Configuration of custom flash memory for standard zephyr driver
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with the standard driver from zephyr.
I added the following to the .overlay:
&qspi {
	status = "okay";
	pinctrl-0 = <&qspi_default>;
	pinctrl-1 = <&qspi_sleep>;
	s25h: s25hl01gt@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		/* MX25R64 supports only pp and pp4io */
		writeoc = "pp4io";
		/* MX25R64 supports all readoc options */
		readoc = "read4io";
		sck-frequency = <8000000>;
		jedec-id = [34 2B 1B 0F 03 90];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
	aliases {
		spi-flash0 = &s25h;
And I use the following code:
  const struct device *flash_dev = DEVICE_DT_GET(DT_ALIAS(spi_flash0));
	if (!device_is_ready(flash_dev)) {
		printk("%s: device not ready.\n", flash_dev->name);
		return 0;
But it doesn't work and I don't understand how to debug such problems. I'm not even sure that the jedec-id is correct. When compiling into zephyr.dts, I see that for qspi there are two mx25r64 flash memories and my s25h is also in the list, is this bad? I tried to delete it via /delete-node/mx25r6435f; in &qspi but it didn't work.
Thanks in advance!
  • I'm using a custom board with a BL5340PA module. Inside it is an nrf in a bga case, just like an external flash memory. I'm not sure I can show it.
  • From what I can see, there is no external flash inside the BL5340PA, so I assume that external flash is on your custom board.
    If we were to dabble in hindsight, we would say that a good idea would have been to add probe points for not-exposed signals on the test-PCB that you made. However all we can do with hindsight is to learn from it.
    If you want, I can have a look at your custom PCB layout?
    If so, make a private ticket and ask for a review. And link to the private ticket here, so I know about it.
    Then, if we find something wrong in the layout, it may be hard to fix it in firmware. However, if everything looks good in the layout, I can continue to help you figure out why the firmware will not cooperate.
  • Sorry for the short pause, I was waiting for the pcb files to find the required via on the board to connect the oscilloscope.
    It seems the driver is not setting up the memory correctly. One of the data pins (DQ3_RESET#) is used as reset and it turns out there is 2.3V DC.
    It is not clear why it has this particular meaning; there is nothing on the DQ3_RESET# signal track except the memory itself and nrf.
    Jedec-id should have been read on one spi line and then started sfdp synchronization, right?
     No worries at all, I always have other users to answer.
    Try to configure the reset pin in Pinctrl to pullup/pulldown depending on what you need to not reset the external flash.
    I suspect that our external flash driver does not have reset pre-configured.
    If that works, we can look into if external flash drivers support reset pins or not.
  • Hi, thank you for your support.
    It's just a defective board or chip. Jedek-id was successfully read on the other board and the driver was initialized.
    I can say that my configuration works except for sfdp-bfp, which I will check as soon as I have a working board.
    I'll try to post the correct dts before closing the topic.
