the following read and write register commands
static int spi_read_reg(uint8_t reg, uint8_t values[], uint8_t size)
    int err;
    uint8_t tx_buffer[1];
    tx_buffer[0] = reg;
    struct spi_buf tx_spi_bufs[] = {
        { .buf = tx_buffer, .len = sizeof(tx_buffer)},
    struct spi_buf_set spi_tx_buffer_set = {
        .buffers = tx_spi_bufs,
        .count = 1
    struct spi_buf rx_spi_bufs[] = {
        {.buf = values, .len = size,}
    struct spi_buf_set spi_rx_buffer_set = {
        .buffers = rx_spi_bufs,
        .count = 1
    gpio_pin_set(gpio1_dev, GPIO_1_CS, 0);
    do{
        err=spi_write(spi_dev,&spi_cfg,&spi_tx_buffer_set);
        if (err < 0){break;}
        err=spi_read(spi_dev,&spi_cfg,&spi_rx_buffer_set);
    }while (false);
    gpio_pin_set(gpio1_dev, GPIO_1_CS, 1);
    uint8_t data = values[2];
    printk("Read: 0x%02X\n\r", data);
    if (err < 0)
        printk("Read Registers Failed");
static int spi_write_reg(uint8_t reg, uint8_t value)
	int err;
	uint8_t tx_buf[] = {(reg & 0x7F), value};
	struct spi_buf 		tx_spi_buf 		= {.buf = tx_buf, .len = sizeof(tx_buf)};
	struct spi_buf_set 	tx_spi_buf_set	= {.buffers = &tx_spi_buf, .count = 1};
    err=spi_write(spi_dev,&spi_cfg,&tx_spi_buf_set);
	if (err < 0) {
		printk("spi_write_dt() failed, err %d", err);
		return err;
	return 0;
and I have the following definitions for my registers set up in the code:
#define WRITE_EN 0x00
#define READ_EN 0xFF
#define REG_INT_STAT_1         0x00      //Interrupt Status 1
#define REG_INT_STAT_2         0x01      //Interrupt Status 2
#define REG_INT_EN_1           0x02      //Interrupt Enable 1
#define REG_INT_EN_2           0x03      //Interrupt Enable 2
#define REG_FIFO_WR_PTR        0x04      //FIFO Buffer Write Pointer
#define REG_FIFO_RD_PTR        0x05      //FIFO Buffer Read Pointer
#define REG_OVF_COUNTER        0x06      //Over Flow Counter
#define REG_FIFO_DATA_COUNT    0x07      //FIFO Data Counter
#define REG_FIFO_DATA          0x08      //FIFO Data Register
#define REG_FIFO_CONFIG_1      0x09      //FIFO Configuration 1
#define REG_FIFO_CONFIG_2      0x0A      //FIFO Configuration 2
#define REG_MODE_CONFIG        0x0D      //System Control
//Photoplethysmogram (PPG) registers
#define REG_PPG_SYNC_CTRL      0x10      //PPG Sync Control
#define REG_PPG_CONFIG_1       0x11      //PPG Configuration Settings Group 1
#define REG_PPG_CONFIG_2       0x12      //PPG Configuration Settings Group 2
#define REG_PPG_CONFIG_3       0x13      //PPG Configuration Settings Group 3
#define REG_PROX_INTR_THRESH   0x14      //Prox Interrupt Threshold
#define REG_PD_BIAS            0x15      //Photo Diode Bias
#define REG_PICKET_FENCE       0x16      //Picket Fence Settings
#define REG_LED_SEQ_1          0x20      //LED Sequence 1
#define REG_LED_SEQ_2          0x21      //LED Sequence 2
#define REG_LED_SEQ_3          0x22      //LED Sequence 3
#define REG_LED1_PA            0x23      //LED 1 Pulse Amplitude
#define REG_LED2_PA            0x24     //LED 2 Pulse Amplitude
#define REG_LED3_PA            0x25      //LED 3 Pulse Amplitude
#define REG_LED4_PA            0x26      //LED 4 Pulse Amplitude
#define REG_LED5_PA            0x27      //LED 5 Pulse Amplitude
#define REG_LED6_PA            0x28      //LED 6 Pulse Amplitude
#define REG_LED_PILOT_PA       0x29      //LED Pilot Pulse Amplitude
#define REG_LED_RANGE_1        0x2A      //LED Amplitude Range 1
#define REG_LED_RANGE_2        0x2B      //LED Amplitude Range 2
//Hi resolution DAC settings for each LED.
#define REG_S1_HI_RES_DAC1     0x2C
#define REG_S2_HI_RES_DAC1     0x2D
#define REG_S3_HI_RES_DAC1     0x2E
#define REG_S4_HI_RES_DAC1     0x2F
#define REG_S5_HI_RES_DAC1     0x30
#define REG_S6_HI_RES_DAC1     0x31
#define REG_S1_HI_RES_DAC2     0x32
#define REG_S2_HI_RES_DAC2     0x33
#define REG_S3_HI_RES_DAC2     0x34
#define REG_S4_HI_RES_DAC2     0x35
#define REG_S5_HI_RES_DAC2     0x36
#define REG_S6_HI_RES_DAC2     0x37
//Die-temp registers
#define REG_TEMP_CONFIG        0x40
#define REG_TEMP_INTR          0x41
#define REG_TEMP_FRAC          0x42
//SHA256 registers
#define REG_SHA_CMD            0xF0
#define REG_SHA_CONFIG         0xF1
//Memory registers
#define REG_MEM_CTRL           0xF2
#define REG_MEM_IDX            0xF3
#define REG_MEM_DATA           0xF4
#define REG_PART_ID            0xFF
#define SIZE 			20
#define FIFO_SAMPLES 		128 //0x78
Page 20 of the datasheet gives the following pseudocode for initializing the optical AFE:
DEVICE OPEN
START;
// AFE Initialization
WRITE 0x1 to RESET[0]; // Soft Reset (Register 0x0D[0])
DELAY 1ms;
READ Interrupt Status 1; // Clear Interrupt (Register 0x00)
READ Interrupt Status 2; // Clear Interrupt (Register 0x01)
WRITE 0x1 to SHDN[0]; // Shutdown (Register 0x0D[1])
WRITE 0x3 to PPG_TINT[1:0]; // Pulse Width = 123.8ms (Register 0x11[1:0])
WRITE 0x2 to PPG1_ADC_RGE1:0]; // ADC Range = 16μA (Register 0x11[3:2])
WRITE 0x2 to PPG2_ADC_RGE1:0]; // ADC Range = 16μA (Register 0x11[3:2])
// For MAX86141 when used in Dual Channel only
WRITE 0x0 to SMP_AVE[2:0]; // Sample Averaging = 1 (Register 0x12[2:0])
WRITE 0x00 to PPG_SR[4:0]; // Sample Rate = 25sps (Register 0x12[7:3])
WRITE 0x3 to LED_SETLNG[1:0]; // LED Settling Time = 12ms (Register 0x13[7:6])
WRITE 0x01 to PDBIAS1[2:0]; // PD 1 Biasing for Cpd = 0~65pF (Register 0x15[2:0])
WRITE 0x01 to PDBIAS2[2:0]; // PD 1 Biasing for Cpd = 0~65pF (Register 0x15[2:0])
WRITE 0x3 to LED1_RGE[1:0]; // LED Driver 1 Range = 124mA (Register 0x15[2:0])
WRITE 0x3 to LED2_RGE[1:0]; // LED Driver 2 Range = 124mA (Register 0x15[2:0])
WRITE 0x20 to LED1_DRV[1:0]; // LED 1 Drive Current = 15.36mA (Register 0x23[7:0])
WRITE 0x20 to LED2_DRV[1:0]; // LED 2 Drive Current = 15.36mA (Register 0x24[7:0])
WRITE 0x1 to LP_Mode[0]; // Low Power mode enabled
// FIFO Configuration
WRITE 0x10 to FIFO_A_FULL[6:0]; // FIFO INT triggered condition (Register 0x09[6:0])
WRITE 0x1 to FIFO_RO; // FIFO Roll Over enabled (Register 0x0A[1])
WRITE 0x1 to A_FULL_EN; // FIFO_A_FULL interrupt enabled (Register 0x02[7])
WRITE 0x1 to LEDC1[3:0]; // LED1 exposure configured in time slot 1
WRITE 0x2 to LEDC2[3:0]; // LED2 exposure configured in time slot 1
WRITE 0x0 to LEDC3[3:0];
WRITE 0x0 to LEDC4[3:0];
WRITE 0x0 to LEDC5[3:0];
WRITE 0x0 to LEDC6[3:0];
WRITE 0x0 to SHDN[0]; // Start Sampling STOP;
which I have tried to translate into the following code using my read and write register functions. I'm almost certain that something is wrong in this, but I'm not sure how else to interpret the pseudocode. (Note, I'm still not terribly confident on how to shift a value to write to specific bits in a register, so my attempt to do so may be completely off.)
void MAX86141_Initialize_AFE(void){
    uint8_t values[3];
    uint8_t size = 3;
    spi_write_reg(REG_MODE_CONFIG, 0x01);
    k_msleep(1);
    spi_write_reg(REG_MODE_CONFIG, (0x01<<1));
    spi_read_reg(REG_INT_STAT_1, values, size);
    spi_read_reg(REG_INT_STAT_2, values, size);
    spi_write_reg(REG_PPG_CONFIG_1, 0x2);
    spi_write_reg(REG_PPG_CONFIG_1, (0x2<<3));
    spi_write_reg(REG_PPG_CONFIG_2, 0x0);
    spi_write_reg(REG_PPG_CONFIG_2, (0x0<<7));
    spi_write_reg(REG_PPG_CONFIG_3, (0x3<<7));
    spi_write_reg(REG_PD_BIAS, 0x01);
    spi_write_reg(REG_PD_BIAS,0x1);
    spi_write_reg(REG_PD_BIAS,0x3);
    spi_write_reg(REG_LED_SEQ_1, 0x20);
    spi_write_reg(REG_LED_SEQ_2, 0x20);
    spi_write_reg(REG_LED_SEQ_3, 0x00);
    spi_write_reg(REG_FIFO_CONFIG_1, 0xF);
    spi_write_reg(REG_FIFO_CONFIG_2, (0x1<<1));
    spi_write_reg(REG_INT_EN_1, (0x1<<7));
    spi_write_reg(REG_LED_SEQ_1, 0x1);
    spi_write_reg(REG_LED_SEQ_1, 0x2<<4);
    spi_write_reg(REG_LED_SEQ_2, 0x0);
    spi_write_reg(REG_LED_SEQ_2, 0x0<<4);
    spi_write_reg(REG_LED_SEQ_3, 0x0);
    spi_write_reg(REG_LED_SEQ_3, 0x0<<4);
    spi_write_reg(REG_SHA_CMD, 0x0);
and the following pseudocode is on page 21 for reading from the FIFO after initialization:
#define FIFO_SAMPLES (128-0x10) // FIFO_A_FULL[6:0] = 0x10
void device_data_read(void) {
    int i;
    uint8_t sampleCnt;
    uint8_t dataBuf[FIFO_SAMPLES*3]; //(128 - FIFO_A_FULL[6:0]) samples, 3 byte/channel
    uint8_t tag1A[FIFO_SAMPLES/4]; //(128 - FIFO_A_FULL[6:0])/4channels samples
    uint8_t tag1B[FIFO_SAMPLES/4]; //(128 - FIFO_A_FULL[6:0])/4channels samples
    uint8_t tag2A [FIFO_SAMPLES/4]; //(128 - FIFO_A_FULL[6:0])/4channels samples
    uint8_t tag2B [FIFO_SAMPLES/4]; //(128 - FIFO_A_FULL[6:0])/4channels samples
    int led1A[FIFO_SAMPLES/4];
    int led1B[FIFO_SAMPLES/4];
    int led2A[FIFO_SAMPLES/4];
    int led2B[FIFO_SAMPLES/4];
    ReadReg(0x07, &sampleCnt); // sampleCnt should be the same value as FIFO_SAMPLES
    //Read FIFO ReadFifo(dataBuf, sampleCnt * 3);
    for ( i = 0; i < sampleCnt/4/*channels*/; i++ ) {
        tag1A[i] = (dataBuf[i*12+0] >> 3) & 0x1f;
        led1A[i] = ((dataBuf[i*12+0] << 16) | (dataBuf[i*12+1] << 8) |
            dataBuf[i*12+2])) & 0x7ffff; // LED1, PD1
        tag1B[i] = (dataBuf[i*12+3] >> 3) & 0x1f;
        led1B[i] = ((dataBuf[i*12+3] << 16) | (dataBuf[i*12+4] << 8) |
            (dataBuf[i*12+5])) & 0x7ffff; // LED1, PD2
        tag2A[i] = (dataBuf[i*12+6] >> 3) & 0x1f;
        led2A[i] = ((dataBuf[i*12+6] << 16) | (dataBuf[i*12+7] << 8) |
            (dataBuf[i*12+8])) & 0x7ffff; // LED2, PD1
        tag2B[i] = (dataBuf[i*12+9] >> 3) & 0x1f;
        led2B[i] = ((dataBuf[i*12+9] << 16) | (dataBuf[i*12+10] << 8) |
            (dataBuf[i*12+11])) & 0x7ffff; // LED2, PD2 } }
which I have tried to translate to the following code:
void MAX86141_Read_FIFO(void){
    uint8_t values[3];
    uint8_t size = 3;
    int i;
    uint8_t sampleCnt[FIFO_SAMPLES];
    uint8_t sampleCnt3[FIFO_SAMPLES*3];
    uint8_t tag2A[FIFO_SAMPLES/4];
    uint8_t tag2B[FIFO_SAMPLES/4];
    spi_read_reg(0x07, sampleCnt, sizeof(sampleCnt));
    spi_read_reg(dataBuf, sampleCnt3, sizeof(sampleCnt3));
    for ( i = 0; i < FIFO_SAMPLES/4; i++) {
        led1A[i] = ((dataBuf[i*12+0] << 16) | (dataBuf[i*12+1] << 8 | dataBuf[i*12+2])) & 0x7ffff; //LED1 PD1
        led1B[i] = ((dataBuf[i*12+3] << 16) | (dataBuf[i*12+4] << 8 | dataBuf[i*12+5])) & 0x7ffff; //LED1 PD2
        led2A[i] = ((dataBuf[i*12+6] << 16) | (dataBuf[i*12+7] << 8 | dataBuf[i*12+8])) & 0x7ffff; //LED1 PD2
        led2B[i] = ((dataBuf[i*12+9] << 16) | (dataBuf[i*12+10] << 8 | dataBuf[i*12+11])) & 0x7ffff; //LED1 PD2
I know for sure that this code isn't correct since when I run it as is it can't run the program and keeps restarting on the serial monitor. Still, I've tried to change things around to no avail (I know that the issue seems to be the way the read register works not allowing for these inputs for the "values" and "size", since changing that will allow the program to run, albeit incorrectly). I just don't know what the issue is and how to fix it.
Ultimately all I'd like to do right now is turn on the LEDs and read the photodiodes connected to the sensor, and I can't seem to get either of those things to work. I currently have it physically set up with three LEDs and two photodiodes, but as long as I can get any of them functioning I should be able to work out how to get the combinations I need to work functioning.
Thanks in advance!
  • I just tried changing every instance of a uint8_t field to a uint16_t, and while the program does keep failing partway through and keeps returning to the message:
    *** Booting nRF Connect SDK v.3.5.99-ncs1 ***
    and then restarting the program, now one of the LEDS is turning on, which definitely helps! I'm not sure why it's only LED2, when it should be turning on LED1 and LED2 or why the program still fails partway through, but changing the uint8_t definitely seems to have been necessary. Notably, it seems to fail during the "MAX86141_Read_FIFO" function, so there still seems to be another error I'm not seeing in that section.
  • It is difficult to say without seeing your application. Perhaps you can upload it (zip and upload the zipped application folder)? It is a lot easier to navigate than just some snippets.
    So where do you try to turn on the LEDs? The face that one of them isn't working may indicate that it is not building for the proper target. Perhaps it sets the wrong pin output for the LED.
    What HW are you running on? A  DK with the standard LED pin numbers?
    Did you try to analyze the SPI pins with a logic analyzer?
    Edvin
  • Certainly! A link to the file on Google Drive can be found here. (If there's a different preferred place to upload files to, I'm certainly happy to make that adjustment.)
    Yes, I'm using an nRF534 DK, but the LEDs are being controlled by the sensor, not directly by the dk.
    If I'm understanding correctly, the LEDs should be controlled by what is written to the LED range registers, the LED pulse amplitude registers, and the LED sequence registers. This takes place in the MAX6141_Initialization_AFE function in my code.
    According to the datasheet, writing 0x3 to 0x2A[1:0] and 0x2A[3:2] will set the LED range for LED 1 and LED 2 to 124mA which I have done by writing 0x0F to 0x2A.
    Then the LED pulse amplitude registers 0x23 and 0x24 for LEDs 1 and 2 are set to 15.36mA by writing 0x20 to each of them. I'm honestly not entirely sure what the difference is between these two currents, but the datasheet uses these values in the pseudocode so they're what I went with.
    Finally, the LED sequence can be set by changing the LED sequence registers 0x20, 0x21, and 0x22, each of which have two sequence registers built in -- the first in [3:0] and the second in [7:4]. The first register set to 0 will reset the sequence. Writing 0x21 to register 0x20 should first pulse LED1, then LED2, and the rest are left at 0 which should end the sequence.
    It's possible I'm misunderstanding the way some of these work, but even so it follows the way the pseudocode is setup for 2 LEDs and 2 Photodiodes, so I believe I should at least be understanding the expected outcome correctly.
    I've checked the wiring and had a few other people check it, too, so I think it should be wired correctly for the pins that are being used, but those pins aren't being used by the dk.
    Finally, I've been trying to find a usable logic analyzer for this but haven't had any luck. We do have an old oscilloscope I tried to use, but it's difficult to get it to check multiple lines at once and make sure the signals are lining up as expected. It does seem to be functioning properly as far as I can tell so far by checking individual signals, however. I'm still trying to see if I can get a better tool to actually make sure that it's working correctly, though.
    Best,
    Joe
  • I see a number of bugs which you could fix and see if it helps. As an aside, there are other ways to extract the data, though I'm not suggesting you change at this stage. The AFE sends data in 24-bit lumps, MSB-first - which is ok - but in Big-endian order, which is a pain. This is the quoted 3x24-bit transfer:
    // MAX86140 MAX86141 MSB first, Big Endian (ARM is generally using Little Endian)
    //      |------------Byte 0--------------| |--------------Byte 1---------------| |-----------Byte 2------------|
    //      |-----Tag Bits----| |--------------------------------ADC Value Bits------------------------------------|
    //        4   3   2   1   0   18   17   16   15   14   13   12   11   10   9   8   7   6   5   4   3   2   1   0
    // SCLK  17  18  19  20  21   22   23   24   25   26   27   28   29   30  31  32  33  34  35  36  37  38  39  40
    // SDO  T4A T3A T2A T1A T0A O18A O17A O16A O15A O14A O13A O12A O11A O10A O9A O8A O7A O6A O5A O4A O3A O2A O1A O0A
    // SCLK  41  42  43  44  45   46   47   48   49   50   51   52   53   54  55  56  57  58  59  60  61  62  63  64
    // SDO  T4B T3B T2B T1B T0B O18B O17B O16B O15B O14B O13B O12B O11B O10B O9B O8B O7B O6B O5B O4B O3B O2B O1B O0B
    // SDO  T4C T3C T2C T1C T0C O18C O17C O16C O15C O14C O13C O12C O11C O10C O9C O8C O7C O6C O5C O4C O3C O2C O1C O0C
    This could be modeled like so:
    typedef struct {
       uint32_t ADC_Value : 19;       // 19-bit value
       uint32_t Tag       :  5;       //  5-bit Tag
    }__attribute__((packed)) fifo_24_bit_t;
    typedef union {
       fifo_24_bit_t  Fifo_24_bit;         // Treat as 24-bit fifo data
       uint8_t        Bytes[sizeof(fifo_24_bit_t)];            // Treat as an array of bytes
    }__attribute__((packed)) fifoUnion_t;
    Test layout with an example:
    // Test layout
    const fifoUnion_t __packed fifoUnion = {
       .Fifo_24_bit = {
          .Tag       = {0x0},
          .ADC_Value = {0x034567}
    STATIC_ASSERT(sizeof(fifoUnion) == 3, "fifoUnion_t incorrect size");
    snprintf(Info, sizeof(Info), "Tag 0x%02X, Value 0x%05X, Bytes 0x%02X%02X%02X 0x%06X\r\n", fifoUnion.Fifo_24_bit.Tag, fifoUnion.Fifo_24_bit.ADC_Value, fifoUnion.Bytes[0], fifoUnion.Bytes[1], fifoUnion.Bytes[2], *(uint32_t*)fifoUnion.Bytes );
    Looking at the log for this example:
    // Tag 0x00, Value 0x34567, Bytes012 0x674503, treat as word: 0x034567
    This works fine, but incoming data has to be converted to little endian, so don't bother.
    Here are the bugs:
    read_reg use 8-bit data and 16-bit size:
    static int spi_read_reg(uint8_t reg, uint8_t values[], uint16_t size)    // <<== 16-bit size
    write_reg 8-bit data, 8-bit size:
    static int spi_write_reg(uint8_t reg, uint8_t value)                   // <<== 8-bit reg, 8-bit data
    8-bit data:
        uint8_t values[3];                   // <<== 8-bit data
    read_fifo:
    //The FIFO is 128 sample depth and is designed to support various data types. Each sample width is 3 bytes, which includes a 5-bit tag width  <==
        uint8_t values[3];
        uint8_t size = 3;
        int i;
        uint16_t sampleCnt = FIFO_SAMPLES;                 // <<== 16-bit size, play safe
        uint8_t dataBuf[FIFO_SAMPLES*3];                   // <<== 8-bit data
        uint8_t tag1A[FIFO_SAMPLES/4];                     //  <== why /4 instead of /3?
    Not clear why using /4 instead of /3 in many places.
  • Thanks! That does seem to help. For the tag1A and other times that I used /4, I believe that it's because there are 4 channels the data is being stored in, so it separates the data out into 4 groups like what's described on page 18 and 19 of the datasheet. I could be wrong about that, but that was how the pseudocode wrote the function and how I understand it to be operating.
    Also, I've noticed that while the LED 1 driver still isn't working even after the changes you suggested, LED 2 and LED 3 are responding as intended. I've checked that the LED isn't bad for LED1 since it works fine when connected to the other drivers. It's possible that there's an issue with the sensor itself, but I've tried multiple boards now and all of them give the same results so that seems unlikely to me.
    I've noticed another thing that may or may not be pertinent to what's going wrong. I have started printing out the values stored in led2A using the following code at the end of the MAX86141_Read_FIFO function:
     int j;
        for (j = 0; j < FIFO_SAMPLES/4; j++){
            printk("Value %02X: %02X\n\r",j,led2A[j]);
    and it had been printing out the same values for the data it was "collecting" each time. (I don't expect the exact numbers to be elucidating, but just in case they are I'll print the values from led2A here.)
    0
    0
    92
    9C
    FF
    31
    2
    F5
    D0
    0
    23
    7C
    0C
    22
    A0
    3
    2
    D3
    22
    8A
    0
    69
    1D
    80
    0
    61
    1F
    28
    80
    1C
    40
    70
    C3
    41
    4B
    13
    90
    53
    8B
    7
    8
    70
    D8
    D0
    50
    FF
    FF
    30
    70
    0
    0
    0
    0
    0
    0
    0
    61
    88
    28
    21
    51
    90
    48
    1
    0F
    0
    31
    63
    0
    4F
    1
    1
    24
    9
    CC
    A4
    1
    2D
    8
    81
    61
    48
    8
    A1
    1E
    21
    84
    84
    42
    1A
    A0
    2
    88
    0
    12
    50
    0
    61
    25
    8
    6D
    A2
    4
    0
    0
    89
    13
    2A
    4B
    96
    14
    1C
    2
    8
    30
    8
    0
    0C
    0
    12
    0
    18
    2
    83
    I made the adjustments that you noted in your response, and now the data is actually changing, but it's still not collecting in a way that seems right. For instance, now I received the following data during one of the collections:
    1000
    1000
    1000
    1000
    11000
    11000
    1000
    1000
    1000
    11000
    4
    52525
    52525
    129
    0
    40000
    52525
    12929
    20000
    24A4A
    24800
    49494
    49494
    2500
    14949
    14949
    24A4A
    29292
    This is very typical for the data that's collected. A lot of round numbers like 1000, 11000, etc., or numbers with repeating digits like 52525 or 49494 that show up multiple times. The data also doesn't seem to correspond to the actual stimulus of light on the photodiodes. I'm not sure if this is helpful, but I thought it could help to indicate a potential flaw in the code.
    I'll also take a look at what you're talking about with big-endian and little-endian, but that's a new area for me so it might take me a little bit to work through and try to make any adjustments that you mentioned.
    Thanks for all the help you both have given so far! It's been extremely useful and I appreciate you taking the time to help me try and figure this out!
